SFSD016GL1BM1TO-I-QG-221-STD
    SWISSBIT
    MEM CARD MICROSDHC 16GB UHS SLC
SFSD016GL1BM1TO-I-QG-221-STD 数据手册
Product Fact Sheet Industrial SD/SDHC Memory Card S-450 Series UHS-I Interface, SLC S-450 Series (UHS-I, SLC) Industrial SD/SDHC Memory Card - 512MByte to 32GByte Main Feature  Fully compliant with SD Memory Card specification 3.0 o SD ultra high speed mode, speed class 1 (SDR104) o SD high speed mode, up to speed class 10 o SD2.0 SDHC backward compliant, default speed and high speed mode o FAT32 up to 32GB SDHC  High performance 3.0 specification o SD burst up to 104MB/s o SD Normal speed 0…25MHz clock rate o SD High speed 25…50MHz clock rate o SD UHS-I speed 0...50MHz (DDR) and 0…208MHz (SDR) o Up to 90MByte/sec sequential data rate  Power Supply: (Low-power CMOS technology) o 2.7…3.6V operating voltage  Standard SD Memory card form factor o 32.0mm x 24.0mm x 2.1mm and Write Protect slider  Optimized FW algorithms especially for high read access and long data retention applications o Patented power-off reliability technology o Wear Leveling technology Equal wear leveling of static and dynamic data. The wear leveling assures that dynamic data as well as static data is balanced evenly across the memory. With that the maximum write endurance of the device is guaranteed o Write Endurance technology Due to intelligent wear leveling an even use of the entire flash is guaranteed, regardless how much “static” (OS) data is stored. o Read Disturb Management The read commands are monitored and the content is refreshed when critical levels have occurred o Data Care Management The interruptible background process maintain the user data for Read Disturb effects or Retention degradation due to high temperature effects o Near Miss ECC technology Minimize the risk of uncorrectable bit failure over the product life time. Each read command analyzes the ECC margin level and refresh data if necessary o Diagnostic features with Life Time Monitoring tool support  High reliability o SLC Flash o Designed for industrial market especially read intensive application like navigation, infotainment, POS/POI, medical and general boot medium use case o The product is optimized for long life cycle that requires good data retention because of high temperature mission profile. o Intensive write application should use the S-450 Series SLC cards o Number of card insertions/removals 20,000 o Extended and Industrial Temperature range -25° up to 85°C and -40° up to 85°C, respectively o SIP (System In Package) process for extreme dust, water and ESD proof o Selected AEC-Q100 qualification    Controlled BOM & PCN process Manufactured in a TS 16949 certified factory Customized options like CID registers, CPRM keys, firmware incl. settings and marking by projects Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Revision: 1.02 www.swissbit.com industrial@swissbit.com S-450_fact_sheet_SD-LxBM_Rev102.docx Page 2 of 3 Order Information for S-450 Series UHS-I SD Memory Cards Density 512MB 1GB 2GB 4GB 8GB 16GB 32GB Part Number SFSD0512LgBM1TO-t-ME-2xx-STD SFSD1024LgBM1TO-t-DF-2xx-STD SFSD2048LgBM1TO-t-QG-2xx-STD SFSD4096LgBM1TO-t-ME-2xx-STD SFSD8192LgBM1TO-t-DF-2xx-STD SFSD016GLgBM1TO-t-QG-2xx-STD SFSD032GLgBM1TO-t-NG-2xx-STD Temp. Range Flash Technology t = E -25°C to 85°C t = I -40°C to 85°C SLC NAND Flash g = generation; x = options, firmware and custom configuration System Performance System Performance Burst Data transfer Rate (max clock 208MHz SDR) Sustained Sequential Read 512MB / 1GB…2GB / 4GB…32GB Sustained Sequential Write 512MB / 1GB…2GB / 4GB / 8GB…32GB typ 28 / 28 / 88 18 / 20 / 37 / 73 max 104 30 / 34 / 90 20 / 24 / 40 / 75 typ 60 70 120 1.2 max 120 120 130 5 Current Consumption @3.3V Write Read Autoread Idle Unit MB/s Unit mA Physical Dimensions Physical Dimensions Length Width Thickness Weight (typ.) Value 32.00±0.10 24.00±0.10 2.10±0.15 2 Unit mm g Recommended Temperature Conditions Parameter min typ max Unit Extended Operating Temperature -25 25 85*) °C Industrial Operating Temperature -40 25 85*) °C Storage Temperature -40 25 100*) °C *) high temperature storage without operation reduces the data retention, in operation the data will be refreshed, if data error issues were detected Humidity and EMC Parameter Humidity (non-condensing) ESD Operating Non Operating max 95% Non Contact Pads area: ±15 kV (air discharge), according to IEC61000-4-2 Contact Pads: ±6 kV, according to IEC61000-4-2 Non Contact Pads area: ±8kV (indirect) contact discharge, according to IEC61000-4-2 Durability Parameter Operating Non Operating Salt water spray 3% NaCI/35°C; 24h acc. MIL STD Method 1009 Insertions / Drop test >20,000 / 1.5m free fall Bending / Torque / Bump 10N / 0.15Nm or ±2.5deg Shock / Vibration (peak -to-peak) 1500G max / 50G max Data Retention at beginning @ 40°C 10 years*) *) From time to time in idle mode the card reads the whole flash and performs a data refresh if necessary. So the data retention can be much longer in most use cases. For more information on SD Memory card Specification, please visit SD association (www.sdcard.org) Why Swissbit? Swissbit strives to create innovative technologies for future market opportunities utilizing a highly skilled inhouse product research and development team. Swissbit maintains a marketing edge by continuing to manufacture world-class high quality memory products and providing customers with both high value and low cost of ownership achieved through efficient processes and procedures. Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Revision: 1.02 www.swissbit.com industrial@swissbit.com S-450_fact_sheet_SD-LxBM_Rev102.docx Page 3 of 3
SFSD016GL1BM1TO-I-QG-221-STD 价格&库存
很抱歉,暂时无法提供与“SFSD016GL1BM1TO-I-QG-221-STD”相匹配的价格&库存,您可以联系我们找货
