SFCA240GH1AA2TO-I-OC-216-STD
    SWISSBIT
    Memory Card CFast 240GB MLC
SFCA240GH1AA2TO-I-OC-216-STD 数据手册
Product Fact Sheet durabit™ “the better MLC” Industrial CFastTM Card F-60 Series SATA Gen3 - 6.0 Gbit/s, MLC Commercial and Industrial Temperature Grade Date : Re vi si o n: Janu ar y 2 7, 20 2 2 1 .0 7 Product Fact Sheet F-60 Series Product Summary                Capacities: 8 GBytes, 16 GBytes, 30 GBytes, 60 GBytes, 120 GBytes, 240 GBytes Form Factor: CFast-Sized Solid State Drive (36.4 mm x 42.8 mm x 3.6 mm) Compliance: SATA Gen3 - 6 Gbit/s (Gen2 - 3 Gbit/s and Gen1 - 1.5 Gbit/s backward compatible) Command Sets: Supports ATA/ATAPI-8 and ACS-2 Performance: o Read Performance: Sequential Read up to 520 MBytes/s, Random Read 4K up to 72,000 IOPS o Write Performance: Sequential Write up to 180 MBytes/s, Random Write 4K up to 43,000 IOPS Operating Temperature Range1: Commercial: 0 °C to 70 °C; Industrial: -40 °C to 85 °C Storage Temperature Range: -40 °C to 85 °C Operating Voltage: 3.3 V ± 5% Power (Max Capacity): Read (Active): 1.3 W; Write (Active): 1.6 W; Idle: 363 mW; Slumber: 115 mW Data Retention: 10 Years @ Life Begin / 1 Year @ Life End Endurance in TeraBytes Written (TBW) Max Capacity2: Client > 540; Embedded > 145; Enterprise > 135 Shock/Vibration: 1,500 g / 50 g Hardware BCH Code ECC: up to 66 bit correction per 1 KByte page Mean Time Between Failure: > 2,000,000 hours Data Reliability: < 1 non-recoverable error per 1016 bits read Product Features  Best-in-Class Performance and Endurance with durabit™ Technology  Dynamic and Static Wear Leveling  Active and Passive Data Care Management  Lifetime Enhancements o Dynamic Bad Block Remapping o Write Amplification Reduction  On-Board Power Fail Protection  AHCI, TRIM, and NCQ Support  ATA Security Feature Set Support  DEVSLP Compatible  In-Field Firmware Update  Enterprise Grade Self-Monitoring, Analysis, and Reporting Technology (S.M.A.R.T.)  AES256 Encryption (on request)  30 µinch Gold-Plated Connector (on request)  Swissbit Life Time Monitoring (SBLTM) Tool and SDK for SBLTM (on request) Why Swissbit? Swissbit is focused on the design, development, manufacture, and support of leading edge memory and storage solutions for the worldwide OEM/ODM marketplace. As a global supplier, Swissbit recognizes and addressees the higher level of application requirements of today’s industrial, Netcom, and automotive customers by providing best-in-class products and services, with uncompromised attention to driving overall value and quality. 1 Adequate airflow is required to ensure the temperature, as reported in the S.M.A.R.T. data, does not exceed 115°C (industrial temperature drive) and 100°C (commercial temperature drive) respectively. According to JEDEC (JESD47I), the time to write the full TBW is a minimum of 18 months. Higher average daily data volume reduces the specified TBW. The values listed are estimates and are subject to change without notice. Swissbit AG Revision: 1.07 Industriestrasse 4 TLP: Swissbit public Template: Doc-4991 CH-9552 Bronschhofen File: F-60_fact_sheet_Rev107 Switzerland www.swissbit.com/contact Page 2 of 2 2
- 物料型号: swissbit F-60系列 - 器件简介: - 容量选择:8GB到240GB - 外形尺寸:36.4 mm x 42.8 mm x 3.6 mm - 接口:SATA Gen3 - 6 Gbit/s,向下兼容Gen2和Gen1 - 支持命令集:ATA/ATAPI-8和ACS-2 - 引脚分配: 未在文档中明确列出 - 参数特性: - 顺序读取性能高达520MB/s - 4K随机读取高达72000 IOPS - 顺序写入性能高达180MB/s - 4K随机写入高达43000 IOPS - 工作温度范围:商业级0°C至70°C,工业级-40°C至85°C - 存储温度范围:-40°C至85°C - 工作电压:3.3V ± 5% - 数据保持期:开始使用10年/生命末期1年 - 耐用性:客户端>540TBW,嵌入式>145TBW,企业级>135TBW - 功能详解: - 采用durabit™技术,提供最佳性能和耐用性 - 动态和静态磨损平衡 - 主动和被动数据护理管理 - 终身增强,包括动态坏块重映射和写入放大减少 - 板载电源故障保护 - 支持AHCI、TRIM和NCQ - 支持ATA安全特性集 - DEVSLP兼容 - 现场固件更新 - 企业级自我监控、分析和报告技术(S.M.A.R.T.) - 可选AES256加密和30µ英寸镀金连接器 - 可选Swissbit终身监控(SBLTM)工具和SDK - 应用信息: 面向全球OEM/ODM市场,专注于工业、网络通信和汽车客户 - 封装信息: 金手指为30µ英寸镀金连接器(可选)
SFCA240GH1AA2TO-I-OC-216-STD 价格&库存
很抱歉,暂时无法提供与“SFCA240GH1AA2TO-I-OC-216-STD”相匹配的价格&库存,您可以联系我们找货
