APM2T42P100008GAN-HTM1W
    APACERMEMORYAMERICA(宇瞻科技)
    M.2 2242 P100-M 16GB 15NM MLC ET
APM2T42P100008GAN-HTM1W 数据手册
RoHS Recast Compliant Serial ATA Flash Drive M.2 2242 P100-M Product Specifications (Toshiba 15nm) January 20, 2016 Version 1.1 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 M.2 2242 Flash Drive APM2T42P100xxxxAN-XTM1X Features: Compliance with SATA Interface Serial ATA Revision 3.1 SATA 6.0 Gbps ATA-8 command set Backward compatible with SATA 1.5/3.0 Gbps Temperature Range Operating: Standard : 0°C to 70°C Extended : -40°C to 85°C Storage: -40°C to 100°C Supply Voltage 3.3 V 5% Capacity 8, 16, 32, 64, 128, 256 GB Power Consumption* Active mode: 455 mA Idle mode: 95 mA Performance* Interface burst read/write: 600 MB/sec Sustained read: up to 450 MB/sec Sustained write: up to 165 MB/sec Connector Type 75-pin SATA-based M.2 module pinout Flash Management Built-in hardware ECC Wear-leveling Flash bad-block management S.M.A.R.T. Power Failure Management ATA Secure Erase TRIM Form Factor M.2 2242 form factor Dimensions: 42mm(L)x22mm(W)x3.65mm(H) Shock & Vibration** Shock:1,500 G Vibration: 15 G NAND Flash Type: MLC MTBF: >2,000,000 hours Endurance 8 GB: 7 TBW 16 GB: 14 TBW 32 GB: 28 TBW 64 GB: 57 TBW 128 GB: 114 TBW 256 GB: 228 TBW RoHS Recast Compliant Device Sleep Mode (optional) *Varies from capacities. The values for performances and power consumptions presented are typical and may vary depending on flash configurations or platform settings. The term idle refers to the standby state of the device. **Non-operating 1 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2242 Flash Drive APM2T42P100xxxxAN-XTM1X Table of Contents 1. GENERAL DESCRIPTION .................................................................................................... 3 2. PIN ASSIGNMENTS ............................................................................................................... 3 3. PRODUCT SPECIFICATIONS .............................................................................................. 6 3.1 CAPACITY .............................................................................................................................................................6 3.2 PERFORMANCE .....................................................................................................................................................6 3.3 ENVIRONMENTAL SPECIFICATIONS ....................................................................................................................... 7 3.4 MEAN TIME BETWEEN FAILURES (MTBF) ...........................................................................................................7 3.5 CERTIFICATION AND COMPLIANCE .......................................................................................................................7 4. FLASH MANAGEMENT ........................................................................................................ 8 4.1 ERROR CORRECTION/DETECTION .........................................................................................................................8 4.2 BAD BLOCK MANAGEMENT .................................................................................................................................8 4.3 WEAR LEVELING ..................................................................................................................................................8 4.4 POWER FAILURE MANAGEMENT........................................................................................................................... 8 4.5 ATA SECURE ERASE ............................................................................................................................................8 4.6 TRIM ...................................................................................................................................................................9 4.7 SATA POWER MANAGEMENT .............................................................................................................................. 9 4.8 ENDURANCE ....................................................................................................................................................... 10 5. SOFTWARE INTERFACE ................................................................................................... 11 5.1 COMMAND SET ................................................................................................................................................... 11 5.2 S.M.A.R.T.......................................................................................................................................................... 12 6. ELECTRICAL SPECIFICATION ....................................................................................... 13 7. MECHANICAL SPECIFICATIONS ................................................................................... 14 8. PRODUCT ORDERING INFORMATION ......................................................................... 15 8.1 PRODUCT CODE DESIGNATIONS ......................................................................................................................... 15 8.2 VALID COMBINATIONS ....................................................................................................................................... 16 2 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2242 Flash Drive APM2T42P100xxxxAN-XTM1X 1. General Description Apacer P100-M is the next generation modularized Solid State Drive (SSD) with the shape of all new M.2 form factor, with the aim to be the more suitable for mobile and compact computers with standard width at only 22.00 mm. P100-M appears in M.2 2242 mechanical dimensions and is believed to be the leading add-in storage solution for future host computing systems. The M.2 SSD is designed with SATA-based connector pinouts, providing full compliance with the latest SATA Revision 3.2 interface specifications. Aside from SATA compliance, P100-M delivers exceptional performance and power efficiency. On the other hand, the extreme thin and light form factor makes P100M the ideal choice for mobile computing systems, which appears to be the trend in near future. Regarding reliability, P100-M is built with a powerful SATA controller that supports on-the-module ECC as well as efficient wear leveling scheme. Since it is operating under SATA 6.0 Gbps interface, P100-M is provided with Apacer latest S.M.A.R.T. that are primarily oriented for the latest SATA interface SSD, for drive lifetime monitoring and analyzing. 2. Pin Assignments This connector does not support hot plug capability. There are a total of 75 pins. 12 pin locations are used for mechanical key locations; this allows such a module to plug into both Key B and Key M connectors. Notch B Notch M Pin1 Pin Type Description 1 CONFIG_3 Ground (according to M.2 configurations for SSD-SATA definition) 2 3.3V Supply Pin, 3.3V 3 GND Ground 4 3.3V Supply pin, 3.3V 5 No connect No connect 6 Not available No connect (used for other purposes) 7 Not available No connect (used for other purposes) 8 Not available No connect (used for other purposes) 3 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2242 Flash Drive APM2T42P100xxxxAN-XTM1X 9 No connect No connect 10 DAS/DSS Device Activity Signal/Disable Staggered Spin-up 11 No connect No connect (used for other purposes) 12 (removed for key) Mechanical notch B 13 (removed for key) Mechanical notch B 14 (removed for key) Mechanical notch B 15 (removed for key) Mechanical notch B 16 (removed for key) Mechanical notch B 17 (removed for key) Mechanical notch B 18 (removed for key) Mechanical notch B 19 (removed for key) Mechanical notch B 20 Not available No connect (used for other purposes) 21 CONFIG_0 Ground (according to M.2 configurations for SSD-SATA definition) 22 Not available No connect (used for other purposes) 23 Not available No connect (used for other purposes) 24 Not available No connect (used for other purposes) 25 Not available No connect (used for other purposes) 26 Not available No connect (used for other purposes) 27 GND Ground 28 Not available No connect (used for other purposes) 29 PERn1 Not used 30 Not available No connect (used for other purposes) 31 PERp1 Not used 32 Not available No connect (used for other purposes) 33 GND Ground 34 Not available No connect (used for other purposes) 35 PETn1 Not used 36 Not available No connect (used for other purposes) 37 PETp1 Not used 38 DEVSLP Device Sleep, input. If driven high the host is informing the SSD to enter a low power state 39 GND Ground 40 Not available No connect (used for other purposes) 41 SATA-Rx+ Host receiver differential signal pair 42 Not available No connect (used for other purposes) 43 SATA-Rx- Host receiver differential signal pair 44 Not available No connect (used for other purposes) 4 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2242 Flash Drive APM2T42P100xxxxAN-XTM1X 45 GND Ground 46 Not available No connect (used for other purposes) 47 SATA-Tx- Host transmitter differential pair 48 Not available No connect (used for other purposes) 49 SATA-Tx+ Host transmitter differential pair 50 PERST# Not used 51 GND Ground 52 CLKREQ# Not used 53 REFCLKN Not used 54 PEWAKE# Not used 55 REFCLKP Not used 56 MFG1 Manufacturing pin. Use determined by vendor (no connect on a host) 57 GND Ground 58 MFG2 Manufacturing pin. Use determined by vendor (no connect on a host) 59 (removed for key) Mechanical notch M 60 (removed for key) Mechanical notch M 61 (removed for key) Mechanical notch M 62 (removed for key) Mechanical notch M 63 (removed for key) Mechanical notch M 64 (removed for key) Mechanical notch M 65 (removed for key) Mechanical notch M 66 (removed for key) Mechanical notch M 67 Not available No connect (used for other purposes) 68 SUSCLK Not used 69 CONFIG_1 Ground 70 3.3V Supply pin, 3.3V 71 GND Ground 72 3.3V Supply pin, 3.3V 73 GND Ground 74 3.3V Supply pin, 3.3V 75 CONFIG_2 Ground 5 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2242 Flash Drive APM2T42P100xxxxAN-XTM1X 3. Product Specifications 3.1 Capacity Capacity specification of P100-M is available as shown in Table 3-1. It lists the specific capacity and the default numbers of heads, sectors and cylinders for each product line. Table 3-1 Capacity Specifications Capacity Total bytes* Cylinders Heads Sectors Max LBA 8 GB 8,012,390,400 15,525 16 63 15,649,200 16 GB 16,013,942,784 16,383 16 63 31,277,232 32 GB 32,017,047,552 16,383 16 63 62,533,296 64 GB 64,023,257,088 16,383 16 63 125,045,424 128 GB 128,035,676,160 16,383 16 63 250,069,680 256 GB 256,060,514,304 16,383 16 63 500,118,192 *Display of total bytes varies from file systems, which means not all of the bytes can be used for storage. **Notes: 1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 3.2 Performance Performances of P100-M are listed below in Table 3-2. Table 3-2 Performance Capacity 8 GB 16 GB 32 GB 64 GB 128 GB 256 GB Sustained read (MB/s) 120 215 230 405 450 440 Sustained write (MB/s) 85 150 130 160 165 160 Performance Note: Results may differ from various flash configurations or host system setting 6 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2242 Flash Drive APM2T42P100xxxxAN-XTM1X 3.3 Environmental Specifications Environmental specification of P100-M series follows MIL-STD-810, as shown in Table 3-3. Table 3-3 P100-M Environmental Specifications Item Temperature Humidity Shock Specifications 0°C to 70°C (Operating) -40 C to 85 C (Extended) -40 C to 85 C (in storage) RH 90% under 40 C (Operating) RH 95% under 55 C (Extended) Bending 1500G, 0.5ms 20Hz~80Hz/1.52mm (frequency/displacement) 80Hz~2000Hz/20G (frequency/displacement) X, Y, Z axis/60mins each 80cm free fall, 6 face of each 20N, hold 1min/5times Torque 0.5N-m or 5deg, hold 5min/5times ESD 24°C, RH 49% Vibration Drop 3.4 Mean Time Between Failures (MTBF) Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components in P100-M. The prediction result for P100-M is more than 2,000,000 hours. Notes about the MTBF: The MTBF is predicated and calculated based on Telcordia Technologies Special Report, SR-332, Issue 2 method. 3.5 Certification and Compliance P100-M complies with the following standards: CE FCC RoHS Recast MIL-STD-810 BSMI 7 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2242 Flash Drive APM2T42P100xxxxAN-XTM1X 4. Flash Management 4.1 Error Correction/Detection P100-M implements a hardware ECC scheme, based on the BCH algorithm. It can detect and correct up to 72 bits error in 1K bytes. 4.2 Bad Block Management Bad blocks are blocks that include one or more invalid bits, and their reliability is not guaranteed. Blocks blocks that are developed during the lifespan of the flash are Apacer implements an efficient bad block management algorithm to detect the factory-produced bad blocks and manages any bad blocks that appear with use. This practice further prevents data being stored into bad blocks and improves the data reliability. 4.3 Wear Leveling NAND flash devices can only undergo a limited number of program/erase cycles, and in most cases, the flash media are not used evenly. If some areas get updated more frequently than others, the lifetime of the device would be reduced significantly. Thus, Wear Leveling is applied to extend the lifespan of NAND flash by evenly distributing write and erase cycles across the media. Apacer provides advanced Wear Leveling algorithm, which can efficiently spread out the flash usage through the whole flash media area. Moreover, by implementing both dynamic and static Wear Leveling algorithms, the life expectancy of the NAND flash is greatly improved. 4.4 Power Failure Management Power Failure Management plays a crucial role when experiencing unstable power supply. Power disruption may occur when users are storing data into the SSD. In this urgent situation, the controller would run multiple write-to-flash cycles to store the metadata for later block rebuilding. This urgent operation requires about several milliseconds to get it done. At the next power up, the firmware will perform a status tracking to retrieve the mapping table and resume previously programmed NAND blocks to check if there is any incompleteness of transmission. 4.5 ATA Secure Erase ATA drives and SSDs. When this command is issued, the SSD controller will empty its storage blocks and return to its factory default settings. 8 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2242 Flash Drive APM2T42P100xxxxAN-XTM1X 4.6 TRIM TRIM is a feature which helps improve the read/write performance and speed of solid-state drives (SSD). Unlike hard disk drives (HDD), SSDs are not able to overwrite existing data, so the available space gradually becomes smaller with each use. With the TRIM command, the operating system can inform the SSD which blocks of data are no longer in use and can be removed permanently. Thus, the SSD will perform the erase action, which prevents unused data from occupying blocks all the time. 4.7 SATA Power Management By complying with SATA 6.0 Gb/s specifications, the SSD supports the following SATA power saving modes: ACTIVE: PHY ready, full power, Tx & Rx operational PARTIAL: Reduces power, resumes in under 10 µs (microseconds) SLUMBER: Reduces power, resumes in under 10 ms (milliseconds) HIPM: Host-Initiated Power Management DIPM: Device-Initiated Power Management AUTO-SLUMBER: Automatic transition from partial to slumber. Device Sleep (DevSleep or DEVSLP): PHY powered down; power consumption 5 mW; host assertion time 10 ms; exit timeout from this state 20 ms (unless specified otherwise in SATA Identify Device Log). Note: 1. The behaviors of power management features would depend on host/device settings. 2. Device Sleep mode is optional, depending on product ordering selections. 9 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2242 Flash Drive APM2T42P100xxxxAN-XTM1X 4.8 Endurance The endurance of a storage device is predicted by Tera Bytes Written based on several factors related to usage, such as the amount of data written into the drive, block management conditions, and daily workload for the drive. Thus, key factors, such as Write Amplifications and the number of P/E cycles, can influence the lifespan of the drive. Capacity Tera Bytes Written 8 GB 7 16 GB 14 32 GB 28 64 GB 57 128 GB 114 256 GB 228 Notes: The measurement follows the standard metric: 1 TB (Terabyte) = 1,000 GB. This estimation complies with JEDEC JESD-219, enterprise endurance workload of random data with payload size distribution. The estimated values are based on JEDEC Enterprise endurance workload comprised of random data with the payload size distribution with sequential write behavior. 10 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2242 Flash Drive APM2T42P100xxxxAN-XTM1X 5. Software Interface 5.1 Command Set This section defines the software requirements and the format of the commands the host sends to P100M. Commands are issued to P100-M by loading the required registers in the command block with the supplied parameters, and then writing the command code to the Command register. Table 5-1 Command Set Command Code Command Code NOP 00h Idle 97h Data Set Management 06h Check Power Mode 98h Sleep 99h Recalibrate 10h-1Fh Read Sectors 20h SMART B0h Read Sectors without Retry 21h Device Configuration B1h Read Sectors EXT 24h Read Multiple C4h Read DMA EXT 25h Write Multiple C5h Read Native Max Address EXT 27h Set Multiple Mode C6h Read Multiple EXT 29h Read DMA C8h Read Log EXT 2Fh Read DMA without Retry C9h Write Sectors 30h Write DMA CAh Write Sectors Without Retry 31h Write DMA without Retry CBh Write Sectors EXT 34h Write Multiple FUA EXT CEh Write DMA EXT 35h Standby Immediate E0h Set Native Max Address EXT 37h Idle Immediate E1h CFA Write Sectors without erase 38h Standby E2h Write Multiple EXT 39h Idle E3h Write DMA FUA EXT 3Dh Read Buffer E4h Write Long EXT 3Fh Check Power Mode E5h Read Verify Sectors 40h Sleep E6h Read Verify Sectors without Retry 41h Flush Cache E7h Read Verify Sectors EXT 42h Write Buffer E8h Write Uncorrectable EXT 45h Flush Cache EXT EAh Read FPDMA Queued 60h Identify Device ECh Write FPDMA Queued 61h Set Features EFh Security Set Password F1h Seek 70h-7Fh Execute Device Diagnostic 90h Security Unlock F2h Initialize Device Parameters 91h Security Erase Prepare F3h 11 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2242 Flash Drive APM2T42P100xxxxAN-XTM1X Download Microcode 92h Security Erase Unit F4h Download Microcode DMA 93h Security Freeze Lock F5h Standby Immediate 94h Security Disable Password F6h Idle Immediate 95h Read Native Max Address F8h Standby 96h Set Max Address F9h 5.2 S.M.A.R.T. SMART, an acronym for Self-Monitoring, Analysis and Reporting Technology, is an open standard that allows a hard disk drive to automatically detect its health and report potential failures. When a failure is recorded by SMART, users can choose to replace the drive to prevent unexpected outage or data loss. Moreover, SMART can inform users of impending failures while there is still time to perform proactive actions, such as copy data to another device. 12 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2242 Flash Drive APM2T42P100xxxxAN-XTM1X 6. Electrical Specification Table 6-1 Operating Range Supply Voltage 3.3V 5% (3.135-3.465V) Table 6-2 Power Consumption (typical) Capacity 8 GB 16 GB 32 GB 64 GB 128 GB 256 GB 300 300 315 360 455 450 85 85 85 95 95 Idle (mA) Note: Results may differ from various flash configurations or host system setting. 95 Modes Active (mA) 13 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2242 Flash Drive APM2T42P100xxxxAN-XTM1X 7. Mechanical Specifications Dimension: 42mm(L) x 22mm(W) x 3.65mm(H) Unit: Tolerance: ± 0.25 14 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2242 Flash Drive APM2T42P100xxxxAN-XTM1X 8. Product Ordering Information 8.1 Product Code Designations AP M2 T42 P100 xxxx AN X TM1 X Temperature Range Blank: Standard W: Extended Temperature Flash Type Version Control Apacer Brand Capacities: 008G = 8GB 016G = 16GB 032G = 32GB 064G = 64GB 128G = 128GB 256G = 256GB Solution version Form Factor M.2 Apacer Product Code 15 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2242 Flash Drive APM2T42P100xxxxAN-XTM1X 8.2 Valid Combinations 8.2.1 Standard Temperature Capacity No DEVSLP 8GB 16GB 32GB 64GB 128GB 256GB DEVSLP APM2T42P100008GAN-GTM1 APM2T42P100016GAN-GTM1 APM2T42P100032GAN-GTM1 APM2T42P100064GAN-GTM1 APM2T42P100128GAN-GTM1 APM2T42P100256GAN-GTM1 8.2.2 Extended Temperature Capacity No DEVSLP APM2T42P100008GAN-HTM1 APM2T42P100016GAN-HTM1 APM2T42P100032GAN-HTM1 - DEVSLP 8GB 16GB 32GB 64GB APM2T42P100008GAN-GTM1W APM2T42P100016GAN-GTM1W APM2T42P100032GAN-GTM1W APM2T42P100064GAN-GTM1W APM2T42P100008GAN-HTM1W APM2T42P100016GAN-HTM1W APM2T42P100032GAN-HTM1W - 128GB 256GB APM2T42P100128GAN-GTM1W APM2T42P100256GAN-GTM1W - Note: Valid combinations are those products in mass production or will be in mass production. Consult your Apacer sales representative to confirm availability of valid combinations and to determine availability of new combinations. 16 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2242 Flash Drive APM2T42P100xxxxAN-XTM1X Revision History Revision Date Description Remark 1.0 10/22/2015 Official release 1.1 1/20/2016 Removed 64GB model with DEVSLP support 17 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2242 Flash Drive APM2T42P100xxxxAN-XTM1X Global Presence Taiwan (Headquarters) Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 46732 Lakeview Blvd., Fremont, CA 94538 Tel: 1-408-518-8699 Fax: 1-510-249-9568 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd Room D, 22/FL, No.2, Lane 600, JieyunPlaza, Tianshan RD, Shanghai, 200051, China Tel: 86-21-6228-9939 Fax: 86-21-6228-9936 sales@apacer.com.cn India Apacer Technologies Pvt Ltd, th Unit No.201, Brigade Corner 7 Block Jayanagar, Yediyur Circle, Bangalore 560082, India Tel: 91-80-4152-9061 Fax: 91-80-4170-0215 sales_india@apacer.com 18 © 2016 Apacer Technology Inc. Rev. 1.1
APM2T42P100008GAN-HTM1W 价格&库存
很抱歉,暂时无法提供与“APM2T42P100008GAN-HTM1W”相匹配的价格&库存,您可以联系我们找货
