SFSA480GQ1BJ8TO-I-OC-226-STC
    SWISSBIT
    SSD480GB2.5"MLCSATAII5V
SFSA480GQ1BJ8TO-I-OC-226-STC 数据手册
Product fact sheet Industrial SATA SSD 2.5’’ X-55 Series SATA II, high performance, high reliability MLC NAND Flash X-500 Series - Industrial SATA Solid State Drive 2.5” 30GB to 480GB based on SLC NAND flash 1 Feature summary                        Form factor: o 2.5-inch SATA Solid State Drive (SSD) o 100.1mm x 69.85mm x 9.2mm o 7+15 pin (SATA+power) locking/latching SATA connector Interface: o SATA Rev 2.6 - 3Gbit/s (1.5Gbit/s compatible) Feature connector for o Secure erase and write protect input o Device activity and secure erase output (LED) o Ground pin Optional various secure erase/sanitize/purge methods (HW and SW triggered, simple erase also in standard SSD) Highly-integrated memory controller o SLC NAND Flash o Hardware BCH-code ECC (up to 40 Bit correction per 2 sectors) o Fix drive configuration Low-power CMOS technology 5.0V ± 10% power supply Low Power, less than 1 W (idle) / 3.5 W (operation) / 0.7 W slumber average current No mechanical noise Wear Leveling: active wear leveling of static and dynamic data The wear leveling assures that dynamic data as well as static data is balanced evenly across the memory. With that the maximum write endurance of the device is guaranteed. Mechanical robustness (MIL-STD810) High reliability o Endurance Managed EM-MLC NAND Flash technology o Data retention 10 years o StaticDataRefresh and EarlyRetirement Technologies for data refresh o MTBF ≥ 2,000,000 hours o Number of connector insertions/removals: 500 on SATA back plane, 50 on SATA cable High performance o Up to 300MB/s burst transfer rate in SATA II - 3.0Gb/sec o Sustained Read / Write Performance: up to 240MB/s / 160MB/s o 4KB Read / Write IOPS: up to 14500 / 3100 o Access time
SFSA480GQ1BJ8TO-I-OC-226-STC 价格&库存
很抱歉,暂时无法提供与“SFSA480GQ1BJ8TO-I-OC-226-STC”相匹配的价格&库存,您可以联系我们找货
