AP-MSD04GIA-1FTM
AP-MSD04GIA-1FTM
    APACERMEMORYAMERICA(宇瞻科技)
    MEMORY CARD MICROSDHC 4GB MLC
AP-MSD04GIA-1FTM 数据手册
Industrial microSD card Industrial MicroSD(HC) card Industrial MicroSD H1-M Overview Apacer Industrial microSD H1-M series conforming to SD3.0 speficiation are designed with high performance, good reliability and wide compatibility, through UHS-I, supporting speed class up to U3. The new microSD 3.0 card is capable of delivering better performance and P/E cycles by the latest firmware architecture including a powerful built-in Error Correction, Read Retry , Wear Leveling & Bad Block Management algorithms. Feature ‧Compliant with SD 3.0 Specification ‧ S.M.A.R.T supported ‧ Wear-Leveling and Block Management ‧ Support SD mode and SPI mode ‧ Low Power Consumption ‧ Wide Temperature Support Specifications Model Industrial microSDHC Interface SD3.0 NAND Flash Type MLC Capacity 4G~64G Sustained Read Performance (MB/sec) Up to 44 Sustained Write Performance (MB/sec) Up to 36 ECC Engine* Built-in 42-bit per 1K bytes BCH ECC Standard Operating Temperature ( °C ) -25 ~ + 85 Extended Operating Temperature ( °C ) -40 ~ + 85 Storage Temperature ( °C ) -40 ~ + 85 Shock 1,500G, 0.5ms Vibration 20Hz~80Hz/1.52mm (frequency/displacement) 80Hz~2,000Hz/20G (frequency/accelerate) Humidity 95% Operating Voltage 3.3 V ± 5% Low Power Consumption Active mode: 135 mA & Idle mode: 250 uA Dimension (L x W x H ) 15x11x1 (mm) MTBF (hours) >3,000,000 Features / Technology S.M.A.R.T./Wide Temp. Applications Military/Cloud Computing/InVehicle/Gaming/HealthCare/Embedded System Ordering Info Model Standard temp: -25~85 Extended temp: -40~85 4G AP-MSD04GCA-1GTM AP-MSD04GIA-1GTM 8G AP-MSD08GCA-1GTM AP-MSD08GIA-1GTM 16G AP-MSD16GCA-1GTM AP-MSD16GIA-1GTM 32G AP-MSD32GCA-1GTM AP-MSD32GIA-1GTM 64G AP-MSD64GCA-1FTM AP-MSD64GIA-1FTM Global Presence Taiwan (Headquarters) Apacer Technology Inc. Tel: +886-2-2267-8000 Fax: +886-2-2267-2261 Europe Apacer Technology B.V. Tel: +31-40-267-0000 Fax: +31-40-290-0686 Japan Apacer Technology Corp. Tel: +81-3-5419-2668 Fax: +81-3-5419-0018 India Apacer Technologies Pvt. Ltd. Tel: +91-80-41529061~3 Fax: +91-80-41700215 U.S.A. Apacer Memory America, Inc. Tel: +1-408-518-8699 Fax: 1-510-249-9551 China Apacer Electronic(Shanghai) Co., Ltd. Tel: +86-21-6228-9939
AP-MSD04GIA-1FTM 价格&库存
很抱歉,暂时无法提供与“AP-MSD04GIA-1FTM”相匹配的价格&库存,您可以联系我们找货
