PWD-5522-12-TNC-79
PWD-5522-12-TNC-79
    CINCH
    模块
    CONN12WAYDIVIDER
PWD-5522-12-TNC-79 数据手册
361545_pp99_106.qxp:1 12/13/07 8:20 AM Page 106 Power Dividers • • • • Eight Way • Twelve Way 500 MHz - 18.0 GHz High Performance Full 2.0 - 18.0 GHz bandwidth units Low VSWR - High Isolation Rugged Stripline Construction Meets Mil-E-5400 and Mil-E16400 Environment Midwest Microwave's series of high performance isolated Power Dividers are small, lightweight, ruggedly constructed stripline units that possess inherently low insertion loss and VSWR with high isolation and excellent phase and amplitude tracking. Units are available in multi-octave, and ultrawideband frequency bandwidths covering the entire range of 0.5 - 18.0 GHz. FREQUENCY RANGE (GHZ) CASE STYLE .50-2.0 2.0-8.0 5.0-19.0 2-0-18.0 0.5-18.0 1 2 3 2 4 .50-2.0 2.0-18.0 6.0-18.0 2.0-19.0 0.5-18.0 ELECTRICAL SPECIFICATIONS MODEL NUMBER 8 6 5 6 7 A 3.00 (76.2) 4.60 (116.8) 3.50 (88.9) 5.20 (132.1) 4.60 (116.8) 5.20 (132.1) 7.50 (190.5) 5.20 (132.1) PHASE BALANCE (degrees) INSERTION LOSS (dB) max EIGHT WAY MULTI-OCTAVE TYPES PWD-5520-08-SMA-79 0.5 5 1.0 PWD-5522-08-SMA-79 0.8 10 1.2 PWD-5526-08-SMA-79 .03f 0.4f 0.4+.08f PWD-5532-08-SMA-79 0.6 10 0.7+.10f PWD-5530-08-SMA-79 1.0 15 1.0+.25f TWELVE WAY MULTI-OCTAVE TYPES PWD-5520-12-SMA-79 0.6 10 1.2 PWD-5522-12-SMA-79 0.8 10 1.0+.14f PWD-5526-12-SMA-79 0.8 10 0.4+.10f PWD-5532-12-SMA-79 1.0 15 1.0+.14f PWD-5530-12-SMA-79 1.2 20 1.2+.30f * Output port, 1.35:1 max CASE STYLE 1 2 3 4 5 6 7 8 AMPLITUDE BALANCE (dB) B 0.15 (3.8) 0.55 (14.0) 0.50 (12.7) 1.00 (25.4) 0.25 (6.4) 1.13 (28.7) 1.50 (38.1) 0.50 (12.7) MECHANICAL SPECIFICATIONS - C 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 (6.4) (6.4) (6.4) (6.4) (6.4) (6.4) (6.4) (6.4) 4.00 4.00 4.00 4.00 6.00 6.00 6.00 6.00 D (101.6) (101.6) (101.6) (101.6) (152.4) (152.4) (152.4) (152.4) E 0.50 (12.7) 0.25 (6.4) 0.20 (5-1) 0.20 (5-1) 0.25 (6.4) 0.25 (6-4) 0.25 (6-4) 1.00 (25.4) F 1.00 (25.4) 0.25 (6.4) 0.20 (5-1) 0.20 (5-1) 0.25 (6.4) 0.25 (6.4) 0.25 (6-4) 1.00 (25.4) INCHES (mm) G ISOLATION (dB) min VSWR max 15 15 20 15 15 1.50 1.50* 1.50 1.50 1.50 15 15 15 15 15 H 1.50 1.50 1.50 1.50 1.50 I 2.60 (66.0) 3.00 (76.2) 2.00 (50.8) 3.50 (88.9) 3.50 (88.9) 3.50 (88.9) 2.50 (63.5) 3.60 (91.4) 3.60 (91.4) 3.20 (81.3) 3.60 (91.4) 3.60 (91.4) 3.50 (88.9) 2.60 (66.0) 2.60 (66.0) 2.94 (74.7) 5.50 (139.7) 5.50 (139.7) 4.50 (114.3) 5.50 (139.7) 5.50 (139.7) 4.20 (106.7 4.00 (101.6) 4.00 (101.6) Note: 1. Specifications assume that all of the outputs are terminated with a load that has a VSWR not greater than 2.0:1. 2. TNC or NType output connectors are available by substituting "TNC" or "NNN" for "SMA" in the Model Number. 106 Oz 8.4 10.5 9.0 13.9 24.0 21.2 24.5 21.2 INPUT POWER max (W) 10 10 10 50 30 10 10 10 30 30 WEIGHT Gr 239 298 273 390 680 600 700 600 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Emerson Connectivity Solutions: PWD-5522-12-TNC-79
PWD-5522-12-TNC-79
物料型号: - 八路多八度类型:PWD-5520-08-SMA-79、PWD-5522-08-SMA-79、PWD-5526-08-SMA-79、PWD-5532-08-SMA-79、PWD-5530-08-SMA-79 - 十二路多八度类型:PWD-5520-12-SMA-79、PWD-5522-12-SMA-79、PWD-5526-12-SMA-79、PWD-5532-12-SMA-79、PWD-5530-12-SMA-79
器件简介: - 这些功率分配器是小型、轻便、坚固的条带线单元,具有固有的低插入损耗和VSWR,以及高隔离度和出色的相位及幅度跟踪。
引脚分配: - 文档中没有提供具体的引脚分配图,但提到了SMA、TNC或N型输出连接器的可用性。
参数特性: - 频率范围:0.5-18.0 GHz - 典型幅度平衡:0.5 dB 至 1.2 dB - 典型相位平衡:5 度至 20 度 - 最大插入损耗:0.4 dB 至 1.2 dB - 最小隔离度:15 dB - 最大VSWR:1.50 - 最大输入功率:10 W 至 50 W
功能详解: - 这些功率分配器适用于多八度和超宽带频率带宽,覆盖整个0.5 - 18.0 GHz的范围。 - 符合Mil-E-5400和Mil-E-16400环境标准。
应用信息: - 适用于需要高性能隔离和功率分配的应用。
封装信息: - 提供了不同尺寸的封装,包括A、B、C、D、E、F、G、H、I的尺寸,以及相应的重量。
PWD-5522-12-TNC-79 价格&库存
很抱歉,暂时无法提供与“PWD-5522-12-TNC-79”相匹配的价格&库存,您可以联系我们找货
