APCFA016GBAD-DT
APCFA016GBAD-DT
    APACERMEMORYAMERICA(宇瞻科技)
    MEMORYCARDCFAST16GBSLC
APCFA016GBAD-DT 数据手册
RoHS Compliant CFast 2H CFast 2H Product Specifications July 6, 2015 Version 1.2 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 CFast 2H APCFAxxxxBXX-XXXX Features:  Standard Serial ATA Interface – SATA Revision 3.1 compliance – SATA 6.0 Gbps interface speed – Backward compatible with SATA 1.5 and 3.0 Gbps interfaces – ATA-compatible command set  Connector type – 7 + 17 pin female connector  Power consumption (typical)* – Supply voltage: 3.3V – Active mode: 540 mA – Idle mode: 85 mA  Performance* – Sustained read: Up to 515 MB/sec – Sustained write: Up to 145 MB/sec  Capacity – 2, 4, 8, 16, 32, 64 GB  NAND Flash Type: SLC  MTBF: >2,000,000 hours  Temperature ranges – Operating: Standard: 0°C to 70°C Wide: -40°C to 85°C – Storage: -40°C to 85°C  Flash Management – Built-in hardware ECC – Static/dynamic wear-leveling – Flash bad-block management – S.M.A.R.T. – Power Failure Management – ATA Secure Erase – TRIM  RoHS Compliant  DEVSLP Supported *The values presented in Power consumption and Performances are typical, and may vary depending on different settings and platforms. 1 © 2015 Apacer Technology Inc. Rev. 1.2 CFast 2H APCFAxxxxBXX-XXXX Table of Contents 1. GENERAL DESCRIPTION .................................................................................................... 3 2. FUNCTIONAL BLOCK .......................................................................................................... 3 3. PIN ASSIGNMENTS ............................................................................................................... 4 4. PRODUCT SPECIFICATION ................................................................................................ 6 4.1 CAPACITY ............................................................................................................................................................. 6 4.2 PERFORMANCE .....................................................................................................................................................6 4.3 ENVIRONMENTAL SPECIFICATIONS .......................................................................................................................7 4.4 MEAN TIME BETWEEN FAILURES (MTBF) ...........................................................................................................7 4.5 CERTIFICATION AND COMPLIANCE .......................................................................................................................7 5. FLASH MANAGEMENT ........................................................................................................ 8 5.1 ERROR CORRECTION/DETECTION .........................................................................................................................8 5.2 BAD BLOCK MANAGEMENT .................................................................................................................................8 5.3 WEAR LEVELING ..................................................................................................................................................8 5.4 POWER FAILURE MANAGEMENT........................................................................................................................... 8 5.5 ATA SECURE ERASE ............................................................................................................................................9 5.6 S.M.A.R.T............................................................................................................................................................ 9 5.7 TRIM ................................................................................................................................................................. 10 6. SOFTWARE INTERFACE .................................................................................................. 11 6.1 ATA COMMAND SET .......................................................................................................................................... 11 7. ELECTRICAL SPECIFICATION ...................................................................................... 12 7.1 OPERATING VOLTAGE ........................................................................................................................................ 12 7.2 POWER CONSUMPTION ....................................................................................................................................... 12 8. PHYSICAL CHARACTERISTICS ..................................................................................... 13 8.1 DIMENSIONS ....................................................................................................................................................... 13 9. PRODUCT ORDERING INFORMATION ........................................................................ 14 2 © 2015 Apacer Technology Inc. Rev. 1.2 CFast 2H APCFAxxxxBXX-XXXX 1. General Description Apacer CFast 2H is the latest enhancement of conventional CFast form factor that delivers various technological advantages. This new flash memory card comes with SATA 6.0 Gbps interface for higher performance and is compliant with standard CFast specifications. CFast 2H consists of SATA-based 7-pin signal segment and 17-pin for power and control purposes. It can offer moderate capacity and decent data transfer performance. For power efficiency, this new flash memory card leverages the technological benefits of SATA Revision 3.0 specifications. For data integrity, the CFast card is built with ECC engine correcting up to 72-bit. Together with its small form factor nature, Apacer CFast 2H is definitely the ideal solution to replace conventional PATA-based CompactFlash for applications in industrial computing systems, mobile computers and video processing instruments. 2. Functional Block Apacer CFast 2H includes a single-chip SATA 6.0 Gbbps and the flash media. The controller integrates the flash management unit to support multi-channel, multi-bank flash arrays. Figure 2-1 shows the functional block diagram. Host Interface SATAI/O & PHY SATA 6.0 Gbps Interface Controller Flash data bus & ECC engine SDR Flash Flash Flash Flash Figure 2-1 Apacer CFast block diagram 3 © 2015 Apacer Technology Inc. Rev. 1.2 CFast 2H APCFAxxxxBXX-XXXX 3. Pin Assignments Table 3-1 describes CFast 2H signal segment, and Table 3-2, its power segment. Figure 3-1 Pin Assignment Table 3-1 Signal Segment Pin Type Description S1 GND Ground S2 A+ S3 A- SATA Differential Signal Pair A S4 GND Ground S5 B- S6 B+ SATA Differential Signal Pair B S7 GND Ground Table 3-2 Power Segment Pin Definition Type Description PC1 CDI Input Card Detect In PC2 PGND Device GND Device GND PC3 Reserved PC4 Reserved PC5 Reserved PC6 Reserved PC7 PGND Device GND Device GND PC8 LED1 LED Output LED Output PC9 LED2 LED Output LED Output PC10 Reserved PC11 Reserved PC12 IFDet GND Card output, connect to PGND on card PC13 PWR 3.3V Device power (3.3V) PC14 3.3V Device power (3.3V) PC15 PWR w PGND Device GND Device GND PC16 PGND Device GND Device GND PC17 CDO Output Card Detect Out 4 © 2015 Apacer Technology Inc. Rev. 1.2 CFast 2H APCFAxxxxBXX-XXXX Figure 3-2 SATA Cable / Connector Connection Diagram The connector on the left represents the Host with TX/RX differential pairs connected to a cable while the connector on the right shows the Device with TX/RX differential pairs also connected to the cable. Notice also the ground path connecting the shielding of the cable to the Cable Receptacle. 5 © 2015 Apacer Technology Inc. Rev. 1.2 CFast 2H APCFAxxxxBXX-XXXX 4. Product Specification 4.1 Capacity Capacity specification of the CFast 2H is available as shown in Table 4-1. It lists the specific capacity and the default numbers of heads, sectors and cylinders for each product line. Table 4-1: Capacity specifications Capacity Total bytes* Cylinders Heads Sectors Max LBA 2 GB 2,011,226,112 3,897 16 63 3,928,176 4 GB 4,011,614,208 7,773 16 63 7,835,184 8 GB 8,012,390,400 15,525 16 63 15,649,200 16 GB 16,013,942,784 16,383 16 63 31,277,232 32 GB 32,017,047,552 16,383 16 63 62,533,296 64 GB 64,023,257,088 16,383 16 63 125,045,424 *Display of total bytes varies from file systems. **Cylinders, heads or sectors are not applicable for these capacities. Only LBA addressing applies LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the CFast is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 4.2 Performance Performance of CFast 2H product family is available as shown in Table 4-2. Table 4-2: Performance table Capacity 2 GB 4 GB 8 GB 16 GB 32 GB 64 GB Sustained Read (MB/s) 65 65 280 510 495 515 Sustained Write (MB/s) 35 50 80 140 140 145 Performance Note: Performances results are measured by CrystalDiskMark under Windows 7 and may vary from host system configurations. 6 © 2015 Apacer Technology Inc. Rev. 1.2 CFast 2H APCFAxxxxBXX-XXXX 4.3 Environmental Specifications Environmental specification of the CFast 2H follows the MIL-STD-810F testing standards, shown in Table 4-3. Table 4-3 Environmental specification Environment Temperature Humidity Specification Operation 0°C to 70°C / -40°C to 85°C Storage -40°C to 85°C Operation 40°C 93%RH Storage 40°C 95%RH Shock (Non-Operating) 80~2000Hz/20G (acceleration) ; 20~80Hz/1.52mn (displacement), X,Y, Z axis/30 min for each Half sine wave, 1500 G (X, Y, Z ; All 6 axis) Drop (non-operating) 110cm free fall, 6-face each unit Bending (non-operating) ≧20N, hold 1min/5times Torque (non-operating) 0.5N-m or ±2.5 degree, hold 5min/5times Vibration (Non-Operating) Note: this Environmental Specification table indicates the conditions for testing the device. Real world usages may affect the results. 4.4 Mean Time Between Failures (MTBF) Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components in CFast 2H. Serving as statistical reference, the prediction result for CFast 2H is more than 2,000,000 hours. 4.5 Certification and Compliance CFast 2H complies with the following standards     CE FCC BSMI RoHS 7 © 2015 Apacer Technology Inc. Rev. 1.2 CFast 2H APCFAxxxxBXX-XXXX 5. Flash Management 5.1 Error Correction/Detection Flash memory cells will deteriorate with use, which might generate random bit errors in the stored data. Thus, the CFast applies the BCH ECC Algorithm, which can detect and correct errors up to 72-bit in 1K byte data during Read process, ensure data been read correctly, as well as protect data from corruption. 5.2 Bad Block Management Bad blocks are blocks that include one or more invalid bits, and their reliability is not guaranteed. Blocks that are identified and marked as bad by the manufacturer are referred to as “Initial Bad Blocks”. Bad blocks that are developed during the lifespan of the flash are named “Later Bad Blocks”. Apacer implements an efficient bad block management algorithm to detect the factory-produced bad blocks and manages any bad blocks that appear with use. This practice further prevents data being stored into bad blocks and improves the data reliability. 5.3 Wear Leveling NAND Flash devices can only undergo a limited number of program/erase cycles, and in most cases, the flash media are not used evenly. If some areas get updated more frequently than others, the lifetime of the device would be reduced significantly. Thus, Wear Leveling technique is applied to extend the lifespan of NAND Flash by evenly distributing write and erase cycles across the media. Apacer provides advanced Wear Leveling algorithm, which can efficiently spread out the flash usage through the whole flash media area. Moreover, by implementing both dynamic and static Wear Leveling algorithms, the life expectancy of the NAND Flash is greatly improved. 5.4 Power Failure Management Power Failure Management is a mechanism to prevent data loss during unexpected power failure. When power outage occurs, the data that has not been written into NAND Flash is in risk. Thus, the purpose of this mechanism is to request the controller to transfer data to the cache. In this CFast 2H structure, SDR performs as a cache, and its sizes is 32MB. Only when the data is fully committed to the NAND flash will the controller send acknowledgement (ACK) to the host. Such implementation can prevent false-positive performance and the risk of power cycling issues. Additionally, it is critical for a controller to shorten the time the in-flight data stays in the cache. Thus, this CFast 2H memory card applies an algorithm to reduce the amount of data resides in the cache to provide a better performance. This allows incoming data to only have a “pit stop” in the cache and then move to the NAND flash at once. If the flash is jammed due to particular file sizes (random 4K), the cache will be treated as an “organizer”, consolidating incoming data into groups before written into the flash to improve write amplification. 8 © 2015 Apacer Technology Inc. Rev. 1.2 CFast 2H APCFAxxxxBXX-XXXX 5.5 ATA Secure Erase ATA Secure Erase is an ATA disk purging command currently embedded in most of the storage drives. Defined in ATA specifications, (ATA) Secure Erase is part of Security Feature Set that allows storage drives to erase all user data areas. The erase process usually runs on the firmware level as most of the ATA-based storage media currently in the market are built-in with this command. ATA Secure Erase can securely wipe out the user data in the drive and protects it from malicious attack. 5.6 S.M.A.R.T. SMART, an acronym for Self-Monitoring, Analysis and Reporting Technology, is an open standard that allows a hard disk drive to automatically detect its health and report potential failures. When a failure is recorded by SMART, users can choose to replace the drive to prevent unexpected outage or data loss. Moreover, SMART can inform users of impending failures while there is still time to perform proactive actions, such as copy data to another device. Apacer devices use the standard SMART command B0h to read data out from the drive to activate our S.M.A.R.T. feature that complies with the ATA/ATAPI specifications. S.M.A.R.T. Attribute IDs shall include initial bad block count, total later bad block count, maximum erase count, average erase count, power on hours and power cycle. When the S.M.A.R.T. Utility running on the host, it analyzes and reports the disk status to the host before the device reaches in critical condition. Note: attribute IDs may vary from product models due to various solution design and supporting capabilities. Apacer memory products come with S.M.A.R.T. commands and subcommands for users to obtain information of drive status and to predict potential drive failures. Users can take advantage of the following commands/subcommands to monitor the health of the drive. CODE D0H D1H D2H D4H D5H D6H D8H D9H DAH SMART SUBCOMMAND READ DATA READ ATTRIBUTE THRESHOLDS ENABLE/DISABLE ATTRIBUTE AUTOSAVE EXECUTE OFF-LINE IMMEDIATE READ LOG (OPTIONAL) W RITE LOG (OPTIONAL) ENABLE OPERATIONS DISABLE OPERATIONS RETURN STATUS GENERAL SMART ATTRIBUTE STRUCTURE BYTE DESCRIPTION 0 ID (HEX) 1–2 STATUS FLAG 3 VALUE 4 W ORST 5*-11 RAW DATA *Byte 5: LSB 9 © 2015 Apacer Technology Inc. Rev. 1.2 CFast 2H APCFAxxxxBXX-XXXX ID (HEX) 9 (0X09) 12 (0X0C) 163 (0XA3) 164 (0XA4) 166 (0XA6) 167 (0XA7) 168 (0XA8) 175 (0XAF) 192 (0XC0) 194 (0XC2) 241 (0XF1) SMART attribute ID list ATTRIBUTE NAME POWER-ON HOURS POWER CYCLE COUNT MAX. ERASE COUNT AVG. ERASE COUNT TOTAL LATER BAD BLOCK COUNT SSD PROTECT MODE (VENDOR SPECIFIC) SATA PHY ERROR COUNT BAD CLUSTER TABLE COUNT UNEXPECTED POWER LOSS COUNT TEMPERATURE TOTAL SECTORS OF WRITE 5.7 TRIM TRIM is a feature which helps improve the read/write performance and speed of Solid-State Drives (SSD). Unlike Hard Disk Drives (HDD), SSDs are not able to overwrite existing data, so the available space gradually becomes smaller with each use. With the TRIM command, the operating system can inform the SSD which blocks of data are no longer in use and can be removed permanently. Thus, the SSD will perform the erase action, which prevents unused data from occupying blocks all the time. 10 © 2015 Apacer Technology Inc. Rev. 1.2 CFast 2H APCFAxxxxBXX-XXXX 6. Software Interface 6.1 ATA Command Set Table 6-1: Command set Code 06h Command Code Command Data Set Management 98h Check Power Mode Recalibrate 99h Sleep 20h Read Sectors B0h SMART 21h Read Sectors without Retry B1h Device Configuration 24h Read Sectors EXT C4h Read Multiple 25h Read DMA EXT C5h Write Multiple 27h Read Native Max Address EXT C6h Set Multiple Mode 29h Read Multiple EXT C8h Read DMA 2Fh Read Log EXT C9h Read DMA without Retry 30h Write Sectors Cah Write DMA 31h Write Sectors without Retry CBh Write DMA without Retry 34h Write Sectors EXT Ceh Write Multiple FUA EXT 35h Write DMA EXT E0h Standby immediate 37h Set Native Max Address EXT E1h Idle Immediate 38h CFA Write Sectors without Erase E2h Standby 39h Write Multiple EXT E3h Idle 3Dh Write DMA FUA EXT E4h Read Buffer 3Fh Write Long EXT E5h Check Power Mode 40h Read Verify Sectors E6h Sleep 41h Read Verify Sectors without Retry E7h Flush Cache 42h Read Verify Sectors EXT E8h Write Buffer 45h Write Uncorrectable EXT Eah Flush Cache EXT 60h Read FPDMA Queued Ech Identify Device 61h Write FPDMA Queued Efh Set Features Seek F1h Security Set Password 90h Execute Device Diagonstic F2h Security Unlock 91h Initialize Device Parameters F3h Security Erase Prepare 92h Download Microcode F4h Security Erase Unit 93h Download Microcode DMA F5h Security Freeze Lock 94h Standby Immediate F6h Security Disable Password 95h Idle Immediate F8h Read Native Max Address 96h Standby F9h Set Max Address 97h Idle 10h-1Fh 70h-7Fh 11 © 2015 Apacer Technology Inc. Rev. 1.2 CFast 2H APCFAxxxxBXX-XXXX 7. Electrical Specification 7.1 Operating Voltage Table 7-1 lists operating voltage of CFast 2H Table 7-1: Operating voltage Parameter Symbol Min Typ Max Units Vcc 3.135 3.3 3.465 V Power Supply 7.2 Power Consumption Table 7-2 lists power consumption of CFast 2H Table 7-2 Power consumption (typical) Capacity Mode Active 2 GB 4 GB 8 GB 16 GB 32 GB 64 GB 210 225 340 500 515 540 65 65 85 85 85 85 (mA) Standby (mA) Note: Power consumption may vary from flash configurations and/or platform settings. 12 © 2015 Apacer Technology Inc. Rev. 1.2 CFast 2H APCFAxxxxBXX-XXXX 8. Physical Characteristics 8.1 Dimensions Unit: ㎜ FIGURE 8-1: Physical dimension 13 © 2015 Apacer Technology Inc. Rev. 1.2 CFast 2H APCFAxxxxBXX-XXXX 9. Product Ordering Information 9.1 Product Code Designations A P CFA x x x x B X X – X X XX Flash Type FW W : Wide Temp. N:Standard D:High Speed A= Standard CTL Type Capacities: 002G 004G 008G 016G 032G 064G 2GB 4GB 8GB 16GB 32GB 64GB Model Name Apacer Product Code 14 © 2015 Apacer Technology Inc. Rev. 1.2 CFast 2H APCFAxxxxBXX-XXXX 9.2 Valid Combinations 9.2.1 Standard Temperature Capacity AP/N 2GB APCFA002GBAN-DT 4GB APCFA004GBAN-DT 8GB APCFA008GBAD-DT 16GB APCFA016GBAD-DT 32GB APCFA032GBAD-DT 64GB APCFA064GBAD-DT 9.2.2 Wide Temperature Capacity AP/N 2GB APCFA002GBAN-WDT 4GB APCFA004GBAN-WDT 8GB APCFA008GBAD-WDT 16GB APCFA016GBAD-WDT 32GB APCFA032GBAD-WDT 64GB APCFA064GBAD-WDT 15 © 2015 Apacer Technology Inc. Rev. 1.2 CFast 2H APCFAxxxxBXX-XXXX Revision History Revision Date Description Remark 1.0 11/28/2014 Official Released 1.1 12/03/2014 Revised 5.6 SMART section 1.2 07/06/2015 Revised product ordering information 16 © 2015 Apacer Technology Inc. Rev. 1.2 CFast 2H APCFAxxxxBXX-XXXX Global Presence Taiwan (Headquarters) Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 386 Fairview Way, Suite102, Milpitas, CA 95035 Tel: 1-408-518-8699 Fax: 1-408-935-9611 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd 1301, No.251,Xiaomuqiao Road, Shanghai, 200032, China Tel: 86-21-5529-0222 Fax: 86-21-5206-6939 sales@apacer.com.cn India Apacer Technologies Pvt Ltd, # 535, 1st Floor, 8th cross, JP Nagar 3rd Phase, Bangalore – 560078, India Tel: 91-80-4152-9061 sales_india@apacer.com 17 © 2015 Apacer Technology Inc. Rev. 1.2
APCFA016GBAD-DT 价格&库存
很抱歉,暂时无法提供与“APCFA016GBAD-DT”相匹配的价格&库存,您可以联系我们找货
