AF128GSD3-WAAXX
AF128GSD3-WAAXX
    ATPELECTRONICS
    Memory Card microSDXC™ 128GB Class 10, UHS Class 1 MLC
AF128GSD3-WAAXX 数据手册
ATP Industrial Grade SD/SDHC/SDXC Targeted Product Portfolio, Engineered Specifically for Your Mission Critical Applications Key Features ATP Industrial Grade SD/SDHC/SDXC cards are designed for application in demanding industries, such as automotive, healthcare, and aviation, where critical data requires the highest level of reliability, durability, and data integrity. They are also suitable for removable application and small footprint mechanism devices. ATP SD cards with read disturb protector-AutoRefresh technology and Autoscan features are best suited for read intensive applications. For instance in the automotive industry, ATP SD cards have been recognized by worldwide major tier 1 Auto Infotainment Suppliers and tier 2 telematics electronic vehicle system developers/service providers for their map system, IVI (in-vehicle-infotainment), and OS boot-up. On the other hand, ATP SD cards with SLC mode and Power cycling solution are ideal for write intensive applications. Such applications include data logging and storage of hospital medical devices and surveillance systems. • SLC (Single-Level-Cell) NAND flash and MLC (Multi-Level Cell / 2-bit per Cell) NAND Flash • Advanced Wear Leveling algorithm • Bad Block Management • Read Disturb Protector - AutoRefresh to ensure data integrity during read operation • IP67 waterproof/Dustproof test (IEC 60529) • Highly reliable and pass environmental test (Bend/Torque/Salt Spray/Solar radiation) • ESD resistance • Life Monitor (Note : The compatibility and support of Life Monitor may vary on different platform/operation system) Applications • Industrial PC • Medical devices • Automation • Automotive IVI systems • Test and Measurement • Surveillance systems • Drive recorders • Navigations • Network cameras • Mobile/Handheld computers Moreover, with ATP's SIP (System-In-Packaging) manufacturing process, the operating/ storage temperature of ATP Industrial Grade SD cards is -40 to 85 degrees Celsius. All ATP Industrial Grade products go through multi data pattern burn in test. This is to screen for early fallout occasionally seen in any semiconductor technology. SHOCK RESISTANCE E.S.D. RESISTANCE DUST PROOF Specifications Product Name SD/SDHC/SDXC Flash Type SLC MLC Density 512MB to 32GB 8GB to 128GB Performance Sequential Read up to 20MB/s Sequential Read up to 87.2MB/s Sequential Write up to 18MB/s Sequential Write up to 58.9MB/s Interface SD2.0 SD3.0 UHS Mode Operation Temperature -40°C to +85°C -25°C to +85°C Advanced Static/Dynamic Wear-Leveling Reliability TBW**(max.): 384TB TBW**(max.): 38.4TB MTBF@25°C:>5,000,000 hours MTBF@25°C:>2,000,000 hours Number of Insertions: 10,000 minimum Dimensions: LxWxH (mm) 32.0 x 24.0 x 2.1 ** All TBW data listed are under highest random write value in each product line. The TBW data are subject to change by density, configuration and customers’ applications. Ordering Information Density SD / SDHC (SLC) SDHC / SDXC (MLC) 512MB AF512SDI-5ACXX - 1GB AF1GSDI-5ACXX - 2GB AF2GSDI-5ADXX - 4GB AF4GSDI-5ACXX - 8GB AF8GSDI-5ACXX AF8GSD3-WABXX 16GB AF16GSDI-5ABXX AF16GSD3-WABXX AF16GSD3-WACXX* 32GB AF32GSDI-5AAXX AF32GSD3-WABXX 64GB - AF64GSD3-WACXX* 128GB - AF128GSD3-WAAXX* * New product, contact ATP sales ATP TAIWAN(HQ) ATP USA ATP EUROPE ATP JAPAN ATP CHINA TEL: +886-2-2659-6368 FAX: +886-2-2659-4982 sales-apac@atpinc.com TEL: +1-408-732-5000 FAX: +1-408-732-5055 sales@atpinc.com TEL: +49-89-374-9999-0 FAX: +49-89-374-9999-29 sales-europe@atpinc.com TEL: +81-3-6206-8097 FAX: +81-3-6206-8098 sales-japan@atpinc.com TEL: +86-21-5080-2220 FAX: +86-21-5080-2219 sales@cn.atpinc.com
AF128GSD3-WAAXX 价格&库存
很抱歉,暂时无法提供与“AF128GSD3-WAAXX”相匹配的价格&库存,您可以联系我们找货
