APCFA016GACAN-AT
APCFA016GACAN-AT
    APACERMEMORYAMERICA(宇瞻科技)
    MEMORY CARD CFAST 16GB SLC
APCFA016GACAN-AT 数据手册
CFast 2 CFast 2 Overview Since CompactFlash Association released the specification of CFast 2.0, Apacer takes the lead to roll out the first industrialgrade SATA 3.0 (6Gb/s) high-speed transmission interface CFast 2.0 memory card around the globe. Its sequential speed is up to 285/260 MB/sec and dimensions is 42.8mm x 36.4mm x 3.6mm with (7+17) pin connector. Besides featuring a 2-Channel bidirectional structure, the CFast 2.0 adopts Toggle DDR 2.0 NAND Flash, which brings its performance to a higher level. Support for DEVSLP (Device Sleep) power mode enables them to switch into a low power state on standby mode so as to save power for companies. Feature ‧ Compliant with CFast 2.0 specifications ‧ Built-in ATA Secure Erase and S.M.A.R.T. Functions ‧ Advanced wear-leveling and Block Management ‧ Intelligent Power Failure Recovery ‧ DEVSLP Support (Optional) ‧ HW Write-Protect Switch (Optional) Specifications Model CFast 2 Interface SATA 3.0 (6Gb/s) Connector (7+17) pin male Form Factor NAND Flash Type Capacity External DRAM CFast 3.0 SLC 4GB~64GB NA Sustained Read Performance (MB/sec) Up to 285 Sustained Write Performance (MB/sec) Up to 260 ECC Engine Built-in 40-bit per 1K bytes BCH ECC Standard Operating Temperature ( °C ) 0 ~ + 70 Extended Operating Temperature ( °C ) -40 ~ + 85 Storage Temperature ( °C ) -40 ~ + 100 Shock Vibration Operating Voltage Power Consumption Dimension (L x W x H ) MTBF (hours) Operating Shock: 50G, 11ms Non-operating Shock: 1500G, 0.5ms) Operating Vibration: 7.69 Grms, 20~2000 Hz/random (compliant with MIL-STD-810G) Non-operating Vibration: 15 Grms, 10~2000 Hz/sine (compliant with MIL-STD-810G) 3.3 V ± 5% Active mode: 500 mA & Idle mode: 90 mA 42.8 x 36.4 x 3.6 (mm) >2,000,000 Mechanical Specification Unit: mm For more information, contact your Apacer representative Global Presence Taiwan (Headquarters) Apacer Technology Inc. Tel: +886-2-2267-8000 Fax: +886-2-2267-2261 Europe Apacer Technology B.V. Tel: +31-40-267-0000 Fax: +31-40-290-0686 Japan Apacer Technology Corp. Tel: +81-3-5419-2668 Fax: +81-3-5419-0018 India Apacer Technologies Pvt. Ltd. Tel: +91-80-41529061~3 Fax: +91-80-41700215 U.S.A. Apacer Memory America, Inc. Tel: +1-408-518-8699 Fax: 1-510-249-9551 China Apacer Electronic(Shanghai) Co., Ltd. Tel: +86-21-6228-9939 DOC:20161130
APCFA016GACAN-AT 价格&库存
很抱歉,暂时无法提供与“APCFA016GACAN-AT”相匹配的价格&库存,您可以联系我们找货
