AP-CF001GRANS-ETNRC
AP-CF001GRANS-ETNRC
    APACERMEMORYAMERICA(宇瞻科技)
    MEM CARD COMPACTFLASH 1GB 10 SLC
AP-CF001GRANS-ETNRC 数据手册
Halogen-free & RoHS Recast Compliant CompactFlash Series 6 Industrial CompactFlash Card Specifications June 23, 2015 Version 1.1 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 Compact Flash 6 series AP-CFxxxxRANS-XXXXXXC Features: CompactFlash Association Specification Revision 6.0 Standard Interface ATA command set compatible ATA transfer mode supports: PIO Mode 6 Multiword DMA Mode 4 Ultra DMA Mode 7 PCMCIA UDMA Mode 7 Temperature ranges Operating: Standard: 0°C to 70°C Extended: -40°C to +85°C Storage: -40°C to +100°C Operating voltage for read and write 3.3 V 5.0 V Capacities 512 MB 1, 2, 4, 8, 16, 32, 64 GB Power consumption (typical)* Active mode: 310 mA Standby mode: 5 mA Performance* Sustained read: Up to 110 MB/sec Sustained write: Up to 80 MB/sec Connector Type 50 pins female Physical Dimensions 36.4mm x 42.8mm x 3.3mm Intelligent ATA/IDE module Wear-leveling algorithms to substantially increase longevity of flash media Built-in BCH ECC capable of correcting up to 72 bits in 1KB data Supports S.M.A.R.T commands Halogen free RoHS Recast Complient Complies with 2011/65/EU NAND Flash Type: SLC *Performance and power consumption may vary depending on capacities, flash configuration or host system settings. 1 © 2015 Apacer Technology Inc. Rev. 1.1 Compact Flash 6 series AP-CFxxxxRANS-XXXXXXC Table of Contents 1. GENERAL DESCRIPTION .................................................................................................... 3 1.1 INTELLIGENT ENDURANCE DESIGN.......................................................................................................................3 1.1.1 Error Correction Code (ECC) ......................................................................................................................3 1.1.2 Wear-leveling algorithms .............................................................................................................................3 1.1.3 S.M.A.R.T. Technology .................................................................................................................................3 1.1.4 Flash Block Management .............................................................................................................................4 2. FUNCTIONAL BLOCK .......................................................................................................... 5 3. PIN ASSIGNMENTS ............................................................................................................... 6 4. PRODUCT SPECIFICATION ................................................................................................ 8 4.1 CAPACITY .............................................................................................................................................................8 4.2 PERFORMANCE .....................................................................................................................................................8 4.3 ENVIRONMENTAL SPECIFICATIONS ....................................................................................................................... 9 4.4 MEAN TIME BETWEEN FAILURES(MTBF) ............................................................................................................9 4.4 CERTIFICATION & COMPLIANCE ...........................................................................................................................9 5. SOFTWARE INTERFACE .................................................................................................. 10 5.1 CF-ATA COMMAND SET .................................................................................................................................... 10 6. OPERATING CONDITIONS............................................................................................... 12 7. PHYSICAL CHARACTERISTICS ..................................................................................... 13 7.1 DIMENSION ......................................................................................................................................................... 13 8. PRODUCT ORDERING INFORMATION ........................................................................ 14 8.1 PRODUCT CODE DESIGNATIONS ......................................................................................................................... 14 2 © 2015 Apacer Technology Inc. Rev. 1.1 Compact Flash 6 series AP-CFxxxxRANS-XXXXXXC 1. General Description value-added Industrial CompactFlash Card offers high performance, high reliability and powerefficient storage. Regarding standard compliance, this CompactFlash Card complies with CompactFlash specification revision 6.0, supporting transfer modes up to Programmed Input Output (PIO) Mode 6, Multiword Direct Memory Access (DMA) Mode 4, Ultra DMA Mode 7, and PCMCIA Ultra DMA Mode 7. value-added CFC provides complete PCMCIA ATA functionality and compatibility. Apacer s CompactFlash technology is designed for applications in Point of Sale (POS) terminals, telecom, IP-STB, medical instruments, surveillance systems, industrial PCs and handheld applications such as the new generation of Digital Single Lens Reflex (DSLR) cameras. 1.1 Intelligent Endurance Design 1.1.1 Error Correction Code (ECC) The CompactFlash card is programmed with BCH Error Detection Code (EDC) and Error Correction Code (ECC) algorithms capable of correcting up to 72 random bits in 1KB bytes data. High performance is achieved through hardware-based error detection and correction. 1.1.2 Wear-leveling algorithms Flash memory devices differ from Hard Disk Drives (HDDs) in terms of how blocks are utilized. For HDDs, when a change is made to stored data, like erase or update, the controller mechanism on HDDs will perform overwrites on blocks. Unlike HDDs, flash blocks cannot be overwritten and each P/E cycle wears down the lifespan of blocks gradually. Repeatedly program/erase cycles performed on the same memory cells will eventually cause some blocks to age faster than others. This would bring flash storages to their end of service term sooner. Wear leveling is an important mechanism that level out the wearing of blocks so that the wearing-down of blocks can be almost evenly distributed. This will increase the lifespan of SSDs. Commonly used wear leveling types are Static and Dynamic. 1.1.3 S.M.A.R.T. Technology S.M.A.R.T. is an acronym for Self-Monitoring, Analysis and Reporting Technology, an open standard allowing disk drives to automatically monitor their own health and report potential problems. It protects the user from unscheduled downtime by monitoring and storing critical drive performance and calibration parameters. Ideally, this should allow taking proactive actions to prevent impending drive failure. Apacer SMART feature adopts the standard SMART command B0h to read data from the drive. When the Apacer SMART Utility running on the host, it analyzes and reports the disk status to the host before the device is in critical condition. 3 © 2015 Apacer Technology Inc. Rev. 1.1 Compact Flash 6 series AP-CFxxxxRANS-XXXXXXC 1.1.4 Flash Block Management Current production technology is unable to guarantee total reliability of NAND flash memory array. When a flash memory device leaves factory, it comes with a minimal number of initial bad blocks during production or out-of-factory as there is no currently known technology that produce flash chips free of bad blocks. In addition, bad blocks may develop during program/erase cycles. When host performs program/erase command on a block, bad block may appear in Status Register. Since bad blocks are inevitable, the solution is to keep them in control. Apacer flash devices are programmed with ECC, block mapping technique and S.M.A.R.T to reduce invalidity or error. Once bad blocks are detected, data in those blocks will be transferred to free blocks and error will be corrected by designated algorithms. 4 © 2015 Apacer Technology Inc. Rev. 1.1 Compact Flash 6 series AP-CFxxxxRANS-XXXXXXC 2. Functional Block The CompactFlash Card (CFC) includes a controller and flash media, as well as the CompactFlash standard interface. Figure 2-1 shows the functional block diagram. Figure 2-1: Functional block diagram 5 © 2015 Apacer Technology Inc. Rev. 1.1 Compact Flash 6 series AP-CFxxxxRANS-XXXXXXC 3. Pin Assignments Table 3-1 lists the pin assignments with respective signal names for the 50-pin configuration. A indicates the active low signal. The pin type can be input, output or input/output. Table 3-1: Pin assignments (1 of 2) Pin No. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 Memory card mode Signal name GND D3 D4 D5 D6 D7 #CE1 A10 #OE A9 A8 A7 VCC A6 A5 A4 A3 A2 A1 A0 D0 D1 D2 WP #CD2 #CD1 D11 D12 D13 D14 D15 #CE2 #VS1 #IORD #IOWR #WE RDY/-BSY VCC #CSEL #VS2 RESET Pin I/O type I/O I/O I/O I/O I/O I I I I I I I I I I I I I I/O I/O I/O O O O I/O I/O I/O I/O I/O I O I I I O I O I I/O card mode Signal name GND D3 D4 D5 D6 D7 #CE1 A10 #OE A9 A8 A7 VCC A6 A5 A4 A3 A2 A1 A0 D0 D1 D2 #IOIS16 #CD2 #CD1 D11 D12 D13 D14 D15 #CE2 #VS1 #IORD #IOWR #WE #IREQ VCC #CSEL #VS2 RESET Pin I/O type I/O I/O I/O I/O I/O I I I I I I I I I I I I I I/O I/O I/O O O O I/O I/O I/O I/O I/O I O I I I O I O I True IDE mode Signal name GND D3 D4 D5 D6 D7 #CS0 1 A10 #ATA SEL 1 A9 1 A8 1 A7 VCC 1 A6 1 A5 1 A4 1 A3 A2 A1 A0 D0 D1 D2 #IOCS16 #CD2 #CD1 D11 D12 D13 D14 D15 #CS1 #VS1 #IORD #IOWR #WE INTRQ VCC #CSEL #VS2 #RESET Pin I/O type I/O I/O I/O I/O I/O I I I I I I I I I I I I I I/O I/O I/O O O O I/O I/O I/O I/O I/O I O I I I O I O I 6 © 2015 Apacer Technology Inc. Rev. 1.1 Compact Flash 6 series AP-CFxxxxRANS-XXXXXXC Table 3-1: Pin assignments (2 of 2) Pin No. 42 43 44 45 46 47 48 49 50 1. 2. Memory card mode Signal name #WAIT #INPACK #REG BVD2 BVD1 D8 D9 D10 GND Pin I/O type O O I O O I/O I/O I/O - I/O card mode Signal name #WAIT #INPACK #REG #SPKR #STSCHG D8 D9 D10 GND Pin I/O type O O I O O I/O I/O I/O - True IDE mode Signal name IORDY 2 DMARQ 2 DMACK #DASP #PDIAG D8 D9 D10 GND Pin I/O type O O I I/O I/O I/O I/O I/O - The signal should be grounded by the host. Connection required when UDMA is in use. 7 © 2015 Apacer Technology Inc. Rev. 1.1 Compact Flash 6 series AP-CFxxxxRANS-XXXXXXC 4. Product Specification 4.1 Capacity Capacity specification of the Compact Flash Card series (CFC) is available as shown in Table 4-1. It lists the specific capacity and the default numbers of heads, sectors and cylinders for each product line. Table 4-1: Capacity specifications Capacity Total bytes 1 Cylinders Heads Sectors Max LBA 512 MB 512,483,328 993 16 63 1,000,944 1 GB 1,024,966,656 1,986 16 63 2,001,888 2 GB 2,048,901,120 3,970 16 83 4,001,760 4 GB 4,110,188,544 7,964 16 63 8,027,712 8 GB 8,195,604,480 15,880 16 83 16,007,040 16 GB 16,391,340,032 16,383 16 63 32,014,336 32 GB 32,019,316,736 16,383 16 63 62,537,728 64 GB 64,030,244,864 16,383 16 63 125,059,072 Notes: Display of total bytes varies from operating systems. Cylinders, heads or sectors are not applicable for these capacities. Only LBA addressing applies Notes: 1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 4.2 Performance Performances of the CF cards are listed in Table 4-2 Table 4-2: Performance specifications Capacity 512 MB 1 GB 2 GB 4 GB 8 GB 16 GB 32 GB 64 GB Sustained read (MB/s) 85 85 105 110 110 110 110 110 Sustained write (MB/s) 20 40 70 70 75 75 80 80 Performance Notes: performance may vary depending on flash configurations or host system settings. 8 © 2015 Apacer Technology Inc. Rev. 1.1 Compact Flash 6 series AP-CFxxxxRANS-XXXXXXC 4.3 Environmental Specifications Environmental specification of the Compact Flash Card series (CFC) which follows the MIL-STD-810F standards is available as shown in Table 4-3. Table 4-3: Environmental specifications Environment Temperature Specification Operation Storage Humidity Vibration (Non-Operating) Shock (Non-Operating) 0°C to 70°C; -40°C to 85°C (Extended Temperature) -40°C to 100°C 5% to 95% RH (Non-condensing) Sine wave : 10~2000Hz, 15G (X, Y, Z axes) Half sine wave 1,500G (X, Y, Z ; All 6 axes) 4.4 Mean Time Between Failures(MTBF) MTBF, an acronym for Mean Time Between Failures, is a represents the average time between a repair and the next failure. The measure is typically in units of hours. The higher the MTBF value, the higher the reliability of the device. The predicted result of this mSATA device is higher than 1.99 106 hours. 4.4 Certification & Compliance The CompactFlash card complies with the following global standards: CE FCC Halogen-free EMC RoHS Recast (2011/65/EU) 9 © 2015 Apacer Technology Inc. Rev. 1.1 Compact Flash 6 series AP-CFxxxxRANS-XXXXXXC 5. Software Interface 5.1 CF-ATA Command Set Table 5-1 summarizes the CF-ATA command set with the paragraphs that follow describing the individual commands and the task file for each. Table 5-1: CFC-ATA command set Command Set Command CFA Feature Set General Feature Set Code Protocol Request Sense 03h Non-data Write Sectors Without Erase 38h PIO data-out Erase Sectors C0h Non-data Write Multiple Without Erase CDh PIO data-out Translate Sector 87h PIO data-in Set Features Enable/Disable 8-bit Transfer EFh Non-data Execute Drive Diagnostic 90h Device diagnostic Flush Cache E7h Non-data Identify Device ECh PIO data-in Read DMA C8h DMA Read Multiple C4h PIO data-in Read Sector(s) 20h or 21h PIO data-in Read Verify Sector(s) 40h or 41h Non-data Set Feature EFh Non-data Set Multiple Mode C6h Non-data Write DMA CAh DMA Write Multiple C5h PIO data-out 30h or 31h PIO data-out NOP 00h Non-data Read Buffer E4h PIO data-in Write Buffer E8h PIO data-out Set Feature EFh Non-data Check Power Mode E5h or 98h Non-data Idle E3h or 97h Non-data Idle Immediate E1h or 95h Non-data Sleep E6h or 99h Non-data Standby E2h or 96h Non-data Standby Immediate E0h or 94h Non-data Write Sector(s) Power Management Feature Set 10 © 2015 Apacer Technology Inc. Rev. 1.1 Compact Flash 6 series AP-CFxxxxRANS-XXXXXXC Security Mode Feature Set SMART Feature Set Host Protected Area Feature Set Others 48-bit Address Feature Set Security Set Password F1h PIO data-out Security Unlock F2h PIO data-out Security Erase Prepare F3h Non-data Security Erase Unit F4h PIO data-out Security Freeze Lock F5h Non-data Security Disable Password F6h PIO data-out SMART Disable Operations B0h Non-data SMART Enable/Disable Autosave B0h Non-data SMART Enable Operations B0h Non-data SMART Return Status B0h Non-data SMART Execute Off-line Immediate B0h Non-data SMART Read Data B0h PIO data-in Read Native Max Address F8h Non-data Set Max Address F9h Non-data Set Max Set Password F9h PIO data-out Set Max Lock F9h Non-data Set Max Freeze Lock F9h Non-data Set Max Unlock F9h PIO data-out Format Track 50h PIO data-out Initialize Drive Parameters 91h Non-data Recalibrate 1Xh Non-data Seek 7Xh Non-data Wear Level F5h Non-data Write Verify 3Ch PIO data-out Read Sector Ext 24h PIO data-in Read DMA Ext 25h DMA Read Multiple Ext 29h PIO data-in Write Sector Ext 34h PIO data-out Write DMA Ext 35h DMA Read Verify Sector Ext 42h Non-data Write Multiple FUA Ext CEh PIO data-out Flush Cache Ext EAh Non-data 11 © 2015 Apacer Technology Inc. Rev. 1.1 Compact Flash 6 series AP-CFxxxxRANS-XXXXXXC 6. Operating Conditions Table 6-1: Operating range Parameters Range Ambient temperature Extended temperature 0°C to 70°C -40°C to 85°C Supply voltage at 3.3V 3.135 ~ 3.465 V Supply voltage at 5V 4.75 ~ 5.25 V Table 6-2: Power consumption (typical) Capacity Mode Active (mA) Stand By (mA) 512 MB 1 GB 2 GB 4 GB 8 GB 16 GB 8 GB 16 GB 220 220 260 260 260 290 290 310 5 5 5 5 5 5 5 5 Note: Power consumptions may vary depending on settings and platforms 12 © 2015 Apacer Technology Inc. Rev. 1.1 Compact Flash 6 series AP-CFxxxxRANS-XXXXXXC 7. Physical Characteristics 7.1 Dimension FIGURE 7-1: Physical dimension Unit: mm 13 © 2015 Apacer Technology Inc. Rev. 1.1 Compact Flash 6 series AP-CFxxxxRANS-XXXXXXC 8. Product Ordering Information 8.1 Product Code Designations AP CF x x x x R A N S XXXXXX C FW Specification RM: Removable NR: Non-Removable ET: Extended Temperature NDRM: Non-DMA + Removable NDNR: Non-DMA + Non-Removable ETRM: Ext. Temp. + Removable ETNR: Ext. Temp. + Non-Removable ETNDRM: Ext. Temp + Non-DMA + Removable ETNDNR: Ext. Temp + Non-DMA + Non-Removable Halogen Free Compliant Configuration CTL Type CFC Type Capacities: 512M 001G 002G 004G 008G 016G 032G 064G 512MB 1GB 2GB 4GB 8GB 16GB 32GB 64GB Model Name Apacer Product Code 14 © 2015 Apacer Technology Inc. Rev. 1.1 Compact Flash 6 series AP-CFxxxxRANS-XXXXXXC 8.2 Valid Combinations 8.2.1 Standard Temperature 8.2.1.1 Non-Removable Capacity AP/N 512MB AP-CF512MRANS-NRC 1GB AP-CF001GRANS-NRC 2GB AP-CF002GRANS-NRC 4GB AP-CF004GRANS-NRC 8GB AP-CF008GRANS-NRC 16GB AP-CF016GRANS-NRC 32GB AP-CF032GRANS-NRC 64GB AP-CF064GRANS-NRC 8.2.1.2 Removable Capacity AP/N 512MB AP-CF512MRANS-RMC 1GB AP-CF001GRANS-RMC 2GB AP-CF002GRANS-RMC 4GB AP-CF004GRANS-RMC 8GB AP-CF008GRANS-RMC 16GB AP-CF016GRANS-RMC 32GB AP-CF032GRANS-RMC 64GB AP-CF064GRANS-RMC Note: Valid combinations are those products in mass production or will be in mass production. Consult your Apacer sales representative to confirm availability of valid combinations and to determine availability of new combinations. 15 © 2015 Apacer Technology Inc. Rev. 1.1 Compact Flash 6 series AP-CFxxxxRANS-XXXXXXC 8.2.1.3 Non-DMA + Removable Capacity AP/N 512MB AP-CF512MRANS-NDNRC 1GB AP-CF001GRANS-NDNRC 2GB AP-CF002GRANS-NDNRC 4GB AP-CF004GRANS-NDNRC 8GB AP-CF008GRANS-NDNRC 16GB AP-CF016GRANS-NDNRC 32GB AP-CF032GRANS-NDNRC 64GB AP-CF064GRANS-NDNRC 8.2.1.4 Non-DMA + Non-Removable Capacity AP/N 512MB AP-CF512MRANS-NDRMC 1GB AP-CF001GRANS-NDRMC 2GB AP-CF002GRANS-NDRMC 4GB AP-CF004GRANS-NDRMC 8GB AP-CF008GRANS-NDRMC 16GB AP-CF016GRANS-NDRMC 32GB AP-CF032GRANS-NDRMC 64GB AP-CF064GRANS-NDRMC Note: Valid combinations are those products in mass production or will be in mass production. Consult your Apacer sales representative to confirm availability of valid combinations and to determine availability of new combinations. 16 © 2015 Apacer Technology Inc. Rev. 1.1 Compact Flash 6 series AP-CFxxxxRANS-XXXXXXC 8.2.2 Extended Temperature 8.2.2.1 Ext. Temp. + Non-Removable Capacity AP/N 512MB AP-CF512MRANS-ETNRC 1GB AP-CF001GRANS-ETNRC 2GB AP-CF002GRANS-ETNRC 4GB AP-CF004GRANS-ETNRC 8GB AP-CF008GRANS-ETNRC 16GB AP-CF016GRANS-ETNRC 32GB AP-CF032GRANS-ETNRC 64GB AP-CF064GRANS-ETNRC 8.2.2.2 Ext. Temp. + Removable Capacity AP/N 512MB AP-CF512MRANS-ETRMC 1GB AP-CF001GRANS-ETRMC 2GB AP-CF002GRANS-ETRMC 4GB AP-CF004GRANS-ETRMC 8GB AP-CF008GRANS-ETRMC 16GB AP-CF016GRANS-ETRMC 32GB AP-CF032GRANS-ETRMC 64GB AP-CF064GRANS-ETRMC Note: Valid combinations are those products in mass production or will be in mass production. Consult your Apacer sales representative to confirm availability of valid combinations and to determine availability of new combinations. 17 © 2015 Apacer Technology Inc. Rev. 1.1 Compact Flash 6 series AP-CFxxxxRANS-XXXXXXC 8.2.2.3 Non-DMA + Removable Capacity AP/N 512MB AP-CF512MRANS-ETNDNRC 1GB AP-CF001GRANS-ETNDNRC 2GB AP-CF002GRANS-ETNDNRC 4GB AP-CF004GRANS-ETNDNRC 8GB AP-CF008GRANS-ETNDNRC 16GB AP-CF016GRANS-ETNDNRC 32GB AP-CF032GRANS-ETNDNRC 64GB AP-CF064GRANS-ETNDNRC 8.2.2.4 Non-DMA + Non-Removable Capacity AP/N 512MB AP-CF512MRANS-ETNDRMC 1GB AP-CF001GRANS-ETNDRMC 2GB AP-CF002GRANS-ETNDRMC 4GB AP-CF004GRANS-ETNDRMC 8GB AP-CF008GRANS-ETNDRMC 16GB AP-CF016GRANS-ETNDRMC 32GB AP-CF032GRANS-ETNDRMC 64GB AP-CF064GRANS-ETNDRMC Note: Valid combinations are those products in mass production or will be in mass production. Consult your Apacer sales representative to confirm availability of valid combinations and to determine availability of new combinations. 18 © 2015 Apacer Technology Inc. Rev. 1.1 Compact Flash 6 series AP-CFxxxxRANS-XXXXXXC Revision History Revision Date Description Remark 1.0 04/20/2015 First release 1.1 06/23/2015 Added MTBF information 19 © 2015 Apacer Technology Inc. Rev. 1.1 Compact Flash 6 series AP-CFxxxxRANS-XXXXXXC Global Presence Taiwan (Headquarters) Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 386 Fairview Way, Suite102, Milpitas, CA 95035 Tel: 1-408-518-8699 Fax: 1-408-935-9611 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd 1301, No.251,Xiaomuqiao Road, Shanghai, 200032, China Tel: 86-21-5529-0222 Fax: 86-21-5206-6939 sales@apacer.com.cn India Apacer Technologies Pvt. Ltd. # 535, 1st Floor, 8th cross, JP Nagar 3rd Phase, Bangalore 560078, India Tel: 91-80-4152-9061 sales_india@apacer.com 20 © 2015 Apacer Technology Inc. Rev. 1.1
AP-CF001GRANS-ETNRC 价格&库存
很抱歉,暂时无法提供与“AP-CF001GRANS-ETNRC”相匹配的价格&库存,您可以联系我们找货
AP-CF001GRANS-ETNRC
  • 1+1254.003931+161.25133
AP-CF001GRANS-ETNRC
  • 1+692.029501+88.98750
  • 3+645.894203+83.05500
