AP-CF008GLAFS-NR
AP-CF008GLAFS-NR
    APACERMEMORYAMERICA(宇瞻科技)
    MEMORY CARD COMPACTFLASH 8GB SLC
AP-CF008GLAFS-NR 数据手册
Halogen Free & RoHS Recast Complaint CompactFlash Series 6 Specifications for Industrial CompactFlash Card January 30th, 2013 Version 1.0 Apacer Technology Inc. th 4 Fl., 75 Hsin Tai Wu Rd., Sec.1, Xizhi, New Taipei City 221, Taiwan Tel: +886-2-2698-2888 Fax: +886-2-2698-2889 www.apacer.com Compact Flash 6 series AP-CFxxxxLAXS-XXXXXX Features:  CompactFlash Association Specification Revision 6.0 Standard Interface – ATA command set compatible – ATA transfer mode supports: PIO Mode 6 Multiword DMA Mode 4 Ultra DMA Mode 6 PCMCIA UDMA Mode 5  –  – – Capacities 8, 16, 32, 64, 128 GB Performance* – Sustained read: Up to 110 MB/sec – Sustained write: Up to 60 MB/sec   Intelligent ATA/IDE module – Wear-leveling algorithms to substantially increase longevity of flash media – Built-in BCH ECC capable of correcting up to 72 bits in 1KB data – Supports S.M.A.R.T commands  Temperature ranges 0°C to 70°C for operation (Standard) -40°C to 85°C (extended temperature) -40°C to 100°C for storage – – Operating voltage for read and write 3.3 V 5.0 V – – Power consumption (typical)* Active mode: 265 mA/5.0V Standby mode: 1 mA/5.0V – Connector Type 50 pins female – Physical Dimensions 36.4mm x 42.8mm x 3.3mm – RoHS Recast Compliant Complies with 2011/65/EU   NAND Flash Type: MLC   Power Smart Design Built-in 1.2V Power-On-Reset Built-in 2.7V Voltage detector for power fail protection – – –    Power Management  Halogen Free *Performance and power consumption may vary depending on capacities, flash configuration or host system settings. 1 © 2013 Apacer Technology Inc. Rev. 1.0 Compact Flash 6 series AP-CFxxxxLAXS-XXXXXX Table of Contents 1.GENERAL DESCRIPTION ..................................................................................................... 3 1.1 PERFORMANCE-OPTIMIZED CONTROLLER ............................................................................................................3 1.1.1 Power Management ......................................................................................................................................3 1.1.2 RAM..............................................................................................................................................................3 1.1.3 Error Correction Code (ECC) ......................................................................................................................3 1.2 INTELLIGENT ENDURANCE DESIGN.......................................................................................................................3 1.2.1 Wear-leveling algorithms .............................................................................................................................3 1.2.2 S.M.A.R.T. Technology .................................................................................................................................4 1.2.3 Flash Block Management .............................................................................................................................4 1.2.4 Power Failure Management .........................................................................................................................4 2. FUNCTIONAL BLOCK .......................................................................................................... 5 3. PIN ASSIGNMENTS ............................................................................................................... 6 4. PRODUCT SPECIFICATION ................................................................................................ 8 4.1 CAPACITY .............................................................................................................................................................8 4.2 PERFORMANCE .....................................................................................................................................................8 4.3 ENVIRONMENTAL SPECIFICATIONS .......................................................................................................................8 4.4 CERTIFICATION & COMPLIANCE ...........................................................................................................................9 5. SOFTWARE INTERFACE .................................................................................................. 10 5.1 CF-ATA COMMAND SET ....................................................................................................................................10 6. OPERATING CONDITIONS............................................................................................... 12 7. PHYSICAL CHARACTERISTICS ..................................................................................... 13 7.1 DIMENSION .........................................................................................................................................................13 8. PRODUCT ORDERING INFORMATION ........................................................................ 14 8.1 PRODUCT CODE DESIGNATIONS .........................................................................................................................14 2 © 2013 Apacer Technology Inc. Rev. 1.0 Compact Flash 6 series AP-CFxxxxLAXS-XXXXXX 1. General Description Apacer’s value-added Industrial CompactFlash Card offers high performance, high reliability and powerefficient storage. Regarding standard compliance, this CompactFlash Card complies with CompactFlash specification revision 6.0, supporting transfer modes up to Programmed Input Output (PIO) Mode 6, Multiword Direct Memory Access (DMA) Mode 4, Ultra DMA Mode 6, and PCMCIA Ultra DMA Mode 5. For power efficiency, this industrial CompactFlash card supports some power smart design mechanisms such as Power-On-Reset, voltage regulator for output voltage adjustments and power failure protection, as well as the automatic sleep and wake-up feature. Apacer’s value-added CFC provides complete PCMCIA – ATA functionality and compatibility. Apacer ‘s CompactFlash technology is designed for applications in Point of Sale (POS) terminals, telecom, IP-STB, medical instruments, surveillance systems, industrial PCs and handheld applications such as the new generation of Digital Single Lens Reflex (DSLR) cameras. 1.1 Performance-Optimized Controller The CompactFlash Card Controller translates standard CF signals into flash media data and control signals. 1.1.1 Power Management The controller unit of this ComactFlash is built with power management design that optimizes power utilization and voltage flow. It enhances the power efficiency of CompactFlash Card Controller by employing advanced circuit regulator technology. 1.1.2 RAM The controller is implemented with RAM as a data process to optimize data transfer between the host and the flash media. 1.1.3 Error Correction Code (ECC) The CompactFlash card is programmed with BCH Error Detection Code (EDC) and Error Correction Code (ECC) algorithms capable of correcting up to 72 random bits in 1KB bytes data. High performance is achieved through hardware-based error detection and correction. 1.2 Intelligent Endurance Design 1.2.1 Wear-leveling algorithms Flash memory devices differ from Hard Disk Drives (HDDs) in terms of how blocks are utilized. For HDDs, when a change is made to stored data, like erase or update, the controller mechanism on HDDs will perform overwrites on blocks. Unlike HDDs, flash blocks cannot be overwritten and each P/E cycle wears down the lifespan of blocks gradually. Repeatedly program/erase cycles performed on the same memory cells will eventually cause some blocks to age faster than others. This would bring flash storages to their end of service term sooner. Wear leveling is an important mechanism that level out the wearing of blocks so that the wearing-down of blocks can be almost evenly distributed. This will increase the lifespan of SSDs. Commonly used wear leveling types are Static and Dynamic. 3 © 2013 Apacer Technology Inc. Rev. 1.0 Compact Flash 6 series AP-CFxxxxLAXS-XXXXXX 1.2.2 S.M.A.R.T. Technology S.M.A.R.T. is an acronym for Self-Monitoring, Analysis and Reporting Technology, an open standard allowing disk drives to automatically monitor their own health and report potential problems. It protects the user from unscheduled downtime by monitoring and storing critical drive performance and calibration parameters. Ideally, this should allow taking proactive actions to prevent impending drive failure. Apacer SMART feature adopts the standard SMART command B0h to read data from the drive. When the Apacer SMART Utility running on the host, it analyzes and reports the disk status to the host before the device is in critical condition. 1.2.3 Flash Block Management Current production technology is unable to guarantee total reliability of NAND flash memory array. When a flash memory device leaves factory, it comes with a minimal number of initial bad blocks during production or out-of-factory as there is no currently known technology that produce flash chips free of bad blocks. In addition, bad blocks may develop during program/erase cycles. When host performs program/erase command on a block, bad block may appear in Status Register. Since bad blocks are inevitable, the solution is to keep them in control. Apacer flash devices are programmed with ECC, block mapping technique and S.M.A.R.T to reduce invalidity or error. Once bad blocks are detected, data in those blocks will be transferred to free blocks and error will be corrected by designated algorithms. 1.2.4 Power Failure Management Power Failure Management plays a crucial role when experiencing unstable power supply. Power disruption may occur when users are storing data into the SSD. In this urgent situation, the controller would run multiple write-to-flash cycles to store the metadata for later block rebuilding. This urgent operation requires about several milliseconds to get it done. At the next power up, the firmware will perform a status tracking to retrieve the mapping table and resume previously programmed NAND blocks to check if there is any incompleteness of transmission. 4 © 2013 Apacer Technology Inc. Rev. 1.0 Compact Flash 6 series AP-CFxxxxLAXS-XXXXXX 2. Functional Block The CompactFlash Card (CFC) includes a controller and flash media, as well as the CompactFlash standard interface. Figure 2-1 shows the functional block diagram. Figure 2-1: Functional block diagram 5 © 2013 Apacer Technology Inc. Rev. 1.0 Compact Flash 6 series AP-CFxxxxLAXS-XXXXXX 3. Pin Assignments Table 3-1 lists the pin assignments with respective signal names for the 50-pin configuration. A “#” suffix indicates the active low signal. The pin type can be input, output or input/output. Table 3-1: Pin assignments (1 of 2) Pin No. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 Memory card mode Signal name GND D3 D4 D5 D6 D7 #CE1 A10 #OE A9 A8 A7 VCC A6 A5 A4 A3 A2 A1 A0 D0 D1 D2 WP #CD2 #CD1 D11 D12 D13 D14 D15 #CE2 #VS1 #IORD #IOWR #WE RDY/-BSY VCC #CSEL #VS2 RESET Pin I/O type I/O I/O I/O I/O I/O I I I I I I I I I I I I I I/O I/O I/O O O O I/O I/O I/O I/O I/O I O I I I O I O I I/O card mode Signal name GND D3 D4 D5 D6 D7 #CE1 A10 #OE A9 A8 A7 VCC A6 A5 A4 A3 A2 A1 A0 D0 D1 D2 #IOIS16 #CD2 #CD1 D11 D12 D13 D14 D15 #CE2 #VS1 #IORD #IOWR #WE #IREQ VCC #CSEL #VS2 RESET Pin I/O type I/O I/O I/O I/O I/O I I I I I I I I I I I I I I/O I/O I/O O O O I/O I/O I/O I/O I/O I O I I I O I O I True IDE mode Signal name GND D3 D4 D5 D6 D7 #CS0 1 A10 #ATA SEL 1 A9 1 A8 1 A7 VCC 1 A6 1 A5 1 A4 1 A3 A2 A1 A0 D0 D1 D2 #IOCS16 #CD2 #CD1 D11 D12 D13 D14 D15 #CS1 #VS1 #IORD #IOWR #WE INTRQ VCC #CSEL #VS2 #RESET Pin I/O type I/O I/O I/O I/O I/O I I I I I I I I I I I I I I/O I/O I/O O O O I/O I/O I/O I/O I/O I O I I I O I O I 6 © 2013 Apacer Technology Inc. Rev. 1.0 Compact Flash 6 series AP-CFxxxxLAXS-XXXXXX Table 3-1: Pin assignments (2 of 2) Pin No. 42 43 44 45 46 47 48 49 50 1. 2. Memory card mode Signal name #WAIT #INPACK #REG BVD2 BVD1 D8 D9 D10 GND Pin I/O type O O I O O I/O I/O I/O - I/O card mode Signal name #WAIT #INPACK #REG #SPKR #STSCHG D8 D9 D10 GND Pin I/O type O O I O O I/O I/O I/O - True IDE mode Signal name IORDY 2 DMARQ 2 DMACK #DASP #PDIAG D8 D9 D10 GND Pin I/O type O O I I/O I/O I/O I/O I/O - The signal should be grounded by the host. Connection required when UDMA is in use. 7 © 2013 Apacer Technology Inc. Rev. 1.0 Compact Flash 6 series AP-CFxxxxLAXS-XXXXXX 4. Product Specifications 4.1 Capacity Default capacity specification of the Compact Flash Card series (CFC) is available as shown in Table 4-1. Table 4-1: Capacity specifications Capacity Total bytes Cylinders Heads Sectors Max LBA 8 GB 8,195,604,480 15,880 16 83 16,007,040 16 GB 16,391,340,032 16,383 16 63 32,014,336 32 GB 32,019,316,736 16,383 16 63 62,537,728 64 GB 64,030,244,864 16,383 16 63 125,059,072 128 GB 128,043,712,512 16,383 16 63 250,085,376 Display of total bytes varies from operating systems. Cylinders, heads or sectors are not applicable for these capacities. Only LBA addressing applies Notes: 1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 4.2 Performance Performances of the CF cards are listed in Table 4-2 Table 4-2: Performance specifications Capacity 8 GB 16 GB 32 GB 64 GB 128 GB Sustained read (MB/s) 110 105 110 110 110 Sustained write (MB/s) 24 23 34 55 60 Performance Notes: performance may vary depending on flash configurations or host system settings. 4.3 Environmental Specifications Environmental specification of the Compact Flash Card series (CFC) follows the MIL-STD-810F. Table 4-3: Environmental specifications Environment Temperature Specification Operation 0°C to 70°C; -40°C to 85°C (Extended Temperature) Storage -40°C to 100°C Humidity 5% to 95% RH (Non-condensing) Vibration (Non-Operating) Sine wave : 10~2000Hz, 15G (X, Y, Z axes) Shock (Non-Operating) Half sine wave 1,500G (X, Y, Z ; All 6 axes) 8 © 2013 Apacer Technology Inc. Rev. 1.0 Compact Flash 6 series AP-CFxxxxLAXS-XXXXXX 4.4 Certification & Compliance The CompactFlash card complies with the following global standards:      CE FCC Halogen-free EMC RoHS Recast (2011/65/EU) 9 © 2013 Apacer Technology Inc. Rev. 1.0 Compact Flash 6 series AP-CFxxxxLAXS-XXXXXX 5. Software Interface 5.1 CF-ATA Command Set Table 5-1 summarizes the CF-ATA command set with the paragraphs that follow describing the individual commands and the task file for each. Table 5-1: CFC-ATA command set Command Set Command CFA Feature Set General Feature Set Code Protocol Request Sense 03h Non-data Write Sectors Without Erase 38h PIO data-out Erase Sectors C0h Non-data Write Multiple Without Erase CDh PIO data-out Translate Sector 87h PIO data-in Set Features Enable/Disable 8-bit Transfer EFh Non-data Execute Drive Diagnostic 90h Device diagnostic Flush Cache E7h Non-data Identify Device ECh PIO data-in Read DMA C8h DMA Read Multiple C4h PIO data-in Read Sector(s) 20h or 21h PIO data-in Read Verify Sector(s) 40h or 41h Non-data Set Feature EFh Non-data Set Multiple Mode C6h Non-data Write DMA CAh DMA Write Multiple C5h PIO data-out 30h or 31h PIO data-out NOP 00h Non-data Read Buffer E4h PIO data-in Write Buffer E8h PIO data-out Set Feature EFh Non-data Check Power Mode E5h or 98h Non-data Idle E3h or 97h Non-data Idle Immediate E1h or 95h Non-data Sleep E6h or 99h Non-data Standby E2h or 96h Non-data Standby Immediate E0h or 94h Non-data Write Sector(s) Power Management Feature Set 10 © 2013 Apacer Technology Inc. Rev. 1.0 Compact Flash 6 series AP-CFxxxxLAXS-XXXXXX Security Mode Feature Set SMART Feature Set Host Protected Area Feature Set Others 48-bit Address Feature Set Security Set Password F1h PIO data-out Security Unlock F2h PIO data-out Security Erase Prepare F3h Non-data Security Erase Unit F4h PIO data-out Security Freeze Lock F5h Non-data Security Disable Password F6h PIO data-out SMART Disable Operations B0h Non-data SMART Enable/Disable Autosave B0h Non-data SMART Enable Operations B0h Non-data SMART Return Status B0h Non-data SMART Execute Off-line Immediate B0h Non-data SMART Read Data B0h PIO data-in Read Native Max Address F8h Non-data Set Max Address F9h Non-data Set Max Set Password F9h PIO data-out Set Max Lock F9h Non-data Set Max Freeze Lock F9h Non-data Set Max Unlock F9h PIO data-out Format Track 50h PIO data-out Initialize Drive Parameters 91h Non-data Recalibrate 1Xh Non-data Seek 7Xh Non-data Wear Level F5h Non-data Write Verify 3Ch PIO data-out Read Sector Ext 24h PIO data-in Read DMA Ext 25h DMA Read Multiple Ext 29h PIO data-in Write Sector Ext 34h PIO data-out Write DMA Ext 35h DMA Read Verify Sector Ext 42h Non-data Write Multiple FUA Ext CEh PIO data-out Flush Cache Ext EAh Non-data 11 © 2013 Apacer Technology Inc. Rev. 1.0 Compact Flash 6 series AP-CFxxxxLAXS-XXXXXX 6. Operating Conditions Table 6-1: Operating range Parameters Range Ambient temperature Extended temperature 0°C to 70°C -40°C to 85°C Supply voltage at 3.3V Supply voltage at 5V 3.135 ~ 3.465 V 4.75 ~ 5.25 V Table 6-2: Power consumption (typical) Capacity Mode 8 GB 16 GB 32 GB 64 GB 128 GB 250 245 245 250 265 1 1 1 1 1 Active (mA) Stand By (mA) Note: Power consumptions were measured at 5V power supply and may vary depending on settings and platforms 12 © 2013 Apacer Technology Inc. Rev. 1.0 Compact Flash 6 series AP-CFxxxxLAXS-XXXXXX 7. Physical Characteristics 7.1 Dimension FIGURE 7-1: Physical dimension Unit: mm 13 © 2013 Apacer Technology Inc. Rev. 1.0 Compact Flash 6 series AP-CFxxxxLAXS-XXXXXX 8. Product Ordering Information 8.1 Product Code Designations A P – CF x x x x L A X S – XXXXXX Specification RM: Removable NR: Non-Removable ET: Extended Temperature NDRM: Non-DMA + Removable NDNR: Non-DMA + Non-Removable ETRM: Ext. Temp. + Removable ETNR: Ext. Temp. + Non-Removable ETNDRM: Ext. Temp + Non-DMA + Removable ETNDNR: Ext. Temp + Non-DMA + Non-Removable Halogen Free Compliant Configuration : : E Single Channel F Dual Channel CTL Type CFC Type Capacities: 08G 016G 032G 064G 128G 8GB 16GB 32GB 64GB 128GB Model Name Apacer Product Code 14 © 2013 Apacer Technology Inc. Rev. 1.0 Compact Flash 6 series AP-CFxxxxLAXS-XXXXXX 8.2 Valid Combinations 8.2.1 Standard Temperature 8.2.1.1 Non-Removable Capacity AP/N 8GB AP-CF008GLAFS-NR 16GB AP-CF016GLAFS-NR 32GB AP-CF032GLAFS-NR 64GB AP-CF064GLAFS-NR 128GB AP-CF128GLAFS-NR 8.2.1.2 Removable Capacity AP/N 8GB AP-CF008GLAFS-RM 16GB AP-CF016GLAFS-RM 32GB AP-CF032GLAFS-RM 64GB AP-CF064GLAFS-RM 128GB AP-CF128GLAFS-RM 8.2.1.3 Non-DMA + Removable Capacity AP/N 8GB AP-CF008GLAFS-NDRM 16GB AP-CF016GLAFS-NDRM 32GB AP-CF032GLAFS-NDRM 64GB AP-CF064GLAFS-NDRM 128GB AP-CF128GLAFS-NDRM 8.2.1.4 Non-DMA + Non-Removable Capacity AP/N 8GB AP-CF008GLAFS-NDNR 16GB AP-CF016GLAFS-NDNR 32GB AP-CF032GLAFS-NDNR 64GB AP-CF064GLAFS-NDNR 128GB AP-CF128GLAFS-NDNR 15 © 2013 Apacer Technology Inc. Rev. 1.0 Compact Flash 6 series AP-CFxxxxLAXS-XXXXXX 8.2.2 Extended Temperature 8.2.2.1 Ext. Temp. + Non-Removable Capacity AP/N 8GB AP-CF008GLAFS-ETNR 16GB AP-CF016GLAFS-ETNR 32GB AP-CF032GLAFS-ETNR 64GB AP-CF064GLAFS-ETNR 128GB AP-CF128GLAFS-ETNR 8.2.2.2 Ext. Temp. + Removable Capacity AP/N 8GB AP-CF008GLAFS-ETRM 16GB AP-CF016GLAFS-ETRM 32GB AP-CF032GLAFS-ETRM 64GB AP-CF064GLAFS-ETRM 128GB AP-CF128GLAFS-ETRM 8.2.2.3 Non-DMA + Removable Capacity AP/N 8GB AP-CF008GLAFS-ETNDRM 16GB AP-CF016GLAFS-ETNDRM 32GB AP-CF032GLAFS-ETNDRM 64GB AP-CF064GLAFS-ETNDRM 128GB AP-CF064GLAFS-ETNDRM 8.2.2.4 Non-DMA + Non-Removable Capacity AP/N 8GB AP-CF008GLAFS-ETNDNR 16GB AP-CF016GLAFS-ETNDNR 32GB AP-CF032GLAFS-ETNDNR 64GB AP-CF064GLAFS-ETNDNR 128GB AP-CF128GLAFS-ETNDNR Note: Please consult with Apacer sales representatives for availabilities. 16 © 2013 Apacer Technology Inc. Rev. 1.0 Compact Flash 6 series AP-CFxxxxLAXS-XXXXXX Revision History Revision 1.0 Date Description Remark 01/30/2013 Official release 17 © 2013 Apacer Technology Inc. Rev. 1.0
AP-CF008GLAFS-NR 价格&库存
很抱歉,暂时无法提供与“AP-CF008GLAFS-NR”相匹配的价格&库存,您可以联系我们找货
AP-CF008GLAFS-NR
