APS25H12128G-HTM1
APS25H12128G-HTM1
    APACERMEMORYAMERICA(宇瞻科技)
    Solid State Drive (SSD) 128GB SATA III FLASH - NAND (MLC) 2.5" 5V
APS25H12128G-HTM1 数据手册
RoHS Compliant SATA Flash Drive SFD25H1-M Product Specifications (Toshiba 15nm) October 21, 2015 Version 1.0 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 Serial ATA Flash Drive APS25H12xxxG-XTM1X Features: Serial ATA Revision 3.1 Compliance SATA 6.0 Gbps interface Backward compatible with SATA 3.0/1.5 Gbps interface ATA Command set Temperature Ranges Operating: Standard: 0°C to 70°C Extended : -40°C to 85°C Storage: -40°C to 85°C Capacities 8, 16, 32, 64, 128, 256 GB Supply Voltage 5 V 5% Performance* Interface burst read/write: 600 MB/sec Sustained read: up to 430 MB/sec Sustained write: up to 190 MB/sec Power Consumption (typical)* Active mode : 320 mA Idle mode : 75 mA Flash Management Built-in hardware ECC Wear-leveling Flash bad block management S.M.A.R.T. Power Failure Management TRIM Connector 7-pin SATA male connector 15-pin SATA power connector Form Factor 2.5 inch (100.10 x 69.85 x 7.00, unit: mm) RoHS Compliant Device Sleep (optional) NAND Flash Type: MLC MTBF (hours): >1,000,000 Endurance 8GB: 7 TBW 16GB: 14 TBW 32GB: 28 TBW 64GB: 57 TBW 128GB: 114 TBW 256GB: 228 TBW *The values presented for Performances and Power Consumption are typical and may vary depending on different configurations and platforms. 1 © 2015 Apacer Technology Inc. Rev. 1.0 Serial ATA Flash Drive APS25H12xxxG-XTM1X Table of Contents 1. Product Description ................................................................................................. 3 1.1 Introduction ...................................................................................................................................................3 1.2 Capacity Specification ...................................................................................................................................3 1.3 Performance ................................................................................................................................................... 3 1.4 Pin Assignments .............................................................................................................................................4 2. Software Interface .................................................................................................... 6 2.1 Command Set .................................................................................................................................................6 2.2 S.M.A.R.T. ......................................................................................................................................................7 3. Flash Management ................................................................................................... 8 3.1 Error Correction/Detection .......................................................................................................................... 8 3.2 Bad Block Management ................................................................................................................................8 3.3 Wear Leveling ................................................................................................................................................8 3.4 Power Failure Management ..........................................................................................................................8 3.5 TRIM .............................................................................................................................................................. 8 3.6 Secure Erase ...................................................................................................................................................9 4. Reliability Specifications ....................................................................................... 10 4.1 Environments ............................................................................................................................................... 10 4.2 Mean Time Between Failures (MTBF) ...................................................................................................... 10 4.3 Certification and Compliance ..................................................................................................................... 10 4.4 Endurance .................................................................................................................................................... 11 5. Electrical Characteristics ...................................................................................... 12 5.1 Operating Voltage........................................................................................................................................ 12 5.2 Power Consumption .................................................................................................................................... 12 6. Mechanical Specifications ..................................................................................... 13 7. Product Ordering Information ............................................................................... 14 7.1 Product Code Designation........................................................................................................................... 14 7.2 Valid Combination....................................................................................................................................... 15 2 © 2015 Apacer Technology Inc. Rev. 1.0 Serial ATA Flash Drive APS25H12xxxG-XTM1X 1. Product Description 1.1 Introduction Apacer SFD25H1-M k technology with Serial ATA 6.0 Gbps interface, including being fully compliant with standard 2.5-inch form factor, providing low power consumption compared to traditional hard drive and hot-swapping when removing/replacing/upgrading flash disks. The device is designed based on the standard 7-pin interface for data segment and 15-pin for power segment, compatible with mainstream computing systems. Performance wise, this SSD can reach up to 525 MB/s for read and 180 MB/s for write. 1.2 Capacity Specification Table 1-1 Capacity specification Capacity Total Bytes* Cylinders Heads Sectors Max LBA** 8 GB 8,012,390,400 15,525 16 63 15,649,200 16 GB 16,013,942,784 16,383 16 63 31,277,232 32 GB 32,017,047,552 16,383 16 63 62,533,296 64 GB 64,023,257,088 16,383 16 63 125,045,424 128 GB 128,035,676,160 16,383 16 63 250,069,680 256 GB 256,060,514,304 16,383 16 63 500,118,192 *Display of total bytes varies from file systems. **Cylinders, heads or sectors are not applicable for these capacities. Only LBA addressing applies. ***Notes: 1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 1.3 Performance Table 1-2 Performance specifications Capacity Performance Sustained Read (MB/s) Sustained Write (MB/s) 8 GB 16 GB 32 GB 64 GB 128 GB 256 GB 120 215 405 425 430 405 85 150 170 190 170 160 Note: 1. Results may vary depending on host system configurations. 2. Sustained Read/Write: The read/write performances are measured by CrystalDiskMark under Windows 7 operating system. 3 © 2015 Apacer Technology Inc. Rev. 1.0 Serial ATA Flash Drive APS25H12xxxG-XTM1X 1.4 Pin Assignments Table 1-4: Signal segment Table 1-5: Power segment Pin Type Description Pin S1 GND P1 Not used (3.3V) S2 RxP P2 Not used (3.3V) S3 RxN P3* Not used (3.3V) or Device Sleep S4 GND P4 Ground S5 TxN S6 TxP S7 GND Serial Data Receiver Signal Pair Serial Data Transmitter Signal Pair Signal/Description P5 Ground P6 Ground P7 5V P8 5V P9 5V P10 Ground P11 Reserved P12 Ground P13 Not used (12V) P14 Not used (12V) P15 Not used (12V) *Device Sleep is optional 4 © 2015 Apacer Technology Inc. Rev. 1.0 Serial ATA Flash Drive APS25H12xxxG-XTM1X Figure 1-3 SATA Cable / Connector Connection Diagram The connector on the left represents the Host with TX/RX differential pairs connected to a cable while the connector on the right shows the Device with TX/RX differential pairs also connected to the cable. Notice also the ground path connecting the shielding of the cable to the Cable Receptacle. 5 © 2015 Apacer Technology Inc. Rev. 1.0 Serial ATA Flash Drive APS25H12xxxG-XTM1X 2. Software Interface 2.1 Command Set Command Code Command Code NOP 00h Idle 97h Data Set Management 06h Check Power Mode 98h Sleep 99h Recalibrate 10f-1Fh Read Sectors 20h SMART B0h Read Sectors without Retry 21h Device Configuration B1h Read Sectors EXT 24h Read Multiple C4h Read DMA EXT 25h Write Multiple C5h Read Native Max Address EXT 27h Set Multiple Mode C6h Read Multiple EXT 29h Read DMA C8h Read Log EXT 2Fh Read DMA without Retry C9h Write Sectors 30h Write DMA CAh Write Sectors Without Retry 31h Write DMA without Retry CBh Write Sectors EXT 34h Write Multiple FUA EXT CEh Write DMA EXT 35h Standby Immediate E0h Set Native Max Address EXT 37h Idle Immediate E1h CFA Write Sectors without erase 38h Standby E2h Write Multiple EXT 39h Idle E3h Write DMA FUA EXT 3Dh Read Buffer E4h Write Long EXT 3Fh Check Power Mode E5h Read Verify Sectors 40h Sleep E6h Read Verify Sectors without Retry 41h Flush Cache E7h Read Verify Sectors EXT 42h Write Buffer E8h Write Uncorrectable EXT 45h Flush Cache EXT EAh Read FPDMA Queued 60h Identify Device ECh Write FPDMA Queued 61h Set Features EFh Security Set Password F1h Seek 70h-7Fh Execute Device Diagnostic 90h Security Unlock F2h Initialize Device Parameters 91h Security Erase Prepare F3h Download Microcode 92h Security Erase Unit F4h Download Microcode DMA 93h Security Freeze Lock F5h Standby Immediate 94h Security Disable Password F6h Idle Immediate 95h Read Native Max Address F8h Standby 96h Set Max Address F9h 6 © 2015 Apacer Technology Inc. Rev. 1.0 Serial ATA Flash Drive APS25H12xxxG-XTM1X 2.2 S.M.A.R.T. SMART, an acronym for Self-Monitoring, Analysis and Reporting Technology, is an open standard that allows a hard disk drive to automatically detect its health and report potential failures. When a failure is recorded by SMART, users can choose to replace the drive to prevent unexpected outage or data loss. Moreover, SMART can inform users of impending failures while there is still time to perform proactive actions, such as copy data to another device. 7 © 2015 Apacer Technology Inc. Rev. 1.0 Serial ATA Flash Drive APS25H12xxxG-XTM1X 3. Flash Management 3.1 Error Correction/Detection Flash memory cells will deteriorate with use, which might generate random bit errors in the stored data. Thus, this SSD applies the BCH ECC Algorithm, which can detect and correct errors occur during Read process, ensure data been read correctly, as well as protect data from corruption. This ECC supports up to 72bit/1K data. 3.2 Bad Block Management Bad blocks are blocks that include one or more invalid bits, and their reliability is not guaranteed. Blocks that are identified and marked as bad by the manufacturer are referred to as Initial Bad Blocks . Bad blocks that are developed during the lifespan of the flash are named Later Bad Blocks . Apacer implements an efficient bad block management algorithm to detect the factory-produced bad blocks and manages any bad blocks that appear with use. This practice further prevents data being stored into bad blocks and improves the data reliability. 3.3 Wear Leveling NAND Flash devices can only undergo a limited number of program/erase cycles, and in most cases, the flash media are not used evenly. If some areas get updated more frequently than others, the lifetime of the device would be reduced significantly. Thus, Wear Leveling technique is applied to extend the lifespan of NAND Flash by evenly distributing write and erase cycles across the media. Apacer provides advanced Wear Leveling algorithm, which can efficiently spread out the flash usage through the whole flash media area. Moreover, by implementing both dynamic and static Wear Leveling algorithms, the life expectancy of the NAND Flash is greatly improved. 3.4 Power Failure Management Power Failure Management plays a crucial role when experiencing unstable power supply. Power disruption may occur when users are storing data into the SSD. In this urgent situation, the controller would run multiple flush cycles to store the metadata for later block rebuilding. This urgent operation requires about several milliseconds to get it done. At the next power up, the firmware will perform a status tracking to retrieve the mapping table and resume previously programmed NAND blocks to check if there is any incompleteness of transmission. 3.5 TRIM TRIM is a feature which helps improve the read/write performance and speed of solid-state drives (SSD). Unlike hard disk drives (HDD), SSDs are not able to overwrite existing data, so the available space gradually becomes smaller with each use. With the TRIM command, the operating system can inform the SSD which blocks of data are no longer in use and can be removed permanently. Thus, the SSD will perform the erase action, which prevents unused data from occupying blocks all the time. 8 © 2015 Apacer Technology Inc. Rev. 1.0 Serial ATA Flash Drive APS25H12xxxG-XTM1X 3.6 Secure Erase Secure Erase is a standard ATA command and will write all 0xFF SSDs. When this command is issued, the SSD controller will empty its storage blocks and return to its factory default settings. Note. Secure erase command belongs to ATA security command. 9 © 2015 Apacer Technology Inc. Rev. 1.0 Serial ATA Flash Drive APS25H12xxxG-XTM1X 4. Reliability Specifications 4.1 Environments Table 4-1 SFD25H1-M environmental specifications Environment Specification 0°C to 70°C (Operating) -40 C to 85 C (Extended) Temperature -40 C to 85 C (in storage) RH 90% under 40 C Humidity 1500G, 0.5ms Shock 20Hz~80Hz/1.52mm (frequency/displacement) 80Hz~2000Hz/20G (frequency/displacement) Vibration X, Y, Z axis/60mins each 80cm free fall, 6 face of each Drop 50N, hold 1min/5times Bending 1.263N-m or 10deg, hold 1min/5times Torque Pass ESD Note: Shock and Vibration specifications are subject to change without notice. 4.2 Mean Time Between Failures (MTBF) Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components in SFD drive. The prediction result for SFD25H1-M is more than 1,000,000 hours. Notes about the MTBF: The MTBF is predicated and calculated based on Telcordia Technologies Special Report, SR-332, Issue 2 method. 4.3 Certification and Compliance RoHS SATA Revision 3.1 ATA/ATAPI FCC CE BSMI MIL-STD-810G 10 © 2015 Apacer Technology Inc. Rev. 1.0 Serial ATA Flash Drive APS25H12xxxG-XTM1X 4.4 Endurance The endurance of a storage device is predicted by TeraBytes Written based on several factors related to usage, such as the amount of data written into the drive, block management conditions, and daily workload for the drive. Thus, key factors, such as Write Amplifications and the number of P/E cycles, can influence the lifespan of the drive. Capacity TeraBytes Written 8 GB 7 16 GB 14 32 GB 28 64 GB 57 128 GB 114 256 GB 228 Notes: The measurement assumes the data written to the SSD for test is under a typical and constant rate. The measurement follows the standard metric: 1 TB (Terabyte) = 1000 GB. This estimation complies with JEDEC JESD-219, enterprise endurance workload of random data with payload size distribution. 11 © 2015 Apacer Technology Inc. Rev. 1.0 Serial ATA Flash Drive APS25H12xxxG-XTM1X 5. Electrical Characteristics 5.1 Operating Voltage Table 5-1 lists the supply voltage for SFD25H1-M. Table 5-1 SFD25H1-M operating voltage Parameter Conditions Supply voltage 5V ±5% 5.2 Power Consumption Table 5-2 lists the power consumption for SFD25H1-M. Table 5-2 SFD25H1-M power consumption (typical) Capacity Performance Active (mA) Idle (mA) 8 GB 16 GB 32 GB 64 GB 128 GB 256 GB 175 230 280 295 315 320 65 70 70 75 75 75 Note: power consumption may vary depending on flash configurations or platforms.. 12 © 2015 Apacer Technology Inc. Rev. 1.0 Serial ATA Flash Drive APS25H12xxxG-XTM1X 6. Mechanical Specifications 13 © 2015 Apacer Technology Inc. Rev. 1.0 Serial ATA Flash Drive APS25H12xxxG-XTM1X 7. Product Ordering Information 7.1 Product Code Designation A P S 25H 1 2 xxxG - X TM1 X Operating Temperature Range Blank: 0°C ~ 70°C W: -40°C ~ 85°C Flash Type Version Control Capacity 008G = 8GB 016G = 16GB 032G = 32GB 064G = 64GB 128G = 128GB 256G = 256GB Housing Type Solution version 2.5 inch Form Factor Serial ATA Flash Drive Apacer Product Code 14 © 2015 Apacer Technology Inc. Rev. 1.0 Serial ATA Flash Drive APS25H12xxxG-XTM1X 7.2 Valid Combination 7.2.1 Operating Temperature (0°C ~ 70°C) Capacity 8GB 16GB 32GB 64GB 128GB 256GB no DEVSLP APS25H12008G-GTM1 APS25H12016G-GTM1 APS25H12032G-GTM1 APS25H12064G-GTM1 APS25H12128G-GTM1 APS25H12256G-GTM1 DEVSLP APS25H12008G-HTM1 APS25H12016G-HTM1 APS25H12032G-HTM1 APS25H12064G-HTM1 APS25H12128G-HTM1 APS25H12256G-HTM1 7.2.2 Operating Temperature (-40°C ~ 85°C) Capacity 8GB 16GB 32GB 64GB 128GB 256GB no DEVSLP APS25H12008G-GTM1W APS25H12016G-GTM1W APS25H12032G-GTM1W APS25H12064G-GTM1W APS25H12128G-GTM1W APS25H12256G-GTM1W DEVSLP APS25H12008G-HTM1W APS25H12016G-HTM1W APS25H12032G-HTM1W APS25H12064G-HTM1W APS25H12128G-HTM1W APS25H12256G-HTM1W Note: Valid combinations are those products in mass production or will be in mass production. Consult your Apacer sales representative to confirm availability of valid combinations and to determine availability of new combinations. 15 © 2015 Apacer Technology Inc. Rev. 1.0 Serial ATA Flash Drive APS25H12xxxG-XTM1X Revision History Revision 1.0 Description Date Official release 10/21/2015 16 © 2015 Apacer Technology Inc. Rev. 1.0 Serial ATA Flash Drive APS25H12xxxG-XTM1X Global Presence Taiwan (Headquarters) Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 46732 Lakeview Blvd., Fremont, CA 94538 Tel: 1-408-518-8699 Fax: 1-510-249-9568 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd Room D, 22/FL, No.2, Lane 600, JieyunPlaza, Tianshan RD, Shanghai, 200051, China Tel: 86-21-6228-9939 Fax: 86-21-6228-9936 sales@apacer.com.cn India Apacer Technologies Pvt Ltd, th Unit No.201, Brigade Corner 7 Block Jayanagar, Yediyur Circle, Bangalore 560082, India Tel: 91-80-4152-9061 Fax: 91-80-4170-0215 sales_india@apacer.com 17 © 2015 Apacer Technology Inc. Rev. 1.0
APS25H12128G-HTM1 价格&库存
很抱歉,暂时无法提供与“APS25H12128G-HTM1”相匹配的价格&库存,您可以联系我们找货
