SFSD2048N1BW1MT-I-ME-111-STD
    SWISSBIT
    Memory Card microSD™ 2GB Class 6 SLC
SFSD2048N1BW1MT-I-ME-111-STD 数据手册
Product Fact Sheet Industrial MICRO SD Memory Card S-300u Series SPI, SD and SDHC compliant S-300u Series MICRO SD Memory Card 1 Feature summary               Highly-integrated memory controller o Fully compliant with SD Memory Card specification SD1.01, SD1.1, SD2.0 and SD3.01 and MICRO SD Memory Card Addendum 4.00 Standard MICRO SD Memory Card form factor o 15.0mm x 11.0mm x 0.7mm Operating voltage 2.7…3.6V Low-power CMOS technology High reliability o MTBF: > 3,000,000 hours o Number of insertions: > 10,000 o Extended Temperature range -25° up to 85°C o Industrial Temperature range -40° up to 85°C Hot swappable High performance o Speed class  2GB Card speed class 6  4GB, 8GB speed class 10 o SD burst up to 25MB/s o SD Low/High speed 0…25/50MHz clock rate o Flash burst up to 40MB/s o Flash Bus interleave Operating bus modes: SD 1 & 4bit and SPI Error Correction up to 24bit/1KB BCH ECC Wear Leveling: equal wear leveling of static and dynamic data The wear leveling assures that dynamic data as well as static data is balanced evenly across the memory. With that the maximum write endurance of the device is guaranteed. Write Endurance: Due to advanced wear leveling an even use of the entire flash is guaranteed, regardless how much “static” (OS) data is stored. Example: If the average file size is 10MByte and the total capacity is 8GByte, 48Mio write cycles can be performed. Available densities o 2, 4, and 8GBytes (SLC NAND Flash) Controlled BOM Life Cycle Management 2 Order Information 2.1 Standard product list Table 1: Standard Product List Density general part number current part number revision 2GB SFSD2048NgBW1MT-t-ME-1x1-STD SFSD2048N1BW1MT-t-ME-111-STD 4GB SFSD4096NgBW1MT-t-DF-1x1-STD SFSD4096N1BW1MT-t-DF-111-STD 8GB SFSD8192NgBW1MT-t-QG-1x1-STD SFSD8192N1BW1MT-t-QG-111-STD g defines the product generation x defines the FW t defines the temperature range (E=-25°C to +85°C, I=-40°C to +85°C) Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Revision: 1.12 www.swissbit.com industrial@swissbit.com S-300u_fact_sheet_Rev112.doc Page 2 of 3 3 System Specification 3.1 System Performance System Performance Burst Data transfer Rate (max SD clock 50MHz) Sustained Sequential Read Sustained Sequential Write typ max 25 (1)(3) 24 (1)(3) 24 (1)(3) 12 (1)(3) 22 (1)(2) 2GB 4…8GB 2GB 4…8GB 20 (1)(2) 20 (1)(2) 11 (1)(2) 17 Unit MB/s 1. All values refer to Micron Flash 8/16Gb MICRO SD Memory Card in SD mode 50MHz, cycle time 20ns, 2. Sustained Speed measured with USB-SD Memory Card reader. It depends on burst speed, flash number, and file size. 3. Maximum values were measured with Testmetrix tester. 3.2 Power Consumption Current Consumption @ 3.3V Write Read Sleep Mode Typ 60 50 0.15 Max 70 60 2 Unit mA 3.3 Physical Dimensions Physical Dimensions Length Width Thickness Weight (typ.) Value 15.0±0.1 11.0±0.1 0.7 (1.0)±0.1 0.4 Unit mm g 3.4 Recommended Temperature Conditions Parameter Min Typ Max Unit Storage Temperature Operating Temperature -25 -25 25 25 85 85 °C °C 3.5 Humidity and ESD Parameter Humidity (non-condensing) EMC / EMI Operating Non Operating operation: 95% RH @25°C storage: 93% RH @40°C, 500h Non Contact Pads area: Contact Pads: ±8 kV (air discharge) ±4 kV, Human body model according to Human body model according to IEC61000-4-2 IEC61000-4-2 3.6 Environmental Conditions Parameter UV light exposure Durability Drop test Bending / Torque Operating Non Operating 2 UV: 254nm, 15Ws/cm according to ISO7816-1 10,000 mating cycles 1.5m free fall 10N / 0.10Nm ±2.5° max For more information on SD Memory Card Spec 3.01, please visit SD association (www.sdcard.org) Why Swissbit? Swissbit strives to create innovative technologies for future market opportunities utilizing a highly skilled inhouse product research and development team. Swissbit maintains a marketing edge by continuing to manufacture world-class high quality memory products and providing customers with both high value and low cost of ownership achieved through efficient processes and procedures. Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Revision: 1.12 www.swissbit.com industrial@swissbit.com S-300u_fact_sheet_Rev112.doc Page 3 of 3
SFSD2048N1BW1MT-I-ME-111-STD 价格&库存
很抱歉,暂时无法提供与“SFSD2048N1BW1MT-I-ME-111-STD”相匹配的价格&库存,您可以联系我们找货
