MMM-3033-DSL
MMM-3033-DSL
    TERASIC(友晶科技)
    SODIMM-200
    MODULEDDR2SDRAM1GB200-SODIMM
MMM-3033-DSL 数据手册
DDR2-800 1GB SO-DIMM 200PIN With samsung 128Mx8 DRAM D2SS28081XH25AA Specifications Density: 1GB Data Rate: 800 Mbps Version: Unbuffered CAS Latency: 6 Package: SO-DIMM Votage: 1.8V Pin Count: 200pin PCB Layers: 6 Speed: PC2-6400 ECC : Non ECC Component Config: 128Meg x 8 Module Ranks : Singel Rank Features Ʉġ All of Lead-Free products are compliant for ROHS Ʉġ 200-pin,small outline,dual in-line memory module(SO-DIMM) Ʉġ 1.8V + 0.1V power supply Ʉġ Data rate:800Mbps(max) Ʉġ 8 Banks Ʉġ JEDEC standard 1.8V I/O(SSTL_18-compatible) Ʉġ Burst Length: 4,8 Ʉġ /CAS Latency (CL):3,4,5,6 Ʉġ Double-data-rate architecture: two data transfers per clock cycle Ʉġ Differential clock inputs (CK and /CK) Ʉġ Four-bit prefetch architecture Ʉġ Auto precharge operation for each burst access Ʉġ Auto refresh and self refresh modes Ʉġ Differential data strobe(DQS,DQS#) option Ʉġ DLL to align DQ and DQS transitions with CK Ʉġ Programmable Sequential / Interleave Burst Mode Ʉġ Bi-directional Differential Data-Strobe (Single-ended data-strobe is an optional feature) Ʉġ Posted CAS# additive latency (AL) Ʉġ On Die Termination (ODT) Ʉġ 64ms,8192-cycle refresh Ʉġ Serial presence detect with EEPROM Ʉġ Gold edge contacts Ʉġ Average Refresh Period 7.8us at 0ɗ ʀTCASEʀ為85ɗ, 3.9us at為 85ɗ 烋TCASEʀ為95ɗ 1 REV 3.0 DDR2-800 1GB SO-DIMM 200PIN With samsung 128Mx8 DRAM D2SS28081XH25AA Description The D2SS28081XH25AA is 128M words x 64 bits, 1 ranks DDRII SDRAM Small Outline Dual In-line Memory Module, mounting 8 pieces of 1GB bits DDRII SDRAM sealed in FBGA(ȫBGA®) package. Read and write operations are performed at the cross points of the CK and the /CK. This high-speed data transfer is realized by the 4 bits prefetch-pipelined architecture. Data strobe (DQS and /DQS) both for read and write are available for high speed and reliable data bus design. By setting extended mode register, the on-chip Delay Locked Loop(DLL) can be set enable or disable. This module provides high density mounting without utilizing surface mount technology. Decoupling capacitors are mounted beside each FBGA(ȫBGA) on the module board. ġ Speed Grade & Key Parameters DDR2-533 DDR2-667 CL3 400 400 CL4 533 533 533 Mbps 667 667 Mbps 800 Mbps 6-6-6 tCK CL5 4-4-4 Unit Mbps CL6 CL-tRCD-tRP DDR2-800 5-5-5 ġ ġ Speed Bins Unit DDR2-533 DDR2-667 DDR2-800 CL-tRCD-tRP 4-4-4 5-5-5 6-6-6 Parameter min min min CAS Latency 4 5 6 tCK tRCD 15 15 15 ns tRP 15 15 15 ns tRAS 45 45 45 ns tRC 60 60 60 ns ġ 2 REV 3.0 DDR2-800 1GB SO-DIMM 200PIN With samsung 128Mx8 DRAM D2SS28081XH25AA Address Configuration 256MB 512MB 512MB 1GB 1GB 2GB Dram Organization 32Mx16 64Mx8 64Mx16 64Mx8 128Mx8 128Mx8 Row address A0~A12 A0~A13 A0~A12 A0~A13 A0~A13 A0~A13 Column address A0~A9 A0~A9 A0~A9 A0~A9 A0~A9 A0~A9 Auto Precharge A10 A10 A10 A10 A10 A10 Bank address BA0~BA1 BA0~BA1 BA0~BA2 BA0~BA1 BA0~BA2 BA0~BA2 Refresh Method 8K/64ms 8K/64ms 8K/64ms 8K/64ms 8K/64ms 8K/64ms 4 8 4 16 8 16 # of DRAMs Absolute Maximum Ratings Symbol Rating Unit Note TCASE 0 to 95 ɗ IJġ Storage Temperature TSTG -50 to +100 ɗ ġ Storage Humidity HSTG 5 to 95 % Parameter DRAM Component Case Temperature Range Note: 1. If the DRAM case temperature is above 85ɗ炻the AUTO-Refresh command interval has to be reduced to tREFI=3.9usˤ DC Operating Conditions(SSTL_1.8) Parameter Symbol Min Typ. Max Unit VDD 1.7 1.8 1.9 V VDDL 1.7 1.8 1.9 V VDDQ 1.7 1.8 1.9 V Reference voltage VREF 0.49*VDDQ 0.5*VDDQ 0.51*VDDQ V Termination voltage VTT VREF – 0.04 VREF VREF +0.04 V Input high voltage VIH VREF + 0.15 - VREF + 0.30 V EEPROM Supply Voltage VDDSPD 1.7 - 3.6 V DC input logic high VIH(DC) VREF+0.125 - VDDQ+0.3 V DC input low VIL(DC) -0.3 VREF-0.125 V AC input logic high VIH(AC) VREF+0.250 - - V AC input low VIL(AC) - - VREF-0.250 V Supply Voltage 3 REV 3.0 DDR2-800 1GB SO-DIMM 200PIN With samsung 128Mx8 DRAM D2SS28081XH25AA Pin Description Pin name Description Pin name Description A0~A13 DDR2 SDRAM address bus CK0,CK1 Clock input BA0,BA1 DDR2 SDRAM bank select /CK0,/CK1 Differential clock input /RAS DDR2 SDRAM row address strobe SCL Clock input for serial PD /CAS DDR2 SDRAM column address strobe SDA Data input/output for serial PD /WE Wirte enable S0,S1 SA0-SA1 DIMM Rank Select Lines CKE0,CKE1 DDR2 SDRAM clock enable lines ODT0,ODT1 On-die termination control lines DQ0-DQ63 CB0-CB7 VDD* VDDQ* VREF DIMM memory data bus DIMM ECC check bits VSS VDDSPD DQS0-DQS8 DDR2 SDRAM data strobes DM(0-8) NC DDR2 SDRAM data masks RESET DQS0-DQS8 DDR2 SDRAM differential data strobes TEST Serial address input DDR2 SDRAM core power supply DDR2 SDRAM I/O Driver power supply Input reference supply Ground Power for serial EEPROM No connect Not used on UDIMM Unused on memory DIMMs Pin Configuration Pin 1 3 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39 41 43 45 47 49 Front VREF VSS DQ0 DQ1 VSS DQS0 DQS0 VSS DQ2 DQ3 VSS DQ8 DQ9 VSS DQS1 DQS1 VSS DQ10 DQ11 VSS VSS DQ16 DQ17 VSS DQS2 Pin 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 44 46 48 50 Back VSS DQ4 DQ5 VSS DM0 VSS DQ6 DQ7 VSS DQ12 DQ13 VSS DM1 VSS CK0 CK0 VSS DQ14 DQ15 VSS VSS DQ20 DQ21 VSS NC Pin 51 53 55 57 59 61 63 65 67 69 71 73 75 77 79 81 83 85 87 89 91 93 95 97 99 Front Pin Back Pin Front Pin Back Pin Front DQS2 52 DM2 101 A1 102 A0 151 DQ42 VSS 103 VDD 104 VDD 153 DQ43 VSS 54 DQ18 56 DQ22 105 A10/AP 106 BA1 155 VSS DQ19 58 DQ23 107 BA0 108 RAS 157 DQ48 VSS VSS 109 WE 110 60 S0 159 DQ49 DQ24 62 DQ28 111 VDD 112 VDD 161 VSS DQ25 64 DQ29 113 CAS 114 ODT0 163 NC,TEST VSS VSS 115 NC/S1 116 A13 165 VSS 66 DM3 68 DQS3 117 VDD 118 VDD 167 DQS6 NC 169 DQS6 NC 70 DQS3 119 NC/ODT1 120 VSS VSS 121 VSS 122 VSS 171 VSS 72 DQ26 74 DQ30 123 DQ32 124 DQ36 173 DQ50 DQ27 76 DQ31 125 DQ33 126 DQ37 175 DQ51 VSS VSS 127 VSS 128 VSS 177 VSS 78 CKE0 80 NC/CKE1 129 DQS4 130 DM4 179 DQ56 VDD VDD 131 DQS4 132 VSS 181 DQ57 82 NC 84 NC 133 134 DQ38 183 VSS VSS BA2 86 NC 135 DQ34 136 DQ39 185 DM7 VDD VDD 137 DQ35 138 VSS 187 VSS 88 A12 90 A11 139 VSS 140 DQ44 189 DQ58 A9 92 A7 141 DQ40 142 DQ45 191 DQ59 A8 94 A6 143 DQ41 144 VSS 193 VSS VDD VDD 145 VSS 146 DQS5 195 SDA 96 A5 98 A4 147 DM5 148 DQS5 197 SCL A3 100 A2 149 VSS 150 VSS 199 VDDSPD 4 Pin 152 154 156 158 160 162 164 166 168 170 172 174 176 178 180 182 184 186 188 190 192 194 196 198 200 Back DQ46 DQ47 VSS DQ52 DQ53 VSS CK1 CK1 VSS DM6 VSS DQ54 DQ55 VSS DQ60 DQ61 VSS DQS7 DQS7 VSS DQ62 DQ63 VSS SA0 SA1 REV 3.0 DDR2-800 1GB SO-DIMM 200PIN With samsung 128Mx8 DRAM D2SS28081XH25AA Input/Output Functional Description Symbol Type Function CK0-CK2 CK0-CK2 Input CK and /CK are differential clock inputs. All the SDRAM addr/cntl inputs are sampled on the crossing of positive edge of CK and negative edge of CK. Output (read) data is reference to the crossing of CK and CK (Both directions of crossing) CKE0-CKE1 Input Activates the SDRAM CK signal when high and deactivates the CK Signal When low. By deactivating the clock, CKE low initiates the Powe Down mode, or the Self-Refresh mode. Input Enables the associated SDRAM command decoder when low and disables the command decoder when high. When the command decoder is disbled, new command are ignored but previous operations continue. This signal provides for external rank selection on systems with multiple ranks Input /RAS,/ CAS, and /WE(ALONG WITH CS) define the command being entered. ODT0-ODT1 Input When high, termination resistance is enabled for all DQ, /DQ and DM pins, assuming the function is enabled in the Extended Mode Register Set (EMRS). VREF Supply Reference voltage for SSTL 18 Inputs. VDDQ Supply Power supply for the DDR II SDRAM output buffers to provide improved noise immunity. For all current DDR 2 unbuffered DIMM designs, VDDQ shares the same power plane as VDD pins. BA0-BA1 Input Selects which SDRAM BANK of four is activated. A0-A13 Input During a Bank Activate command cycle, Address input defines the row address(RA0-RA13) During a Read or Write command cycle. Address input defines the column address. In addition to the column address. AP is used to invoke autoprecharge operation at the end of the burst read or write cycle. If AP is high, autoprecharge is selected and BA0, BA1 defines the bank to be precharged. If AP is low, autoprecharge is disbled. During a precharge command cycle, AP is used in conjunction with BA0, BA1 to control which bank(s) to precharge. If AP is high, all banks will be precharged regardless of the state of BA0, BA1. If AP is low, BA0, BA1 are used to define which bank to precharge. DQ0-DQ63 CB0-CB7 In/Out Data and Check Bit Input/Output pins. DM0-DM8 Input DM is and input mask signal for write data. Input data is masked when DM is sampled High coincident with that input data during a write access. DM is sampled on both edges of DQS. Although DM pins are input only, the DM loading matches the DQ and DQS loading. VDD, VSS Supply Power and ground for DDR2 SDRAM input buffers, and core logic. VDD and VDDQ pins are tied to VDD/VDDQ planes on these modules. DQS0-DQS8 DQS0-DQS8 In/Out Data strobe for input and output data. For Rawcards using x16 organized DRAMs DQ0-7 connect to the LDQS pin of the DRAMs and DQ8-17 connect to the UDQS pin of the DRAM SA0-SA2 Input These signals and tied at the system planar to either VSS or VDD to configure the serial SPD EERPOM address range. SDA In/Out This bi-directional pin is used to transfer data into or out of the SPD EEPROM. A resistor must be connected from the SDA bus line to VDD to act as a pullup on the system board. SCL Input This signal is used to clock data into and out of the SPD EEPROM. A resistor may be connected from the SCL bus time to VDD to act as a pullup on the system board. VDD SPD Supply Power supply for SPD EEPROM. This supply is separate from the VDD/VDDQ power plane. EEPROM supply is operable from 1.7V to 3.6V. /S0-/S1 /RAS,/CAS,/WE 5 REV 3.0 DDR2-800 1GB SO-DIMM 200PIN With samsung 128Mx8 DRAM D2SS28081XH25AA FUNCTIONAL BLOCK DIAGRAM 6 REV 3.0 DDR2-800 1GB SO-DIMM 200PIN With samsung 128Mx8 DRAM D2SS28081XH25AA Timing Parameters by Speed Grade 7 REV 3.0 DDR2-800 1GB SO-DIMM 200PIN With samsung 128Mx8 DRAM D2SS28081XH25AA 8 REV 3.0 DDR2-800 1GB SO-DIMM 200PIN With samsung 128Mx8 DRAM D2SS28081XH25AA SERIAL PRESENCE DETECT Byte No. Function Described Function Supported Hex Value 0 # of Serial PD Bytes written during module production 128 Bytes 80 1 Total number of Bytes in SPD device 256 Bytes 08 2 Fundameatal memory type DDR2 SDRAM 08 3 # of row address on this assembly 14 0E 4 # of column address on this assembly 10 0A 5 # of module rows on this assembly 1 rank 60 6 Data width of this assembly 64bits 40 7 Reserved -- 00 8 Voltage interface level of this assembly SSTL 1.8V 05 9 DDR2 SDRAM cycle time at Max. Supported CAS latency=X 2.5ns 25 10 DDR2 SDRAM Access time from clock at CL=X 4.0ns 40 11 DIMM configuration type(address&command parity, data parity,ECC) Non parity/ECC 00 12 Refresh rate 7.8us 82 13 Primary DDR2 SDRAM width X8 08 14 Error checking DDR2 SDRAM width N/A 00 15 Reserved -- 00 16 DDR2 SDRAM device attributes:Burst lengths supported 4,8 0C 4 08 4,6,6 70 DDR2 SDRAM device attributes:# of banks on each DDR2 SDRAM 17 Device 18 DDR2 SDRAM device attributes: CAS latency supported 19 Reservedġ 20 DIMM type information 21 DDR2 SDRAM module attributes 22 DDR2 SDRAM device attributes : General 23 01 SO-DIMM 04 -- 00 50ohm ODT 07 DDR2 SDRAM cycle time at CL = X-1 3.75ns 30 24 DDR2 SDRAM access time from clock at CL = X-1 0.45ns 45 25 DDR2 SDRAM cycle time at CL = X-2 3.75ns 3D 26 DDR2 SDRAM access time from clock at CL = X-2 0.5ns 50 27 Minimum row precharge time(=tRP) 15ns 3C 28 Minimum row active to row active delay(=tRRD) 7.5ns 1E 29 Minimum RAS to CAS delay(=tRCD) 15ns 32 30 Minimum active precharge time(=tRAS) 45ns 2D 9 REV 3.0 DDR2-800 1GB SO-DIMM 200PIN With samsung 128Mx8 DRAM D2SS28081XH25AA Byte No. Function Described 31 Module rank density 32 Function Supported Hex Value 1GB 01 Command and address setup time before clock(=tIS) 0.17ns 17 33 Command and address hold time after clock(=tIH) 0.25ns 25 34 Data input setup time before strobe(=tDS) 0.05ns 05 35 Data input hold time after strobe(=tDH) 0.12ns 12 36 Write recovery time (tWR) 15ns 3C 37 Write to read CMD delay (tWTR) 7.5ns 1E 38 Read to precharge CMD delay (tRTP) 7.5ns 1E 39 Mem analysis probe TBD 00 40 Extension of byte 41 and 42 41 Active command period (tRC) 60ns 3C 42 Auto refresh to active/ Auto refresh command cycle (tRFC) 105ns 7F 43 SDRAM tCK cycle max (tCK max) 8ns 80 44 Dout to DQS skew 0.20ns 14 45 Data hold skew (tQHS) 0.30ns 1E 46 PLL relock time Undefined 00 -- -- Revision 1.0 12 E2 47 to 61 Undefined Reserved 62 SPD data revision code 63 Checksum for Bytes 0~ 62 -- 64 to 94 Manufacturer JEDEC ID code -- 95 to 98 Assembly serial # -- 99 to 127 Manufacturer specific data(may be used in future) Undefined 128 to 225 Open for customer use Undefined 10 06 REV 3.0 DDR2-800 1GB SO-DIMM 200PIN With samsung 128Mx8 DRAM D2SS28081XH25AA PACKAGE DIMENSIONS Unit:mm 67.60Ʋ0.15mm The used device is SAMSUNG, 128M x 8 ,FBGA DDR2 SDRAM Part No.: K4T1G084QG-BCF7 *8EA 11 REV 3.0 DDR2-800 1GB SO-DIMM 200PIN With samsung 128Mx8 DRAM D2SS28081XH25AA Declaration of Compliance with the RoHS Directive DATA SPECIALTIES CO.,LTD. Hereby declares that the products compliant with the European Union Directive 2002/95/EC for Restriction of the use of certain Hazardous Substances in Electrical and Electronic Equipment(RoHS Directive). Below list of DSL(DATA SPECIALTIES CO.,LTD.) products are Compliance. No. Substance Max. Conc. 1 Cd (Cadmium)
MMM-3033-DSL 价格&库存
很抱歉,暂时无法提供与“MMM-3033-DSL”相匹配的价格&库存,您可以联系我们找货
