APSDM016GN1HN-1TMW
APSDM016GN1HN-1TMW
    APACERMEMORYAMERICA(宇瞻科技)
    Solid State Drive (SSD) 16GB SATA III FLASH - NAND (MLC) mSATA 3.3V
APSDM016GN1HN-1TMW 数据手册
RoHS Compliant mSATA Flash Drive mSATA mini H1-M Product Specifications September 24th, 2014 Version 1.1 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 mSATA Flash Drive APSDMxxxxN1HN-XTMX Features:  Compliance with SATA Revision 3.0 – Serial ATA Revision 3.0 – SATA 6.0 Gbps interface – Backward compatible with SATA 1.5/3.0 Gbps interfaces – ATA command set  Capacities – 8, 16, 32, 64, 128 GB  Performance* – Interface burst read/write: 600 MB/sec – Sustained read: up to 520 MB/sec – Sustained write: up to 180 MB/sec   Flash Management – Built-in hardware ECC – Wear leveling – Bad block management – S.M.A.R.T. – Power Failure Management – TRIM  Temperature ranges – Operating: Standard: 0°C to 70°C Extended: -40°C to +85°C – Storage: -40°C to +85°C  Supply voltage – 3.3 V 5%  Power consumption (typical)* – Active mode: 475 mA – Idle mode: 85 mA  Form factor – mSATA mini, JEDEC MO-300B – Dimensions (29.85 x 26.80 x 1.00**, unit: mm)  Connector – 52-pin mSATA signal connector  RoHS compliant  Device Sleep (optional) *** ± NAND Flash Type: MLC *Varies from capacities. The values addressed here are typical and may vary depending on host system settings. **Only the height of the PCB ***Not available in 64GB and 128GB models 1 ©2014 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APSDMxxxxN1HN-XTMX Table of Contents 1. Product Description ............................................................................................... 3 1.1 1.2 1.3 1.4 2. Introduction .................................................................................................................................................3 Capacity Specification.................................................................................................................................3 Performance.................................................................................................................................................3 Pin Assignments ..........................................................................................................................................4 Software Interface................................................................................................... 6 2.1 Command Set ..............................................................................................................................................6 2.2 S.M.A.R.T. ...................................................................................................................................................7 3. Flash Management ................................................................................................. 8 3.1 Error Correction/Detection ........................................................................................................................8 3.2 Bad Block Management .............................................................................................................................8 3.3 Wear Leveling .............................................................................................................................................8 3.4 Power Failure Management .......................................................................................................................8 3.5 TRIM ...........................................................................................................................................................8 3.6 Secure Erase................................................................................................................................................9 3.7 SATA Power Management ........................................................................................................................9 4. Environment Specifications ................................................................................ 10 4.1 Environmental ..........................................................................................................................................10 4.2 Mean Time Between Failures (MTBF)....................................................................................................10 4.3 Certification and Compliance ..................................................................................................................10 5. Electrical Characteristics..................................................................................... 11 5.1 Operating Voltage .....................................................................................................................................11 5.2 Power Consumption .................................................................................................................................11 6. Mechanical Specifications ................................................................................... 12 6.1 Dimensions .................................................................................................................................................12 7. Product Ordering Information ............................................................................. 14 7.1 7.2 Product Code Designation........................................................................................................................14 Valid Combination................................................................................................. ! 錯誤 尚未定義書籤。 2 ©2014 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APSDMxxxxN1HN-XTMX 1. Product Description 1.1 Introduction Apacer’s mSATA mini H1-M delivers all the advantages of flash disk technology with the Serial ATA 6.0 Gbps interface and is fully compliant with the standard mSATA mini form factor, known as JEDEC MO-300B standard. The module is designed to operate at optimal efficiency and reliability while maintained in super compact form factor. Meanwhile, the power consumption of the mSATA mini module remains at minimal level. 1.2 Capacity Specification Table 1-1 Capacity specification Capacity Total Bytes Cylinders Heads Sectors Max LBA 8 GB 8,012,390,400 15,525 16 63 15,649,200 16 GB 16,013,942,784 16,383 16 63 31,277,232 32 GB 32,017,047,552 16,383 16 63 62,533,296 64 GB 64,023,257,088 16,383 16 63 125,045,424 128 GB 128,035,676,160 16,383 16 63 250,069,680 *Display of total bytes varies from file systems. **Cylinders, heads or sectors are not applicable for these capacities. Only LBA addressing applies. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 1.3 Performance Performance of mSATA mini H1-M is shown in Table 1-2. Table 1-2 Performance specification Capacity Performance Sustained Read (MB/s) Sustained Write (MB/s) 8 GB 16 GB 32 GB 64 GB 128 GB 150 315 320 520 520 45 150 170 180 180 Note: Performance varies from flash configurations or host system settings. 3 ©2014 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APSDMxxxxN1HN-XTMX 1.4 Pin Assignments Figure 1-2 Apacer mSATA mini H1-M pin assignment Table 1-3 Pin Assignment Description Pin # mSATA Pin Description 1 NC No Connect 2 +3.3V 3.3V Source 3 NC No Connect 4 DGND Digital GND 5 NC No Connect 6 NC No Connect 7 NC No Connect 8 NC No Connect 9 DGND Digital GND 10 NC No Connect 11 NC No Connect 12 NC No Connect 13 NC No Connect 14 NC No Connect 15 DGND Digital GND 16 NC No Connect 17 NC No Connect 18 DGND Digital GND 4 ©2014 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APSDMxxxxN1HN-XTMX 19 NC No Connect 20 NC No Connect 21 SATA GND SATA Ground Return Pin 22 NC No Connect 23 +B Host Receiver Differential Signal Pair 24 +3.3V 3.3V Source 25 -B Host Receiver Differential Signal Pair 26 SATA GND SATA Ground Return Pin 27 SATA GND SATA Ground Return Pin 28 NC No Connect 29 SATA GND SATA Ground Return Pin 30 NC No Connect 31 -A Host Transmitter Differential Signal Pair 32 NC No Connect 33 +A Host Transmitter Differential Signal Pair 34 DGND Digital GND 35 SATA GND SATA Ground Return Pin 36 NC No Connect 37 SATA GND SATA Ground Return Pin 38 NC No Connect 39 +3.3V 3.3V Source 40 DGND Digital GND 41 +3.3V 3.3V Source 42 NC No Connect 43 NC No Connect 44 NC No Connect or Device Sleep* 45 Vendor Vendor specific 46 NC No Connect 47 Vendor Vendor specific 48 NC No Connect 49 DAS Device activity signal 50 DGND Digital GND 51 GND Default connect to GND 52 +3.3V 3.3V Source *Device Sleep is optional 5 ©2014 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APSDMxxxxN1HN-XTMX 2. Software Interface 2.1 Command Set Table 2-1 summarizes the ATA commands supported by mSATA mini H1-M. Table 2-1: Command set Command Code Command NOP 00h Idle Data Set Management 06h Check Power Mode Recalibrate 10f-1Fh Sleep Read Sectors 20h SMART Read Sectors without Retry 21h Device Configuration Read Sectors EXT 24h Read Multiple Read DMA EXT 25h Write Multiple Read Native Max Address EXT 27h Set Multiple Mode Read Multiple EXT 29h Read DMA Read Log EXT 2Fh Read DMA without Retry Write Sectors 30h Write DMA Write Sectors Without Retry 31h Write DMA without Retry Write Sectors EXT 34h Write Multiple FUA EXT Write DMA EXT 35h Standby Immediate Set Native Max Address EXT 37h Idle Immediate CFA Write Sectors without erase 38h Standby Write Multiple EXT 39h Idle Write DMA FUA EXT 3Dh Read Buffer Write Long EXT 3Fh Check Power Mode Read Verify Sectors 40h Sleep Read Verify Sectors without Retry 41h Flush Cache Read Verify Sectors EXT 42h Write Buffer Write Uncorrectable EXT 45h Flush Cache EXT Read FPDMA Queued 60h Identify Device Write FPDMA Queued 61h Set Features Seek 70h-7Fh Security Set Password Execute Device Diagnostic 90h Security Unlock Initialize Device Parameters 91h Security Erase Prepare Download Microcode 92h Security Erase Unit Download Microcode DMA 93h Security Freeze Lock Standby Immediate 94h Security Disable Password Idle Immediate 95h Read Native Max Address Standby 96h Set Max Address Note. Security command will only be workable when device runs in non-OPAL compliant mode. Code 97h 98h 99h B0h B1h C4h C5h C6h C8h C9h CAh CBh CEh E0h E1h E2h E3h E4h E5h E6h E7h E8h EAh ECh EFh F1h F2h F3h F4h F5h F6h F8h F9h 6 ©2014 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APSDMxxxxN1HN-XTMX 2.2 S.M.A.R.T. SMART, an acronym for Self-Monitoring, Analysis and Reporting Technology, is an open standard that allows a hard disk drive to automatically detect its health and report potential failures. When a failure is recorded by SMART, users can choose to replace the drive to prevent unexpected outage or data loss. Moreover, SMART can inform users of impending failures while there is still time to perform proactive actions, such as copy data to another device. 7 ©2014 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APSDMxxxxN1HN-XTMX 3. Flash Management 3.1 Error Correction/Detection Flash memory cells will deteriorate with use, which might generate random bit errors in the stored data. Thus, this mSATA SSD module applies the BCH ECC Algorithm, which can detect and correct errors occur during Read process, ensure data been read correctly, as well as protect data from corruption. This device can correct up to 72bit/1K data. 3.2 Bad Block Management Bad blocks are blocks that include one or more invalid bits, and their reliability is not guaranteed. Blocks that are identified and marked as bad by the manufacturer are referred to as “Initial Bad Blocks”. Bad blocks that are developed during the lifespan of the flash are named “Later Bad Blocks”. Apacer implements an efficient bad block management algorithm to detect the factory-produced bad blocks and manages any bad blocks that appear with use. This practice further prevents data being stored into bad blocks and improves the data reliability. 3.3 Wear Leveling NAND Flash devices can only undergo a limited number of program/erase cycles, and in most cases, the flash media are not used evenly. If some areas get updated more frequently than others, the lifetime of the device would be reduced significantly. Thus, Wear Leveling technique is applied to extend the lifespan of NAND Flash by evenly distributing write and erase cycles across the media. Apacer provides advanced Wear Leveling algorithm, which can efficiently spread out the flash usage through the whole flash media area. Moreover, by implementing both dynamic and static Wear Leveling algorithms, the life expectancy of the NAND Flash is greatly improved. 3.4 Power Failure Management Power Failure Management plays a crucial role when experiencing unstable power supply. Power disruption may occur when users are storing data into the SSD. In this urgent situation, the controller would run multiple flush cycles to store the metadata for later block rebuilding. This urgent operation requires about several milliseconds to get it done. At the next power up, the firmware will perform a status tracking to retrieve the mapping table and resume previously programmed NAND blocks to check if there is any incompleteness of transmission. 3.5 TRIM TRIM is a feature which helps improve the read/write performance and speed of solid-state drives (SSD). Unlike hard disk drives (HDD), SSDs are not able to overwrite existing data, so the available space gradually becomes smaller with each use. With the TRIM command, the operating system can inform the SSD which blocks of data are no longer in use and can be removed permanently. Thus, the SSD will perform the erase action, which prevents unused data from occupying blocks all the time. 8 ©2014 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APSDMxxxxN1HN-XTMX 3.6 Secure Erase Secure Erase is a standard ATA command and will write all “0xFF” to fully wipe all the data on hard drives and SSDs. When this command is issued, the SSD controller will empty its storage blocks and return to its factory default settings. Note. Secure erase command belongs to ATA security command. 3.7 SATA Power Management By complying with SATA 6.0 Gb/s specifications, the mSATA SSD supports Device Sleep power state:  ≦ Device Sleep (DevSleep or DEVSLP): PHY powered down; power consumption 5 mW; host assertion time 10 ms; exit timeout from this state 20 ms (unless specified otherwise in SATA Identify Device Log). ≦ ≦ Note: Device Sleep mode is optional, depending on product ordering selections. 9 ©2014 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APSDMxxxxN1HN-XTMX 4. Environment Specifications 4.1 Environmental Table 4-1 mSATA mini H1-M environmental specifications Environment Temperature Humidity Shock Vibration Drop Bending Torque ESD Note: 4.2 Specification 0°C to 70°C (Operating) / -40°C to +85°C (Extended) -40°C to +85°C (in storage) RH 90% under 40°C 1500G, 0.5ms 20Hz~80Hz/1.52mm (frequency/displacement) 80Hz~2000Hz/20G (frequency/displacement) X, Y, Z axis/60mins each 80cm free fall, 6 face of each 50N, hold 1min/5times 0.5N-m or 5deg, hold 5min/5times Pass ≧ Shock and Vibration specifications are subject to change without notice. Mean Time Between Failures (MTBF) MTBF, an acronym for Mean Time Between Failures, is a measure of a device’s reliability. Its value represents the average time between a repair and the next failure. The measure is typically in units of hours. The higher the MTBF value, the higher the reliability of the device. The predicted result of this mSATA device is higher than 1,000,000 hours. 4.3 Certification and Compliance mSATA mini H1-M complies with the following standards:       SATA Revision 3.0 RoHS ATA/ATAPI FCC CE BSMI 10 ©2014 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APSDMxxxxN1HN-XTMX 5. Electrical Characteristics 5.1 Operating Voltage Table 5-1 lists the supply voltage for mSATA mini H1-M. Table 5-1 mSATA mini H1-M operating voltage Parameter Conditions Supply voltage 5.2 3.3V ±5% Power Consumption Table 5-2 Power consumption (typical) Capacity Mode Active (mA) Idle (mA) 8 GB 16 GB 32 GB 64 GB 128 GB 340 340 365 465 475 85 85 85 85 85 Note: Power consumptions may vary depending on host system settings. 11 ©2014 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APSDMxxxxN1HN-XTMX 6. Mechanical Specifications 6.1 Dimensions ㎜ Unit: Tolerance: ± 0.2 12 ©2014 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APSDMxxxxN1HN-XTMX ㎜ Unit: Tolerance: ± 0.2 13 ©2014 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APSDMxxxxN1HN-XTMX 7. Product Ordering Information 7.1 Product Code Designation AP SDM xxxx N 1 HN - X TM X Operating Temperature Range Blank: 0℃ ~ 70℃ W: -40℃ ~ 85℃ Flash Type Version Control Apacer Brand Solution Version Form Factor: N= mSATA mini Capacity 008G = 8GB 016G = 16GB 032G = 32GB 064G = 64GB 128G = 128GB SATA Disk Module Apacer Product Code 14 ©2014 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APSDMxxxxN1HN-XTMX 7.2 Valid Combination 7.2.1 Operating Temperature (0℃ Capacity 8GB 16GB 32GB 64GB 128GB No DEVSLP APSDM008GN1HN-1TM APSDM016GN1HN-1TM APSDM032GN1HN-1TM APSDM064GN1HN-1TM APSDM128GN1HN-1TM 7.2.2 Operating Temperature (-40℃ Capacity 8GB 16GB 32GB 64GB 128GB ℃) ~ 70 DEVSLP APSDM008GN1HN-2TM APSDM016GN1HN-2TM APSDM032GN1HN-2TM --- ℃) ~ 85 No DEVSLP APSDM008GN1HN-1TMW APSDM016GN1HN-1TMW APSDM032GN1HN-1TMW APSDM064GN1HN-1TMW APSDM128GN1HN-1TMW DEVSLP APSDM008GN1HN-2TMW APSDM016GN1HN-2TMW APSDM032GN1HN-2TMW --- Note: Please consult with Apacer sales representatives for availabilities. 15 ©2014 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APSDMxxxxN1HN-XTMX Revision History Revision Description Date 1.0 Official release 09/19/2014 1.1 Revised Product Ordering Information 09/24/2014 16 ©2014 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APSDMxxxxN1HN-XTMX Global Presence Taiwan (Headquarters) Apacer Technology Inc. Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 386 Fairview Way, Suite102, Milpitas, CA 95035 Tel: 1-408-518-8699 Fax: 1-408-935-9611 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd 1301, No.251,Xiaomuqiao Road, Shanghai, 200032, China Tel: 86-21-5529-0222 Fax: 86-21-5206-6939 sales@apacer.com.cn India Apacer Technologies Pvt Ltd, # 535, 1st Floor, 8th cross, JP Nagar 3rd Phase, Bangalore – 560078, India Tel: 91-80-4152-9061 sales_india@apacer.com 17 ©2014 Apacer Technology Inc. Rev. 1.1
APSDM016GN1HN-1TMW 价格&库存
很抱歉,暂时无法提供与“APSDM016GN1HN-1TMW”相匹配的价格&库存,您可以联系我们找货
