APSDM256GM9TD-3ATMW
APSDM256GM9TD-3ATMW
    APACERMEMORYAMERICA(宇瞻科技)
    SSD256GBMSATAMLCSATAIII3.3V
APSDM256GM9TD-3ATMW 数据手册
RoHS Compliant Serial ATA Flash Drive mSATA A1-M HighSpeed Product Specifications Aug 5, 2015 Version 2.1 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 Serial ATA Flash Drive APSDMxxxxMXXD-XXTMX Features: z Compliance with SATA Revision 3.1 SATA 6.0 Gbps interface Backward compatible with SATA 1.5 and 3.0 Gbps interfaces – ATA-8 command set Temperature ranges Operating: Standard: 0°C to 70°C Extended: -40°C to 85°C – Storage: -40°C to 100°C z – – z Capacities 32, 64, 128, 256 GB – Supply voltage 3.3 V s 5% z – z Performance* Burst read/write: 600 MB/sec Sustained read: up to 530 MB/sec Sustained write: up to 460 MB/sec Random read 4K: up to 85,000 IOPS Random write 4K: up to 79,000 IOPS – – – – – z z z Flash Management – Built-in hardware ECC – Static/dynamic wear leveling – Flash bad-block management – S.M.A.R.T. – Power Failure Management – ATA Secure Erase – TRIM NAND Flash Type: MLC Endurance (in Terabytes Written: TBW) 32GB: 68 TBW 64GB: 136 TBW 128GB: 272 TBW 256 GB: 545 TBW – – – – – Power consumption (typical)* Active mode: 930 mA Idle mode: 80 mA z – – Form factor JEDEC MO-300 z – Shock & Vibration** Shock: 1500 G Vibration: 15 G z – – z DRAM cache for enhanced random performance z SATA power management modes z Device Sleep mode (optional) z Write Protect Switch (optional) z RoHS compliant z Thermal sensor (optional) *Varies from capacities. The values addressed here are typical and may vary depending on settings and platforms. **Non-operating 1 ©2015 Apacer Technology Inc. Rev. 2.1 Serial ATA Flash Drive APSDMxxxxMXXD-XXTMX Table of Contents 1. Product Description ............................................................................................... 3 1.1 1.2 1.3 1.4 Introduction .................................................................................................................................................3 Capacity Specification.................................................................................................................................3 Performance.................................................................................................................................................3 Pin Assignments ..........................................................................................................................................4 2. Software Interface ................................................................................................... 6 2.1 Command Set ..............................................................................................................................................6 2.2 S.M.A.R.T. ...................................................................................................................................................6 3. Flash Management ................................................................................................. 8 3.1 3.2 3.3 3.4 3.5 3.6 3.7 3.8 4. Error Correction/Detection ........................................................................................................................8 Bad Block Management ..............................................................................................................................8 Wear Leveling..............................................................................................................................................8 Power Failure Management .......................................................................................................................8 ATA Secure Erase .......................................................................................................................................8 TRIM ............................................................................................................................................................9 Thermal Sensor ...........................................................................................................................................9 SATA Power Management .........................................................................................................................9 Reliability Specifications ..................................................................................... 10 4.1 Environmental .......................................................................................................................................... 10 4.2 Mean Time Between Failures (MTBF) .................................................................................................... 10 4.3 Certification and Compliance .................................................................................................................. 10 4.4 Endurance .................................................................................................................................................. 10 5. Electrical Characteristics ..................................................................................... 11 5.1 Operating Voltage ..................................................................................................................................... 11 5.2 Power Consumption .................................................................................................................................. 11 6. Mechanical Specifications ................................................................................... 12 6.1 Dimensions ................................................................................................................................................. 12 6.2 Write Protect Switch (optional) ............................................................................................................... 13 7. Product Ordering Information ............................................................................. 14 7.1 Product Code Designations ...................................................................................................................... 14 7.2 Valid Combinations .................................................................................................................................. 15 2 ©2015 Apacer Technology Inc. Rev. 2.1 Serial ATA Flash Drive APSDMxxxxMXXD-XXTMX 1. Product Description 1.1 Introduction Apacer mSATA A1-M is a well-balanced solid-state disk (SSD) drive with compact form factor (JEDEC MO-300) and great performance. Designed in SATA 6.0 Gbps interface, the mSATA SSD is able to deliver exceptional read/write speed, making it the ideal companion for heavy-loading embedded or server operations with space constraints for host computing systems. For data efficiency, the internal controlling unit of the mSATA SSD is engineered with DRAM for enhanced random performance. In regard of reliability, the drive comes with various implementations including powerful hardware ECC engine, power saving modes, wear leveling, flash block management, S.M.A.R.T., TRIM, and power failure management. 1.2 Capacity Specification Table 1-1 Capacity specification Capacity Total Bytes Cylinders Heads Sectors Max LBA 32 GB 32,017,047,552 16,383 16 63 62,533,296 64 GB 64,023,257,088 16,383 16 63 125,045,424 128 GB 128,035,676,160 16,383 16 63 250,069,680 256 GB 256,060,514,304 16,383 16 63 500,118,192 1. Display of total bytes varies from file systems. 2. Cylinders, heads or sectors are not applicable for these capacities. Only LBA addressing applies. 3. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 1.3 Performance Table 1-2 Performance Capacity 32 GB 64 GB 128 GB 256 GB Sustained Read (MB/s) 380 530 530 530 Sustained Write (MB/s) 80 145 305 460 Random Read IOPS (4K) 47,000 79,000 85,000 85,000 Random Write IOPS (4K) 18,000 34,000 72,000 79,000 Performance Note: Performance varies from flash configurations or host system settings. IOPS: measured on 8GB span (16777216 sectors Disk Size), 32 Outstanding I/Os (QD=32), Full Random Data pattern, 4KB Align I/Os and test durations 15minutes. 3 ©2015 Apacer Technology Inc. Rev. 2.1 Serial ATA Flash Drive APSDMxxxxMXXD-XXTMX 1.4 Pin Assignments Pin assignment of the mSATA A1-M is shown in Figure 1-2 and described in Table 1-3. Pin 1 Pin 51 Figure 1-2 Apacer mSATA A1-M pin assignment Pin 1 2 3 4 Type Reserved +3.3V Reserved GND Description No Connect 3.3V source No Connect Ground Pin 27 28 29 30 Type GND Reserved GND Reserved 5 Reserved No Connect 31 -A 6 Reserved No Connect 32 Reserved 7 Reserved No Connect 33 +A 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 Reserved GND Reserved Reserved Reserved Reserved Reserved GND Reserved Reserved GND Reserved Reserved GND Reserved No Connect Ground No Connect No Connect No Connect No Connect No Connect Ground No Connect No Connect Ground No Connect No Connect Ground No Connect 34 35 36 37 38 39 40 41 42 43 44* 45 46 47 48 GND GND Reserved GND Reserved +3.3V GND +3.3V Reserved Device Type DEVSLP Reserved Reserved Reserved Reserved 23 +B Host Receiver Differential Signal Pair 49 DAS/DSS 24 +3.3V Description Ground No Connect Ground No Connect Host Transmitter Differential Signal Pair No Connect Host Transmitter Differential Signal Pair Ground Ground No Connect Ground No Connect 3.3V source Ground 3.3V source No Connect No Connect Device Sleep No Connect No Connect No Connect No Connect Device Activity Signal/Disable Staggered Spin-up Ground 3.3V Source 50 GND Host Receiver 25 -B 51** Detect 0 ohm Differential Signal Pair 26 GND Ground 52 +3.3V 3.3V source *Pin44 can be configured as Device Sleep enabling pin by option. **Notes about Pin51: It is a presence detection pin that shall be connected to GND by a 0 ohm to 220 ohm Resistor on device. Please see the diagram below. 4 ©2015 Apacer Technology Inc. Rev. 2.1 Serial ATA Flash Drive APSDMxxxxMXXD-XXTMX 5 ©2015 Apacer Technology Inc. Rev. 2.1 Serial ATA Flash Drive APSDMxxxxMXXD-XXTMX 2. Software Interface 2.1 Command Set Table 2-1 summarizes the ATA commands supported by mSATA A1-M. Table 2-1: Code Command set Command Code Command E5h Check Power Mode F6h Security Disable Password 90h Execute Diagnostics F3h Security Erase Prepare E7h Flush Cache F4h Security Erase Unit ECh Identify Device F5h Security Freeze Lock E3h Idle F1h Security Set Password E1h Idle Immediate F2h Security Unlock 91h Initialize Device Parameters 7xh Seek C8h Read DMA EFh Set Features 25h Read DMA EXT C6h Set Multiple Mode 60h Read FPDMA Queued E6h Sleep 47h Read Log DMA EXT B0h S.M.A.R.T. 2Fh Read Log EXT E2h Standby C4h Read Multiple E0h Standby Immediate 20 or 21h Read Sector(s) CAh Write DMA 40 or 41h Read Verify Sector(s) 35h Write DMA EXT 10h Recalibrate 61h Write FPDMA Queued 57h Write Log DMA EXT 3Fh Write Log EXT C5h Write Multiple 30h or 31h Write Sector(s) 2.2 S.M.A.R.T. S.M.A.R.T. is an abbreviation for Self-Monitoring, Analysis and Reporting Technology, a self-monitoring system that provides indicators of drive health as well as potential disk problems. It serves as a warning for users from unscheduled downtime by monitoring and displaying critical drive information. Ideally, this should allow taking proactive actions to prevent drive failure and make use of S.M.A.R.T. information for future product development reference. Apacer devices use the standard SMART command B0h to read data out from the drive to activate our S.M.A.R.T. feature that complies with the ATA/ATAPI specifications. S.M.A.R.T. Attribute IDs shall include initial bad block count, total later bad block count, maximum erase count, average erase count, power on hours and power cycle. When the S.M.A.R.T. Utility running on the host, it analyzes and reports the disk status to the host before the device reaches in critical condition. Note: attribute IDs may vary from product models due to various solution design and supporting capabilities. 6 ©2015 Apacer Technology Inc. Rev. 2.1 Serial ATA Flash Drive APSDMxxxxMXXD-XXTMX Apacer memory products come with S.M.A.R.T. commands and subcommands for users to obtain information of drive status and to predict potential drive failures. Users can take advantage of the following commands/subcommands to monitor the health of the drive. Code D0h D1h D2h D4h D5h D6h D8h D9h DAh Byte 0 1–2 3 4 5*-11 SMART Subcommand READ DATA READ ATTRIBUTE THRESHOLDS Enable/Disable Attribute Autosave Execute Off-line Immediate Read Log (optional) Write Log (optional) Enable Operations Disable operations Return Status General SMART attribute structure Description ID (Hex) Status flag Value Worst Raw Data *Byte 5: LSB ID (Hex) 9 (0x09) 12 (0x0C) 163 (0xA3) 164 (0xA4) 166 (0xA6) 167 (0xA7) 168 (0xA8) 175 (0xAF) 192 (0xC0) 194 (0xC2) 241 (0xF1) SMART attribute ID list Attribute Name Power-on hours Power cycle count Max. erase count Avg. erase count Total later bad block count SSD Protect Mode (vendor specific) SATA PHY Error Count Bad Cluster Table Count Unexpected Power Loss Count Temperature Total sectors of write 7 ©2015 Apacer Technology Inc. Rev. 2.1 Serial ATA Flash Drive APSDMxxxxMXXD-XXTMX 3. Flash Management 3.1 Error Correction/Detection mSATA A1-M implements a hardware ECC scheme, based on the BCH algorithm. It can detect and correct up to 40 bits error in 1K bytes. 3.2 Bad Block Management Current production technology is unable to guarantee total reliability of NAND flash memory array. When a flash memory device leaves factory, it comes with a minimal number of initial bad blocks during production or out-of-factory as there is no currently known technology that produce flash chips free of bad blocks. In addition, bad blocks may develop during program/erase cycles. When host performs program/erase command on a block, bad block may appear in Status Register. Since bad blocks are inevitable, the solution is to keep them in control. Apacer flash devices are programmed with ECC, block mapping technique and S.M.A.R.T to reduce invalidity or error. Once bad blocks are detected, data in those blocks will be transferred to free blocks and error will be corrected by designated algorithms. 3.3 Wear Leveling Flash memory devices differ from Hard Disk Drives (HDDs) in terms of how blocks are utilized. For HDDs, when a change is made to stored data, like erase or update, the controller mechanism on HDDs will perform overwrites on blocks. Unlike HDDs, flash blocks cannot be overwritten and each P/E cycle wears down the lifespan of blocks gradually. Repeatedly program/erase cycles performed on the same memory cells will eventually cause some blocks to age faster than others. This would bring flash storages to their end of service term sooner. Wear leveling is an important mechanism that level out the wearing of blocks so that the wearing-down of blocks can be almost evenly distributed. This will increase the lifespan of SSDs. Commonly used wear leveling types are Static and Dynamic. 3.4 Power Failure Management Power Failure Management plays a crucial role when experiencing unstable power supply. Power disruption may occur when users are storing data into the SSD. In this urgent situation, the controller would run multiple write-to-flash cycles to store the metadata for later block rebuilding. This urgent operation requires about several milliseconds to get it done. At the next power up, the firmware will perform a status tracking to retrieve the mapping table and resume previously programmed NAND blocks to check if there is any incompleteness of transmission. Note: The controller unit of this product model is designed with a DRAM as a write cache for improved performance and data efficiency. Though unlikely to happen in most cases, the data cached in the volatile DRAM might be potentially affected if a sudden power loss takes place before the cached data is flushed into non-volatile NAND flash memory. 3.5 ATA Secure Erase ATA Secure Erase is an ATA disk purging command currently embedded in most of the storage drives. Defined in ATA specifications, (ATA) Secure Erase is part of Security Feature Set that allows storage drives to erase all user data areas. The erase process usually runs on the firmware level as most of the ATA-based storage media currently in the market are built-in with this command. ATA Secure Erase can securely wipe out the user data in the drive and protects it from malicious attack. 8 ©2015 Apacer Technology Inc. Rev. 2.1 Serial ATA Flash Drive APSDMxxxxMXXD-XXTMX 3.6 TRIM TRIM is a SATA command that helps improve the read/write performance and efficiency of solid-state drives (SSD). The command enables the host operating system to inform SSD controller whick blocks contain invalid data, mostly because of the erase commands from host. The invalid will be discarded permanently and the SSD will retain more space for itself. 3.7 Thermal Sensor Apacer Thermal Sensor is a digital temperature sensor with serial interface. By using designated pins for transmission, storage device owners are able to read temperature data. 3.8 SATA Power Management By complying with SATA 6.0 Gb/s specifications, the SSD supports the following SATA power saving modes: y ACTIVE: PHY ready, full power, Tx & Rx operational y PARTIAL: Reduces power, resumes in under 10 μs (microseconds) y SLUMBER: Reduces power, resumes in under 10 ms (milliseconds) y HIPM: Host-Initiated Power Management y DIPM: Device-Initiated Power Management y AUTO-SLUMBER: Automatic transition from partial to slumber. y Device Sleep (DevSleep or DEVSLP): PHY powered down; power consumption ʀ 5 mW; host assertion time ʀ 10 ms; exit timeout from this state ʀ 20 ms (unless specified otherwise in SATA Identify Device Log). Note: 1. The behaviors of power management features would depend on host/device settings. 2. Device Sleep mode is optional, depending on product ordering selections. 9 ©2015 Apacer Technology Inc. Rev. 2.1 Serial ATA Flash Drive APSDMxxxxMXXD-XXTMX 4. Reliability Specifications 4.1 Environmental mSATA A1-M environmental specifications follow MIL-STD-810F, as indicated in the following table. Table 4-1 mSATA A1-M environmental specifications Environment Specification 0°C to 70°C(standard); -40°C to 85°C (extended) Temperature 4.2 -40°C to 100°C (Non-operating) Vibration Non-operating : Sine wave, 15(G), 10~2000(Hz), Operating : Random, 7.69(Grms), 20~2000(Hz) Shock Non-operating: Acceleration, 1,500 G, 0.5 ms Operating: Peak acceleration, 50 G, 11 ms Mean Time Between Failures (MTBF) Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components in SATA drive. The prediction result for the mSATA A1-M is more than 1,000,000 hours. Notes about the MTBF: the MTBF is predicated and calculated based on “Telcordia Technologies Special Report, SR-332, Issue 2” method. 4.3 Certification and Compliance mSATA A1-M complies with the following standards: CE FCC RoHS MIL-STD-810F 4.4 Endurance The endurance of a storage device is predicted by TeraBytes Written based on several factors related to usage, such as the amount of data written into the drive, block management conditions, and daily workload for the drive. Thus, key factors, such as Write Amplifications and the number of P/E cycles, can influence the lifespan of the drive. Capacity TeraBytes Written 32 GB 68 64 GB 136 128 GB 272 256 GB 545 Notes: y The measurement assumes the data written to the SSD for test is under a typical and constant rate. y The measurement follows the standard metric: 1 TB (Terabyte) = 1000 GB. 10 ©2015 Apacer Technology Inc. Rev. 2.1 Serial ATA Flash Drive APSDMxxxxMXXD-XXTMX 5. Electrical Characteristics 5.1 Operating Voltage Table 5-1 lists the supply voltage for mSATA A1-M. Table 5-1 mSATA A1-M operating voltage Parameter Conditions Supply voltage 3.3V ±5% 5.2 Power Consumption Table 5-2 lists the power consumption for mSATA A1-M. Table 5-2: Typical power consumption Capacity 32 GB 64 GB 128 GB 256 GB Active (mA) 340 420 680 930 Idle (mA) 75 80 80 80 Modes Note: Results may differ from various flash configurations or host system setting 11 ©2015 Apacer Technology Inc. Rev. 2.1 Serial ATA Flash Drive APSDMxxxxMXXD-XXTMX 6. Mechanical Specifications 6.1 Dimensions Unit: ੈ Tolerance: ± 0.2 12 ©2015 Apacer Technology Inc. Rev. 2.1 Serial ATA Flash Drive APSDMxxxxMXXD-XXTMX 6.2 Write Protect Switch (optional) Apacer implements the Virtual Write scheme that allows write commands to go through the flash controller and data temporarily stored, but no data has been actually written into the flash. Once the system is reset and rebooted, the temporarily stored data will be lost and nowhere to be found in the system. Since the Virtual Write scheme runs at device level, it requires no software or driver installation and is independent from the host OS. Disable Enable Write Protect switch Note: Write Protect is optional and the image is for reference only. 13 ©2015 Apacer Technology Inc. Rev. 2.1 Serial ATA Flash Drive APSDMxxxxMXXD-XXTMX 7. Product Ordering Information 7.1 Product Code Designations A P SDM x x x x M X XX – XX TM X Operating Temperature Range Blank: 0ɗ ~ 70ɗ W: -40ɗ ~ 85ɗ Flash Type Version Control Add on value AD = Standard WD = No DEVSLP + Write Protect CD = DEVSLP + Write Protect TD = No DEVSLP + Thermal Sensor FD = DEVSLP + Thermal Sensor Solution Version Form Factor: M= MO-300 Capacities: 032G = 32GB 064G = 64GB 128G = 128GB 256G = 256GB SATA Disk Module Apacer Product Code 14 ©2015 Apacer Technology Inc. Rev. 2.1 Serial ATA Flash Drive APSDMxxxxMXXD-XXTMX 7.2 Valid Combinations A. Without Write Protect 7.2.1 Operating Temperature (0ɗ ~ 70ɗ) Capacity 32GB 64GB 128GB 256GB NO DEVSLP APSDM032GM4AD-3ATM APSDM064GM9AD-3ATM APSDM128GM9AD-3ATM APSDM256GM9AD-3ATM DEVSLP APSDM032GM4AD-3BTM APSDM064GM9AD-3BTM APSDM128GM9AD-3BTM APSDM256GM9AD-3BTM ġ DEVSLP APSDM032GM4AD-3BTMW APSDM064GM9AD-3BTMW APSDM128GM9AD-3BTMW APSDM256GM9AD-3BTMW ġ 7.2.2 Operating Temperature (-40ɗ ~ 85ɗ) Capacity 32GB 64GB 128GB 256GB NO DEVSLP APSDM032GM4AD-3ATMW APSDM064GM9AD-3ATMW APSDM128GM9AD-3ATMW APSDM256GM9AD-3ATMW B. Write Protect 7.2.3 Operating Temperature (0ɗ ~ 70ɗ) Capacity 32GB 64GB 128GB 256GB NO DEVSLP APSDM032GM4WD-3ATM APSDM064GM9WD-3ATM APSDM128GM9WD-3ATM APSDM256GM9WD-3ATM DEVSLP APSDM032GM4CD-3BTM APSDM064GM9CD-3BTM APSDM128GM9CD-3BTM APSDM256GM9CD-3BTM 7.2.4 Operating Temperature (-40ɗ ~ 85ɗ) Capacity 32GB 64GB 128GB 256GB NO DEVSLP APSDM032GM4WD-3ATMW APSDM064GM9WD-3ATMW APSDM128GM9WD-3ATMW APSDM256GM9WD-3ATMW DEVSLP APSDM032GM4CD-3BTMW APSDM064GM9CD-3BTMW APSDM128GM9CD-3BTMW APSDM256GM9CD-3BTMW 15 ©2015 Apacer Technology Inc. Rev. 2.1 Serial ATA Flash Drive APSDMxxxxMXXD-XXTMX C. Thermal Sensor without Write Protect 7.2.5 Operating Temperature (0ɗ ~ 70ɗ) Capacity 32GB 64GB 128GB 256GB NO DEVSLP APSDM032GM4TD-3ATM APSDM064GM9TD-3ATM APSDM128GM9TD-3ATM APSDM256GM9TD-3ATM DEVSLP APSDM032GM4FD-3BTM APSDM064GM9FD-3BTM APSDM128GM9FD-3BTM APSDM256GM9FD-3BTM 7.2.6 Operating Temperature (-40ɗ ~ 85ɗ) Capacity 32GB 64GB 128GB 256GB NO DEVSLP APSDM032GM4TD-3ATMW APSDM064GM9TD-3ATMW APSDM128GM9TD-3ATMW APSDM256GM9TD-3ATMW DEVSLP APSDM032GM4FD-3BTMW APSDM064GM9FD-3BTMW APSDM128GM9FD-3BTMW APSDM256GM9FD-3BTMW Note: Valid combinations are those products in mass production or will be in mass production. Consult your Apacer sales representative to confirm availability of valid combinations and to determine availability of new combinations. 16 ©2015 Apacer Technology Inc. Rev. 2.1 Serial ATA Flash Drive APSDMxxxxMXXD-XXTMX Revision History Revision Description Date 0.1 Preliminary release 05/17/2013 0.2 Updated performance and power consumption 09/17/2013 Removed 16GB information 0.3 Added IOPS 10/16/2013 Integrates categories of standard and high-speed types 0.4 Revised the capacity information for 128GB 11/07/2013 0.5 Updated performance and power consumption after a re-test 11/08/2013 1.0 Official release 12/10/2013 1.1 Revised Product Ordering Information with the addition of standard type with DEVSLP feature 02/20/2014 1.2 Removed “DSS” from pin49 03/14/2014 1.3 Added write protect switch 04/07/2014 1.4 Added Enhanced temperature grade into the specifications 04/28/2014 1.5 Updated performance and power consumption due to firmware upgrade 05/14/2014 1.6 Revised pin assignments (pin43) 09/12/2014 1.7 Added Thermal Sensor feature 09/19/2014 1.8 Updated 6.1 Dimensions (Standard type) 02/05/2015 1.9 Removed standard type and enhanced temperature grade support 04/09/2015 2.0 Revised Product Code Designations 06/01/2015 2.1 Revised Product Ordering Information with the addition of extended temperature support 08/05/2015 17 ©2015 Apacer Technology Inc. Rev. 2.1 Serial ATA Flash Drive APSDMxxxxMXXD-XXTMX Global Presence Taiwan (Headquarters) Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 386 Fairview Way, Suite102, Milpitas, CA 95035 Tel: 1-408-518-8699 Fax: 1-408-935-9611 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd Room D,22/FL,No2,Lane600,JieyunPlaza, Tianshan RD,Shanghai,200051,China Tel: 86-21-6228-9939 Fax: 86-21-6228-9936 sales@apacer.com.cn India Apacer Technologies Pvt Ltd Unit No.201, "Brigade Corner", 7th Block Jayanagar, Yediyur Circle, Bangalore – 560082, INDIA. Tel: +91-80-4152-9061/62/63 Fax:+91-80-4170-0215 sales_india@apacer.com 18 ©2015 Apacer Technology Inc. Rev. 2.1
APSDM256GM9TD-3ATMW 价格&库存
很抱歉,暂时无法提供与“APSDM256GM9TD-3ATMW”相匹配的价格&库存,您可以联系我们找货
