APCFA032GBAD-BT
APCFA032GBAD-BT
    APACERMEMORYAMERICA(宇瞻科技)
    MEMORY CARD CFAST 32GB SLC
APCFA032GBAD-BT 数据手册
CFast 2H CFast 2H Overview CFast 2H is the latest enhancement of conventional Cfast form factor that delivers various technological advantages. This new flash memory card comes with SATA 6.0 Gbps interface for higher performance and is compliant with standard Cfast specifications. Cfast 2H consists of SATA-based 7-pin signal segment and 17-pin for power and control purposes. It can offer moderate capacity and decent data transfer performance. For power efficiency, this new flash memory card leverages the technological benefits of SATA Revision 3.0 specifications. For data integrity, the Cfast card is built with ECC engine correcting up to 72-bit. Together with its small form factor nature, Apacer Cfast 2H is definitely the ideal solution for applications in industrial computing systems, mobile computers and video processing instruments. Feature ‧ SATA 6.0 Gbps interface speed ‧ Built-in hardware ECC and S.M.A.R.T. Functions ‧ Static/dynamic wear-leveling and Block Management ‧ Power Failure Management ‧ DEVSLP Support Specifications Model CFast 2H Interface SATA 3.0 (6Gb/s) Connector (7+17) pin male Form Factor CFast 3.0 Operation Mode NULL Transfer Mode NULL NAND Flash Type Capacity External DRAM SLC 2GB~64GB NA Sustained Read Performance (MB/sec) Up to 515 Sustained Write Performance (MB/sec) Up to 145 ECC Engine Built-in 72-bit per 1K bytes BCH ECC Standard Operating Temperature ( °C ) 0 ~ + 70 Extended Operating Temperature ( °C ) -40 ~ + 85 Storage Temperature ( °C ) -40 ~ + 85 Shock Vibration Operating Voltage Power Consumption Dimension (L x W x H ) MTBF (hours) Operating Shock: 50G, 11ms Non-operating Shock: 1500G, 0.5ms) Operating Vibration: 7.69 Grms, 20~2000 Hz/random (compliant with MIL-STD-810G) Non-operating Vibration: 15 Grms, 10~2000 Hz/sine (compliant with MIL-STD-810G) 3.3 V ± 5% Active mode: 540 mA & Idle mode: 85 mA 42.8 x 36.4 x 3.6 (mm) >2,000,000 Mechanical Specification Unit: mm For more information, contact your Apacer representative Global Presence Taiwan (Headquarters) Apacer Technology Inc. Tel: +886-2-2267-8000 Fax: +886-2-2267-2261 Europe Apacer Technology B.V. Tel: +31-40-267-0000 Fax: +31-40-290-0686 Japan Apacer Technology Corp. Tel: +81-3-5419-2668 Fax: +81-3-5419-0018 India Apacer Technologies Pvt. Ltd. Tel: +91-80-41529061~3 Fax: +91-80-41700215 U.S.A. Apacer Memory America, Inc. Tel: +1-408-518-8699 Fax: 1-510-249-9551 China Apacer Electronic(Shanghai) Co., Ltd. Tel: +86-21-6228-9939 DOC:20161129
APCFA032GBAD-BT 价格&库存
很抱歉,暂时无法提供与“APCFA032GBAD-BT”相匹配的价格&库存,您可以联系我们找货
