SFSD016GL2BM1TO-E-GE-121-STD
    SWISSBIT
    MEMORYCARDSDHC16GBCLASS6
SFSD016GL2BM1TO-E-GE-121-STD 数据手册
Product Fact Sheet Industrial SDHC Memory Card S-40 Series SDHC compliant S-40 Series Industrial SDHC Memory Card - 4/8/16/32GByte Main Features  Fully compliant with SD Memory Card specification 3.0  SDHC high speed mode, non UHS  Speed class 6 according SD3.0 specification  SD2.0 backward compliant  FAT32 preformatted  High performance 3.0 specification  SD burst up to 25MB/s  SD Normal speed 0…25MHz clock rate  SD High speed 25…50MHz clock rate  Flash burst up to 90MB/s  Up to 24MByte/sec sequential data rate  Power Supply: (Low-power CMOS technology)  2.7…3.6V normal operating voltage  Standard SD Memory card form factor  32.0mm x 24.0mm x 2.1mm and Write Protect slider  Optimized FW algorithms especially for high read access and long data retention applications  Patented power-off reliability technology  Wear Leveling technology Equal wear leveling of static and dynamic data. The wear leveling assures that dynamic data as well as static data is balanced evenly across the memory. With that the maximum write endurance of the device is guaranteed  Write Endurance technology Due to intelligent wear leveling an even use of the entire flash is guaranteed, regardless how much “static” (OS) data is stored.  Read Disturb Management The read commands are monitored and the content is refreshed when critical levels have occurred  Data Care Management The interruptible background process maintain the user data for Read Disturb effects or Retention degradation due to high temperature effects  Near miss ECC technology Minimize the risk of uncorrectable bit failure over the product life time. Each read command analyzes the ECC margin level and refresh data if necessary  Diagnostic features with Life Time Monitoring tool support  High reliability  Designed for industrial market especially read intensive application like navigation, infotainment, POS/POI, Medical and general boot medium use case  The product is optimized for long life cycle that requires a good data retention because of high temperature mission profile.  Intensive write application should use the S-450 Series SLC cards  Number of card insertions/removals up to 20,000  Extended and Industrial Temperature range -25° up to 85°C and -40° up to 85°C, respectively  SIP (System In Package) process for extreme dust, water and ESD proof  Selected AEC-Q100 qualification    Controlled BOM & PCN process Manufactured in a TS 16949 certified factory Customized options like CID registers, CPRM keys, firmware incl. settings and marking by projects Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Revision: 1.01 www.swissbit.com industrial@swissbit.com S-40_fact_sheet_SD-LxBM_Rev101.doc Page 2 of 3 Order Information Density 4GB 8GB 16GB 32GB Part Number SFSD4096LgBM1TO-t-GE-1x1-STD SFSD8192LgBM1TO-t-LF-1x1-STD SFSD016GLgBM1TO-t-HG-1x1-STD SFSD032GLgBM1TO-t-LF-1x1-STD Temp. Range Flash Technology -25°C to 85°C or -40°C to 85°C MLC NAND Flash System Performance System Performance (estimated target) Burst Data transfer Rate (max clock 50MHz) Sustained Sequential Read Sustained Sequential Write typ 23 11 max 25 24 14 Current Consumption @3.3V Read Write Idle typ 40 60 2.5 max 60 80 5 Unit MB/s Unit mA Physical Dimensions Physical Dimensions Length Width Thickness Weight (typ.) Value 32.00±0.10 24.00±0.10 2.10±0.15 2 Unit mm g Recommended Temperature Conditions Parameter Extended Operating Temperature Industrial Operating Temperature Storage Temperature min -25 -40 -40 typ 25 25 25 max 85*) 85*) 100*) Unit °C °C °C *) high temperature storage without operation reduces the data retention, in operation the data will be refreshed, if data error issues were detected Humidity and EMC Parameter Humidity (non-condensing) ESD Operating Non Operating max 95% Non Contact Pads area: ±15 kV (air discharge), according to IEC61000-4-2 Contact Pads: ±6 kV, according to IEC61000-4-2 Non Contact Pads area: ±8kV (indirect) contact discharge, according to IEC61000-4-2 Durability Parameter Operating Non Operating Salt water spray 3% NaCI/35°C; 24h acc. MIL STD Method 1009 Insertions / Drop test >20,000 / 1.5m free fall Bending / Torque / Bump 10N / 0.15Nm or ±2.5deg Shock / Vibration (peak -to-peak) 1500G max / 15G max Data Retention at beginning @ 40°C 10 years*) *) After every power on the card reads the whole flash and performs a data refresh if necessary. So the data retention can be much longer in most use cases. For more information on SD Memory card Specification, please visit SD association (www.sdcard.org) Why Swissbit? Swissbit strives to create innovative technologies for future market opportunities utilizing a highly skilled inhouse product research and development team. Swissbit maintains a marketing edge by continuing to manufacture world-class high quality memory products and providing customers with both high value and low cost of ownership achieved through efficient processes and procedures. Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Revision: 1.01 www.swissbit.com industrial@swissbit.com S-40_fact_sheet_SD-LxBM_Rev101.doc Page 3 of 3
SFSD016GL2BM1TO-E-GE-121-STD 价格&库存
很抱歉,暂时无法提供与“SFSD016GL2BM1TO-E-GE-121-STD”相匹配的价格&库存,您可以联系我们找货
