SFCA128GH1AD4TO-I-LT-216-STD
    SWISSBIT
    MEMCARDCOMPACTFLASH128GBMLC
SFCA128GH1AD4TO-I-LT-216-STD 数据手册
Product Fact Sheet Industrial CFastTM Card F-50 Series SATA Gen3 - 6.0 Gbit/s, MLC Commercial and Industrial Temperature Grade Date : Re vi si o n: N ove m be r 23 , 2 0 21 1 .0 7 Product Fact Sheet F-50 Series Product Summary      Capacities: 8 GBytes, 16 GBytes, 32 GBytes, 64 GBytes, 128 GBytes, 256 GBytes Form Factor: CFastTM 2.0 (36.4 mm x 42.8 mm x 3.6 mm) Compliance: SATA Gen3 - 6 Gbit/s (Gen2 - 3 Gbit/s and Gen1 - 1.5 Gbit/s backward compatible) Command Sets: Supports ATA/ATAPI-8 and ACS-2 Performance: o Read Performance: Sequential Read up to 500 MBytes/s, Random Read 4K up to 53,500 IOPS o Write Performance: Sequential Write up to 330 MBytes/s, Random Write 4K up to 74,000 IOPS Operating Temperature Range1: o Commercial: 0 °C to 70 °C o Industrial: -40 °C to 85 °C Storage Temperature Range: -40 °C to 85 °C Operating Voltage: 3.3 V ± 5% Power (Max Capacity): Read (Active): 1.2 W; Write (Active): 2.0 W; Idle: 248 mW; Slumber: 17 mW Data Retention: 10 Years @ Life Begin / 1 Year @ Life End Endurance in TeraBytes Written (TBW) Max Capacity2: Client ≥ 165; Enterprise ≥ 8 Shock/Vibration: 500 g / 20 g Hardware BCH Code ECC: up to 66 bit correction per 1 KByte page NAND Flash Technology: Multi-Level Cell (MLC) Mean Time Between Failure (MTBF): > 2,000,000 hours Data Reliability: < 1 non-recoverable error per 1016 bits read            Product Features  Dynamic and Static Wear Leveling  Subpage Mode Flash Translation Layer (FTL)  Active Data Care Management: Read Refresh  Lifetime Enhancements o Dynamic Bad Block Remapping o Write Amplification Reduction  On-Board Power Fail Protection  AHCI, TRIM, and NCQ Support  ATA Security Feature Set Support  DEVSLP Compatible  In-Field Firmware Update  Enterprise-Grade Self-Monitoring, Analysis, and Reporting Technology (S.M.A.R.T.)  Controlled “Locked” BOM  30 µinch Gold-Plated Connector (on request)  Conformal coating (on request)  Swissbit Life Time Monitoring (SBLTM) Tool and SDK for SBLTM (on request) Why Swissbit? Swissbit is focused on the design, development, manufacture, and support of leading edge memory and storage solutions for the worldwide OEM/ODM marketplace. As a global supplier, Swissbit recognizes and addresses the higher level of application requirements of today’s industrial, Netcom, and automotive customers by providing best-in-class products and services, with uncompromised attention to driving overall value and quality. 1 Adequate airflow is required to ensure the temperature, as reported in the S.M.A.R.T. data, does not exceed 120°C (industrial temperature drive) and 105°C (commercial temperature drive) respectively. 2 According to JEDEC (JESD47I), the time to write the full TBW is a minimum of 18 months. Higher average daily data volume reduces the specified TBW. The values listed are estimates and are subject to change without notice. Swissbit AG Revision: 1.07 Industriestrasse 4 TLP: Swissbit public Template: Doc-4991 CH-9552 Bronschhofen File: F-50_fact_sheet_Rev107 Switzerland www.swissbit.com/contact Page 2 of 2
SFCA128GH1AD4TO-I-LT-216-STD 价格&库存
很抱歉,暂时无法提供与“SFCA128GH1AD4TO-I-LT-216-STD”相匹配的价格&库存,您可以联系我们找货
