APSDM256GM1HN-1TM
APSDM256GM1HN-1TM
    APACERMEMORYAMERICA(宇瞻科技)
    Solid State Drive (SSD) 256GB SATA III FLASH - NAND (MLC) mSATA 3.3V
APSDM256GM1HN-1TM 数据手册
RoHS Compliant Serial ATA Flash Drive mSATA H1-M Product Specifications November 20th, 2014 Version 1.3 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 Serial ATA Flash Drive APSDMxxxxM1HN-XTMX Features: Compliance with SATA Revision 3.1 SATA 6.0 Gbps interface Backward compatible with SATA 1.5/3.0 Gbps interfaces ATA command set Temperature ranges Operating: Standard: 0°C to 70°C Extended: -40°C to 85°C Storage: -40°C to 85°C Capacities 16, 32, 64, 128, 256 GB Supply voltage 3.3 V 5% Performance* Interface burst read/write: 600 MB/sec Sustained read: up to 520 MB/sec Sustained write: up to 185 MB/sec Power consumption (typical)* Active mode: 485 mA Idle mode: 95 mA Form factor JEDEC MO-300 Dimensions (50.80 x 29.85 x 1.00, unit: mm) Flash Management Built-in hardware ECC Wear leveling Bad block management S.M.A.R.T. Power Failure Management TRIM Connector 52-pin mSATA signal connector RoHS compliant Device Sleep (optional) NAND Flash Type: MLC Endurance 16GB: 27 TBW 32GB: 54 TBW 64GB: 108 TBW 128GB: 217 TBW 256 GB: 434 TBW *Varies from capacities. The values addressed here are typical and may vary depending on host system settings. 1 ©2014 Apacer Technology Inc. Rev. 1.3 Serial ATA Flash Drive APSDMxxxxM1HN-XTMX Table of Contents 1. Product Description ............................................................................................... 3 1.1 Introduction ...................................................................................................................................................3 1.2 Capacity Specification ...................................................................................................................................3 1.3 Performance ...................................................................................................................................................3 1.4 Pin Assignments ............................................................................................................................................. 4 2. Software Interface................................................................................................... 6 2.1 Command Set .................................................................................................................................................6 2.2 S.M.A.R.T. ......................................................................................................................................................6 3. Flash Management ................................................................................................. 7 3.1 Error Correction/Detection .......................................................................................................................... 7 3.2 Bad Block Management ................................................................................................................................7 3.3 Wear Leveling ................................................................................................................................................7 3.4 Power Failure Management .......................................................................................................................... 7 3.5 TRIM .............................................................................................................................................................. 7 3.6 Secure Erase ...................................................................................................................................................8 4. Environment Specifications .................................................................................. 9 4.1 Environmental ...............................................................................................................................................9 4.2 Mean Time Between Failures (MTBF) ........................................................................................................9 4.3 Certification and Compliance .......................................................................................................................9 4.4 Endurance .................................................................................................................................................... 10 5. Electrical Characteristics ..................................................................................... 11 5.1 Operating Voltage........................................................................................................................................ 11 5.2 Power Consumption .................................................................................................................................... 11 6. Mechanical Specifications ................................................................................... 12 6.1 Dimensions ................................................................................................................................................... 12 7. Product Ordering Information ............................................................................. 13 7.1 Product Code Designation........................................................................................................................... 13 7.2 Valid Combination....................................................................................................................................... 14 2 ©2014 Apacer Technology Inc. Rev. 1.3 Serial ATA Flash Drive APSDMxxxxM1HN-XTMX 1. Product Description 1.1 Introduction mSATA H1-M delivers all the advantages of flash disk technology with the Serial ATA 6.0 Gbps interface and is fully compliant with the standard mSATA form factor, known as JEDEC MO-300 standard. The module is designed to operate at optimal efficiency and reliability. Its performance can reach up to 520 MB/s read and up to 185MB/s write. Meanwhile, the power consumption of the mSATA module is much lower than traditional hard drives. 1.2 Capacity Specification Table 1-1 Capacity specification Capacity Total Bytes Cylinders Heads Sectors Max LBA 16 GB 16,013,942,784 16,383 16 63 31,277,232 32 GB 32,017,047,552 16,383 16 63 62,533,296 64 GB 64,023,257,088 16,383 16 63 125,045,424 128 GB 128,035,676,160 16,383 16 63 250,069,680 256 GB 256,060,514,304 16383 16 63 500,118,192 *Display of total bytes varies from file systems. **Cylinders, heads or sectors are not applicable for these capacities. Only LBA addressing applies. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 1.3 Performance Performance of mSATA H1-M is shown in Table 1-2. Table 1-2 Performance specification Capacity Performance Sustained Read (MB/s) Sustained Write (MB/s) 16 GB 32 GB 64 GB 128 GB 256 GB 315 520 520 525 520 150 180 185 175 170 Note: Performance varies from flash configurations or host system settings. 3 ©2014 Apacer Technology Inc. Rev. 1.3 Serial ATA Flash Drive APSDMxxxxM1HN-XTMX 1.4 Pin Assignments Pin assignment of the mSATA H1-M is shown in Figure 1-2 and described in Table 1-3. Pin 1 Pin 51 Figure 1-2 Apacer mSATA H1-M pin assignment Table 1-3 Pin Assignment Description Pin # mSATA Pin Description 1 NC No Connect 2 +3.3V 3.3V Source 3 NC No Connect 4 DGND Digital GND 5 NC No Connect 6 NC No Connect 7 NC No Connect 8 NC No Connect 9 DGND Digital GND 10 NC No Connect 11 NC No Connect 12 NC No Connect 13 NC No Connect 14 NC No Connect 15 DGND Digital GND 16 NC No Connect 17 NC No Connect 18 DGND Digital GND 19 NC No Connect 20 NC No Connect 21 SATA GND SATA Ground Return Pin 22 NC No Connect 23 +B Host Receiver Differential Signal Pair 4 ©2014 Apacer Technology Inc. Rev. 1.3 Serial ATA Flash Drive APSDMxxxxM1HN-XTMX 24 +3.3V 3.3V Source 25 -B Host Receiver Differential Signal Pair 26 SATA GND SATA Ground Return Pin 27 SATA GND SATA Ground Return Pin 28 NC No Connect 29 SATA GND SATA Ground Return Pin 30 NC No Connect 31 -A Host Transmitter Differential Signal Pair 32 NC No Connect 33 +A Host Transmitter Differential Signal Pair 34 DGND Digital GND 35 SATA GND SATA Ground Return Pin 36 NC No Connect 37 SATA GND SATA Ground Return Pin 38 NC No Connect 39 +3.3V 3.3V Source 40 DGND Digital GND 41 +3.3V 3.3V Source 42 NC No Connect 43 NC No Connect 44 NC No Connect 45 Vendor Vendor specific 46 NC No Connect 47 Vendor Vendor specific 48 NC No Connect 49 DA/DSS Device activity signal 50 DGND Digital GND 51 GND Default connect to GND 52 +3.3V 3.3V Source 5 ©2014 Apacer Technology Inc. Rev. 1.3 Serial ATA Flash Drive APSDMxxxxM1HN-XTMX 2. Software Interface 2.1 Command Set Table 2-1 summarizes the ATA commands supported by mSATA H1-M. Table 2-1: Command set Code Command Code Command E5h Check power mode F6h Security Disable Password 06h Data Set management F3h Security Erase Prepare B1H DCO F4h Security Erase Unit 92h Download Microcode PIO F5h Security Freeze Lock 93h Download Microcode DMA F1h Security Set Password 90h Execute drive diagnostic F2h Security Unlock E7h Flush cache 70h Seek Eah Flush cache Ext Efh Set features Ech Identify device F9h Set Max Address E3h Idle 37h Set Max Address Ext E1h Idle immediate C6h Set multiple mode 91h Initialize drive parameters E6h Sleep E4h Read buffer B0h Smart C9h Read DMA (w/o retry) E2h Standby C8h Read DMA (w/retry) E0h Standby immediate 25h Read DMA Ext E8h Write buffer 60h Read FPDMA QUEUED CBh Write DMA (w/o retry) 2Fh Read Log Ext Cah Write DMA (w/retry) C4h Read multiple 35h Write DMA Ext 29h Read multiple Ext 3Dh Write DMA FUA Ext F8h Read native max address 61h Write FPDMA QUEUED 27h Read native max Ext 3Fh Write Log Ext 21h Read sector(s) (w/o retry) C5h Write multiple 20h Read sector(s) (w/retry) 39h Write multiple Ext 24h Read sector(s) Ext Ceh Write multiple FUA Ext 42h Read Verify Ext 31h Write sector(s) (w/o retry) 41h Read verify sector(s) (w/o retry) 30h Write sector(s) (w/retry) 40h Read verify sector(s) (w/retry) 34h Write sector(s) Ext 10h Recalibrate 45h Write uncorrectable Note. Security command will only be workable when device runs in non-OPAL compliant mode. 2.2 S.M.A.R.T. SMART, an acronym for Self-Monitoring, Analysis and Reporting Technology, is an open standard that allows a hard disk drive to automatically detect its health and report potential failures. When a failure is recorded by SMART, users can choose to replace the drive to prevent unexpected outage or data loss. Moreover, SMART can inform users of impending failures while there is still time to perform proactive actions, such as copy data to another device. 6 ©2014 Apacer Technology Inc. Rev. 1.3 Serial ATA Flash Drive APSDMxxxxM1HN-XTMX 3. Flash Management 3.1 Error Correction/Detection Flash memory cells will deteriorate with use, which might generate random bit errors in the stored data. Thus, this mSATA SSD module applies the BCH ECC Algorithm, which can detect and correct errors occur during Read process, ensure data been read correctly, as well as protect data from corruption. This device can correct up to 72bit/1K data. 3.2 Bad Block Management Bad blocks are blocks that include one or more invalid bits, and their reliability is not guaranteed. Blocks that are identified and marked as bad by the manufacturer are referred to as Initial Bad Blocks . Bad blocks that are developed during the lifespan of the flash are named Later Bad Blocks . Apacer implements an efficient bad block management algorithm to detect the factory-produced bad blocks and manages any bad blocks that appear with use. This practice further prevents data being stored into bad blocks and improves the data reliability. 3.3 Wear Leveling NAND Flash devices can only undergo a limited number of program/erase cycles, and in most cases, the flash media are not used evenly. If some areas get updated more frequently than others, the lifetime of the device would be reduced significantly. Thus, Wear Leveling technique is applied to extend the lifespan of NAND Flash by evenly distributing write and erase cycles across the media. Apacer provides advanced Wear Leveling algorithm, which can efficiently spread out the flash usage through the whole flash media area. Moreover, by implementing both dynamic and static Wear Leveling algorithms, the life expectancy of the NAND Flash is greatly improved. 3.4 Power Failure Management Power Failure Management plays a crucial role when experiencing unstable power supply. Power disruption may occur when users are storing data into the SSD. In this urgent situation, the controller would run multiple flush cycles to store the metadata for later block rebuilding. This urgent operation requires about several milliseconds to get it done. At the next power up, the firmware will perform a status tracking to retrieve the mapping table and resume previously programmed NAND blocks to check if there is any incompleteness of transmission. 3.5 TRIM TRIM is a feature which helps improve the read/write performance and speed of solid-state drives (SSD). Unlike hard disk drives (HDD), SSDs are not able to overwrite existing data, so the available space gradually becomes smaller with each use. With the TRIM command, the operating system can inform the SSD which blocks of data are no longer in use and can be removed permanently. Thus, the SSD will perform the erase action, which prevents unused data from occupying blocks all the time. 7 ©2014 Apacer Technology Inc. Rev. 1.3 Serial ATA Flash Drive APSDMxxxxM1HN-XTMX 3.6 Secure Erase Secure Erase is a standard ATA command and will write all 0xFF ly wipe all the data on hard drives and SSDs. When this command is issued, the SSD controller will empty its storage blocks and return to its factory default settings. Note. Secure erase command belongs to ATA security command. 8 ©2014 Apacer Technology Inc. Rev. 1.3 Serial ATA Flash Drive APSDMxxxxM1HN-XTMX 4. Environment Specifications 4.1 Environmental Table 4-1 mSATA H1-M environmental specifications Environment Specification 0°C to 70°C (Operating) -40°C to 85°C (Extended) Temperature -40 C to 85 C (in storage) RH 90% under 40 C Humidity 1500G, 0.5ms Shock 20Hz~80Hz/1.52mm (frequency/displacement) 80Hz~2000Hz/20G (frequency/displacement) Vibration X, Y, Z axis/60mins each 80cm free fall, 6 face of each Drop 20N, hold 1min/5times Bending 0.5N-m or 5deg, hold 5min/5times Torque Pass ESD Note: Shock and Vibration specifications are subject to change without notice. 4.2 Mean Time Between Failures (MTBF) the average time between a repair and the next failure. The measure is typically in units of hours. The higher the MTBF value, the higher the reliability of the device. The predicted result of this mSATA device is higher than 1,000,000 hours. 4.3 Certification and Compliance mSATA H1-M complies with the following standards: SATA Revision 3.0 RoHS ATA/ATAPI FCC CE BSMI 9 ©2014 Apacer Technology Inc. Rev. 1.3 Serial ATA Flash Drive APSDMxxxxM1HN-XTMX 4.4 Endurance The endurance of a storage device is predicted by TeraBytes Written based on several factors related to usage, such as the amount of data written into the drive, block management conditions, and daily workload for the drive. Thus, key factors, such as Write Amplifications and the number of P/E cycles, can influence the lifespan of the drive. Capacity TeraBytes Written 16 GB 27 32 GB 54 64 GB 108 128 GB 217 256 GB 434 Notes: The measurement assumes the data written to the SSD for test is under a typical and constant rate. The measurement follows the standard metric: 1 TB (Terabyte) = 1000 GB. 10 ©2014 Apacer Technology Inc. Rev. 1.3 Serial ATA Flash Drive APSDMxxxxM1HN-XTMX 5. Electrical Characteristics 5.1 Operating Voltage Table 5-1 lists the supply voltage for mSATA H1-M. Table 5-1 mSATA H1-M operating voltage Parameter Conditions Supply voltage 3.3V ±5% 5.2 Power Consumption Table 5-2 Power consumption (typical) Capacity Mode Active (mA) Idle (mA) 16 GB 32 GB 64 GB 128 GB 256 GB 325 415 440 460 485 95 95 95 95 95 Note: Power consumptions may vary depending on host system settings. 11 ©2014 Apacer Technology Inc. Rev. 1.3 Serial ATA Flash Drive APSDMxxxxM1HN-XTMX 6. Mechanical Specifications 6.1 Dimensions Unit: Tolerance: ± 0.2 12 ©2014 Apacer Technology Inc. Rev. 1.3 Serial ATA Flash Drive APSDMxxxxM1HN-XTMX 7. Product Ordering Information 7.1 Product Code Designation AP SDM xxxx M 1 HN - X TM X Operating Temperature Range Blank: 0 ~ 70 W: -40 ~ 85 Flash Type Version Control Apacer Brand Solution Version Form Factor: M= JEDEC MO-300 Capacity 016G = 16GB 032G = 32GB 064G = 64GB 128G = 128GB 256G = 256GB SATA Disk Module Apacer Product Code 13 ©2014 Apacer Technology Inc. Rev. 1.3 Serial ATA Flash Drive APSDMxxxxM1HN-XTMX 7.2 Valid Combination 7.2.1 Operating Temperature (0 Capacity 16GB 32GB 64GB 128GB 256GB ) No DEVSLP APSDM016GM1HN-1TM APSDM032GM1HN-1TM APSDM064GM1HN-1TM APSDM128GM1HN-1TM APSDM256GM1HN-1TM 7.2.2 Operating Temperature (-40 Capacity 16GB 32GB 64GB 128GB 256GB ~ 70 ~ 85 DEVSLP APSDM016GM1HN-2TM APSDM032GM1HN-2TM APSDM064GM1HN-2TM APSDM128GM1HN-2TM APSDM256GM1HN-2TM ) No DEVSLP APSDM016GM1HN-1TMW APSDM032GM1HN-1TMW APSDM064GM1HN-1TMW APSDM128GM1HN-1TMW APSDM256GM1HN-1TMW DEVSLP APSDM016GM1HN-2TMW APSDM032GM1HN-2TMW APSDM064GM1HN-2TMW APSDM128GM1HN-2TMW APSDM256GM1HN-2TMW Note: Please consult with Apacer sales representatives for availabilities. 14 ©2014 Apacer Technology Inc. Rev. 1.3 Serial ATA Flash Drive APSDMxxxxM1HN-XTMX Revision History Revision Description Date 1.0 Official release 09/04/2014 1.1 Revised temperature specifications 09/26/2014 1.2 Revised Serial ATA spec support : 3.0 -> 3.1 11/07/2014 1.3 Added endurance information 11/20/2014 15 ©2014 Apacer Technology Inc. Rev. 1.3 Serial ATA Flash Drive APSDMxxxxM1HN-XTMX Global Presence Taiwan (Headquarters) Apacer Technology Inc. Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 386 Fairview Way, Suite102, Milpitas, CA 95035 Tel: 1-408-518-8699 Fax: 1-408-935-9611 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd 1301, No.251,Xiaomuqiao Road, Shanghai, 200032, China Tel: 86-21-5529-0222 Fax: 86-21-5206-6939 sales@apacer.com.cn India Apacer Technologies Pvt Ltd, # 535, 1st Floor, 8th cross, JP Nagar 3rd Phase, Bangalore 560078, India Tel: 91-80-4152-9061 sales_india@apacer.com 16 ©2014 Apacer Technology Inc. Rev. 1.3
APSDM256GM1HN-1TM
物料型号:Serial ATA Flash Drive APSDMxxxxM1HN-XTMX
器件简介:mSATA H1-M是一款符合SATA 6.0 Gbps接口的串行ATA闪存驱动器,设计用于在最佳效率和可靠性下运行。它采用JEDEC MO-300标准,即标准mSATA外形尺寸,具有高达520MB/s的读取速度和185MB/s的写入速度,并且功耗远低于传统硬盘。
引脚分配:mSATA H1-M的引脚分配如图1-2所示,共有52个引脚,其中包括3.3V电源引脚、地线、SATA信号对引脚等,部分引脚被标记为无连接(NC)。
参数特性: - 容量规格:16GB、32GB、64GB、128GB、256GB - 性能:持续读取速度最高520MB/s,持续写入速度最高185MB/s - 工作温度范围:标准0°C至70°C,扩展-40°C至85°C - 供电电压:3.3V ±5% - 功耗:活动模式典型值485mA,空闲模式典型值95mA
功能详解: - 支持S.M.A.R.T.技术,可自动检测硬盘健康状况并报告潜在故障。 - 内置硬件ECC、磨损平衡、坏块管理和TRIM功能,以提高数据的可靠性和设备的使用寿命。 - TRIM命令可以帮助操作系统告知SSD哪些数据块不再使用,可以被永久删除,从而提高读写性能。
应用信息:mSATA H1-M适用于需要高性能、低功耗存储解决方案的应用场景。
封装信息:符合JEDEC MO-300标准,尺寸为50.80 x 29.85 x 1.00毫米。
APSDM256GM1HN-1TM 价格&库存
很抱歉,暂时无法提供与“APSDM256GM1HN-1TM”相匹配的价格&库存,您可以联系我们找货
