APM2T80P201128GAN-HTM1W
    APACERMEMORYAMERICA(宇瞻科技)
    SSD128GBM.2MLCSATAIII3.3V
APM2T80P201128GAN-HTM1W 数据手册
ġ RoHS Recast Compliant M.2 2280 Flash Drive P201-M Product Specifications (Toshiba 15nm) October 21, 2015 Version 1.0 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 M.2 2280 Flash Drive APM2T80P201xxxGAN-XTM1X Features: z Standard SATA Interface Compliance – Serial ATA Revision 3.2 compliance – SATA 6.0 Gbps interface – ATA-8 command set z Capacities – 16, 32, 64, 128, 256 GB z z Performance* – Burst read/write: 600 MB/sec – Sustained read: up to 430 MB/sec – Sustained write: up to 160 MB/sec Flash Management – Built-in hardware ECC – Static/dynamic wear-leveling – Flash bad-block management – S.M.A.R.T. – Power Failure Management – ATA Secure Erase – TRIM z NAND Flash Type: MLC z Endurance – 16GB: 14 TBW – 32GB: 28 TBW – 64GB: 57 TBW – 128GB: 114 TBW – 256GB: 228 TBW z Temperature ranges – Operating: Standard :0°C to 70°C Extended: -40°C to 85°C – Storage: -40°C to 85°C z Supply voltage – 3.3 V Ʋ 5% z Power consumption (typical)* – Active mode: 450 mA – Idle mode: 95 mA z Connector type – 75-pin SATA-based M.2 module pinout z Form factor – M.2 2280 form factor – Dimensions: 80.00x22.00x3.80, unit: ϩ z Shock & Vibration*** – Shock:1,500 G – Vibration: 15 G z MTBF: >2,000,000 hours z SATA Power Management z RoHS Recast compliant (complies with 2011/65/EU standard) z Device Sleep mode (optional) *Varies from capacities. The values for performances and power consumptions presented are typical and may vary depending on flash configurations or platform settings. The term idle refers to the standby state of the device. **Non-operating 1 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2280 Flash Drive APM2T80P201xxxGAN-XTM1X Table of Contents 1. General Description .............................................................................. 3 2. Pin Assignments .................................................................................... 3 3. Product Specifications.......................................................................... 6 3.1 Capacity ............................................................................................................................................... 6 3.2 Performance ........................................................................................................................................ 6 3.3 Environmental Specifications .............................................................................................................. 7 3.4 Mean Time Between Failures (MTBF) ................................................................................................ 7 3.5 Certification and Compliance .............................................................................................................. 7 4. Flash Management ................................................................................ 8 4.1 Error Correction/Detection ................................................................................................................... 8 4.2 Bad Block Management ...................................................................................................................... 8 4.3 Wear Leveling ...................................................................................................................................... 8 4.4 Power Failure Management ................................................................................................................ 8 4.5 ATA Secure Erase ............................................................................................................................... 8 4.6 TRIM .................................................................................................................................................... 9 4.7 SATA Power Management .................................................................................................................. 9 4.8 Endurance ......................................................................................................................................... 10 5. Software Interface .............................................................................. 11 5.1 Command Set .................................................................................................................................... 11 5.2 S.M.A.R.T. ......................................................................................................................................... 12 6. Electrical Specification ...................................................................... 13 7. Physical Characteristics ..................................................................... 14 8. Product Ordering Information ............................................................. 16 2 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2280 Flash Drive APM2T80P201xxxGAN-XTM1X 1. General Description Apacer’s P201-M is the next generation modularized Solid State Drive (SSD) with the shape of all new M.2 form factor, aimed to be the more suitable for mobile and compact computers with standard width at only 22.00 mm. P201-M appears in M.2 2280 mechanical dimensions and is believed to be the leading add-in storage solution for future host computing systems. The M.2 SSD is designed with SATA-based connector pinouts, providing full compliance with the latest SATA Revision 3.2 interface specifications. Aside from SATA compliance, P201-M delivers exceptional performance and power efficiency. On the other hand, the extreme thin and light form factor makes P201M the ideal choice for mobile computing systems, which appears to be the trend in near future. Regarding reliability, P201-M is built with a powerful SATA controller that supports on-the-module ECC as well as efficient wear leveling scheme. In terms of power efficiency, P201-M is compliant with SATA 6.0 Gbps interface standard so that it can operate on SATA power management modes, which greatly save on power consumption. 2. Pin Assignments This connector does not support hot plug capability. There are a total of 75 pins. 12 pin locations are used for mechanical key locations; this allows such a module to plug into both Key B and Key M connectors. Notch M Notch B Pin1 Pin Type Description 1 CONFIG_3 Ground (according to M.2 configurations for SSD-SATA definition) 2 3.3V Supply Pin, 3.3V 3 GND Ground 4 3.3V Supply pin, 3.3V 5 No connect No connect 6 Not available No connect (used for other purposes) 7 Not available No connect (used for other purposes) 8 Not available No connect (used for other purposes) 9 No connect No connect 10 DAS/DSS Device Activity Signal/Disable Staggered Spin-up 11 No connect No connect (used for other purposes) 12 (removed for key) Mechanical notch B 3 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2280 Flash Drive APM2T80P201xxxGAN-XTM1X 13 (removed for key) Mechanical notch B 14 (removed for key) Mechanical notch B 15 (removed for key) Mechanical notch B 16 (removed for key) Mechanical notch B 17 (removed for key) Mechanical notch B 18 (removed for key) Mechanical notch B 19 (removed for key) Mechanical notch B 20 Not available No connect (used for other purposes) 21 CONFIG_0 Ground (according to M.2 configurations for SSD-SATA definition) 22 Not available No connect (used for other purposes) 23 Not available No connect (used for other purposes) 24 Not available No connect (used for other purposes) 25 Not available No connect (used for other purposes) 26 Not available No connect (used for other purposes) 27 GND Ground 28 Not available No connect (used for other purposes) 29 PERn1 Not used 30 Not available No connect (used for other purposes) 31 PERp1 Not used 32 Not available No connect (used for other purposes) 33 GND Ground 34 Not available No connect (used for other purposes) 35 PETn1 Not used 36 Not available No connect (used for other purposes) 37 PETp1 Not used 38 DEVSLP Device Sleep, input. If driven high the host is informing the SSD to enter a low power state (optional) 39 GND Ground 40 Not available No connect (used for other purposes) 41 SATA-Rx+ Host receiver differential signal pair 42 Not available No connect (used for other purposes) 43 SATA-Rx- Host receiver differential signal pair 44 Not available No connect (used for other purposes) 45 GND Ground 46 Not available No connect (used for other purposes) 47 SATA-Tx- Host transmitter differential pair 48 Not available No connect (used for other purposes) 4 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2280 Flash Drive APM2T80P201xxxGAN-XTM1X 49 SATA-Tx+ Host transmitter differential pair 50 PERST# Not used 51 GND Ground 52 CLKREQ# Not used 53 REFCLKN Not used 54 PEWAKE# Not used 55 REFCLKP Not used 56 MFG1 Manufacturing pin. Use determined by vendor (no connect on a host) 57 GND Ground 58 MFG2 Manufacturing pin. Use determined by vendor (no connect on a host) 59 (removed for key) Mechanical notch M 60 (removed for key) Mechanical notch M 61 (removed for key) Mechanical notch M 62 (removed for key) Mechanical notch M 63 (removed for key) Mechanical notch M 64 (removed for key) Mechanical notch M 65 (removed for key) Mechanical notch M 66 (removed for key) Mechanical notch M 67 Not available No connect (used for other purposes) 68 SUSCLK Not used 69 CONFIG_1 Ground 70 3.3V Supply pin, 3.3V 71 GND Ground 72 3.3V Supply pin, 3.3V 73 GND Ground 74 3.3V Supply pin, 3.3V 75 CONFIG_2 Ground 5 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2280 Flash Drive APM2T80P201xxxGAN-XTM1X 3. Product Specifications 3.1 Capacity Capacity specification of P201-M is available as shown in Table 3-1. It lists the specific capacity and the default numbers of heads, sectors and cylinders for each product line. Table 3-1: Capacity specifications Capacity Total bytes* Cylinders Heads Sectors Max LBA 16 GB 16,013,942,784 16,383 16 63 31,277,232 32 GB 32,017,047,552 16,383 16 63 62,533,296 64 GB 64,023,257,088 16,383 16 63 125,045,424 128 GB 128,035,676,160 16,383 16 63 250,069,680 256 GB 256,060,514,304 16,383 16 63 500,118,192 *Display of total bytes varies from file systems, which means not all of the bytes can be used for storage. **Notes: 1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 3.2 Performance Performances of P201-M are listed below in table 3-2. Table 3-2: Performance Capacity 16 GB 32 GB 64 GB 128 GB 256 GB Sustained read (MB/s) 215 230 415 410 430 Sustained write (MB/s) 150 130 155 160 160 Performance Note: Results were measured by CrystalDiskMark and may differ from various flash configurations or host system setting 6 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2280 Flash Drive APM2T80P201xxxGAN-XTM1X 3.3 Environmental Specifications Environmental specification of P201-M series follows MIL-STD-810 standards as shown in Table 3-3. Table 3-3 P201-M environmental specifications Item Specification Operating temperature 0°C ~70°C (standard) ; -40°C to 85°C(extended) Non-operating temperature -40°C ~85°C Operating humidity 40°C90%RH Non-operating humidity 40°C93%RH Frequency/Displacement: 20Hz~80Hz/1.52mm Frequency/Acceleration: 80Hz~2000Hz/20G X, Y, Z axis/60mins 1500G, 0.5ms Vibration (Non-operating) shock (Non-operating) Drop (Non-operating) Bending (non-operating) 80cm free fall, 6 face of each unit ʁ20N, hold 1min/5times Torque (non-operating) 0.5N-m or Ʋ2.5 deg, hold 1min/5times ESD (Electrostatic) Passed (at relative temp/humidity: 24°C, 49%RH) 3.4 Mean Time Between Failures (MTBF) Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components in P201-M. The prediction result for P201-M is more than 2,000,000 hours. Notes about the MTBF: The MTBF is predicated and calculated based on “Telcordia Technologies Special Report, SR-332, Issue 2” method. 3.5 Certification and Compliance P201-M complies with the following standards: z z z z CE: EN55022 FCC :CISPR22 BSMI 13438 RoHS Recast 7 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2280 Flash Drive APM2T80P201xxxGAN-XTM1X 4. Flash Management 4.1 Error Correction/Detection P201-M implements a hardware ECC scheme, based on the BCH algorithm. It can detect and correct up to 72 bits error in 1K bytes. 4.2 Bad Block Management Current production technology is unable to guarantee total reliability of NAND flash memory array. When a flash memory device leaves factory, it comes with a minimal number of initial bad blocks during production or out-of-factory as there is no currently known technology that produce flash chips free of bad blocks. In addition, bad blocks may develop during program/erase cycles. When host performs program/erase command on a block, bad block may appear in Status Register. Since bad blocks are inevitable, the solution is to keep them in control. Apacer flash devices are programmed with ECC, block mapping technique and S.M.A.R.T to reduce invalidity or error. Once bad blocks are detected, data in those blocks will be transferred to free blocks and error will be corrected by designated algorithms. 4.3 Wear Leveling Flash memory devices differ from Hard Disk Drives (HDDs) in terms of how blocks are utilized. For HDDs, when a change is made to stored data, like erase or update, the controller mechanism on HDDs will perform overwrites on blocks. Unlike HDDs, flash blocks cannot be overwritten and each P/E cycle wears down the lifespan of blocks gradually. Repeatedly program/erase cycles performed on the same memory cells will eventually cause some blocks to age faster than others. This would bring flash storages to their end of service term sooner. Wear leveling is an important mechanism that level out the wearing of blocks so that the wearing-down of blocks can be almost evenly distributed. This will increase the lifespan of SSDs. Commonly used wear leveling types are Static and Dynamic. 4.4 Power Failure Management Power Failure Management plays a crucial role when experiencing unstable power supply. Power disruption may occur when users are storing data into the SSD. In this urgent situation, the controller would run multiple write-to-flash cycles to store the metadata for later block rebuilding. This urgent operation requires about several milliseconds to get it done. At the next power up, the firmware will perform a status tracking to retrieve the mapping table and resume previously programmed NAND blocks to check if there is any incompleteness of transmission. Note: The controller unit of this product model is designed with a DRAM as a write cache for improved performance and data efficiency. Though unlikely to happen in most cases, the data cached in the volatile DRAM might be potentially affected if a sudden power loss takes place before the cached data is flushed into non-volatile NAND flash memory. 4.5 ATA Secure Erase ATA Secure Erase is an ATA disk purging command currently embedded in most of the storage drives. Defined in ATA specifications, (ATA) Secure Erase is part of Security Feature Set that allows storage drives to erase all user data areas. The erase process usually runs on the firmware level as most of the ATA-based storage media currently in the market are built-in with this command. ATA Secure Erase can securely wipe out the user data in the drive and protects it from malicious attack. 8 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2280 Flash Drive APM2T80P201xxxGAN-XTM1X 4.6 TRIM TRIM, though in capital letters usually, is a memory computation command rather than an abbreviation. It is mainly a SATA command that enables the operating system to inform the SSD (Solid State Drive) which blocks of previously stored data are no longer valid, due to erases by the host or operating system, such as file deletions or disk formatting. Once notified, SSD will begin the discard of the invalid LBAs and retain more space for itself, in fact, the discarded is no longer recoverable. When an LBA is replaced by the operating system, as with overwrite of a file, the SSD is informed that the originally occupied LBA is determined as no longer in use or invalid. The SSD will not save those blocks in garbage collected sectors. Noticeably, a file deletion command by host or operating system never actually erases the actual content, rather, just the file is marked as deleted. This issue is even specifically noticeable for flash based memory devices, such as SSDs. In fact, an SSD will keep garbage collecting the invalid, previously occupied LBAs, if it is not informed that these LBAs can be erased. Thus, the SSD would experience a significant performance downfall. 4.7 SATA Power Management By complying with SATA 6.0 Gb/s specifications, the SSD supports the following SATA power saving modes: y ACTIVE: PHY ready, full power, Tx & Rx operational y PARTIAL: Reduces power, resumes in under 10 μs (microseconds) y SLUMBER: Reduces power, resumes in under 10 ms (milliseconds) y HIPM: Host-Initiated Power Management y DIPM: Device-Initiated Power Management y Device Sleep (DevSleep or DEVSLP): PHY powered down; power consumption ʀ 5 mW; host assertion time ʀ 10 ms; exit timeout from this state ʀ 20 ms (unless specified otherwise in SATA Identify Device Log). Note: 1. The behaviors of power management features would depend on host/device settings. 2. Device Sleep mode is optional, depending on product ordering selections. 9 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2280 Flash Drive APM2T80P201xxxGAN-XTM1X 4.8 Endurance The endurance of a storage device is predicted by TeraBytes Written based on several factors related to usage, such as the amount of data written into the drive, block management conditions, and daily workload for the drive. Thus, key factors, such as Write Amplifications and the number of P/E cycles, can influence the lifespan of the drive. Capacity TeraBytes Written 16 GB 14 32 GB 28 64 GB 57 128 GB 114 256 GB 228 Notes: y The measurement assumes the data written to the SSD for test is under a typical and constant rate. y The measurement follows the standard metric: 1 TB (Terabyte) = 1000 GB. y This estimation complies with JEDEC JESD-219, enterprise endurance workload of random data with payload size distribution. 10 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2280 Flash Drive APM2T80P201xxxGAN-XTM1X 5. Software Interface 5.1 Command Set This section defines the software requirements and the format of the commands the host sends to P201M. Commands are issued to P201-M by loading the required registers in the command block with the supplied parameters, and then writing the command code to the Command register. Table 6-1: Command set Command Code Command Code CHECK POWER MODE 98h 10h-1Fh SLEEP 99h Read Sectors 20h SMART B0h Read Sectors without Retry 21h DEVICE CONFIGURATION B1h Read Sectors EXT 24h Read Multiple C4h 25h Write Multiple C5h Read Native Max Address EXT 27h Set Multiple Mode C6h Read Multiple EXT 29h Read DMA C8h Read Log EXT 2Fh Read DMA without Retry C9h Write Sectors 30h Write DMA CAh 31h Write DMA without Retry CBh Write Sectors EXT 34h Write Multiple FUA EXT CEh Write DMA EXT 35h Standby Immediate E0h Set Native Max Address EXT 37h Idle Immediate E1h 38h Standby E2h E3h Data Set Management Recalibrate Read DMA EXT Write Sectors without Retry CFA WRITE SECTORS WITHOUT ERASE Write Multiple EXT 06h 39h IDLE Write DMA FUA EXT 3Dh Read Buffer E4h Write Long EXT 3Fh Check Power Mode E5h Read Verify Sectors 40h Sleep E6h 41h Flush Cache E7h E8h Read Verify Sectors without Retry Read Verify Sectors EXT 42h Write Buffer WRITE UNCORRECTABLE EXT 45h Flush Cache EXT EAh Read FPDMA Queued 60h Identify Device ECh Write FPDMA Queued 61h Set Features EFh Security Set Password F1h F2h Seek 70h-71h Execute Device Diagnostic 90h Security Unlock Initialize Device Parameters 91h Security Erase Prepare F3h Download Microcode 92h Security Erase Unit F4h 11 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2280 Flash Drive APM2T80P201xxxGAN-XTM1X DOWNLOAD MICROCODE DMA 93h Security Freeze Lock F5h STANDBY IMMEDIATE 94h Security Disable Password F6h IDLE IMMEDIATE 95h Read Native Max Address F8 STANDBY 96h Set Max Address F9 IDLE 97h 5.2 S.M.A.R.T. SMART, an acronym for Self-Monitoring, Analysis and Reporting Technology, is an open standard that allows a hard disk drive to automatically detect its health and report potential failures. When a failure is recorded by SMART, users can choose to replace the drive to prevent unexpected outage or data loss. Moreover, SMART can inform users of impending failures while there is still time to perform proactive actions, such as copy data to another device 12 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2280 Flash Drive APM2T80P201xxxGAN-XTM1X 6. Electrical Specification Table 6-1: Operating range Ambient Temperature 0°C to 70°C(standard) -40°C to 85°C(extended) Supply Voltage 3.3VƲ5% (3.135-3.465V) Table 6-2: Typical power consumption Capacity 16 GB 32 GB 64 GB 128 GB 256 GB Active (mA) 300 315 360 440 450 Idle (mA) 85 85 95 95 95 Modes Note: Results may differ from various flash configurations or host system setting 13 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2280 Flash Drive APM2T80P201xxxGAN-XTM1X 7. Physical Characteristics 8QLWᓔ 7ROHUDQFHs ᓔ 14 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2280 Flash Drive APM2T80P201xxxGAN-XTM1X 8QLWᓔ 7ROHUDQFHs ᓔ 15 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2280 Flash Drive APM2T80P201xxxGAN-XTM1X 8. Product Ordering Information 8.1 Product Code Designations $3073[[[*$1ದ ;70 X Temperature Range Blank: Standard W: Extended Temperature Flash Type Version Control Apacer Brand Capacities: 016G = 16GB 032G = 32GB 064G = 64GB 128G = 128GB 256G = 256GB Solution version Form Factor M.2 Apacer Product Code 16 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2280 Flash Drive APM2T80P201xxxGAN-XTM1X 8.2 Valid Combinations 8.2.1 Standard Temperature Capacity No DEVSLP DEVSLP 16GB APM2T80P201016GAN-GTM1 APM2T80P201016GAN-HTM1 32GB 64GB APM2T80P201032GAN-GTM1 APM2T80P201064GAN-GTM1 APM2T80P201032GAN-HTM1 APM2T80P201064GAN-HTM1 128GB 256GB APM2T80P201128GAN-GTM1 APM2T80P201256GAN-GTM1 APM2T80P201128GAN-HTM1 APM2T80P201256GAN-HTM1 8.2.2 Extended Temperature Capacity No DEVSLP DEVSLP 16GB APM2T80P201016GAN-GTM1W APM2T80P201016GAN-HTM1W 32GB 64GB APM2T80P201032GAN-GTM1W APM2T80P201032GAN-HTM1W APM2T80P201064GAN-GTM1W APM2T80P201064GAN-HTM1W 128GB APM2T80P201128GAN-GTM1W APM2T80P201128GAN-HTM1W 256GB APM2T80P201256GAN-GTM1W APM2T80P201256GAN-HTM1W Note: Valid combinations are those products in mass production or will be in mass production. Consult your Apacer sales representative to confirm availability of valid combinations and to determine availability of new combinations. 17 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2280 Flash Drive APM2T80P201xxxGAN-XTM1X Revision History Revision 1.0 Date Description 10/21/2015 Official release Remark 18 © 2015 Apacer Technology Inc. Rev. 1.0
物料型号:Apacer M.2 2280 Flash Drive APM2T80P201xxxGAN-XTM1X
器件简介: - Apacer的P201-M是新一代的模块化固态硬盘(SSD),采用全新的M.2外形尺寸,专为移动和紧凑型计算机设计,具有22.00毫米的标准宽度。 - M.2 SSD设计有基于SATA的连接器引脚,完全符合最新的SATA修订版3.2接口规范。
引脚分配: - 该连接器共有75个引脚,其中12个引脚位置用于机械键位;这样模块可以插入Key B和Key M连接器。
参数特性: - 容量:16GB, 32GB, 64GB, 128GB, 256GB - 性能:突发读写速度600MB/s,持续读取速度高达430MB/s,持续写入速度高达160MB/s - 闪存管理:内置硬件ECC、静态/动态磨损平衡、闪存坏块管理 - 耐压:16GB型号14TBW,32GB型号28TBW,64GB型号57TBW,128GB型号114TBW,256GB型号228TBW - 工作温度范围:标准0°C至70°C,扩展-40°C至85°C - 供电电压:3.3V ±5% - 功耗(典型值):活动模式450mA,空闲模式95mA - 连接器类型:75针SATA基础M.2模块引脚排列
功能详解: - 错误校正/检测:基于BCH算法的硬件ECC方案,能检测并纠正1KB内最多72位错误。 - 坏块管理:出厂时NAND闪存设备带有初始坏块,生产技术无法保证完全可靠性。 - 磨损平衡:静态和动态磨损平衡机制,延长SSD寿命。 - 电源故障管理:在电源不稳定时,控制器会执行多个写入闪存周期以存储元数据。 - ATA安全擦除:ATA安全擦除是ATA磁盘清除命令,可安全擦除用户数据区域。 - TRIM命令:操作系统通知SSD哪些块的数据不再有效,SSD将开始丢弃无效的LBAs。 - SATA电源管理:支持ACTIVE、PARTIAL、SLUMBER、HIPM、DIPM和设备睡眠模式。
应用信息: - P201-M适用于移动计算系统,具有轻薄外形和高性能。
封装信息: - 外形尺寸:M.2 2280,尺寸为80.00x22.00x3.80mm。
MTBF:预计MTBF超过200万小时。
APM2T80P201128GAN-HTM1W 价格&库存
很抱歉,暂时无法提供与“APM2T80P201128GAN-HTM1W”相匹配的价格&库存,您可以联系我们找货
