SFCA120GH1AA2TO-I-HC-216-STD 数据手册
Product Fact Sheet
durabit™
“the better MLC”
Industrial
CFastTM Card
F-60 Series
SATA Gen3 - 6.0 Gbit/s, MLC
Commercial and Industrial
Temperature Grade
Date :
Re vi si o n:
Janu ar y 2 7, 20 2 2
1 .0 7
Product Fact Sheet
F-60 Series
Product Summary
Capacities: 8 GBytes, 16 GBytes, 30 GBytes, 60 GBytes, 120 GBytes, 240 GBytes
Form Factor: CFast-Sized Solid State Drive (36.4 mm x 42.8 mm x 3.6 mm)
Compliance: SATA Gen3 - 6 Gbit/s (Gen2 - 3 Gbit/s and Gen1 - 1.5 Gbit/s backward compatible)
Command Sets: Supports ATA/ATAPI-8 and ACS-2
Performance:
o Read Performance: Sequential Read up to 520 MBytes/s, Random Read 4K up to 72,000 IOPS
o Write Performance: Sequential Write up to 180 MBytes/s, Random Write 4K up to 43,000 IOPS
Operating Temperature Range1: Commercial: 0 °C to 70 °C; Industrial: -40 °C to 85 °C
Storage Temperature Range: -40 °C to 85 °C
Operating Voltage: 3.3 V ± 5%
Power (Max Capacity): Read (Active): 1.3 W; Write (Active): 1.6 W; Idle: 363 mW; Slumber: 115 mW
Data Retention: 10 Years @ Life Begin / 1 Year @ Life End
Endurance in TeraBytes Written (TBW) Max Capacity2: Client > 540; Embedded > 145; Enterprise > 135
Shock/Vibration: 1,500 g / 50 g
Hardware BCH Code ECC: up to 66 bit correction per 1 KByte page
Mean Time Between Failure: > 2,000,000 hours
Data Reliability: < 1 non-recoverable error per 1016 bits read
Product Features
Best-in-Class Performance and Endurance with durabit™ Technology
Dynamic and Static Wear Leveling
Active and Passive Data Care Management
Lifetime Enhancements
o Dynamic Bad Block Remapping
o Write Amplification Reduction
On-Board Power Fail Protection
AHCI, TRIM, and NCQ Support
ATA Security Feature Set Support
DEVSLP Compatible
In-Field Firmware Update
Enterprise Grade Self-Monitoring, Analysis, and Reporting Technology (S.M.A.R.T.)
AES256 Encryption (on request)
30 µinch Gold-Plated Connector (on request)
Swissbit Life Time Monitoring (SBLTM) Tool and SDK for SBLTM (on request)
Why Swissbit?
Swissbit is focused on the design, development, manufacture, and support of leading edge memory and
storage solutions for the worldwide OEM/ODM marketplace. As a global supplier, Swissbit recognizes and
addressees the higher level of application requirements of today’s industrial, Netcom, and automotive
customers by providing best-in-class products and services, with uncompromised attention to driving overall
value and quality.
1
Adequate airflow is required to ensure the temperature, as reported in the S.M.A.R.T. data, does not exceed 115°C (industrial
temperature drive) and 100°C (commercial temperature drive) respectively.
According to JEDEC (JESD47I), the time to write the full TBW is a minimum of 18 months. Higher average daily data volume reduces the
specified TBW. The values listed are estimates and are subject to change without notice.
Swissbit AG
Revision: 1.07
Industriestrasse 4
TLP: Swissbit public
Template: Doc-4991
CH-9552 Bronschhofen
File: F-60_fact_sheet_Rev107
Switzerland
www.swissbit.com/contact
Page 2 of 2
2
SFCA120GH1AA2TO-I-HC-216-STD 价格&库存
很抱歉,暂时无法提供与“SFCA120GH1AA2TO-I-HC-216-STD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1429.971591+185.35155
