AP-ISD016GIA-1ATM
AP-ISD016GIA-1ATM
    APACERMEMORYAMERICA(宇瞻科技)
    MEM CARD SDHC 16GB CLASS 6 MLC
AP-ISD016GIA-1ATM 数据手册
Industrial SD card Industrial SD card ISD H1-M Overview Apacer Industrial Secure Digital 3.0 card is ideal for its high performance, good reliability and wide compatibility. Not to mention that it’s well adapted for hand-held applications in semi-industrial/medical markets already. Apacer industrial SD card H1-M series providing wide range capacities from 4GB to 128GB fully compliant to SD3.0, and SD2.0 specifications are built with MLC NAND Flash and the latest firmware including read disturb , wear Leveling & Bad Block Management algorithms .Furthermore, by adapting very particular flash IC and IC packaging configuration, this product also has an optional industrial -45C to 85C extended temperature range version. Feature ‧Compliant with SD 3.0 Specification ‧ S.M.A.R.T supported ‧ Wear-Leveling and Block Management ‧ Support Class 10 with UHS-I ‧ Low Power Consumption ‧ Wide Temperature Support(Optional) Specifications Model Industrial SD Interface SD3.0 NAND Flash Type MLC Capacity SDHC:4GB~128GB Sustained Read Performance (MB/sec) Up to 43 Sustained Write Performance (MB/sec) Up to 25 ECC Engine* Built-in 42-bit per 1K bytes BCH ECC Standard Operating Temperature ( °C ) -25 ~ + 85 Extended Operating Temperature ( °C ) -40 ~ + 85 Storage Temperature ( °C ) -40 ~ + 85 Shock 1,500G, 0.5ms Vibration 20Hz~80Hz/1.52mm (frequency/displacement) 80Hz~2,000Hz/20G (frequency/accelerate) Humidity 95% Operating Voltage 3.3 V ± 5% Low Power Consumption Active mode: 145 mA & Idle mode: 235 uA Dimension (L x W x H ) 24x32x2.1 (mm) MTBF (hours) >3,000,000 Features / Technology S.M.A.R.T./Wide Temp. Applications Military/Cloud Computing/InVehicle/Gaming/HealthCare/Embedded System Ordering Info Model Standard temp: -25~85 Extended temp: -40~85 4G AP-ISD004GCA-1GTM AP-ISD004GIA-1GTM 8G AP-ISD008GCA-1GTM AP-ISD008GIA-1GTM 16G AP-ISD016GCA-1GTM AP-ISD016GIA-1GTM 32G AP-ISD032GCA-1GTM AP-ISD032GIA-1GTM 64G AP-ISD064GCA-1FTM AP-ISD064GIA-1FTM 128G AP-ISD128GCA-1FTM AP-ISD128GIA-1FTM Global Presence Taiwan (Headquarters) Apacer Technology Inc. Tel: +886-2-2267-8000 Fax: +886-2-2267-2261 Europe Apacer Technology B.V. Tel: +31-40-267-0000 Fax: +31-40-290-0686 Japan Apacer Technology Corp. Tel: +81-3-5419-2668 Fax: +81-3-5419-0018 India Apacer Technologies Pvt. Ltd. Tel: +91-80-41529061~3 Fax: +91-80-41700215 U.S.A. Apacer Memory America, Inc. Tel: +1-408-518-8699 Fax: 1-510-249-9551 China Apacer Electronic(Shanghai) Co., Ltd. Tel: +86-21-6228-9939
AP-ISD016GIA-1ATM 价格&库存
很抱歉,暂时无法提供与“AP-ISD016GIA-1ATM”相匹配的价格&库存,您可以联系我们找货
