AP-ISD32GID4B-8T
AP-ISD32GID4B-8T
    APACERMEMORYAMERICA(宇瞻科技)
    Memory Card SDHC™ 32GB Class 10 SLC
AP-ISD32GID4B-8T 数据手册
Industrial SD card Industrial SD card ISD Overview The Apacer industrial SD featured with high reliability and resistance to extended temperatures is widely applied to industrial, military, communication, surveillance, medical devices and car navigation, thereby satisfying the storage need of demanding industrial enterprises. Compliant with Ver. 2.0 standard and SDHC Class 10 high-speed transmission standard as defined by the SD Association, Apacer ISD also supports SD and SPI modes. By using the superbly reliable SLC chip, it not only delivers the features of anti-shock, anti-vibration and low power consumption, but also boasts resistance to extended temperatures (-40ºC to 85ºC). Available in capacities from 256 MB to 32 GB, and with its last but not the least advantage of automatic standby and sleep modes help save power more effectively. Feature ‧Industrial Grade SD card ‧ S.M.A.R.T supported ‧ Wear-Leveling and Block Management ‧ Auto Standby and Sleep Mode Support ‧ Golden finger 30u” Specifications Model Interface NAND Flash Type Capacity Industrial SD SD2.0 SLC SD:256MB~2GB;SDHC:4GB~32GB Sustained Read Performance (MB/sec) Up to 23 Sustained Write Performance (MB/sec) Up to 17 ECC Engine* Built-in 24-bit per 1K bytes BCH ECC Standard Operating Temperature ( °C ) 0 ~ + 70 Extended Operating Temperature ( °C ) -40 ~ + 85 Storage Temperature ( °C ) -40 ~ + 100 Shock 1,000G, 0.5ms Vibration 10Hz~50Hz/3mm (frequency/displacement) 50Hz~2,000Hz/15G (frequency/accelerate) Humidity 95% Operating Voltage Low Power Consumption Dimension (L x W x H ) MTBF (hours) Features / Technology Applications 3.3 V ± 5% Active mode: 55 mA & Idle mode: 105 mA 24x32x2.1 (mm) >2,000,000 S.M.A.R.T./Wide Temp. Military/Cloud Computing/InVehicle/Gaming/HealthCare/Embedded System Ordering Info Model Standard temp: 0~70 Extended temp:-40~85 256MB AP-ISD256CS2A-8T AP-ISD256IS2B-8T 512MB AP-ISD512CS2A-8T AP-ISD512IS2B-8T 1G AP-ISD01GCS2A-8T AP-ISD01GIS2B-8T 2G AP-ISD02GCS2A-8T AP-ISD02GIS2B-8T 4G AP-ISD04GCS4A-8T AP-ISD04GIS4B-8T 8G AP-ISD08GCD4A-8T AP-ISD08GID4B-8T 16G AP-ISD16GCD4A-8T AP-ISD16GID4B-8T 32G AP-ISD32GCD4A-8T AP-ISD32GID4B-8T Global Presence Taiwan (Headquarters) Apacer Technology Inc. Tel: +886-2-2267-8000 Fax: +886-2-2267-2261 Europe Apacer Technology B.V. Tel: +31-40-267-0000 Fax: +31-40-290-0686 Japan Apacer Technology Corp. Tel: +81-3-5419-2668 Fax: +81-3-5419-0018 India Apacer Technologies Pvt. Ltd. Tel: +91-80-41529061~3 Fax: +91-80-41700215 U.S.A. Apacer Memory America, Inc. Tel: +1-408-518-8699 Fax: 1-510-249-9551 China Apacer Electronic(Shanghai) Co., Ltd. Tel: +86-21-6228-9939
AP-ISD32GID4B-8T 价格&库存
很抱歉,暂时无法提供与“AP-ISD32GID4B-8T”相匹配的价格&库存,您可以联系我们找货
AP-ISD32GID4B-8T
  • 1+9490.090431+1227.79652
