AP-CF004GL9FS-NR
AP-CF004GL9FS-NR
    APACERMEMORYAMERICA(宇瞻科技)
    MEMORY CARD COMPACTFLASH 4GB MLC
AP-CF004GL9FS-NR 数据手册
RoHS Compliant CompactFlash Series 5 Specifications for Industrial CompactFlash Card October 1, 2015 Version 1.3 Apacer Technology Inc. th 4 Fl., 75 Hsin Tai Wu Rd., Sec.1, Hsichih, Taipei Hsien 221, Taiwan Tel: +886-2-2698-2888 Fax: +886-2-2698-2889 www.apacer.com Compact Flash 5 series AP-CFxxxxL9XS-XXXXXX Features: CompactFlash Association Specification Revision 4.1 Standard Interface 512 bytes per sector ATA command set compatible ATA transfer mode supports: PIO Mode 6 Multiword DMA Mode 4 Ultra DMA Mode 5 PCMCIA UDMA Mode 5 Power Smart Design Capacities 4, 8, 16, 32, 64 GB Power Consumption (typical)** Active mode: 165 mA Standby mode: 2 mA Temperature Ranges Standard: 0°C to 70°C Extended: -40°C to 85°C Storage: -40°C to 100°C Operating Voltage for Read and Write 3.3 V 5.0 V Performance Sustained read: Up to 50 MB/sec Sustained write: Up to 18 MB/sec Connector Type 50 pins female Flash Management Wear-leveling algorithms to substantially increase longevity of flash media Built-in BCH ECC capable of correcting up to 24 bits in 1,024 byte data Supports S.M.A.R.T commands Physical Dimensions 36.4mm x 42.8mm x 3.3mm RoHS Compliant NAND Flash Type: MLC (commercial/Industrial grade) *Performance and power consumption may vary depending on capacities and the platforms. 1 © 2015 Apacer Technology Inc. Rev. 1.3 Compact Flash 5 series AP-CFxxxxL9XS-XXXXXX Table of Contents 1. GENERAL DESCRIPTION .................................................................................................... 3 2. FUNCTIONAL BLOCK DIAGRAM ..................................................................................... 3 3. PIN ASSIGNMENTS ............................................................................................................... 4 4. PRODUCT SPECIFICATION ................................................................................................ 6 4.1 CAPACITY .............................................................................................................................................................6 4.2 PERFORMANCE .....................................................................................................................................................6 4.3 ENVIRONMENTAL SPECIFICATIONS ....................................................................................................................... 7 5. SOFTWARE INTERFACE ..................................................................................................... 7 5.1 CF-ATA COMMAND SET ......................................................................................................................................7 6. FLASH MANAGEMENT ........................................................................................................ 9 6.1 INTELLIGENT ENDURANCE DESIGN.......................................................................................................................9 6.1.1 Advanced wear-leveling algorithms .............................................................................................................9 6.1.2 S.M.A.R.T. Technology .................................................................................................................................9 6.1.3 Built-in Hardware ECC ................................................................................................................................9 6.2 INTELLIGENT POWER FAILURE RECOVERY ...........................................................................................................9 7. ELECTRICAL SPECIFICATION ....................................................................................... 10 8. PHYSICAL CHARACTERISTICS ...................................................................................... 11 8.1 DIMENSIONS ....................................................................................................................................................... 11 9. PRODUCT ORDERING INFORMATION ......................................................................... 12 9.1 PRODUCT CODE DESIGNATIONS ......................................................................................................................... 12 9.2 VALID COMBINATIONS ....................................................................................................................................... 13 2 © 2015 Apacer Technology Inc. Rev. 1.3 Compact Flash 5 series AP-CFxxxxL9XS-XXXXXX 1. General Description value-added Industrial CompactFlash Card offers high performance, high reliability and powerefficient storage. Regarding standard compliance, this CompactFlash Card complies with CompactFlash specification revision 4.1, supporting transfer modes up to Programmed Input Output (PIO) Mode 6, Multiword Direct Memory Access (DMA) Mode 4, Ultra DMA Mode 5, and PCMCIA Ultra DMA Mode 5. For power efficiency, this industrial CompactFlash card supports some power smart design mechanisms such as Power-On-Reset, voltage regulator for output voltage adjustments and power failure protection, as well as the automatic sleep and wake-up feature.. In terms of data integrity and accuracy, the CompactFlash card is built with on-chip hardware 13/24 bit BCH ECC engine that can correct up to 24-bit errors per 1,024 byte data. The 13-bit is used for 2KB page size with 16 bytes spare region per 512 byte data, while the 24-bit ECC is used for flash with 218 or more bytes, companied with 4KB data. The controller of this CompactFlash card is designed to transfer the host data through fast DMA engine and utilize the internal memory buffer in a sufficient way, which greatly minimizes the internal microprocessor s loading and improves performance efficiency. value-added CFC provides complete PCMCIA - ATA functionality and compatibility. Apacer s CompactFlash technology is designed for applications in Point of Sale (POS) terminals, telecom, IP-STB, medical instruments, surveillance systems, industrial PCs and handheld applications such as the new generation of Digital Single Lens Reflex (DSLR) cameras. 2. Functional Block Diagram The CompactFlash Card (CFC) includes a controller and flash media, as well as the CompactFlash standard interface. Figure 2-1 shows the functional block diagram. Figure 2-1: Functional block diagram 3 © 2015 Apacer Technology Inc. Rev. 1.3 Compact Flash 5 series AP-CFxxxxL9XS-XXXXXX 3. Pin Assignments Table 3-1 lists the pin assignments with respective signal names for the 50-pin configuration. A indicates the active low signal. The pin type can be input, output or input/output. Table 3-1: Pin assignments (1 of 2) Pin No. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 Memory card mode Signal name GND D3 D4 D5 D6 D7 #CE1 A10 #OE A9 A8 A7 VCC A6 A5 A4 A3 A2 A1 A0 D0 D1 D2 WP #CD2 #CD1 D11 D12 D13 D14 D15 #CE2 #VS1 #IORD #IOWR #WE RDY/-BSY VCC #CSEL #VS2 RESET Pin I/O type I/O I/O I/O I/O I/O I I I I I I I I I I I I I I/O I/O I/O O O O I/O I/O I/O I/O I/O I O I I I O I O I I/O card mode Signal name GND D3 D4 D5 D6 D7 #CE1 A10 #OE A9 A8 A7 VCC A6 A5 A4 A3 A2 A1 A0 D0 D1 D2 #IOIS16 #CD2 #CD1 D11 D12 D13 D14 D15 #CE2 #VS1 #IORD #IOWR #WE #IREQ VCC #CSEL #VS2 RESET Pin I/O type I/O I/O I/O I/O I/O I I I I I I I I I I I I I I/O I/O I/O O O O I/O I/O I/O I/O I/O I O I I I O I O I True IDE mode Signal name GND D3 D4 D5 D6 D7 #CS0 1 A10 #ATA SEL 1 A9 1 A8 1 A7 VCC 1 A6 1 A5 1 A4 1 A3 A2 A1 A0 D0 D1 D2 #IOCS16 #CD2 #CD1 D11 D12 D13 D14 D15 #CS1 #VS1 #IORD #IOWR #WE INTRQ VCC #CSEL #VS2 #RESET Pin I/O type I/O I/O I/O I/O I/O I I I I I I I I I I I I I I/O I/O I/O O O O I/O I/O I/O I/O I/O I O I I I O I O I 4 © 2015 Apacer Technology Inc. Rev. 1.3 Compact Flash 5 series AP-CFxxxxL9XS-XXXXXX Table 3-1: Pin assignments (2 of 2) Pin No. 42 43 44 45 46 47 48 49 50 1. 2. Memory card mode Signal name #WAIT #INPACK #REG BVD2 BVD1 D8 D9 D10 GND Pin I/O type O O I O O I/O I/O I/O - I/O card mode Signal name #WAIT #INPACK #REG #SPKR #STSCHG D8 D9 D10 GND Pin I/O type O O I O O I/O I/O I/O - True IDE mode Signal name IORDY 2 DMARQ 2 DMACK #DASP #PDIAG D8 D9 D10 GND Pin I/O type O O I I/O I/O I/O I/O I/O - The signal should be grounded by the host. Connection required when UDMA is in use. 5 © 2015 Apacer Technology Inc. Rev. 1.3 Compact Flash 5 series AP-CFxxxxL9XS-XXXXXX 4. Product Specification 4.1 Capacity Capacity specifications of the Compact Flash Card series (CFC) is available as shown in Table 4-1. Table 4-1: Capacity specifications Capacity Total bytes 4GB 8GB 1 Cylinders Heads Sectors Max LBA 4,110,188,544 7,964 16 63 8,027,712 8,195,604,480 15,880 16 63 16,007,040 2 16 63 32,014,336 16GB 16,391,340,032 16,383 32GB 32,019,316,736 16,383 16 63 62,537,728 64GB 64,030,244,864 16,383 16 63 125,059,072 *Cylinders, heads or sectors are not applicable for these capacities. Only LBA addressing applies **Notes: 1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 4.2 Performance Performances of the CompactFlash cards are listed in Table 4-2. Table 4-2: Performance specifications Capacity 4 GB 4 GB (Dual Channel) (Single Channel) Sustained read (MB/s) 49 Sustained write (MB/s) 13 Performance 8 GB 16 GB 32 GB 64 GB 17 50 50 50 50 4 14 14 18 18 Notes: performance may vary depending on flash configurations or host system settings. 6 © 2015 Apacer Technology Inc. Rev. 1.3 Compact Flash 5 series AP-CFxxxxL9XS-XXXXXX 4.3 Environmental Specifications Environmental specification follows the MIL-STD-810F standards is available as shown in Table 4-3. Table 4-3: Environmental specifications Environment Temperature Specification Operation 0°C to 70°C / -40°C to 85°C Storage -40°C to 100°C Vibration (Non-Operation) Shock (Non-Operation) Sine wave: 10~2000Hz, 15G (X, Y, Z axes) Half sine wave, acceleration 1500 G, 0.5 ms (X, Y, Z ; All 6 axes) 5. Software Interface 5.1 CF-ATA Command Set Table 5-1 summarizes the CF-ATA command set with the paragraphs that follow describing the individual commands and the task file for each. Table 5-1: CFC-ATA command set Command Check-Power-Mode Execute-Drive-Diagnostic Code FR 1 SC 2 SN 3 4 CY 8 D 90H C0H Flush-Cache E7H Format-Track 50H Identify-Drive ECH 6 LBA D E5H or 98H Erase-Sector(s) 5 DH 7 Y Y Y 8 Y Y D Y Y Y Y D Idle E3H or 97H Idle-Immediate E1H or 95H Y D D Y Y Initialize-Drive-Parameters 91H NOP 00H D Read-Buffer E4H D Read-Multiple C4H Y Y Y Y Y Read-Sector(s) 20H or 21H Y Y Y Y Y Read-Verify-Sector(s) 40H or 41H Y Y Y Y Y Recalibrate 1XH D Request-Sense 03H D Seek 7XH Set-Features EFH Y Set-Multiple-mode C6H - Y Y Y Y D Y - - D - 7 © 2015 Apacer Technology Inc. Rev. 1.3 Compact Flash 5 series AP-CFxxxxL9XS-XXXXXX Set-Sleep-Mode E6H or 99H D Standby E2H or 96H D Standby-Immediate E0H or 94H D Translate-Sector 87H Write-Buffer E8H Y Y Y Y Y D 7 Write-Multiple C5H Y Y Y Y Y Write-Multiple-Without-Erase CDH Y Y Y Y Y 30H or 31H Y Y Y Y Y Write-Sector(s)-Without-Erase 38H Y Y Y Y Y Write-Verify 3CH Y Y Y Y Y Write-Sector(s) 1. FR - Features register 2. SC - Sector Count register 3. SN - Sector Number register 4. CY - Cylinder registers 5. DH - Drive/Head register 6. LBA - Logical Block Address mode supported 7. Y - The register contains a valid parameter for this command 8. For the Drive/Head register: Y means both the CompactFlash card and head parameters are used; D means only the CompactFlash card parameter is valid and not the head parameter 8 © 2015 Apacer Technology Inc. Rev. 1.3 Compact Flash 5 series AP-CFxxxxL9XS-XXXXXX 6. Flash Management 6.1 Intelligent Endurance Design 6.1.1 Advanced wear-leveling algorithms Flash memory devices differ from Hard Disk Drives (HDDs) in terms of how blocks are utilized. For HDDs, when a change is made to stored data, like erase or update, the controller mechanism on HDDs will perform overwrites on blocks. On the other hand, NAND flash storage adopts flash as their primary media. Unlike HDDs, flash blocks cannot be overwritten and each P/E cycle wears down the lifespan of blocks gradually. Repeatedly program/erase cycles performed on the same memory cells will eventually cause some blocks to age faster than others. This would bring flash storages to their end of service term earlier. Wear leveling is an important mechanism that level out the wearing of blocks so that the wearing-down of blocks can be almost evenly distributed. This will increase the lifespan of SSDs. Commonly used wear leveling types are Static and Dynamic. 6.1.2 S.M.A.R.T. Technology S.M.A.R.T. is an acronym for Self-Monitoring, Analysis and Reporting Technology, an open standard allowing disk drives to automatically monitor their own health and report potential problems. It protects the user from unscheduled downtime by monitoring and storing critical drive performance and calibration parameters. Ideally, this should allow taking proactive actions to prevent impending drive failure. Apacer SMART feature adopts the standard SMART command B0h to read data from the drive. When the Apacer SMART Utility running on the host, it analyzes and reports the disk status to the host before the device is in critical condition. 6.1.3 Built-in Hardware ECC The ECC bit encoding takes places when host/OS writes data to the SSD. This step is simpler and quick. On the other hand, the ECC bit decoding is processed when host/OS reads data from the SSD. In this step, the ECC codes will be in progress for detecting, comparing and detecting potential error. Thus, the power of the ECC lies mostly in the read data side. This ATA CompactFlash card employs BCH Error Correction Code (ECC) algorithms. This on-chip hardware BCH-ECC engines is 13/24 bit programmed that can correct up to 24-bit errors per 1,024 byte data. This built-in hardware ECC performs parity generation and error detection/correction for data integrity. 6.2 Intelligent Power Failure Recovery Power Failure Management ensures data transmission when experiencing unstable power supply. When power disruption takes places, NAND Flash will have to cache multiple write-to-flash cycles to securely store data. This urgent operation requires about several milliseconds to get it done. When the supplied voltage is below a certain percentage of the required, the flash controller will be signaled by a detector IC component with low power detection signal and then the firmware will communicate the controller to flush all the data into the cache of Flash storage area. This can prevent incomplete data transmission. The crucial part lies in the strength of the capacitor of the SSD. The capacitor must be able to hold up some milliseconds of remaining time before the power is totally out, for the urgent write-back-into-flash operations to complete. 9 © 2015 Apacer Technology Inc. Rev. 1.3 Compact Flash 5 series AP-CFxxxxL9XS-XXXXXX 7. Electrical Specification Table 7-1: Operating range Range Ambient Temperature 3.3V 5V Standard Temperature Extended Temperature Storage Temperature 0°C to 70°C -40°C to +85°C -40°C to +100°C 3.135-3.465V 4.75-5.25V Table 7-2: Power consumption (at 5V, typical) Capacity Modes Active (mA) Idle (mA) 4 GB 4 GB 8 GB 16 GB 32 GB 64 GB (Dual Channel) (Single Channel) 150 150 155 165 165 170 5 5 5 5 5 5 Notes: results may vary depending on flash configurations or platforms. 10 © 2015 Apacer Technology Inc. Rev. 1.3 Compact Flash 5 series AP-CFxxxxL9XS-XXXXXX 8. Physical Characteristics 8.1 Dimensions TABLE 8-1: Type I CFC physical specification Length: Width: Thickness (Including Label Area): 36.40 +/- 0.15mm (1.433+/- 0.06 in.) 42.80 +/- 0.10mm (1.685+/- 0.04 in.) 3.3mm+/-0.10mm (0.130+/-0.04in.) FIGURE 8-1: Physical dimension Unit: mm 11 © 2015 Apacer Technology Inc. Rev. 1.3 Compact Flash 5 series AP-CFxxxxL9XS-XXXXXX 9. Product Ordering Information 9.1 Product Code Designations AP CF x x x x L 9 X S XXXXXX Specification RM: Removable NR: Non-Removable NDRM: Non-DMA + Removable NDNR: Non-DMA + Non-Removable ETRM: Ext. Temp. + Removable ETNR: Ext. Temp. + Non-Removable ETNDRM: Ext. Temp + Non-DMA + Removable ETNDNR: Ext. Temp + Non-DMA + Non-Removable Halogen Free Compliant Configuration E Single Channel F Dual Channel CTL Type CFC Type Capacities: 004G = 4GB 008G = 8GB 016G = 16GB 032G = 32GB 064G = 64GB Model Name Apacer Product Code 12 © 2015 Apacer Technology Inc. Rev. 1.3 Compact Flash 5 series AP-CFxxxxL9XS-XXXXXX 9.2 Valid Combinations 9.2.1 Standard Temperature 9.2.1.1 Non-Removable Capacity AP/N 4GB AP-CF004GL9FS-NR 4GB AP-CF004GL9ES-NR 8GB AP-CF008GL9FS-NR 16GB AP-CF016GL9FS-NR 32GB AP-CF032GL9FS-NR 64GB AP-CF064GL9FS-NR 9.2.1.2 Removable Capacity AP/N 4GB AP-CF004GL9FS-RM 4GB AP-CF004GL9ES-RM 8GB AP-CF008GL9FS-RM 16GB AP-CF016GL9FS-RM 32GB AP-CF032GL9FS-RM 64GB AP-CF064GL9FS-RM 9.2.1.3 Non-DMA + Removable Capacity AP/N 4GB AP-CF004GL9FS-NDRM 4GB AP-CF004GL9ES-NDRM 8GB AP-CF008GL9FS-NDRM 16GB AP-CF016GL9FS-NDRM 32GB AP-CF032GL9FS-NDRM 64GB AP-CF064GL9FS-NDRM 13 © 2015 Apacer Technology Inc. Rev. 1.3 Compact Flash 5 series AP-CFxxxxL9XS-XXXXXX 9.2.1.4 Non-DMA + Non-Removable Capacity AP/N 4GB AP-CF004GL9FS-NDNR 4GB AP-CF004GL9ES-NDNR 8GB AP-CF008GL9FS-NDNR 16GB AP-CF016GL9FS-NDNR 32GB AP-CF032GL9FS-NDNR 64GB AP-CF064GL9FS-NDNR Note: please consult with Apacer sales representative for availability. 9.2.2 Extended Temperature 9.2.2.1 Ext. Temp. + Non-Removable Capacity AP/N 4GB AP-CF004GL9ES-ETNR 8GB AP-CF008GL9FS-ETNR 16GB AP-CF016GL9FS-ETNR 32GB AP-CF032GL9FS-ETNR 9.2.2.2 Ext. Temp. + Removable Capacity AP/N 4GB AP-CF004GL9ES-ETRM 8GB AP-CF008GL9FS-ETRM 16GB AP-CF016GL9FS-ETRM 32GB AP-CF032GL9FS-ETRM 14 © 2015 Apacer Technology Inc. Rev. 1.3 Compact Flash 5 series AP-CFxxxxL9XS-XXXXXX 9.2.2.3 Non-DMA + Removable Capacity AP/N 4GB AP-CF004GL9ES-ETNDRM 8GB AP-CF008GL9FS-ETNDRM 16GB AP-CF016GL9FS-ETNDRM 32GB AP-CF032GL9FS-ETNDRM 9.2.2.4 Non-DMA + Non-Removable Capacity AP/N 4GB AP-CF004GL9ES-ETNDNR 8GB AP-CF008GL9FS-ETNDNR 16GB AP-CF016GL9FS-ETNDNR 32GB AP-CF032GL9FS-ETNDNR Note: please consult with Apacer sales representative for availability. 15 © 2015 Apacer Technology Inc. Rev. 1.3 Compact Flash 5 series AP-CFxxxxL9XS-XXXXXX Revision History Revision Date Description Remark 0.1 03/13/2012 Preliminary 1.0 04/12/2012 Official release 1.1 07/23/2012 Updated Product Ordering Information (with the addition of standard operating temperature models) Added 64GB capacity Added standard operating temperature specifications 1.2 09/20/2012 Updated Product Ordering Information due to the addition of standard temperature specifications Added 4GB capacity model 1.3 10/01/2015 Added 4GB models of single channel. 16 © 2015 Apacer Technology Inc. Rev. 1.3 Compact Flash 5 series AP-CFxxxxL9XS-XXXXXX Global Presence Taiwan (Headquarters) Apacer Technology Inc. th 4 Fl., 75 Hsin Tai Wu Rd., Sec.1 Hsichih, 221 Taipei Hsien Taiwan, R.O.C. Tel: +886-2-2698-2888 Fax: +886-2-2698-2889 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 46732 Lakeview Blvd., Fremont, CA 94538 Tel: 1-408-518-8699 Fax: 1-510-249-9568 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd Room D, 22/FL, No.2, Lane 600, JieyunPlaza, Tianshan RD, Shanghai, 200051, China Tel: 86-21-6228-9939 Fax: 86-21-6228-9936 sales@apacer.com.cn India Apacer Technologies Pvt Ltd, th Unit No.201, Brigade Corner 7 Block Jayanagar, Yediyur Circle, Bangalore 560082, India Tel: 91-80-4152-9061 Fax: 91-80-4170-0215 sales_india@apacer.com 17 © 2015 Apacer Technology Inc. Rev. 1.3
AP-CF004GL9FS-NR 价格&库存
很抱歉,暂时无法提供与“AP-CF004GL9FS-NR”相匹配的价格&库存,您可以联系我们找货
