SFSD1024N1BM1TO-I-DF-221-STD
    SWISSBIT
    MEM CARD MICROSDHC 1GB UHS SLC
SFSD1024N1BM1TO-I-DF-221-STD 数据手册
Product Fact Sheet Industrial MICRO SD/SDHC Memory Card S-450u Series UHS-I Interface, SLC S-450u Series (UHS-I, SLC) Industrial MICRO SD/SDHC Memory Card – 512MB to 8GByte Main Feature  Fully compliant with SD Memory Card specification 3.0 and MICRO SD Memory Card Addendum 4.00 o SD ultra high speed mode, speed class 1 (SDR104) o SD high speed mode, up to speed class 10 o SD2.0 SDHC backward compliant, default speed and high speed mode o FAT32 preformatted  High performance 3.0 specification o SD burst up to 104MB/s o SD Normal speed 0…25MHz clock rate o SD High speed 0…50MHz clock rate o SD UHS-I speed 0...50MHz (DDR) and 0…208MHz (SDR) o Up to 24MByte/s sequential data rate  Power Supply: (Low-power CMOS technology) o 2.7…3.6V operating voltage  Standard MICRO SD Memory Card form factor o 15.0mm x 11.0mm x 0.7mm(1.0mm)  Optimized FW algorithms especially for high read access and long data retention applications o Patented power-off reliability technology o Wear Leveling technology Equal wear leveling of static and dynamic data. The wear leveling assures that dynamic data as well as static data is balanced evenly across the memory. With that the maximum write endurance of the device is guaranteed o Write Endurance technology Due to intelligent wear leveling an even use of the entire flash is guaranteed, regardless how much “static” (OS) data is stored. o Read Disturb Management The read commands are monitored and the content is refreshed when critical levels have occurred o Data Care Management The interruptible background process maintain the user data for Read Disturb effects or Retention degradation due to high temperature effects o Near Miss ECC technology Minimize the risk of uncorrectable bit failure over the product life time. Each read command analyzes the ECC margin level and refresh data if necessary o Diagnostic features with Life Time Monitoring tool support  High reliability o SLC Flash o Designed for industrial market especially read intensive application like navigation, infotainment, POS/POI, medical and general boot medium use case o The product is optimized for long life cycle that requires good data retention because of high temperature mission profile. o For less write and performance critical applications S-4x the more cost efficient S-4xu series MLC cards could be used o Number of card insertions/removals up to 20,000 o Extended and Industrial Temperature range -25° up to 85°C and -40° up to 85°C o SIP (System In Package) process for extreme dust, water and ESD proof o Selected AEC-Q100 qualification   Controlled BOM & PCN process Manufactured in a TS 16949 certified factory Customized options like CID registers, CPRM keys, firmware incl. settings and marking by projects  Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Swissbit reserves the right to change products or specifications without notice. www.swissbit.com industrial@swissbit.com Revision: 1.00 S-450u_fact_sheet_SD-NxBM_Rev100 Page 2 of 3 Order Information for S-450 Series UHS-I MICRO SD Memory Cards Density 512MB 1GB 2GB 4GB 8GB Part Number SFSD0512NgBM1TO-t-ME-2xx-STD SFSD1024NgBM1TO-t-DF-2xx-STD SFSD2048NgBM1MT-t-ME-2xx-STD SFSD4096NgBM1MT-t-DF-2xx-STD SFSD8192NgBM1MT-t-QG-2xx-STD Temp. Range Flash Technology t = E -25°C to 85°C SLC NAND Flash t = I -40°C to 85°C g = generation; x = options, firmware and custom configuration System Performance System Performance (estimated target) Burst Data transfer Rate (max clock 208MHz SDR) Sustained Sequential Read (512M / 1G-8G) Sustained Sequential Write (512M / 1G / 2G / 4G / 8G) typ 26 / 27 17 / 20 / 17 / 20 / 20 max 104 30 / 30 20 / 24 / 20 / 24 / 24 Typ 60 50 40 1.4 max 80 80 60 3 Current Consumption @3.3V Write Read Autoread Idle Unit MB/s Unit mA Physical Dimensions Physical Dimensions Length Width Thickness Weight (typ.) Value 15.0±0.1 11.0±0.1 0.7 (1.0)±0.1 0.4 Unit mm g Recommended Temperature Conditions Parameter min typ max Unit Extended Operating Temperature -25 25 85*) °C Industrial Operating Temperature -40 25 85*) °C Storage Temperature -40 25 100*) °C *) high temperature storage without operation reduces the data retention, in operation the data will be refreshed, if data error issues were detected Humidity and EMC Parameter Humidity (non-condensing) Operating Non Operating max 95% Non Contact Pads area: ±15 kV (air discharge), according to IEC61000-4-2 ESD Contact Pads: ±6 kV, according to IEC61000-4-2 Non Contact Pads area: ±8kV (indirect) contact discharge, according to IEC61000-4-2 Durability Parameter Salt water spray Insertions / Drop test Bending / Torque / Bump Shock / Vibration (peak -to-peak) Data Retention initial @ 40°C Operating Non Operating 3% NaCI/35°C; 24h acc. MIL STD Method 1009 >10,000/ 1.5m free fall 10N / 0.15Nm or ±2.5deg / 25g; 6ms; ±3 x 4000 shocks 1000 g max. / 15G max. 10 years For more information on Micro SD Memory card Specification, please visit SD association (www.sdcard.org) Why Swissbit? Swissbit strives to create innovative technologies for future market opportunities utilizing a highly skilled inhouse product research and development team. Swissbit maintains a marketing edge by continuing to manufacture world-class high quality memory products and providing customers with both high value and low cost of ownership achieved through efficient processes and procedures. Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Swissbit reserves the right to change products or specifications without notice. www.swissbit.com industrial@swissbit.com Revision: 1.00 S-450u_fact_sheet_SD-NxBM_Rev100 Page 3 of 3
SFSD1024N1BM1TO-I-DF-221-STD 价格&库存
很抱歉,暂时无法提供与“SFSD1024N1BM1TO-I-DF-221-STD”相匹配的价格&库存,您可以联系我们找货
  • 1+386.908241+50.00097
