Industrial SD card
Industrial SD card
ISD H1-M
Overview
Apacer Industrial Secure Digital 3.0 card is ideal for its high
performance, good reliability and wide compatibility. Not to
mention that it’s well adapted for hand-held applications in
semi-industrial/medical markets already. Apacer industrial SD
card H1-M series providing wide range capacities from 4GB to
128GB fully compliant to SD3.0, and SD2.0 specifications are
built with MLC NAND Flash and the latest firmware including
read disturb , wear Leveling & Bad Block Management
algorithms .Furthermore, by adapting very particular flash IC
and IC packaging configuration, this product also has an
optional industrial -45C to 85C extended temperature range
version.
Feature
‧Compliant with SD 3.0 Specification
‧ S.M.A.R.T supported
‧ Wear-Leveling and Block Management
‧ Support Class 10 with UHS-I
‧ Low Power Consumption
‧ Wide Temperature Support(Optional)
Specifications
Model
Industrial SD
Interface
SD3.0
NAND Flash Type
MLC
Capacity
SDHC:4GB~128GB
Sustained Read Performance (MB/sec)
Up to 43
Sustained Write Performance (MB/sec)
Up to 25
ECC Engine*
Built-in 42-bit per 1K bytes BCH ECC
Standard Operating Temperature ( °C )
-25 ~ + 85
Extended Operating Temperature ( °C )
-40 ~ + 85
Storage Temperature ( °C )
-40 ~ + 85
Shock
1,500G, 0.5ms
Vibration
20Hz~80Hz/1.52mm (frequency/displacement)
80Hz~2,000Hz/20G (frequency/accelerate)
Humidity
95%
Operating Voltage
3.3 V ± 5%
Active mode: 145 mA & Idle mode: 235 uA
Dimension (L x W x H )
24x32x2.1 (mm)
MTBF (hours)
>3,000,000
Features / Technology
S.M.A.R.T./Wide Temp.
Applications
Military/Cloud Computing/InVehicle/Gaming/HealthCare/Embedded System
Ordering Info
Model
Standard temp:
-25~85
Extended temp:
-40~85
4G
AP-ISD004GCA-1GTM
AP-ISD004GIA-1GTM
8G
AP-ISD008GCA-1GTM
AP-ISD008GIA-1GTM
16G
AP-ISD016GCA-1GTM
AP-ISD016GIA-1GTM
32G
AP-ISD032GCA-1GTM
AP-ISD032GIA-1GTM
64G
AP-ISD064GCA-1FTM
AP-ISD064GIA-1FTM
128G
AP-ISD128GCA-1FTM
AP-ISD128GIA-1FTM
Global Presence
Taiwan (Headquarters)
Apacer Technology Inc.
Tel: +886-2-2267-8000
Fax: +886-2-2267-2261
Europe
Apacer Technology B.V.
Tel: +31-40-267-0000
Fax: +31-40-290-0686
Japan
Apacer Technology Corp.
Tel: +81-3-5419-2668
Fax: +81-3-5419-0018
India
Apacer Technologies Pvt. Ltd.
Tel: +91-80-41529061~3
Fax: +91-80-41700215
U.S.A.
Apacer Memory America, Inc.
Tel: +1-408-518-8699
Fax: 1-510-249-9551
China
Apacer Electronic(Shanghai)
Co., Ltd.
Tel: +86-21-6228-9939
很抱歉,暂时无法提供与“AP-ISD064GCA-1FTM”相匹配的价格&库存,您可以联系我们找货
