mSATA SSD to 2.5 in. SATA Enclosure Adapter
Converter
MODEL NUMBER: P960-001-MSATA
Highlights
Boosts computer performance
by adding mSATA SSD speed
Supports SATA I, II and III SSDs
(1.5/3.0/6.0 Gbps)
Enclosed housing protects drive
Reduces system’s power
consumption
Plug-and-play—no software,
drivers or external power supply
System Requirements
mSATA drive
SATA host device
Package Includes
Access an mSATA solid state drive (SSD) with a standard SATA computer, SATA drive enclosure or
docking station by converting it into a 2.5 in. SATA SSD.
Description
The P960-001-MSATA mSATA SSD to 2.5 in. SATA Enclosure Adapter Converter lets you use an
mSATA SSD with a standard SATA-enabled computer, drive enclosure or docking station. To share data,
just remove the adapter’s cover, connect the drive to the mSATA connector, secure it with the included
screws, put the cover back, and connect the adapter to your computer’s SATA port. Or connect it to your
computer’s USB port using a USB docking station, such as Tripp Lite’s U339-000 (sold separately).
The enclosed housing protects the drive when used in applications requiring more durability, such as hotswap drive bays and external docking stations. The P960-001-MSATA supports SATA I, II and III drives
and data transfer rates up to 6 Gbps. It’s plug-and-play, so no software, drivers or external power supply
are required.
Features
Use an mSATA SSD as a Standard 2.5 in. SATA SSD
● Access an mSATA drive with a standard SATA computer, drive enclosure or docking station
Supports SATA I, II and III SSDs (1.5/3.0/6.0 Gbps)
Maximizes SATA III controller capabilities to boost data transfer speeds up to 6 Gbps
Enclosed housing protects drive in applications requiring more durability
High-efficiency mSATA SSD reduces system’s power consumption
Plug-and-play with no software, drivers or external power supply needed
Works with USB-enabled SATA docking stations, such as Tripp Lite’s U339-000 (sold separately)
Specifications
OVERVIEW
UPC Code
037332199249
Technology
SATA/eSATA
1/2
Adapter Converter
Mounting hardware
Screwdriver
Owner’s manual
PHYSICAL
Shipping Dimensions (hwd / cm)
2.54 x 12.19 x 16.51
Shipping Dimensions (hwd / in.)
1.00 x 4.80 x 6.50
Shipping Weight (kg)
0.14
Shipping Weight (lbs.)
0.30
WARRANTY
Product Warranty Period
(Worldwide)
3-year limited warranty
Product Warranty Period (U.S. &
Canada)
1-year limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“P960-001-MSATA”相匹配的价格&库存,您可以联系我们找货
