CFast 2H
CFast 2H
Overview
CFast 2H is the latest enhancement of conventional Cfast form
factor that delivers various technological advantages. This new
flash memory card comes with SATA 6.0 Gbps interface for
higher performance and is compliant with standard Cfast
specifications. Cfast 2H consists of SATA-based 7-pin signal
segment and 17-pin for power and control purposes. It can offer
moderate capacity and decent data transfer performance. For
power efficiency, this new flash memory card leverages the
technological benefits of SATA Revision 3.0 specifications. For
data integrity, the Cfast card is built with ECC engine correcting
up to 72-bit. Together with its small form factor nature, Apacer
Cfast 2H is definitely the ideal solution for applications in
industrial computing systems, mobile computers and video
processing instruments.
Feature
‧ SATA 6.0 Gbps interface speed
‧ Built-in hardware ECC and S.M.A.R.T. Functions
‧ Static/dynamic wear-leveling and Block Management
‧ Power Failure Management
‧ DEVSLP Support
Specifications
Model
CFast 2H
Interface
SATA 3.0 (6Gb/s)
Connector
(7+17) pin male
Form Factor
CFast 3.0
Operation Mode
NULL
Transfer Mode
NULL
NAND Flash Type
Capacity
External DRAM
SLC
2GB~64GB
NA
Sustained Read Performance (MB/sec)
Up to 515
Sustained Write Performance (MB/sec)
Up to 145
ECC Engine
Built-in 72-bit per 1K bytes BCH ECC
Standard Operating Temperature ( °C )
0 ~ + 70
Extended Operating Temperature ( °C )
-40 ~ + 85
Storage Temperature ( °C )
-40 ~ + 85
Shock
Vibration
Operating Voltage
Power Consumption
Dimension (L x W x H )
MTBF (hours)
Operating Shock: 50G, 11ms
Non-operating Shock: 1500G, 0.5ms)
Operating Vibration: 7.69 Grms, 20~2000 Hz/random
(compliant with MIL-STD-810G)
Non-operating Vibration: 15 Grms, 10~2000 Hz/sine
3.3 V ± 5%
Active mode: 540 mA & Idle mode: 85 mA
42.8 x 36.4 x 3.6 (mm)
>2,000,000
Mechanical Specification
Unit: mm
For more information, contact your Apacer representative
Global Presence
Taiwan (Headquarters)
Apacer Technology Inc.
Tel: +886-2-2267-8000
Fax: +886-2-2267-2261
Europe
Apacer Technology B.V.
Tel: +31-40-267-0000
Fax: +31-40-290-0686
Japan
Apacer Technology Corp.
Tel: +81-3-5419-2668
Fax: +81-3-5419-0018
India
Apacer Technologies Pvt. Ltd.
Tel: +91-80-41529061~3
Fax: +91-80-41700215
U.S.A.
Apacer Memory America, Inc.
Tel: +1-408-518-8699
Fax: 1-510-249-9551
China
Apacer Electronic(Shanghai)
Co., Ltd.
Tel: +86-21-6228-9939
DOC:20161129
很抱歉,暂时无法提供与“APCFA016GBAD-BT”相匹配的价格&库存,您可以联系我们找货
