SFCA032GH1AA2TO-I-QC-216-STD
    SWISSBIT
    MEMCARDCOMPACTFLASH32GBSLC
SFCA032GH1AA2TO-I-QC-216-STD 数据手册
. Product Fact Sheet Industrial CFastTM Card F-600 Series SATA Gen3 - 6.0 Gbit/s, SLC Commercial and Industrial Temperature Grade Date : Re vi si o n: Janu ar y 2 7, 20 2 2 1 .08 Product Fact Sheet F-600 Series Product Summary                Capacities: 4 GBytes, 8 GBytes, 16 GBytes, 32 GBytes, 64 GBytes Form Factor: CFast-Sized Solid State Drive (36.4 mm x 42.8 mm x 3.6 mm) Compliance: SATA Gen3 - 6 Gbit/s (Gen2 - 3 Gbit/s and Gen1 - 1.5 Gbit/s backward compatible) Command Sets: Supports ATA/ATAPI-8 and ACS-2 Performance: o Read Performance: Sequential Read up to 520 MBytes/s, Random Read 4K up to 76,000 IOPS o Write Performance: Sequential Write up to 245 MBytes/s, Random Write 4K up to 54,000 IOPS Operating Temperature Range1: Commercial: 0 °C to 70 °C; Industrial: -40 °C to 85 °C Storage Temperature Range: -40 °C to 85 °C Operating Voltage: 3.3 V ± 5% Power (Max Capacity): Read (Active): 1.6 W; Write (Active): 2.4 W; Idle: 347 mW; Slumber: 115 mW Data Retention: 10 Years @ Life Begin / 1 Year @ Life End Endurance in TeraBytes Written (TBW) Max Capacity2: Client ≥ 4,240; Embedded ≥ 1,370; Enterprise ≥ 615 Shock/Vibration: 1,500 g / 50 g Hardware BCH Code ECC: up to 66 bit correction per 1 KByte page Mean Time Between Failure: > 2,000,000 hours Data Reliability: < 1 non-recoverable error per 1016 bits read Product Features              Dynamic and Static Wear Leveling Subpage Mode Flash Translation Layer (FTL) Active and Passive Data Care Management Lifetime Enhancements o Dynamic Bad Block Remapping o Write Amplification Reduction On-Board Power Fail Protection AHCI, TRIM, and NCQ Support ATA Security Feature Set Support DEVSLP Compatible In-Field Firmware Update Enterprise Grade Self-Monitoring, Analysis, and Reporting Technology (S.M.A.R.T.) AES256 Encryption (on request) 30 µinch Gold-Plated Connector (on request) Swissbit Life Time Monitoring (SBLTM) Tool and SDK for SBLTM (on request) Why Swissbit? Swissbit is focused on the design, development, manufacture, and support of leading edge memory and storage solutions for the worldwide OEM/ODM marketplace. As a global supplier, Swissbit recognizes and addressees the higher level of application requirements of today’s industrial, Netcom, and automotive customers by providing best-in-class products and services, with uncompromised attention to driving overall value and quality. 1 Adequate airflow is required to ensure the temperature, as reported in the S.M.A.R.T. data, does not exceed 115°C (industrial temperature drive) and 100°C (commercial temperature drive) respectively. According to JEDEC (JESD47I), the time to write the full TBW is a minimum of 18 months. Higher average daily data volume reduces the specified TBW. The values listed are estimates and are subject to change without notice. Swissbit AG Revision: 1.08 Industriestrasse 4 TLP: Swissbit public Template: Doc-4991 CH-9552 Bronschhofen File: F-600_fact_sheet_Rev108 Switzerland www.swissbit.com/contact Page 2 of 2 2
SFCA032GH1AA2TO-I-QC-216-STD 价格&库存
很抱歉,暂时无法提供与“SFCA032GH1AA2TO-I-QC-216-STD”相匹配的价格&库存,您可以联系我们找货
