PWD-5532-03-SMA-79
PWD-5532-03-SMA-79
    CINCH
    模块
    RF Power Divider 2GHz ~ 18GHz Isolation (Min) 20dB Module
PWD-5532-03-SMA-79 数据手册
1 2 3 4 5 6 ZONE F REV C D E 7 ECO 18601 23117 24395 DESCRIPTION APPR. DATE 10/30/02 12/22/10 8/13/12 JRK F SCALE 2:1 2.50 63.5 E E 1.25 31.8 2X .375 9.5 .29 7.3 D D J2 2X .38 9.5 MIDWEST MICROWAVE .59 15.0 J1 .75 19.0 J3 PWD-5532-03-SMA-79 FREQ. 2-18 GHz MFR 34078 J4 .08 2.0 C A 4X .19 4.7 .38 9.5 1. ELECTRICAL SPECIFICATIONS: 1.1 FREQUENCY RANGE: 2.0 TO 18.0 GHz 1.2 INSERTION LOSS: 1.0 dB MAX. 1.3 ISOLATION: 20 dB MIN. 1.4 VSWR: 1.50:1 MAX. 1.5 OUTPUT UNBALANCE: 1.5.1 AMPLITIDE: 0.5 dB MAX. 1.5.2 PHASE: 5v MAX. 1.6 MAXIMUM INPUT POWER: 5 WATTS WITH OUTPUT LOAD VSWR ≤ 2.0:1 10 WATTS WITH OUTPUT LOAD VSWR ≤ 1.5:1 20 WATTS WITH OUTPUT LOAD VSWR ≤ 1.4:1 30 WATTS WITH OUTPUT LOAD VSWR ≤ 1.2:1 1.7 OPERATING TEMP. RANGE: -65vC TO +125vC B Model No. Cage Code RoHS 34078 Title POWER DIVIDER OUTLINE DRAWING 3 4 Document is property of Emerson Network Power Connectivity Solutions. It is confidential in nature, non,transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. UNLESS OTHERWISE SPECIFIED UNITS: INCHES .XX u.02 .XXX u.005 ANGLES u1v 5 Material 3RD ANGLE PROJECTION This PROPRIETARY 3. DIMENSIONS IN BRACKETS ARE MILLIMETERS. 2 MIDWEST MICROWAVE PWD-5532-03-SMA-79 2. FINISHING: GRAY OVER MIL-E-15090 TYPE II, CLASS 2 OVER MIL-C-5541 CLASS 3A. MEETS MIL-F-14072 AND MIL-E-5400. 2.1 MARK UNIT AS SHOWN. 1 C 4X SMA FEMALE CONN. PER MIL-PRF-39012 NOTES: UNLESS OTHERWISE SPECIFIED. B 3X .38 9.6 2X O .104 2.6 THRU Drawing No. Drawn by CWW Date 10/3/12 Approved by Date JRK 10/4/12 Rev. Finish PWD-5532-03-SMA-79-01 E Size C 6 DO NOT SCALE DRAWING Scale 3:1 Sheet 1 of 1 7 A
PWD-5532-03-SMA-79 价格&库存
很抱歉,暂时无法提供与“PWD-5532-03-SMA-79”相匹配的价格&库存,您可以联系我们找货
