SFCF0512H1BK1MT-I-MS-553-SMA
    SWISSBIT
    MEM CARD COMPACTFLASH 512MB SLC
SFCF0512H1BK1MT-I-MS-553-SMA 数据手册
Product fact sheet Industrial CompactFlashTM Card C-300 Longevity Series up to UDMA4 / MDMA4 / PIO6 B U: Sw i ss b it Gr ou p Date : Se pte mbe r 25 , 2 01 5 Re vi si o n: 1 .0 1 Fi le : C -3 0 0_ lo n ge vi t y_ fac t_ s he e t_ C F H x BK_ Re v 10 1 .d oc Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Revision: 1.01 www.swissbit.com industrial@swissbit.com C-300_longevity_fact_sheet_CF-HxBK_Rev101 Page 1 of 3 C-300 Longevity Series - UDMA CompactFlash™ Card, 128MByte up to 8GByte, 3.3/5V Supply Main Features                   Highly-integrated memory controller o Fully compliant with CompactFlashTM specification 3.0, compatible with specification 4.1 o Fully compatible with PCMCIA specification o PC Card ATA Interface supported o True IDE mode compatible o Up to PIO mode 6 supported o Up to MDMA4 supported o Up to UDMA4 supported o Hardware RS-code ECC (4 Bytes/528 Bytes correction) o Fix drive (IDE mode) & removable drive (PCMCIA mode) as default in the same card Small form factor o CFC Type I: 36.4mm x 42.8mm x 3.3mm Low-power CMOS technology 3.3V or 5.0V power supply Power saving mode (with automatic wake-up) S.M.A.R.T. support by *-SMA product type Wear Leveling: equal wear leveling of static and dynamic data The wear leveling assures that dynamic data as well as static data is balanced evenly across the memory. With that the maximum write endurance of the device is guaranteed. Data Retention: 10 year (JESD47) Patented power-off reliability o No data loss of older sectors o Max. 16 sectors data loss (old data kept) for 2k Page flash respectively o All data written to the flash if card status is ready after write command High reliability o Best available SLC NAND Flash technology o Designed for embedded market o MTBF: > 3,000,000 hours o Data reliability: < 1 non-recoverable error per 1014 bits read o Number of insertions: > 10,000 Hot swappable in PCMCIA modes High random performance o Up to 66MB/s burst transfer rate in UDMA4 o Optimized for random access >150kB/s o Sustained Read/Write performance: up to 38/20MB/s (UDMA4) Available densities o 128MB to 8GBytes (SLC NAND Flash) Operating System support o Standard Software Drivers operation CompactFlashTM 2 Temperature ranges o Commercial Temperature range 0 … +70°C o Industrial Temperature range -40 … +85°C Controlled BOM RoHS compliant Long term support on request Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Revision: 1.01 www.swissbit.com industrial@swissbit.com C-300_longevity_fact_sheet_CF-HxBK_Rev101 Page 2 of 3 System Performance Parameter Typ. Max. Unit Sleep to write 5 Sleep to read 5 ms Power up to Ready 3,000,000 hours 14 < 1 Non-Recoverable Error per 10 bits Read Why Swissbit? Swissbit strives to create innovative technologies for future market opportunities utilizing a highly skilled in-house product research and development team. Swissbit maintains a marketing edge by continuing to manufacture world-class high quality memory products and providing customers with both high value and low cost of ownership achieved through efficient processes and procedures. Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Revision: 1.01 www.swissbit.com industrial@swissbit.com C-300_longevity_fact_sheet_CF-HxBK_Rev101 Page 3 of 3
SFCF0512H1BK1MT-I-MS-553-SMA 价格&库存
很抱歉,暂时无法提供与“SFCF0512H1BK1MT-I-MS-553-SMA”相匹配的价格&库存,您可以联系我们找货
