PWD-5526-12-NNN-79
PWD-5526-12-NNN-79
    CINCH
    模块
    RF Power Divider 6GHz ~ 18GHz Isolation (Min) 15dB Module
PWD-5526-12-NNN-79 数据手册
361545_pp99_106.qxp:1 12/13/07 8:20 AM Page 106 Power Dividers • • • • Eight Way • Twelve Way 500 MHz - 18.0 GHz High Performance Full 2.0 - 18.0 GHz bandwidth units Low VSWR - High Isolation Rugged Stripline Construction Meets Mil-E-5400 and Mil-E16400 Environment Midwest Microwave's series of high performance isolated Power Dividers are small, lightweight, ruggedly constructed stripline units that possess inherently low insertion loss and VSWR with high isolation and excellent phase and amplitude tracking. Units are available in multi-octave, and ultrawideband frequency bandwidths covering the entire range of 0.5 - 18.0 GHz. FREQUENCY RANGE (GHZ) CASE STYLE .50-2.0 2.0-8.0 5.0-19.0 2-0-18.0 0.5-18.0 1 2 3 2 4 .50-2.0 2.0-18.0 6.0-18.0 2.0-19.0 0.5-18.0 ELECTRICAL SPECIFICATIONS MODEL NUMBER 8 6 5 6 7 A 3.00 (76.2) 4.60 (116.8) 3.50 (88.9) 5.20 (132.1) 4.60 (116.8) 5.20 (132.1) 7.50 (190.5) 5.20 (132.1) PHASE BALANCE (degrees) INSERTION LOSS (dB) max EIGHT WAY MULTI-OCTAVE TYPES PWD-5520-08-SMA-79 0.5 5 1.0 PWD-5522-08-SMA-79 0.8 10 1.2 PWD-5526-08-SMA-79 .03f 0.4f 0.4+.08f PWD-5532-08-SMA-79 0.6 10 0.7+.10f PWD-5530-08-SMA-79 1.0 15 1.0+.25f TWELVE WAY MULTI-OCTAVE TYPES PWD-5520-12-SMA-79 0.6 10 1.2 PWD-5522-12-SMA-79 0.8 10 1.0+.14f PWD-5526-12-SMA-79 0.8 10 0.4+.10f PWD-5532-12-SMA-79 1.0 15 1.0+.14f PWD-5530-12-SMA-79 1.2 20 1.2+.30f * Output port, 1.35:1 max CASE STYLE 1 2 3 4 5 6 7 8 AMPLITUDE BALANCE (dB) B 0.15 (3.8) 0.55 (14.0) 0.50 (12.7) 1.00 (25.4) 0.25 (6.4) 1.13 (28.7) 1.50 (38.1) 0.50 (12.7) MECHANICAL SPECIFICATIONS - C 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 (6.4) (6.4) (6.4) (6.4) (6.4) (6.4) (6.4) (6.4) 4.00 4.00 4.00 4.00 6.00 6.00 6.00 6.00 D (101.6) (101.6) (101.6) (101.6) (152.4) (152.4) (152.4) (152.4) E 0.50 (12.7) 0.25 (6.4) 0.20 (5-1) 0.20 (5-1) 0.25 (6.4) 0.25 (6-4) 0.25 (6-4) 1.00 (25.4) F 1.00 (25.4) 0.25 (6.4) 0.20 (5-1) 0.20 (5-1) 0.25 (6.4) 0.25 (6.4) 0.25 (6-4) 1.00 (25.4) INCHES (mm) G ISOLATION (dB) min VSWR max 15 15 20 15 15 1.50 1.50* 1.50 1.50 1.50 15 15 15 15 15 H 1.50 1.50 1.50 1.50 1.50 I 2.60 (66.0) 3.00 (76.2) 2.00 (50.8) 3.50 (88.9) 3.50 (88.9) 3.50 (88.9) 2.50 (63.5) 3.60 (91.4) 3.60 (91.4) 3.20 (81.3) 3.60 (91.4) 3.60 (91.4) 3.50 (88.9) 2.60 (66.0) 2.60 (66.0) 2.94 (74.7) 5.50 (139.7) 5.50 (139.7) 4.50 (114.3) 5.50 (139.7) 5.50 (139.7) 4.20 (106.7 4.00 (101.6) 4.00 (101.6) Note: 1. Specifications assume that all of the outputs are terminated with a load that has a VSWR not greater than 2.0:1. 2. TNC or NType output connectors are available by substituting "TNC" or "NNN" for "SMA" in the Model Number. 106 Oz 8.4 10.5 9.0 13.9 24.0 21.2 24.5 21.2 INPUT POWER max (W) 10 10 10 50 30 10 10 10 30 30 WEIGHT Gr 239 298 273 390 680 600 700 600 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Cinch Connectivity Solutions: PWD-5526-12-NNN-79
PWD-5526-12-NNN-79 价格&库存
很抱歉,暂时无法提供与“PWD-5526-12-NNN-79”相匹配的价格&库存,您可以联系我们找货
