AP-MSD02GIDI-T
AP-MSD02GIDI-T
    APACERMEMORYAMERICA(宇瞻科技)
    MEMORY CARD MICROSD 2GB SLC
AP-MSD02GIDI-T 数据手册
Industrial microSD card Industrial MicroSD(HC) card Industrial MicroSD (SLC) Overview Apacer’s industrial-grade MicroSD memory card is compliant with SD 2.0 Specification. Available in 256MB to 4GB, with sequential read/write speed reaching up to 20/16 MB/sec, it fulfills requirements for flexible-capacity and high-speed data storage. With a superbly reliable SLC (single-level cell) flash memory, it can operate normally in harsh temperature environments ranging from -40°C - +85°C. Apacer stresses "stability" has always been the primary concern for industrial devices. The greatest difference between this industrial-grade MicroSD memory card and other consumer memory cards on the market lies in its firmware version and major components that can be fixed. Apacer’s clients can benefit from the stable, long term supply. Besides, for clients who need long-term and stable supply chains, stock-out risk may be avoided, with compatibility issues caused by frequent product component changes significantly reduced. Time and money spent on product verification can also be saved. Feature ‧Compliant with SD 2.0 Specification ‧ S.M.A.R.T supported ‧ Wear-Leveling and Block Management ‧ Support SD mode and SPI mode ‧ Low Power Consumption ‧ Wide Temperature Support Specifications Model Industrial microSD Interface SD2.0 NAND Flash Type SLC Capacity SD:256MB~2GB;SDHC:4GB Sustained Read Performance (MB/sec) Up to 20 Sustained Write Performance (MB/sec) Up to 16 ECC Engine* Built-in 24-bit per 1K bytes BCH ECC Extended Operating Temperature ( °C ) -40 ~ + 85 Storage Temperature ( °C ) -40 ~ + 85 Shock 1,500G, 0.5ms Vibration 20Hz~80Hz/1.52mm (frequency/displacement) 80Hz~2,000Hz/20G (frequency/accelerate) Humidity 95% Operating Voltage 3.3 V ± 5% Low Power Consumption AcActive mode: 50 mA & Idle mode: 100 uA Dimension (L x W x H ) 15x11x1 (mm) MTBF (hours) >2,000,000 Features / Technology S.M.A.R.T./Wide Temp. Applications Military/Cloud Computing/InVehicle/Gaming/HealthCare/Embedded System Ordering Info Model Extended temp: -40~85 256MB AP-MSD256ISI-1T 512MB AP-MSD512IDI-1T 1G AP-MSD01GISI-T 2G AP-MSD02GIDI-T 4G AP-MSD04GIHI-T Global Presence Taiwan (Headquarters) Apacer Technology Inc. Tel: +886-2-2267-8000 Fax: +886-2-2267-2261 Europe Apacer Technology B.V. Tel: +31-40-267-0000 Fax: +31-40-290-0686 Japan Apacer Technology Corp. Tel: +81-3-5419-2668 Fax: +81-3-5419-0018 India Apacer Technologies Pvt. Ltd. Tel: +91-80-41529061~3 Fax: +91-80-41700215 U.S.A. Apacer Memory America, Inc. Tel: +1-408-518-8699 Fax: 1-510-249-9568 China Apacer Electronic(Shanghai) Co., Ltd. Tel: +86-21-6228-9939
AP-MSD02GIDI-T
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路安全。
3. 引脚分配:EL817有6个引脚,分别为Anode、Cathode、Collector、Emitter、Gate和Source。
4. 参数特性:工作温度范围为-40℃至+85℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低功耗特点。
6. 应用信息:广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:采用DIP-6封装。
AP-MSD02GIDI-T 价格&库存
很抱歉,暂时无法提供与“AP-MSD02GIDI-T”相匹配的价格&库存,您可以联系我们找货
AP-MSD02GIDI-T
  • 1+4156.929391+539.63701
