PWD-5511-T2-TNC-79
PWD-5511-T2-TNC-79
    CINCH
    模块
    CONN 2WAY DIVIDER
PWD-5511-T2-TNC-79 数据手册
361545_pp99_106.qxp:1 12/13/07 8:20 AM Page 103 Power Dividers Two Way Isolated 500 MHz - 18.0 GHz High Performance • Full Octave, Multi-Octave, and Ultra-Wideband Performance • Excellent Phase and Amplitude Tracking • Small Lightweight Rugged Stripline Construction • Meets Mil-E-5400 and Mil-E16400 Midwest Microwave's series of high performance isolated Power Dividers are small, lightweight, ruggedly constructed stripline units that possess inherently low insertion loss and VSWR with high isolation and excellent phase and amplitude tracking. Units are available in octave, multi-octave, and ultra-wideband frequency bandwidths covering the entire range of 0.5 - 18.0 GHz. CASE STYLE 1, 2, 3 & 4 FR EQU EN C Y R AN GE (GH z ) C ASE STYLE CASE STYLE 5, 6, 7, 8 & 9 ELECTRICAL SPECIFICATIONS AMPLITU D E B ALAN C E (dB ) MOD EL N U MB ER IN -LIN E TEE** PH ASE B ALAN C E (degrees) IN SER TION LOSS (dB ) max ISOLATION (dB ) min VSWR max IN PU T POWER max (W) OC TAVE B AN D WID TH TYPES 1.0-2.0 2 6 PWD -5511-02-SMA-79 0.2 2 0.4 20 1.25 3 2.0-4.0 2 7 PWD -5512-02-SMA-79 0.2 2 0.4 20 1.35 3 4.0-8.0 1 5 PWD -5514-02-SMA-79 0.2 3 0.5 20 1.35 3 8.0-12.4 1 5 PWD -5515-02-SMA-79 0.3 5 0.5 20 1.5 3 12.4-18.0 1 5 PWD -5517-02-SMA-79 0.3 5 0.5 20 1.5 3 MU LTI-OC TAVE B AN D WID TH TYPES .5-2.0 2 8 PWD -5520-02-SMA-79 0.2 4 0.5 20 1.25 3 2.0-8.0 2 7 PWD -5522-02-SMA-79 0.3 4 0.5 20 1.35 5 6.0-18.0 1 5 PWD -5526-02-SMA-79 0.3 5 0.5 18 1.50 3 2.0-18.0 3 N/A PWD -5532-02-SMA-79 0.25 8 1.0 15 17 1.60 10 2.0-18.0 2 7 PWD -5533-02-SMA-79 0.3 5 0.8 17 15 1.50 10 0.5-18.0 4 9 PWD -5530-02-SMA-79 0.3 5 0.3+0.1f 10 18 1.50 10 ** Note: for TEE Type Case Style, substitute "T2" for "02" in Model Number C ASE STYLE Note: MECHANICAL SPECIFICATIONS A B C INCHES (mm) D E WEIGH T Oz Gr 1 1.00 (25.4) 0.50 (12.7) 0.250(6.35) 1.00 (25.4) 0.08 (1.91) 1.00 27 2 2.00 (50.8) 0.50 (12.7) 0.250 (6.35) 1.00 (25.4) 0.08 (1.91) 1.60 44 3 2.25 (57.1) 0.50 (12.7) 0.250 (6.35) 1.00 (25.4) 0.08 (1.91) 1.70 46 4 5.50 (139.7) 0.75 (19.1) 0.250 (6.35) 1.00 (25.4) 0.20 (5.08) 3.50 96 5 1.00 (25.4) 0.50 (12.7) 0.22 (5.58) 0.050 (12.7) 0.08 (1.91) 0.60 16 6 2.00 (50.8) 0.50 (12.7) 0.22 (5.58) 0.070 (17.8) 0.08 (1.91) 1.20 33 7 2.00 (50.8) 0.50 (12.7) 0.22 (5.58) 0.050 (12.7) 0.08 (1.91) 1.10 30 8 2.00 (50.8) 0.50 (12.7) 0.22 (5.58) 1.00 (25.4) 0.08 (1.91) 1.40 38 9 5.50 (139.7) 0.75 (19.1) 0.40 (10.16) 0.050 (12.7) 0.08 (1.91) 1.80 49 1. Specifications assume that all of the outputs are terminated with a load that has a VSWR not greater than 2.0:1. 2. TNC or NType output connectors are available by substituting "TNC" or "NNN" for "SMA" in the Model Number. 103
PWD-5511-T2-TNC-79 价格&库存
很抱歉,暂时无法提供与“PWD-5511-T2-TNC-79”相匹配的价格&库存,您可以联系我们找货
