AP-CF016GR9FS-ETNR
AP-CF016GR9FS-ETNR
    APACERMEMORYAMERICA(宇瞻科技)
    MEMORY CARD FLASH CARD 16GB SLC
AP-CF016GR9FS-ETNR 数据手册
Halogen-free CompactFlash Series 5 Specifications for Industrial CompactFlash Card August 7th, 2013 Version 1.2 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 Compact Flash 5 series AP-CFxxxxRXXS-XXXXXXA Features:  CompactFlash Association Specification Revision 4.1 Standard Interface – 512 bytes per sector – ATA command set compatible – ATA transfer mode supports: PIO Mode 6 Multiword DMA Mode 4 Ultra DMA Mode 5 PCMCIA UDMA Mode 5  –  – –  Temperature ranges 0°C to 70°C for operation (Standard) -40°C to 85°C for operation (Extended) -40°C to 100°C for storage – – Operating voltage 3.3 V 5.0 V – – Power consumption (typical)** Active mode: 175 mA Standby mode: 3 mA – Connector Type 50 pins female – Physical Dimensions 36.4mm x 42.8mm x 3.3mm – – – – – – – – – – Endurance (TBW: Terabytes Written) 128 MB: 0.5 TBW 256 MB: 1.1 TBW 512 MB: 2.3 TBW 1 GB: 4.5 TBW 2 GB: 9.1 TBW 4 GB: 18.2 TBW 8 GB: 36.5 TBW 16 GB: 73.0 TBW 32 GB: 146.0 TBW 64 GB: 292.1 TBW   Capacities 128, 256, 512 MB 1, 2, 4, 8, 16, 32, 64 GB  Performance Sustained read: Up to 55 MB/sec Sustained write: Up to 42 MB/sec  Intelligent ATA/IDE module Wear-leveling algorithms to substantially increase longevity of flash media – Built-in BCH ECC capable of correcting up to 24 bits in 1,024 byte data – Flash block management – Power failure management – Supports S.M.A.R.T commands  –  – – –  NAND Flash Type: SLC  Halogen free *Performance and power consumption may vary depending on host system configurations. 1 © 2013 Apacer Technology Inc. Rev. 1.2 Compact Flash 5 series AP-CFxxxxRXXS-XXXXXXA Table of Contents 1. GENERAL DESCRIPTION .................................................................................................... 3 1.1 INTELLIGENT COMPACTFLASH MODULE .............................................................................................................3 1.1.1 Wear-leveling algorithms .............................................................................................................................3 1.1.2 S.M.A.R.T. Technology .................................................................................................................................3 1.1.3 Built-in Hardware ECC ................................................................................................................................3 1.1.4 Flash Block Management .............................................................................................................................3 1.1.5 Power Failure Management .........................................................................................................................4 2. FUNCTIONAL BLOCK .......................................................................................................... 4 3. PIN ASSIGNMENTS ............................................................................................................... 5 4. PRODUCT SPECIFICATION ................................................................................................ 7 4.1 CAPACITY .............................................................................................................................................................7 4.2 PERFORMANCE .....................................................................................................................................................7 4.3 ENVIRONMENTAL SPECIFICATIONS .......................................................................................................................8 4.4 CERTIFICATION & COMPLIANCE ...........................................................................................................................8 4.5 ENDURANCE ........................................................................................................................................................8 5. SOFTWARE INTERFACE .................................................................................................... 9 5.1 CF-ATA COMMAND SET ......................................................................................................................................9 6. ELECTRICAL SPECIFICATION ...................................................................................... 10 7. PHYSICAL CHARACTERISTICS ..................................................................................... 11 7.1 DIMENSION .........................................................................................................................................................11 8. PRODUCT ORDERING INFORMATION ........................................................................ 12 8.1 PRODUCT CODE DESIGNATIONS .........................................................................................................................12 8.2 VALID COMBINATIONS .......................................................................................................................................13 2 © 2013 Apacer Technology Inc. Rev. 1.2 Compact Flash 5 series AP-CFxxxxRXXS-XXXXXXA 1. General Description Apacer’s value-added Industrial CompactFlash Card offers high performance, high reliability and powerefficient storage. Regarding standard compliance, this CompactFlash Card complies with CompactFlash specification revision 4.1, supporting transfer modes up to Programmed Input Output (PIO) Mode 6, Multiword Direct Memory Access (DMA) Mode 4, Ultra DMA Mode 5, and PCMCIA Ultra DMA Mode 5. Apacer’s value-added CFC provides complete PCMCIA – ATA functionality and compatibility. Apacer ‘s CompactFlash technology is designed for applications in Point of Sale (POS) terminals, telecom, IP-STB, medical instruments, surveillance systems, industrial PCs and handheld applications such as the new generation of Digital Single Lens Reflex (DSLR) cameras. 1.1 Intelligent CompactFlash Module 1.1.1 Wear-leveling algorithms Flash memory devices differ from Hard Disk Drives (HDDs) in terms of how blocks are utilized. For HDDs, when a change is made to stored data, like erase or update, the controller mechanism on HDDs will perform overwrites on blocks. On the other hand, NAND flash storage adopts flash as their primary media. Unlike HDDs, flash blocks cannot be overwritten and each P/E cycle wears down the lifespan of blocks gradually. Repeatedly program/erase cycles performed on the same memory cells will eventually cause some blocks to age faster than others. This would bring flash storages to their end of service term earlier. Wear leveling is an important mechanism that level out the wearing of blocks so that the wearing-down of blocks can be almost evenly distributed. This will increase the lifespan of SSDs. Commonly used wear leveling types are Static and Dynamic. 1.1.2 S.M.A.R.T. Technology S.M.A.R.T. is an acronym for Self-Monitoring, Analysis and Reporting Technology, an open standard allowing disk drives to automatically monitor their own health and report potential problems. It protects the user from unscheduled downtime by monitoring and storing critical drive performance and calibration parameters. Ideally, this should allow taking proactive actions to prevent impending drive failure. Apacer SMART feature adopts the standard SMART command B0h to read data from the drive. When the Apacer SMART Utility running on the host, it analyzes and reports the disk status to the host before the device is in critical condition. 1.1.3 Built-in Hardware ECC This CompactFlash card employs BCH Error Correction Code (ECC) algorithms. This on-chip hardware BCH-ECC engines is 13/24 bit programmed that can correct up to 24-bit errors per 1,024 byte data. This built-in hardware ECC performs parity generation and error detection/correction for data integrity. 1.1.4 Flash Block Management Contemporary process technology is unable to guarantee total reliability of NAND flash memory array. When a flash memory device leaves factory, it comes with a highly minimal number of initial bad block during production or out-of-factory as there is no currently known technology that produce flash chips free of bad blocks. On the other hand, bad blocks may develop during program/erase cycles. When host performs program/erase command on a block, bad block may appear in Status Register. Since bad blocks are inevitable, the solution is to keep them in control. Apacer flash devices are programmed with ECC, block mapping technique and S.M.A.R.T to reduce invalidity or error. Once bad blocks are detected, data in those blocks will be transferred to free blocks and error will be corrected by designated algorithms. 3 © 2013 Apacer Technology Inc. Rev. 1.2 Compact Flash 5 series AP-CFxxxxRXXS-XXXXXXA 1.1.5 Power Failure Management Power Failure Management plays a crucial role when experiencing unstable power supply. Power disruption may occur when users are storing data into the SSD. In this urgent situation, the controller would run multiple write-to-flash cycles to store the metadata for later block rebuilding. This urgent operation requires about several milliseconds to get it done. At the next power up, the firmware will perform a status tracking to retrieve the mapping table and resume previously programmed NAND blocks to check if there is any incompleteness of transmission 2. Functional Block The CompactFlash Card (CFC) includes a controller and flash media, as well as the CompactFlash standard interface. Figure 2-1 shows the functional block diagram. Figure 2-1: Functional block diagram 4 © 2013 Apacer Technology Inc. Rev. 1.2 Compact Flash 5 series AP-CFxxxxRXXS-XXXXXXA 3. Pin Assignments Table 3-1 lists the pin assignments with respective signal names for the 50-pin configuration. A “#” suffix indicates the active low signal. The pin type can be input, output or input/output. Table 3-1: Pin assignments (1 of 2) Pin No. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 Memory card mode Signal name GND D3 D4 D5 D6 D7 #CE1 A10 #OE A9 A8 A7 VCC A6 A5 A4 A3 A2 A1 A0 D0 D1 D2 WP #CD2 #CD1 D11 D12 D13 D14 D15 #CE2 #VS1 #IORD #IOWR #WE RDY/-BSY VCC #CSEL #VS2 RESET Pin I/O type I/O I/O I/O I/O I/O I I I I I I I I I I I I I I/O I/O I/O O O O I/O I/O I/O I/O I/O I O I I I O I O I I/O card mode Signal name GND D3 D4 D5 D6 D7 #CE1 A10 #OE A9 A8 A7 VCC A6 A5 A4 A3 A2 A1 A0 D0 D1 D2 #IOIS16 #CD2 #CD1 D11 D12 D13 D14 D15 #CE2 #VS1 #IORD #IOWR #WE #IREQ VCC #CSEL #VS2 RESET Pin I/O type I/O I/O I/O I/O I/O I I I I I I I I I I I I I I/O I/O I/O O O O I/O I/O I/O I/O I/O I O I I I O I O I True IDE mode Signal name GND D3 D4 D5 D6 D7 #CS0 1 A10 #ATA SEL 1 A9 1 A8 1 A7 VCC 1 A6 1 A5 1 A4 1 A3 A2 A1 A0 D0 D1 D2 #IOCS16 #CD2 #CD1 D11 D12 D13 D14 D15 #CS1 #VS1 #IORD #IOWR #WE INTRQ VCC #CSEL #VS2 #RESET Pin I/O type I/O I/O I/O I/O I/O I I I I I I I I I I I I I I/O I/O I/O O O O I/O I/O I/O I/O I/O I O I I I O I O I 5 © 2013 Apacer Technology Inc. Rev. 1.2 Compact Flash 5 series AP-CFxxxxRXXS-XXXXXXA Table 3-1: Pin assignments (2 of 2) Pin No. 42 43 44 45 46 47 48 49 50 1. 2. Memory card mode Signal name #WAIT #INPACK #REG BVD2 BVD1 D8 D9 D10 GND Pin I/O type O O I O O I/O I/O I/O - I/O card mode Signal name #WAIT #INPACK #REG #SPKR #STSCHG D8 D9 D10 GND Pin I/O type O O I O O I/O I/O I/O - True IDE mode Signal name IORDY 2 DMARQ 2 DMACK #DASP #PDIAG D8 D9 D10 GND Pin I/O type O O I I/O I/O I/O I/O I/O - The signal should be grounded by the host. Connection required when UDMA is in use. 6 © 2013 Apacer Technology Inc. Rev. 1.2 Compact Flash 5 series AP-CFxxxxRXXS-XXXXXXA 4. Product Specification 4.1 Capacity Capacity specification of the Compact Flash Card series (CFC) is available as shown in Table 4-1. It lists the specific capacity and the default numbers of heads, sectors and cylinders for each product line. Table 4-1: Capacity specifications Capacity Total bytes 128 MB 1 Cylinders Heads Sectors Max LBA 128,450,560 980 8 32 250,880 256 MB 256,901,120 980 16 32 501,760 512 MB 512,483,328 993 16 63 1,000,944 1GB 1,024,966,656 1,986 16 63 2,001,888 2GB 2,048,901,120 3,970 16 63 4,001,760 4GB 4,110,188,544 7,964 16 63 8,027,712 8GB 8,195,604,480 15,880 16 63 16,007,040 16GB 16,391,340,032 16,383 16 63 32,014,336 32GB 32,019,316,736 16,383 16 63 62,537,728 64 GB 64,030,244,864 16,383 16 83 125,059,072 Notes: Display of total bytes varies from operating systems. Cylinders, heads or sectors are not applicable for these capacities. Only LBA addressing applies Notes: 1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 4.2 Performance Performances of the CF cards are listed in Table 4-2 Table 4-2: Performance specifications Capacity 128 MB 256 MB 512 MB 1 GB 2 GB 4 GB 8 GB 16 GB 32 GB 64 GB Sustained read (MB/s) 21 24 47 45 55 55 55 48 57 50 Sustained write (MB/s) 6 6 22 19 25 35 42 38 27 26 Performance Notes: performance may vary depending on flash configurations or host system settings. 7 © 2013 Apacer Technology Inc. Rev. 1.2 Compact Flash 5 series AP-CFxxxxRXXS-XXXXXXA 4.3 Environmental Specifications Environmental specification of the Compact Flash Card series (CFC) which follows the MIL-STD-810F standards is available as shown in Table 4-3. Table 4-3: Environmental specifications Environment Temperature Specification Operation 0°C to 70°C; -40°C to 85°C (Extended Temperature) Storage -40°C to 100°C Vibration (Non-Operation) Shock (Non-Operation) Sine wave : 10~2000Hz, 15G (X, Y, Z axes) Half sine wave 1,500G (X, Y, Z ; All 6 axes) 4.4 Certification & Compliance The CompactFlash card complies with the following global standards:      CE FCC Halogen-free CompactFlash Association Specification Revision 4.1 EMC 4.5 Endurance The endurance of a storage device is predicted by TeraBytes Written based on several factors related to usage, such as the amount of data written into the drive, block management conditions, and daily workload for the drive. Thus, key factors, such as Write Amplifications and the number of P/E cycles, can influence the lifespan of the drive. Capacity TeraBytes Written 128 MB 0.5 256 MB 1.1 512 MB 2.3 1 GB 4.5 2 GB 9.1 4 GB 18.2 8 GB 36.5 16 GB 73.0 32 GB 146.0 64 GB 292.1 Notes:  The measurement assumes the data written to the SSD for test is under a typical and constant rate.  The measurement follows the standard metric: 1 TB (Terabyte) = 1000 GB. 8 © 2013 Apacer Technology Inc. Rev. 1.2 Compact Flash 5 series AP-CFxxxxRXXS-XXXXXXA 5. Software Interface 5.1 CF-ATA Command Set Table 5-1: CFC-ATA command set Command Code Check-Power-Mode E5H or 98H Execute-Drive-Diagnostic 90H Erase-Sector(s) C0H Flush-Cache E7H Format-Track 50H Identify-Drive ECH Idle E3H or 97H Idle-Immediate E1H or 95H Initialize-Drive-Parameters 91H NOP 00H Read-Buffer E4H Read-Multiple C4H Read-Sector(s) 20H or 21H Read-Verify-Sector(s) 40H or 41H Recalibrate 1XH Request-Sense 03H Seek 7XH Set-Features EFH Set-Multiple-mode C6H Set-Sleep-Mode E6H or 99H Standby E2H or 96H Standby-Immediate E0H or 94H Translate-Sector 87H Write-Buffer E8H Write-Multiple C5H Write-Multiple-Without-Erase CDH Write-Sector(s) 30H or 31H Write-Sector(s)-Without-Erase 38H Write-Verify 3CH 9 © 2013 Apacer Technology Inc. Rev. 1.2 Compact Flash 5 series AP-CFxxxxRXXS-XXXXXXA 6. Electrical Specification Caution: Absolute Maximum Stress Ratings – Applied conditions greater than those listed under “Absolute Maximum Stress Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these conditions or conditions greater than those defined in the operational sections of this data sheet is not implied. Exposure to absolute maximum stress rating conditions may affect device reliability. Table 6-1: Operating range Standard Operating Temperature 0°C to +70°C Extended Operating Temperature Supply voltage -40°C to +85°C 5V± 5% (4.75-5.25V) 3.3V ± 5% (3.135-3.465V) Table 6-2: Absolute maximum power pin stress ratings Parameter Symbol Input Power Voltage on any pin except VDD with respect to GND VDD V Conditions -0.3V min. to 6.5V max. -0.5V min. to VDD + 0.5V max. 10 © 2013 Apacer Technology Inc. Rev. 1.2 Compact Flash 5 series AP-CFxxxxRXXS-XXXXXXA 7. Physical Characteristics 7.1 Dimension FIGURE 7-1: Physical dimension Unit: mm 11 © 2013 Apacer Technology Inc. Rev. 1.2 Compact Flash 5 series AP-CFxxxxRXXS-XXXXXXA 8. Product Ordering Information 8.1 Product Code Designations A P – CF x x x x R X X S – XXXXXX A Firmware version Specification RM: Removable NR: Non-Removable ET: Extended Temperature NDRM: Non-DMA + Removable NDNR: Non-DMA + Non-Removable ETRM: Ext. Temp. + Removable ETNR: Ext. Temp. + Non-Removable ETNDRM: Ext. Temp + Non-DMA + Removable ETNDNR: Ext. Temp + Non-DMA + Non-Removable Halogen Free Compliant Configuration : F Dual Channel N : Standard CTL Type 7: CTL BGA Package 9: CTL TSOP Package CFC Type Capacities: 128M 256M 512M 001G: 002G 004G: 008G 016G 032G 064G 128MB 256MB 512MB 1GB 2GB 4GB 8GB 16GB 32GB 64GB Model Name Apacer Product Code 12 © 2013 Apacer Technology Inc. Rev. 1.2 Compact Flash 5 series AP-CFxxxxRXXS-XXXXXXA 8.2 Valid Combinations 8.2.1 Standard Temperature 8.2.1.1 Non-Removable Capacity AP/N 128MB AP-CF128MR9NS-NRA 256MB AP-CF256MR9NS-NRA 512MB AP-CF512MR9NS-NRA 1GB AP-CF001GR9NS-NRA 2GB AP-CF002GR9NS-NRA 4GB AP-CF004GR9NS-NRA 8GB AP-CF008GR9NS-NRA 16GB AP-CF016GR9FS-NR 32GB AP-CF032GR9FS-NR 64GB AP-CF064GR7FS-NR 8.2.1.2 Removable Capacity AP/N 128MB AP-CF128MR9NS-RMA 256MB AP-CF256MR9NS-RMA 512MB AP-CF512MR9NS-RMA 1GB AP-CF001GR9NS-RMA 2GB AP-CF002GR9NS-RMA 4GB AP-CF004GR9NS-RMA 8GB AP-CF008GR9NS-RMA 16GB AP-CF016GR9FS-RM 32GB AP-CF032GR9FS-RM 64GB AP-CF064GR7FS-RM 13 © 2013 Apacer Technology Inc. Rev. 1.2 Compact Flash 5 series AP-CFxxxxRXXS-XXXXXXA 8.2.1.3 Non-DMA + Removable Capacity AP/N 128MB AP-CF128MR9NS-NDRMA 256MB AP-CF256MR9NS-NDRMA 512MB AP-CF512MR9NS-NDRMA 1GB AP-CF001GR9NS-NDRMA 2GB AP-CF002GR9NS-NDRMA 4GB AP-CF004GR9NS-NDRMA 8GB AP-CF008GR9NS-NDRMA 16GB AP-CF016GR9FS-NDRM 32GB AP-CF032GR9FS-NDRM 64GB AP-CF064GR7FS-NDRM 8.2.1.4 Non-DMA + Non-Removable Capacity AP/N 128MB AP-CF128MR9NS-NDNRA 256MB AP-CF256MR9NS-NDNRA 512MB AP-CF512MR9NS-NDNRA 1GB AP-CF001GR9NS-NDNRA 2GB AP-CF002GR9NS-NDNRA 4GB AP-CF004GR9NS-NDNRA 8GB AP-CF008GR9NS-NDNRA 16GB AP-CF016GR9FS-NDNR 32GB AP-CF032GR9FS-NDNR 64GB AP-CF064GR7FS-NDNR Note: Please consult with Apacer sales representatives for availabilities. 14 © 2013 Apacer Technology Inc. Rev. 1.2 Compact Flash 5 series AP-CFxxxxRXXS-XXXXXXA 8.2.2 Extended Temperature 8.2.2.1 Ext. Temp. + Non-Removable Capacity AP/N 128MB AP-CF128MR9NS-ETNRA 256MB AP-CF256MR9NS-ETNRA 512MB AP-CF512MR9NS-ETNRA 1GB AP-CF001GR9NS-ETNRA 2GB AP-CF002GR9NS-ETNRA 4GB AP-CF004GR9NS-ETNRA 8GB AP-CF008GR9NS-ETNRA 16GB AP-CF016GR9FS-ETNR 32GB AP-CF032GR9FS-ETNR 64GB AP-CF064GR7FS-ETNR 8.2.2.2 Ext. Temp. + Removable Capacity AP/N 128MB AP-CF128MR9NS-ETRMA 256MB AP-CF256MR9NS-ETRMA 512MB AP-CF512MR9NS-ETRMA 1GB AP-CF001GR9NS-ETRMA 2GB AP-CF002GR9NS-ETRMA 4GB AP-CF004GR9NS-ETRMA 8GB AP-CF008GR9NS-ETRMA 16GB AP-CF016GR9FS-ETRM 32GB AP-CF032GR9FS-ETRM 64GB AP-CF064GR7FS-ETRM 15 © 2013 Apacer Technology Inc. Rev. 1.2 Compact Flash 5 series AP-CFxxxxRXXS-XXXXXXA 8.2.2.3 Non-DMA + Removable Capacity AP/N 128MB AP-CF128MR9NS-ETNDRMA 256MB AP-CF256MR9NS-ETNDRMA 512MB AP-CF512MR9NS-ETNDRMA 1GB AP-CF001GR9NS-ETNDRMA 2GB AP-CF002GR9NS-ETNDRMA 4GB AP-CF004GR9NS-ETNDRMA 8GB AP-CF008GR9NS-ETNDRMA 16GB AP-CF016GR9FS-ETNDRM 32GB AP-CF032GR9FS-ETNDRM 64GB AP-CF064GR7FS-ETNDRM 8.2.2.4 Non-DMA + Non-Removable Capacity AP/N 128MB AP-CF128MR9NS-ETNDNRA 256MB AP-CF256MR9NS-ETNDNRA 512MB AP-CF512MR9NS-ETNDNRA 1GB AP-CF001GR9NS-ETNDNRA 2GB AP-CF002GR9NS-ETNDNRA 4GB AP-CF004GR9NS-ETNDNRA 8GB AP-CF008GR9NS-ETNDNRA 16GB AP-CF016GR9FS-ETNDNR 32GB AP-CF032GR9FS-ETNDNR 64GB AP-CF064GR7FS-ETNDNR Note: Please consult with Apacer sales representatives for availabilities. 16 © 2013 Apacer Technology Inc. Rev. 1.2 Compact Flash 5 series AP-CFxxxxRXXS-XXXXXXA Revision History Revision Date Description Remark 1.0 06/19/2012 Official release 1.1 09/07/2012 Revised Product Ordering Information Updated performance and product ordering information due to change in NAND flash use 1.2 08/07/2013 Updated the address of Taiwan headquarter Added endurance (TBW) section 17 © 2013 Apacer Technology Inc. Rev. 1.2
AP-CF016GR9FS-ETNR 价格&库存
很抱歉,暂时无法提供与“AP-CF016GR9FS-ETNR”相匹配的价格&库存,您可以联系我们找货
AP-CF016GR9FS-ETNR
