SFSD016GL3BM1TO-I-LF-2CP-STD
    SWISSBIT
    MEMCARDSDHC16GBCLASS10PSLC
SFSD016GL3BM1TO-I-LF-2CP-STD 数据手册
Product Fact Sheet everbit™ Industrial SD / SDHC / SDXC Memory Card S-46 Series UHS-I Interface, pSLC Extended and Industrial Temperature Grade Date : Re vi si o n: Apr il 04 , 2 0 1 9 1 .0 2 Product Summary           Capacities: 2 GBytes, 4 GBytes, 8 GBytes, 16 GBytes, 32 GBytes, 64 GBytes Form Factor: Standard SD Memory Card 32.0mm x 24.0mm x 2.1mm and Write Protect slider Compliance: Fully compliant with SD Memory Card specification 3.0 o Fully compatible with UHS-I/SDR104 hosts o Up to speed class 10 and U3 according SD3.0 specification o SD2.0 SDHC backward compliant, default speed and high speed mode o FAT16 / FAT 32 / exFAT preformatted Performance: High performance 3.0 specification o SD Default speed, SD High speed, SD UHS-I o Read Performance: Sequential Read up to 46 MBytes/s, Random Read IOPS up to 1,439 o Write Performance: Sequential Write up to 52 MBytes/s, Random Write IOPS up to 1,259 Operating Temperature Range1: o Extended: -25 °C to 85 °C o Industrial: -40 °C to 85 °C Storage Temperature Range: o Extended: -25 °C to 100 °C o Industrial: -40 °C to 100 °C Operating Voltage: 2.7 … 3.6V (Low-power CMOS technology) Data Retention: 10 Years @ Life Begin / 1 Year @ Life End Humidity: 85% RH @85°C 1000h Electromagnetic Compatibility Test: Radiated Emission; Radiated Immunity; Electrostatic Discharge Product Features        Optimized FW algorithms especially for high read access and long data retention applications o Patented power-off reliability technology, Wear Leveling technology o Write Endurance technology, Read Disturb Management o Data Care Management, Near miss ECC technology o Diagnostic features with Life Time Monitoring tool support High reliability S-46 cards with pseudo SLC (pSLC) feature higher random write performance and endurance than MLC based cards (S-45) o The product is optimized for long life cycle and provides excellent data retention in high temperature mission profiles. o Number of card insertions/removals 20,000 o SIP (System In Package) process for extreme dust, water and ESD proof o Selected AEC-Q100 qualification Manufactured in a TS 16949 certified factory Customized options like CID registers, CPRM keys, firmware incl. settings and marking by projects In-field firmware update AES256 Encryption (on request) Swissbit Life Time Monitoring (SBLTM) Tool and SDK for SBLTM (on request) Why Swissbit? Swissbit is focused on the design, development, manufacture, and support of leading edge memory and storage solutions for the worldwide OEM/ODM marketplace. As a global supplier, Swissbit recognizes and addressees the higher level of application requirements of today’s industrial, Netcom, and automotive customers by providing best-in-class products and services, with uncompromised attention to driving overall value and quality. 1 High temperature storage without operation reduces the data retention, in operation the data will be refreshed, if data error issues were detected. Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland www.swissbit.com industrial@swissbit.com Revision: 1.02 Doc-2791 File: S-46_fact_sheet_SD-LxBM_Rev102 Page 2 of 2
SFSD016GL3BM1TO-I-LF-2CP-STD 价格&库存
很抱歉,暂时无法提供与“SFSD016GL3BM1TO-I-LF-2CP-STD”相匹配的价格&库存,您可以联系我们找货
