SFUI016GJ1AB1TO-I-QT-211-STD
    SWISSBIT
    模块
    MODULEFLASHNANDSLC16GB
SFUI016GJ1AB1TO-I-QT-211-STD 数据手册
Product Fact Sheet Industrial USB Flash Drive Module U-400 Series USB2.0, high speed U-400 Series (USB2.0, high speed) Industrial USB Flash Drive Module (eUSB) – 1 to 16GByte Main Features  USB2.0 solid state flash drive for internal 9(10)-pin USB connector terminal o Fully compliant with USB specification 2.0/3.0 (High-Speed, 480Mb/s burst) o Fully backward compliant with USB 1.1 systems (Full speed, 12Mb/s burst) o Dimension of 26.65 x 36.8mm o 2.54mm or 2.00mm connector with keyed pin9 (optional different key pins and pinouts) o Screw hole not connected (optional grounded) o Fix drive (optional removable) o LED for operation indication o Write protect switch (optional) o FAT32 preformatted o Diagnostic features with Life Time Monitoring tool support o Firmware update in field possible  High performance 2.0 specification o Up to 40 IOPS write and 1700 IOPS read (4KByte transfers) o Up to 34MBytes/s sequential write and 36MBytes/s read speed  Power Supply: (Low-power CMOS technology) o 3.1 to 5.5V operating voltage  Optimized FW algorithms especially for high read access and long data retention applications o Patented power-off reliability technology o Near Miss ECC technology Minimize the risk of uncorrectable bit failure over the product life time. Each read command analyzes the ECC margin level and refresh data if necessary o Read Disturb Management The read commands are monitored and the content is refreshed when critical levels have occurred o Wear Leveling technology Equal wear leveling of static and dynamic data. The wear leveling assures that dynamic data as well as static data is balanced evenly across the memory. With that the maximum write endurance of the device is guaranteed o Data Care Management The interruptible background process maintain the user data for Read Disturb effects or Retention degradation due to high temperature effects -17 o UBER
物料型号:U-400系列提供了1GB至16GB不同容量的型号,每个型号都有其特定的部件编号,例如1GB型号为SFUI1024cgAB1TO-t-MS-2xx-STD。
器件简介:U-400系列是一个USB 2.0高速固态闪存驱动器,适用于工业环境,具有1至16GB的存储容量。
引脚分配:模块提供了9(10)引脚的USB连接器终端,支持2.54mm或2.00mm间距的引脚,带有可选的键槽。
参数特性:包括LED操作指示灯、可写保护开关、FAT32预格式化、诊断功能、固件现场更新等。
功能详解:该模块支持高达40次IOPS的写入和1700次IOPS的读取(4KB传输),连续写入速度最高可达34MB/s,读取速度最高可达36MB/s。
应用信息:设计用于工业和网络通信市场,特别适合24/7运行的应用场景,如网络、基站、基础设施系统、医疗设备等。
封装信息:尺寸为26.65mm x 36.8mm,重量约2克,提供商业和工业温度范围,符合RoHS、REACH等环保标准。
定制选项:提供多种定制选项,包括寄存器、可移动设备、连接器选项、写保护开关等。
联系信息:Swissbit AG位于瑞士Bronschhofen的Industriestrasse 4。
SFUI016GJ1AB1TO-I-QT-211-STD 价格&库存
很抱歉,暂时无法提供与“SFUI016GJ1AB1TO-I-QT-211-STD”相匹配的价格&库存,您可以联系我们找货
