RFDIP1608060L0T
RFDIP1608060L0T
    WALSIN(华新科)
RFDIP1608060L0T 数据手册
Table of contents INDEX Subject Page ORDERING CODE…………………………....…………………………………………………………………………………..……………1~5 CHIP ANTENNA…………………………....……………………………………………………………………………………………………6~12 ■ 1.575GHz GPS BAND WORKING FREQUENCY ■ Bluetooth/WiFi BAND WORKING FREQUENCY ■ WiMAX BAND WORKING FREQUENCY HIGH FREQUENCY MULTILAYER BAND PASS FILTER………………………………………………………………………..………13~27 ■ 2.4GHz BAND WORKING FREQUENCY ■ WiMAX BAND WORKING FREQUENCY ■ 5GHz BAND WORKING FREQUENCY ■ 1558 ~ 1606 MHz GNSS Band Applications ■ 860~960MHz/1805~2025 MHz Band Application ■ MoCA / Docsis Application ■ LTE BAND Application HIGH FREQUENCY MULTILAYER BALANCED FILTER……………………………………………………………………..…………28~30 ■ 2.4GHz BAND WORKING FREQUENCY HIGH FREQUENCY MULTILAYER LOW PASS FILTER………………………………………………………………………..…………31~39 ■ GSM850/900GHz BAND WORKING FREQUENCY ■ DCS/PCS BAND WORKING FREQUENCY ■ 2.4GHz BAND WORKING FREQUENCY ■ 5GHz BAND WORKING FREQUENCY ■ LTE BAND APPLICATION ■ MoCA Application HIGH FREQUENCY MULTILAYER HIGH PASS FILTER………………………………………………………………………..…………40~41 ■ 2496 ~ 2690 MHz BAND WORKING FREQUENCY ■ 5GHz BAND WORKING FREQUENCY ■ MoCA Application BALUN TRANSFORMERS………………………………………………………………………………………………………..……………42~50 ■ ISM Band 2.4GHz Application ■ ISM Band 5GHz Application ■ LTE Band Application ■ GSM 850/ GSM 900/ DCS1800/ PCS1900 Application DIPLEXER…………………………………………………………………………………………………………………………..……………51~58 ■ ISM Band 2.4GHz Application ■ GPS 1.575GHz/ISM 2.4GHz/5GHz Band Application ■ 892 MHz & 1.94GHz Band Working Frequency TRIPLEXER……………………………………………………………………………………………………………………………..……………59 ■ GPS 1.575GHz/ISM 2.4GHz/5GHz Band Application COMMON MODE FILTER……………………………………………………………………………………………………………..……………60 ■ DISCRETE CMF for HIGH SPEED TRANSMISSION LINES、USB2.0、IEEE1394、LVDS(mini) COUPLER…………………………………………………………………………………………………………………………..……………61~64 ■ ISM Band 2.4GHz Application ■ ISM Band 2.4/5GHz Application ■ LTE BAND Application SAW FILTER………………………………………………………………………………………………………………………..……………65~70 ANTENNA SWITCH (GPIO) ……………………………………………………………………………………………………..……………71~72 ANTENNA SWITCH (MIPI) …………………………………………………………………………………………………………..……………73 ANTENNA SWITCH MODULE (MIPI) ………………………………………………………………………………………………..……………74 Customer made Antenna………………………………………………………………………………………………………..……………75~85 ■ Dipole Antenna (None Cable and With Cable) ■ PCB Antenna ■ FPA Antenna ■ Metal Antenna ■ NFC Antenna ■ Connector *The specifications are subject to change or our products in it may be discontinued without advance notice. Please check with our sales representatives or product engineers before ordering. *This catalog has only typical specifications because there is no space for detailed specifications. Therefore, please approve our product specifications or transact the approval sheet for product specifications before ordering. 1 ORDERING CODE  CHIP ANTENNA RF ANT 321612 0 A 5 T Type code Product code Dimension code Unit of dimension Application Specification Packing RF/RG: device ANT : Antenna FRA : Free Antenna ECA : SMD Antenna Per 2 digits of Length, Width, Thickness 321612 = Length =32 Width = 16 Thickness = 12 0 : 0.1 mm 1 : 1.0 mm A: 2.4GHz ISM Band E : GPS 1.5GHz L : 2.4/5.2/5.8GHz Tri Band W : WiMAX Code from 0~9 dependent on different electrical specification T: 7” Reeled G: 13” Reeled  HIGH FREQUENCY MULTILAYER BAND PASS FILTER RF BPF 322515 0 A 4 T Type code Product code Dimension code Unit of dimension Application Specification Packing RF device BPF : Band Pass Filter Per 2 digits of Length, Width, Thickness 322515 = Length =32 Width = 25 Thickness = 15 0 : 0.1 mm 1 : 1.0 mm A : 2.4GHz ISM Band W : WiMAX K : ISM 5.2/5.8 Dual Band Code from 0~9 dependent on different electrical specification T: 7” Reeled G: 13” Reeled  HIGH FREQUENCY MULTILAYER BALANCED FILTER RF BPB 252009 0 A 7 T Type code Product code Dimension code Unit of dimension Application Specification Packing RF/RG: device BPB : Balanced Type Band Pass Filter Per 2 digits of Length, Width, Thickness 252009 = Length =25 Width = 20 Thickness = 09 0 : 0.1 mm 1 : 1.0 mm A : 2.4GHz ISM Band W : WiMAX Code from 0~9 dependent on different electrical specification T: 7” Reeled G: 13” Reeled  HIGH FREQUENCY MULTILAYER LOW PASS FILTER RF LPF 201211 0 A 0 T Type code Product code Dimension code Unit of dimension Application Specification Packing RF device LPF : Low Pass Filter Per 2 digits of Length, Width, Thickness 201210 = Length =20 Width = 12 Thickness = 11 0 : 0.1 mm 1 : 1.0 mm A : 2.4GHz ISM Band K : ISM 5.2/5.8 Dual Band Code from 0~9 dependent on different electrical specification T: 7” Reeled G: 13” Reeled  HIGH FREQUENCY MULTILAYER HIGH PASS FILTER RF HPF 252009 0 L 0 T Type code Product code Dimension code Unit of dimension Application Specification Packing RF device HPF : High Pass Filter Per 2 digits of Length, Width, Thickness 252009 = Length =2.5 Width = 2.0 Thickness = 0.9 0 : 0.1 mm 1 : 1.0 mm L : 2.4/4.9/5.2/5.8GHz Multiband Application Code from 0~9 dependent on different electrical specification T: 7” Reeled G: 13” Reeled  BALUN TRANSFORMERS RF BLN 201208 0 A 4 T Type code Product code Dimension code Unit of dimension Application Specification Packing Code from 0~9 dependent on different electrical specification T: 7” Reeled G: 13” Reeled RF/RG: device 2 BLN : BALUN Per 2 digits of Length, Width, Thickness 201208 = Length =20 Width = 12 Thickness = 08 0 : 0.1 mm 1 : 1.0 mm A : 2.4GHz ISM Band K : ISM 5.2/5.8 Dual Band ORDERING CODE  DIPLEXER RF DIP Type code Product code RF device 201210 0 L 0 T Dimension code Unit of dimension Application Specification Packing Per 2 digits of Length, Width, Thickness 201210 = Length =20 Width = 12 Thickness = 10 DIP : Diplexer 0 : 0.1 mm 1 : 1.0 mm Code from 0~9 dependent on different electrical specification L : 2.4/4.9/5.2/5.8GHz Multiband Application T : 7” Reeled G:13” Reeled  TRIPLEXER RF TIP 2109 A T M0T63 Type code Product code Dimension code Pin Define Application Specification RF device Per 2 digits of Length, Width, Thickness e.g. : 21 = Length 2.0 mm, Width 1.2 mm, 09= Thickness 0.9 mm TIP : Triplexer Design Code T: GPS/ ISM 2.4GHz/5 GHz Design Code  COMMON MODE FILTER RF CMF 122010 0 M 3 T Type code Product code Dimension code Unit of dimension Application Specification Packing Code from 0~9 dependent on different electrical specification T : 7” Reeled RF/RG: device CMF : Common Mode Filter Per 2 digits of Length, Width. 122010 = Length =12 Width = 20 Thickness = 10 0 : 0.1 mm 1 : 1.0 mm M: USB 2.0/ IEEE1394  COUPLER RF CPL 18 10 B 2450 T Type code Product code Dimension code Coupling Factor Unit Application Packing RF device e.g. : 18 = Length 16, Width 08, 15= Length 10, Width 05, Coupler 10 dB dB 2.4 GHZ ISM Band T : 7” Reeled  SAW FILTER SF 1411 Product code Dimension code Per 2 digits of Length, Width 1411= Length 1.4mm Width 1.1mm SF:SAW Filter DF:SAW DUPLEXER 2595 B38 03 T Frequency Application Serial Number Packing 2595:Center Freq (2595MHz) B38:Band38 Design Code T: 7” Reeled  ANTENNA SWITCH RF ASW D H2418A T Type code Product code Application Serial Number Packing RF device ASW: Antenna Switch D: SP8T Design Code T: 7” Reeled  ANTENNA SWITCH MODULE RM ASM N T1492A T Type code Product code Application Serial Number Packing RM: Walsin RF Module Device ASM: Antenna Switch Module N: SP16T Design Code T: 7” Reeled 3 ORDERING CODE  Dipole Antenna RF DPA 8709 00 S B A B 8 01 Type code Product code Dimension code Cable Length code Connector Brand code Type of Connector code Application code Project status code Wire Diameter code Project code RF device DPA: Dipole Antenna Per 2 digits of Length, Width 8709 = Length = 87 Width = 9.95 A: N C:MCX D:IPEX III E: IPEX IV F: IPEX A13 2 digits for cable H: Hirose length I: IPEX 00= K:F None Cable M: MMCX S: SMA T: TNC U:MURATA N: None 0: 0GHz 5: 5 GHz A: 2.4GHz ISM band A: Reverse Female B: GSM 900/1800 dual B: Reverse Male band F: Female G: GPS band M: Male L: 2.4/5.2/5.8 GHz N: None tri-band T:LTE band U:UHF W: WCDMA band B: MP T:During Test X: Pile Run 0:None 1:∅0.81 2:∅1.32 3:∅1.13 4:Low Loss∅1.13 5:∅0.50 6:RG316 7:∅1.37 8:RG178 9:Low Loss∅1.37 A:RG174 B:1.5C-2V 01~99 series number  PCB Antenna RF PCA 4305 10 N N Type code Product code Dimension code Cable Length code Connector Brand code Type of Connector code RF device A: N C:MCX D:IPEX III E: IPEX IV Per 2 digits of 2 digits for cable F: IPEX A13 Length, Width length H: Hirose PCA: 4305 = 10= I: IPEX PCB Antenna Length = 43 Cable Length: K:F Width = 5 10cm M: MMCX S: SMA T: TNC U:MURATA N: None A B 4 01 Application code Project status code Wire Diameter code Project code 0: 0GHz 5: 5 GHz A: 2.4GHz ISM band A: Reverse Female B: GSM 900/1800 dual B: Reverse Male band F: Female G: GPS band M: Male L: 2.4/5.2/5.8 GHz N: None tri-band T:LTE band U:UHF W: WCDMA band B: MP T:During Test X: Pile Run 0:None 1:∅0.81 2:∅1.32 3:∅1.13 4:Low Loss∅1.13 5:∅0.50 6:RG316 7:∅1.37 8:RG178 9: Low Loss∅1.37 A:RG174 B:1.5C-2V 01~99 series number  FPA Antenna RF FPA 3025 10 I M A B 3 01 Type code Product code Dimension code Cable Length code Connector Brand code Type of Connector code Application code Project status code Wire Diameter code Project code RF device A: N C:MCX D:IPEX III E: IPEX IV Per 2 digits of 2 digits for cable F: IPEX A13 Length, Width length H: Hirose FPA: 3025 = 10= I: IPEX FPA Antenna Length = 30 Cable Length: K:F Width = 25 10cm M: MMCX S: SMA T: TNC U:MURATA N: None 0: 0GHz 5: 5 GHz A: 2.4GHz ISM band A: Reverse Female B: GSM 900/1800 dual B: Reverse Male band F: Female G: GPS band M: Male L: 2.4/5.2/5.8 GHz N: None tri-band T:LTE band U:UHF W: WCDMA band B: MP T:During Test X: Pile Run 0:None 1:∅0.81 2:∅1.32 3:∅1.13 4:Low Loss∅1.13 5:∅0.50 6:RG316 7:∅1.37 8:RG178 9: Low Loss∅1.37 A:RG174 B:1.5C-2V 01~99 series number  Metal Antenna RF MTA 3109 10 I M L B 7 01 Type code Product code Dimension code Cable Length code Connector Brand code Type of Connector code Application code Project status code Wire Diameter code Project code RF device 4 MTA: Metal Antenna A: N C:MCX D:IPEX III E: IPEX IV Per 2 digits of 2 digits for cable F: IPEX A13 Length, Width length H: Hirose 3109 = 10= I: IPEX Length = 31 Cable Length: K:F Width = 9 10cm M: MMCX S: SMA T: TNC U:MURATA N: None 0: 0GHz 5: 5 GHz A: 2.4GHz ISM band A: Reverse Female B: GSM 900/1800 dual B: Reverse Male band F: Female G: GPS band M: Male L: 2.4/5.2/5.8 GHz N: None tri-band T:LTE band U:UHF W: WCDMA band B: MP T:During Test X: Pile Run 0:None 1:∅0.81 2:∅1.32 3:∅1.13 4:Low Loss∅1.13 5:∅0.50 6:RG316 7:∅1.37 8:RG178 9: Low Loss∅1.37 A:RG174 B:1.5C-2V 01~99 series number ORDERING CODE  Cable Assembly RF CBA 1613 10 I M 3 B 7 01 Type code Product code Dimension code Cable Length code Connector Brand code Type of Connector code Application code Project status code Wire Diameter code Project code RF device CBA: Cable Assembly Per 2 digits of Length, Width 1613 = Length = 16.8 Width = 13.7 A: N C:MCX D:IPEX III E: IPEX IV 2 digits for cable F: IPEX A13 length H: Hirose 10= I: IPEX Cable Length: K:F 10cm M: MMCX S: SMA T: TNC U:MURATA N: None A: Reverse Female B: Reverse Male F: Female M: Male N: None 0: 0GHz 3: 3GHz 6: 6GHz B: MP T:During Test X: Pile Run 0:None 1:∅0.81 2:∅1.32 3:∅1.13 4:Low Loss∅1.13 5:∅0.50 6:RG316 7:∅1.37 8:RG178 9: Low Loss∅1.37 A:RG174 B:1.5C-2V 01~99 series number  Connector RF CON 0201 00 D F 6 B 0 01 Type code Product code Dimension code Cable Length code Connector Brand code Type of Connector code Application code Project status code Wire Diameter code Project code RF device CON: Connector Per 2 digits of Length, Width 0201 = Length = 2.05 Width = 1.40 A: N C:MCX D:IPEX III E: IPEX IV F: IPEX A13 2 digits for cable H: Hirose length I: IPEX 00= K:F None Cable M: MMCX S: SMA T: TNC U:MURATA N: None A: Reverse Female B: Reverse Male F: Female M: Male N: None 0: 0GHz 3: 3GHz 6: 6GHz B: MP T:During Test X: Pile Run 0:None 1:∅0.81 2:∅1.32 3:∅1.13 4:Low Loss∅1.13 5:∅0.50 6:RG316 7:∅1.37 8:RG178 9: Low Loss∅1.37 A:RG174 B:1.5C-2V 01~99 series number  NFC Antenna RF NFC 0201 00 N N N B 0 01 Type code Product code Dimension code Cable Length code Connector Brand code Type of Connector code Application code Project status code Wire Diameter code Project code RF device Per 2 digits of NFC:Near Length, Width Field 5339 = Communicati Length = 53.7 on Antenna Width = 39.7 A: N C:MCX D:IPEX III E: IPEX IV F: IPEX A13 2 digits for cable H: Hirose length I: IPEX 00= K:F None Cable M: MMCX S: SMA T: TNC U:MURATA N: None A: Reverse Female B: Reverse Male F: Female M: Male N: None N: NFC B: MP T:During Test X: Pile Run 0:None 1:∅0.81 2:∅1.32 3:∅1.13 4:Low Loss∅1.13 5:∅0.50 6:RG316 7:∅1.37 8:RG178 9: Low Loss∅1.37 A:RG174 B:1.5C-2V 01~99 series number  WPC Antenna RF WPC 5830 00 N N N B 0 01 Type code Product code Dimension code Cable Length code Connector Brand code Type of Connector code Application code Project status code Wire Diameter code Project code RF device WPC: Wireless Power Charging Antenna Per 2 digits of Length, Width 5830 = Length = 58 Width = 30 A: N C:MCX D:IPEX III E: IPEX IV F: IPEX A13 2 digits for cable H: Hirose length I: IPEX 00= K:F None Cable M: MMCX S: SMA T: TNC U:MURATA N: None A: Reverse Female B: Reverse Male F: Female M: Male N: None N: NFC B: MP T:During Test X: Pile Run 0:None 1:∅0.81 2:∅1.32 3:∅1.13 4:Low Loss∅1.13 5:∅0.50 6:RG316 7:∅1.37 8:RG178 9: Low Loss∅1.37 A:RG174 B:1.5C-2V 01~99 series number Remark: 1. Central Frequency should be defined after customers’ application approval. 5 CHIP ANTENNA CHIP ANTENNA  STRUCTURE AND PIN ASSOCIATED STRUCTURE A a STRUCTURE C a M a rk W STRUCTURE B L T S o ld e r in g t e r m in a l I d e n t if ic a t io n m a rk M ar k F e e d in g STRUCTURE D 6 STRUCTURE E STRUCTURE F STRUCTURE G CHIP ANTENNA  STRUCTURE AND DIMENSION Unit: mm Structure\ Dimension L W T a 10 ± 0.20 3.2 ± 0.20 0.8 ± 0.10 0.8 ± 0.10 2.0 ± 0.20 1.25 ± 0.20 0.90 ± 0.10 3.20 ± 0.20 1.60 ± 0.20 A 5.20 ± 0.20 b c d 1 2 3 0.25 ± 0.15 - - - - - - 0.60 ± 0.10 0.25 ± 0.20 - - - - - - 1.20 ± 0.10 0.25 ± 0.15 - - - - - - 1.30 ± 0.20 0.40 ± 0.20 - - - - - - 1.15 ± 0.10 0.40 ± 0.25 - - - - - - 1.15 ± 0.15 0.40 ± 0.25 - - - - - - 2.00 ± 0.20 5.8 + 0.1 - 0.3 3.0+0.1 -0.3 1.1+0.2 -0.1 0.4 ± 0.25 - - - - - - 8.00 ± 0.20 1.05 ± 0.20 0.80 ± 0.10 0.30 ± 0.20 - - - - - - 9.10 ± 0.20 3.00 ± 0.20 2.00 ± 0.10 0.20 ± 0.20 - - - - - - 9.50± 0.20 2.10 ± 0.20 1.15 ± 0.10 0.50 ± 0.30 - - - - - - B 5.90.3 5.10.3 1.10.1 0.450.2 1.00.2 1.00.2 2.00.2 1.00.2 1.00.2 1.00.2 C 7.60.3 3.50.2 1.10.1 0.80.2 0.80.2 0.80.2 0.50.2 0.50.2 0.80.2 0.500.2 Structure\ Dimension L W T PW P1 P2 P3 P4 P5 D 9.90±0.15 3.70±0.15 3.80±0.20 3.48±0.10 1.4±0.10 1.9±0.10 2.4±0.15 - - E 19.0±0.15 3.00±0.15 3.80±0.20 3.00±0.10 1.0±0.10 1.0±0.10 1.0±0.10 1.0±0.10 - F 12.8±0.15 3.90±0.15 1.10±0.10 1.00±0.10 2.0±0.10 2.0±0.10 2.0±0.10 2.0±0.10 2.0±0.10 G 12.0±0.15 4.00±0.15 2.00±0.10 3.60±0.10 1.0±0.10 1.0±0.10 1.0±0.10 - - 7 CHIP ANTENNA  ELECTRICAL SPECIFICATION 1.575GHz BAND WORKING FREQUENCY Part Number Frequency Range (GHz) Azimuth Beamwidth ( MHz ) Gain (dBi) VSWR (max.) Impedance (Ω) Polarization Size (mm) Structure RFANT5830110E0T 1.575 Omni-directional 0~2 2.0 50 Linear 5.80x3.00x1.10 A RFECA1003011E0T 1.575 Omni-directional 2~3 2.0 50 Linear 10.0x3.20x0.80 A RFECA3216060E□T 1.575 Omni-directional 3 2.0 50 Linear 3.20x1.60x0.60 A Azimuth Beamwidth ( MHz ) Gain (dBi) VSWR (max.) Impedance (Ω) Polarization Size (mm) Structure Omni-directional 0.6/2 2.1 50 Linear 3.20x1.60x0.60 A Omni-directional 4 2.0 50 Linear 5.90x5.10x1.10 B Omni-directional 4 2.0 50 Linear 5.90x5.10x1.10 B Bluetooth/WiFi BAND WORKING FREQUENCY Part Number RFECA3216060L1T RFANT6050110L0T RFANT6050110L1T Frequency Range (GHz) 2.4~2.5 5.25~5.85 2.4~2.5 4.9~5.9 2.4~2.5 4.9~5.9 RFANT2012090A0T 2.4~2.5 Omni-directional 1.72 2.0 50 Linear 2.00x1.25x0.90 A RFANT3216120A1T 2.4~2.5 Omni-directional 2 2.0 50 Linear 3.20x1.60x1.20 A RFANT3216120A3T 2.4~2.5 Omni-directional 2 2.0 50 Linear 3.20x1.60x1.20 A RFANT3216120A5T 2.4~2.5 Omni-directional 2 2.0 50 Linear 3.20x1.60x1.20 A RFANT5220110A0T 2.4~2.5 Omni-directional 2 2.0 50 Linear 5.20x2.00x1.10 A RFANT5220110A2T 2.4~2.5 Omni-directional 2 2.0 50 Linear 5.20x2.00x1.10 A RFANT7635110A1T 2.4~2.5 Omni-directional 0~2 2.0 50 Linear 7.60x3.50x1.10 C RFANT8010080A3T 2.4~2.5 Omni-directional 2 2.0 50 Linear 8.00x1.00x0.80 A RFANT9520120A0T 2.4~2.5 Omni-directional 2 2.0 50 Linear 9.50x2.00x1.20 A RFECA3216060A1T 2.4~2.5 Omni-directional 2 2.1 50 Linear 3.20x1.60x0.60 A RFECA3216060K1T 4.9~5.85 Omni-directional 2.8 2.0 50 Linear 3.20x1.60x0.60 A RFANT9030200A1T 2.4~2.4835 Omni-directional 2 2.1 50 Linear 9.00x 3.00x2.00 A RGFRA1903041A1T 2.4~2.5 Omni-directional 2 2.0 50 Linear 19.0x3.00x3.80 E RGFRA1903041A5T 2.4~2.5 Omni-directional 2 2.0 50 Linear 19.0x3.00x3.80 E RGFRA9937380A3T 2.4~2.55 Omni-directional 2 2.0 50 Linear 9.90x3.70x3.80 D RGFRA1304011A1T 2.4~2.5 Omni-directional 2 2.1 50 Linear 12.8x3.90x1.10 F RGFRA1204021A1T 2.4~2.5 Omni-directional 2 2.0 50 Linear 12.0x4.00x2.00 G WiMAX BAND WORKING FREQUENCY 8 Part Number Frequency Range (GHz) Azimuth Beamwidth (MHz ) Gain (dBi) VSWR (max.) Impedance (Ω) Polarization Size (mm) Structure RFANT32162G6W0T 2.5~2.69 Omni-directional 1 3.0 50 Linear 3.20x1.60x1.20 A RFANT32163G5W0T 3.3~3.8 Omni-directional 2~3 2.0 50 Linear 3.20x1.60x1.20 A  For more information, please contact with local sales representative  All specifications are subject to change without notice CHIP ANTENNA  TYPICAL ELECTRICAL CHARACTERISTICS RFANT5220110A0T Test Board X-Z Plane Vertical X-Y Plane Vertical Y-Z Plane Vertical 3 .3 m m 1 .5 m m 2 .5 m m E m p ty A re a W TC E m p ty A re a 18x9 m m 1m m 18m m 50 Feed lin e GROUND 30x18 m m Peak Gain= -5.97dBi Average Gain=-3.12 dBi Return Loss (S11) Peak Gain= -5.97dBi Average Gain=-3.24 dBi X-Y Plane Horizontal X-Z Plane Horizontal Peak Gain= 2.66dBi Average Gain=-8.61 dBi Peak Gain= 2.59dBi Average Gain=-9.24 dBi Peak Gain= 1.69dBi Average Gain=-3.22 dBi Y-Z Plane Horizontal Peak Gain= -5.42dBi Average Gain=-8.98 dBi RGFAR1903041A1T Test Board X-Y Plane Vertical Peak Gain= -7.42 dBi Average Gain= -10.48 dBi Return Loss (S11) X-Y Plane Horizontal Peak Gain= 2.0 dBi Average Gain= -2.31 dBi X-Z Plane Vertical Peak Gain= 1.95 dBi Average Gain= -0.81 dBi X-Z Plane Horizontal Peak Gain= -2.65 dBi Average Gain= -8.4dBi Y-Z Plane Vertical Peak Gain= -0.26dBi Average Gain=-5 dBi Y-Z Plane Horizontal Peak Gain = 1.11dBi Average Gain = -4.37 dBi 9 CHIP ANTENNA RFANT8010080A3T Test Board X-Y Plane Vertical X-Z Plane Vertical Y-Z Plane Vertical A09 Peak Gain= 0.76 dBi Average Gain= -5.81dBi Return Loss (S11) Peak Gain= -3.76 dBi Average Gain= -8.72dBi X-Y Plane Horizontal Peak Gain= 1.37 dBi Average Gain= -2.67 dBi X-Z Plane Horizontal Peak Gain= -0.25 dBi Average Gain= -4.24 dBi Peak Gain = 3.03 dBi Average Gain = 0.71 dBi Y-Z Plane Horizontal Peak Gain= -1.37 dBi Average Gain=-8.6 dBi RGFAR9937380A3T Test Board X-Y Plane Vertical Peak Gain= -4.48 dBi Average Gain= -8.02 dBi Return Loss (S11) X-Y Plane Horizontal Peak Gain= 3.19 dBi Average Gain= -2.65 dBi 10 X-Z Plane Vertical Peak Gain= 2.49 dBi Average Gain= -2.47 dBi X-Z Plane Horizontal Peak Gain= 3.05 dBi Average Gain= -4.10dBi Y-Z Plane Vertical Peak Gain= -4.05dBi Average Gain=-8.03 dBi Y-Z Plane Horizontal Peak Gain = 0.95dBi Average Gain = -4.26 dBi CHIP ANTENNA RFECA3216060A1T Test Board X-Y Plane Vertical Peak Gain= 0.83 dBi Average Gain= -1.35 dBi Peak Gain = 3.37 dBi Average Gain = -0.65 dBi Return Loss (S11) X-Z Plane Vertical X-Y Plane Horizontal Peak Gain= -4.62 dBi Average Gain=-10.42 dBi X-Z Plane Horizontal Peak Gain= 0.51 dBi Average Gain= -4.07 dBi Y-Z Plane Vertical Peak Gain= -9.59 dBi Average Gain= -15.40 dBi Y-Z Plane Horizontal Peak Gain= 1.39 dBi Average Gain= -2.07 dBi RFECA1003011E0T Antenna S11 on Test Board X-Y Plane Vertical Peak Gain = 3.12dBi Average Gain = -3.99 dBi Antenna VSWR on Test Board X-Y Plane Horizontal Peak Gain = +0.48dBi Average Gain = -4.59dBi X-Z Plane Vertical Peak Gain= 1.97dBi Average Gain= -1.44 dBi X-Z Plane Horizontal Peak Gain = +4.99dBi Average Gain = -1.31dBi Y-Z Plane Vertical Peak Gain = 3.32dBi Average Gain = 1.02 dBi Y-Z Plane Horizontal Peak Gain = +3.02dBi Average Gain = -0.85dBi 11 CHIP ANTENNA RFECA3216060E1T Land Pattern X-Y Plane Vertical Peak Gain= -0.85 dBi Average Gain= -5.22 dBi Peak Gain= -5.51 dBi Average Gain= -7.48 dBi Return Loss (S11) X-Z Plane Vertical X-Y Plane Horizontal Peak Gain= 5.36 dBi Average Gain= 1.25 dBi X-Z Plane Horizontal Peak Gain= 4.85 dBi Average Gain= 1.21 dBi Y-Z Plane Vertical Peak Gain = 6.74 dBi Average Gain = 4.81 dBi Y-Z Plane Horizontal Peak Gain= -6.99 dBi Average Gain=-14.30 dBi RFECA3216060K1T Land Pattern X-Y Plane Vertical Peak Gain= -7.42 dBi Average Gain= -11.78 dBi Return Loss (S11) 12 Peak Gain= 2.86 dBi Average Gain= 0.86 dBi X-Y Plane Horizontal Peak Gain= 2.3 dBi Average Gain= -1.1 dBi   X-Z Plane Vertical X-Z Plane Horizontal Peak Gain=-2.49 dBi Average Gain= -9.61dBi For more information, please contact with local sales representative All specifications are subject to change without notice Y-Z Plane Vertical Peak Gain= -0.55dBi Average Gain=-4.9 dBi Y-Z Plane Horizontal Peak Gain = 0.73dBi Average Gain = -2.86 dBi HIGH FREQUENCY MULTILAYER BAND PASS FILTER HIGH FREQUENCY MULTILAYER BAND PASS FILTER  STRUCTURE AND PIN ASSOCIATED STRUCTURE A STRUCTURE B STRUCTURE C STRUCTURE D STRUCTURE E STRUCTURE F V STRUCTURE G STRUCTURE H STRUCTURE I STRUCTURE J STRUCTURE K 13 HIGH FREQUENCY MULTILAYER BAND PASS FILTER  STRUCTURE AND DIMENSION Unit: mm Structure\ Dimension L W T A B C D E F G H I 0.70±0.10 0.20±0.20 0.55±0.20 0.50±0.20 0.25±0.20 0.20±0.20 - - - - 0.80±0.10 0.20±0.20 0.55±0.20 0.50±0.20 0.20±0.20 0.20±0.20 - - - - 1.00±0.10 0.20±0.20 0.50±0.20 0.50±0.20 0.25±0.20 0.20±0.20 - - - - 1.05±0.10 0.25±0.20 0.50±0.20 0.50±0.20 0.25±0.20 0.25±0.20 - - - - 1.20±0.10 0.25±0.20 0.50±0.20 0.50±0.20 0.25±0.20 0.25±0.20 - - - - 2.05±0.20 0.70±0.20 0.25±0.20 0.50±0.20 0.50±0.20 0.25±0.20 0.25±0.20 - - - - 3.20±0.20 2.50±0.10 1.50±0.10 0.40±0.20 0.60±0.20 0.70±0.20 0.20±0.15 0.40±0.20 - - - - 1.00±0.10 0.50±0.10 0.40±0.10 0.30±0.10 0.30±0.10 0.35±0.10 0.15±0.10 0.15±0.10 - - - - 0.50±0.10 0.35±0.10 0.30±0.10 0.15±0.10 0.15±0.10 0.30±0.10 - - - - 0.60±0.10 0.45±0.15 0.45±0.15 0.20±0.15 0.20±0.15 0.30±0.15 - - - - 0.45±0.15 0.70±0.15 0.20±0.10 0.20±0.10 0.30±0.15 - - - - 0.45±0.15 0.70±0.15 0.15±0.10 0.15±0.10 0.30±0.15 - - - - 0.40±0.15 0.80±0.15 0.20±0.10 0.20±0.10 0.30±0.15 - - - - 0.45±0.15 1.10±0.15 0.25±0.15 0.25±0.15 0.30±0.15 - - - - 0.50±0.15 1.00±0.15 0.20±0.15 0.20±0.15 0.30±0.15 0.45±0.15 - - - 0.45±0.15 1.10±0.15 0.25±0.15 0.25±0.15 0.30±0.15 - - - - 2.00±0.20 2.50±0.20 A 1.60±0.15 0.80±0.15 0.70±0.10 0.50±0.10 1.20±015 B 0.90±0.10 0.60±0.10 2.00±.15 0.45±0.15 0.70±0.15 0.20±0.15 0.20±0.15 0.30±0.15 - - - - 0.80±0.10 0.50±0.15 1.00±0.15 0.25±0.15 0.25±0.15 0.30±0.15 - - - - 0.90±0.10 0.50±0.15 1.00±0.15 0.25±0.15 0.25±0.15 0.30±0.15 - - - - 0.35±0.15 1.30±0.15 0.25±0.15 0.25±0.15 0.30±0.15 - - - - 0.50±0.15 1.00±0.15 0.25±0.15 0.25±0.15 0.30±0.15 - - - - 0.55±0.10 0.40±0.20 0.40±0.20 0.40±0.20 0.40±0.20 0.20±0.10 - - - - 0.60±0.10 0.40±0.20 0.40±0.20 0.40±0.20 0.20±0.10 - - - - - 0.80±0.10 0.40±0.20 0.40±0.20 0.40±0.20 0.40±0.20 0.20±0.10 - - - - 0.60±0.10 0.55±0.10 0.25±0.10 0.23±0.10 0.40±0.10 0.12±0.10 0.125±0.10 - - - 0.45±0.10 0.95±0.10 0.275±0.20 0.25±0.10 0.60±0.10 0.175±0.10 0.15±0.10 - - - 0.70 max 0.95±0.10 0.275±0.10 0.25±0.10 0.60±0.10 0.175±0.10 0.15±0.10 - - - 0.80±0.10 0.95±0.10 0.275±0.10 0.25±0.10 0.60±0.10 0.175±0.10 0.15±0.10 - - - 0.25±0.10 1.25±0.15 0.95±0.10 C 2.00±.15 1.20±0.20 1.60±0.15 0.80±0.15 2.00±.15 1.25±0.10 D E F G 14 1.10±0.10 0.90±0.10 0.60±0.10 1.40±0.15 1.10±0.15 0.70±0.10 0.325±0.10 0.25±0.10 0.25±0.10 2.00±0.20 1.25±0.20 1.00 max. 0.325±0.10 0.25±0.10 0.25±0.10 0.40±0.10 0.55±0.15 0.50±0.15 1.60±0.15 0.80±0.15 0.60±0.10 0.55±0.15 0.80±0.10 0.95±0.10 0.90±0.10 2.00±0.15 0.18±0.10 0.205±0.10 0.25±0.10 - - - - - 0.25±0.10 - - - - - 0.25±0.10 - - - - - 0.35±0.15 0.50±0.15 0.20±0.15 - - - - 0.50±0.15 0.35±0.15 0.50±0.15 0.20±0.15 - - - - 0.40±0.10 0.30±0.10 0.30±0.10 0.15±0.10 0.30±0.10 0.35±0.10 0.15±0.10 - 0.95±0.10 0.40±0.10 0.30±0.10 0.30±0.10 0.15±0.10 0.30±0.10 0.35±0.10 0.15±0.10 - 1.25±0.10 2.50±0.20 2.00±0.20 0.90±0.10 1.70±0.20 0.60±0.20 0.30±0.20 0.40±0.20 0.15±0.10 0.60±0.10 0.50±0.10 0.15±0.10 - H 1.60±0.15 0.80±0.10 0.60 max. 0.25±0.10 0.23±0.05 0.40±0.10 0.30±0.10 0.55±0.10 0.60±0.10 - - - I 2.00±0.15 1.25±0.10 1.00 max. 1.80±0.10 0.35±0.10 0.25±0.10 0.25±0.10 0.275±0.10 0.35±0.10 J 2.50±0.15 2.00±0.15 0.90±0.10 0.30±0.10 0.40±0.10 0.55±0.10 0.40±0.10 0.90±0.10 0.30±0.10 - - - K 3.20±0.20 2.50±0.20 1.80±0.20 0.95±0.20 0.60±0.20 0.30±0.15 0.70±0.15 1.20±0.15 2.00±0.15 - - - 0.25±0.10 0.25±0.10 0.275±0.10 HIGH FREQUENCY MULTILAYER BAND PASS FILTER  ELECTRICAL SPECIFICATION 2.4GHz BAND WORKING FREQUENCY Part Number Frequency Range(GHz) Insertion Loss (dB) RBBPF1005040A1T 2.4~2.5 2.5 RFBPF1005040A3T 2.4~2.5 1.5max.(25℃) 1.7max.(-40~+85℃) RFBPF1109060A0T 2.4~2.5 1.8 RFBPF1411060A1T 2.4~2.5 1.8 RFBPF1411060A2T 2.4~2.5 1.5 RBBPF1411060A3T 2.4~2.5 1.1 RFBPF1608060AA7M1U 2.4~2.5 0.95max.(25℃) 1.25max.(-40~+85℃) RFBPF1608060ADT 2.4~2.5 1.8max.(25℃) 2.1max.(-40~+85℃) RFBPF1608060AET 2.4~2.5 1.7max.(25℃) 2.0max.(-40~+85℃) RFBPF1608070AFT 2.4~2.5 2.4max.(25℃) 2.7max.(-40~+85℃) RFBPF1608070AWT 2.4~2.5 2.0max.(25℃) 2.2max.(-40~+85℃) RFBPF1608050A0T 2.4~2.5 2.0max.(25℃) 2.2max.(-40~+85℃) RFBPF1608060A1T 2.4~2.5 2.8 RFBPF1608060A7T 2.4~2.5 3.0 RFBPF1608060A8T 2.4~2.5 1.7 RFBPF1608070A3T 2.4~2.5 1.8max.(25℃) 2.1max.(-40~+85℃) Attenuation ( dB min. ) 25(824~960 MHz) 20(1710~1910 MHz) 20(4800~5000 MHz) 15(7200~7500 MHz) 13(824~915MHz) 5(1545~1605MHz) 34(4800~5000MHz) 20(7200~7500 MHz) 35(824~960MHz) 38(1545~1605MHz) 20(1710~1990MHz) 8(2110~2170MHz) 35(3600 MHz) 35(4800~5000 MHz) 35(7200~7500 MHz) 40(824~960MHz) 40(1545~1605MHz) 20(1710~1990MHz) 8(2110~2170MHz) 35(3600 MHz) 35(4800~5000 MHz) 35(7200~7500 MHz) 30(500~960MHz) 25(1500~1650MHz) 19(3200~3300MHz) 40(4800~5000 MHz) 30(7200~7500 MHz) 20( 50~960MHz) 10( 1710~1990MHz) 9( 3600 MHz) 22( 4800~7200 MHz) 20(500~960 MHz) 23(3200 MHz) 30(4800~5000 MHz) 32(7200~7500 MHz) 22.5(200~1300MHz) 5.5(2000MHz) 10.5(3000MHz) 23.5(3600~3800MHz) 35(4800~5000MHz) 35(7200~7500MHz) 25(880 MHz) 20(3200 MHz) 35(4800~5000 MHz) 25(7200~7500 MHz) 24.5(80~960MHz) 20(1710~1990 MHz) 8.5(2170 MHz) 15(4800~5000 MHz) 20(7200~7500 MHz) 30 (960 MHz) 25(1910 MHz) 20(1990 MHz) 25(4800 MHz) 15(7200 MHz) 20(960 MHz) 20(1910 MHz) 15(1990 MHz) 18(4800 MHz) 25(7200 MHz) 25(695~800MHz) 20(1910MHz) 35(3200MHz) 20(4800~5000MHz) 20(7200~7500MHz) 25(695~800MHz) 20(1910MHz) 35(3200MHz) 20(4800~5000MHz) 20(7200~7500MHz) 30(880~915MHz) 30(1710~1785MHz) 25(1850~1910MHz) 25(4800~5000MHz) 15(7200~7500MHz) 27(800~900 MHz) 25(4800~5000 MHz) 30(7200~7500 MHz) VSWR (max.) Impedance (Ω) Size(mm) STRUCTURE 2.0 50 1.00x0.50x0.40 B 2.1 50 1.00x0.50x0.40 B 2.0 50 1.10x 0.90x0.60 E 2.0 50 1.40x1.10x0.60 E 2.0 50 1.40x1.10x0.60 E 2.0 50 1.40x1.10x0.60 E 2.0 50 1.60x0.80x0.60 H 2.0 50 1.60x0.80x0.60 B 2.0 50 1.60x0.80x0.60 F 2.0 50 1.60x0.80x0.70 B 2.0 50 1.60x0.80x0.70 B 2.0 50 1.60x0.80x0.50 B 2.0 50 1.60x0.80x0.60 B 2.0 50 1.60x0.80x0.60 B 2.0 50 1.60x0.80x0.60 B 2.0 50 1.60x0.80x0.70 B 15 HIGH FREQUENCY MULTILAYER BAND PASS FILTER 2.4GHz BAND WORKING FREQUENCY Frequency Range(GHz) Insertion Loss (dB) RFBPF2012080AM0T62 2.4~2.5 1.8max.(25℃) 2.0max.(-40~+85℃) RFBPF2012080AC2T00 2.4~2.5 1.35max. RFBPF2012090AS1T35 2.4~2.5 0.9max.(25℃) 1.1max.(-40~+85℃) RFBPF2012060AAT 2.4~2.5 1.5max.(25℃) 1.8max.(-40~+85℃) RFBPF2012040ABT 2.4~2.5 2.5 RFBPF2012050ACT 2.4~2.5 2.5 RFBPF2012080ADT 2.4~2.5 1.5max.(25℃) 1.7max.(-40~+85℃) RFBPF2012080AFT 2.4~2.5 1.8max.(25℃) 2.0max.(-40~+85℃) RFBPF2012080AGT 2.4~2.5 1.8max.(typ.1.5) RFBPF2012040AHT 2.4~2.5 2.5 RBBPF2012050AHT 2.4~2.5 2.5max.(typ.2.2) Part Number 16 Attenuation ( dB min. ) 30(860~960MHz) 30(1545~1605MHz) 35(1710~1990MHz) 30(2170MHz) 30(4800~5000MHz) 30(804~828MHz) 20(1608~1656MHz) 30(3216~3312MHz) 40(4020~4140MHz) 20(4824~4968MHz) 20(5628~5796MHz) 20(6432~6624MHz) 35(7200~7500MHz) 20(7500~10000MHz 28(824~960MHz) 30(1570~1580MHz) 15(1710~1910MHz) 9.5(1910~1990MHz) 25(4800~5000MHz) 25(7200~7500MHz) 30(880~960MHz) 25(1710~1910MHz) 25(4800~5000MHz) 30(7200~7500MHz) 30(824~849MHz) 30(880~915MHz) 30(1545~1605MHz) 30(1565~1585MHz) 35(1710~1785MHz) 40(1850~1910MHz) 32(1920~1980MHz) 7(3168~4752MHz) 11(3300~3800MHz) 35(4800~4967MHz) 26(5150~6000MHz) 23(7200~7450MHz) 35(824~960MHz) 38(1710~1910MHz) 25(4880~5000MHz) 20(7200~7500MHz) 30(860~960MHz) 30(1545~1605MHz) 30(1710~1990MHz) 30(2170MHz)(typical) 30(4800~5000MHz) 30(824~915MHz) 30(1545~1605MHz) 35(1710~1990MHz) 30(2170MHz) 30(4800~4967MHz) 25(5150~6000MHz) 20(7200~7450.5MHz) 35(824~960MHz) 28(1545~1605MHz) 30(1710~1990MHz) 30(2170MHz) 6(3200MHz) 30(4800~4967MHz) 20(5150~6000MHz) 18(7200~7450MHz) 25(746~764MHz) 30(824~849MHz) 26(869~960MHz) 28(1570~1580MHz) 28(1710~1785MHz) 30(1850~1910MHz) 30(1930~1990MHz) 30(2110~2170MHz) 15(3300~3800MHz) 35(4800~5000MHz) 20(7200~7450.5MHz) 25(746~764MHz) 30(824~849MHz) 26(869~960MHz) 28(1570~1580MHz) 28(1710~1785MHz) 30(1850~1910MHz) 30(1930~1990MHz) 25(2110~2170MHz) 15(3300~3800MHz) 35(4800~5000MHz) VSWR (max.) Impedance (Ω) Size(mm) STRUCTURE 2.0 50 2.00x1.20x0.80 D 2.0 50 2.00x1.25x0.80 G 2.0 50 2.00x1.25x0.90 G 2.0 50 2.00x1.20x0.60 C 2.0 50 2.00x1.20x0.40 D 2.0 50 2.00x1.20x0.55 C 2.0 50 2.00x1.25x0.80 D 2.0 50 2.00x1.25x0.80 D 2.0 50 2.00x1.25x0.80 D 2.0 50 2.00x1.25x0.45 D 2.0 50 2.00x1.25x0.45 D HIGH FREQUENCY MULTILAYER BAND PASS FILTER 2.4GHz BAND WORKING FREQUENCY Frequency Range(GHz) Insertion Loss (dB) RFBPF2012090ALT 2.4~2.5 1.0max.(25℃) 1.2max.(-40~+85℃) RFBPF2012090AMT 2.4~2.5 2.6 Part Number VSWR (max.) Impedance (Ω) Size(mm) STRUCTURE 2.0 50 2.00x1.25x0.90 G 2.0 50 2.00x1.20x0.90 B 2.0 50 2.00x1.20x1.00 I 2.0 50 2.00x1.20x0.90 B 2.0 50 2.00x1.20x0.90 B 2.0 50 2.00x1.20x1.00 I 2.0 50 2.00x1.20x0.90 E 2.0 50 2.00x1.20x0.90 B 2.0 50 2.00x1.20x0.90 B 2.0max.(25℃) 2.2max.(-40~+85℃) 25(746~764MHz) 30(824~849MHz) 26(869~960MHz) 28(1570~1580MHz) 28(1710~1785MHz) 30(1850~1910MHz) 30(1930~1990MHz) 25(2110~2170MHz0 15(3300~3800MHz) 35(4800~5000MHz) 20(7200~7450.5MHz) 2.0 50 2.00x1.25x0.45 D 3.5 30(880~960MHz) 30(1710~1990MHz) 20(2110~2170MHz) 30(4800~5000MHz) 30(7200~7500MHz) 2.0 50 2.00x1.20x0.80 C 2.8 (typ.2.5) 40(DC~1600MHz) 35(1710MHz) 25(1900MHz) 12(2100MHz) 8(2170MHz) 30(3100MHz) 40(4800~5000MHz) 20(7200~7500MHz) 2.0 50 2.00x1.20x0.80 B 2.8 30(960MHz) 30(1600MHz) 20(1990MHz) 35(3200MHz) 40(4800MHz) 25(7200MHz) 2.0 50 2.00x1.20x0.60 B RFBPF2012100ANT 2.4~2.5 2.3max.(25℃) 2.6max.(-40~+85℃) RFBPF2012090AQT 2.4~2.5 1.2 RFBPF2012090ART 2.4~2.5 1.0 RFBPF2012100AVT 2.4~2.5 2.3max.(25℃) 2.6max.(-40~+85℃) RBBPF2010A108Q1C 2.4~2.5 1.3 RFBPF2012090A1T 2.4~2.5 1.7 RFBPF2012090A2T 2.4~2.5 1.4 RFBPF2012040A3T RFBPF2012080A6T RFBPF2012080A7T RFBPF2012060A9T 2.4~2.5 2.4~2.5 2.4~2.5 2.4~2.5 Attenuation ( dB min. ) 28(824~960MHz) 28(1570~1580MHz) 23(1710~1910MHz) 17(1920~1990MHz) 25(4800~5000MHz) 40(880~960MHz) 38(1710~1990MHz) 16(2170MHz) 30(4800~5000MHz) 25(7200~7500MHz) 40(699~960MHz) 40(1428~1448MHz) 40(1476~1607MHz) 40(1710~1785MHz) 33(1805~1880MHz) 30(1880~1915MHz) 30(1920~1990MHz) 22(2110~2170MHz) 25(4800~5000MHz) 35(7200~7500MHz 20(1600MHz) 25(3200MHz) 20(4800~5000MHz) 20(1600MHz) 25(3200MHz) 40(699~960MHz) 40(1428~1448MHz) 40(1476~1607MHz) 40(1710~1785MHz) 33(1805~1880MHz) 30(1880~1915MHz) 30(1920~1990MHz) 25(4800~5000MHz) 30(7200~7500MHz 38(50~960MHz) 17(1710~1910MHz) 5(3200MHz) 30(4800~5000MHz) 25(7200~7500MHz) 30(900MHz) 20(1850MHz) 30(4800MHz) 30(824~960MHz) 30(1710~1910MHz) 20(1920~1990MHz) 6(2110~2170MHz) 20(4800~5000MHz) 17 HIGH FREQUENCY MULTILAYER BAND PASS FILTER 2.4GHz BAND WORKING FREQUENCY Part Number Frequency Range(GHz) Insertion Loss (dB) RFBPF2520090ACT 2.4~2.5 2.1max.(25℃) 2.3max.(-40~+85℃) RFBPF2520070AMT 2.4~2.5 2.0max.(25℃) 2.2max.(-40~+85℃) RFBPF2520080AUT 2.4~2.5 2.2 RFBPF2520120A1T 2.4~2.5 1.7 RFBPF2520120A2T 2.4~2.5 2.1 RFBPF2520120A3T 2.4~2.5 ≦1.2(25℃) RFBPF2520120A4T 2.4~2.5 ≦1.7(25℃) RFBPF2520100A5T 2.4~2.5 2.0 RFBPF2520100A6T 2.4~2.5 1.4 RFBPF3225150A3T 2.4~2.5 2.5 RFBPF3225150A4T 2.4~2.5 2.0 RFBPF3225150A5T 2.4~2.5 1.8 Attenuation ( dB min. ) 43(806~960MHz) 43(1570~1580 MHz) 43(1710~1990 MHz) 20(2110~2170MHz) 30(4800~5000 MHz) 25(7200~7500MHz) 45(824~960 MHz) 45(1570~1580 MHz) 45(1710~1785 MHz) 40(1805~1850 MHz) 35(1850~1910 MHz) 35(1920~1990 MHz) 25(2110~2170 MHz) 5(2750~3000 MHz) 15(3000~4800 MHz) 30(4800~5000 MHz) 30(5150~5850 MHz) 20(7200~7500 MHz) 30(900 MHz) 30(1850 MHz) 33(2170 MHz) 35(4800 MHz) 25(7200 MHz) 30(900/1850 MHz) 20(2100 MHz) 40(4800 MHz) 25(7200 MHz) 30(900/1850 MHz) 30(4800 MHz) 30(900/1850 MHz) 25(4800 MHz) 30(900/1850 MHz) 25(4800 MHz) 40(900 MHz) 35(3200 MHz) 30(1990 MHz) 20(2100 MHz) 40(4800 MHz) 25(7200 MHz) 35(1900/4800 MHz) 40(1500 MHz) 30(2100 MHz) 30(4800 MHz) 30(900 MHz) 30(1850 MHz) 20(2100 MHz) 30(4800 MHz) 30(900 MHz) 30(1850MHz) 20(2100 MHz) 30(4800 MHz) VSWR (max.) Impedance (Ω) Size(mm) STRUCTURE 2.0 50 2.50x2.00x0.90 G 2.0 50 2.50x2.00x0.70 A 2.0 50 2.50x2.00x0.80 A 2.0 50 2.50x2.00x1.20 A 2.0 50 2.50x2.00x1.20 A 2.0 50 2.50x2.00x1.20 A 2.0 50 2.50x2.00x1.20 A 2.0 50 2.50x2.00x1.00 A 2.0 50 2.50x2.00x1.00 A 1.7 - 3.20x2.50x1.50 A 2.0 50 3.20x2.50x1.50 A 2.0 50 3.20x2.50x1.50 A VSWR (max.) Impedance (Ω) Size(mm) STRUCTURE 2.0 50 1.10x0.90x0.60 E 2.0 50 1.40x1.10x0.70 E VSWR (max.) Impedance (Ω) Size(mm) STRUCTURE 50 2.50x2.00x0.90 J 1558 ~ 1606 MHz GNSS Band Applications Part Number Frequency Range (MHz) Insertion Loss (dB) RFBPF1109060E0T 1550~1610 1.9max. RFBPF1411070E0T 1558~1606 1.8max. Attenuation ( dB min. ) 25(960MHz) 8(1850MHz) 15(1990MHz) 20(2170MHz) 35(2400~2500MHz) 35(3400~3800MHz) 30(824~849 MHz) 30(880~915 MHz) 22(1850~1910 MHz) 22(1920~1980 MHz) 30(2400MHz) 860~960MHz/1805~2025 MHz Band Application Part Number Frequency Range (MHz) Insertion Loss (dB) 869~960 0.7max.(25℃) 0.75max.(-40~+85℃) 1805~2025 1.1max.(25℃) 1.2max.(-40~+85℃) RFBPF2520090B08Q1C 18 Attenuation ( dB min. ) 25(430~490MHz) 10(1700~1900MHz) 20(2400~2500MHz) 20(4905~5845MHz) 25(900~1015MHz) 15(2400~2500MHz) 15(3610~3980MHz) 20(4905~5845MHz) 1.9 2.0 HIGH FREQUENCY MULTILAYER BAND PASS FILTER 5GHz BAND WORKING FREQUENCY Part Number Frequency Range(GHz) Insertion Loss (dB) RFBPF1608060K2T 4.9~5.84 1.5max.(25℃) 1.7max.(-40~+85℃) RFBPF1608060K68Q1C 4.9~5.9 1.3 RFBPF1608060K78D1T 5.15~5.95 0.8 RFBPF1608060K88Q1C 5.15~5.95 0.7 (typ.0.6) RFBPF1608060KG8D1T 5.15~5.95 0.8 RFBPF2012100KST 4.9~5.9 VSWR (max.) Impedance (Ω) Size(mm) STRUCTURE 2.0 50 1.60x0.80x0.70 B 2.0 50 1.60x0.80x0.60 D 1.67 50 1.60x0.80x0.60 D 1.5 50 1.60x0.80x0.60 D 1.67 50 1.60x0.80x0.60 D 30(3450 MHz) 20(11000 MHz) 2.0 50 2.00x1.20x1.00 B RFBPF2012100K0T 4.9~5.9 30(3450 MHz) 20(11000 MHz) 2.0 50 2.00x1.20x1.00 B RFBPF2012100K1T 5.15~5.9 3.0 (typ.2.5) 2.0 50 2.00x1.20x1.00 B RFBPF2012090K5T 4.9~5.85 2.2 2.0 50 2.00x1.20x0.90 B RFBPF2012100K3T 4.9~5.85 1.8max.(25℃) 2.1max.(-40~+85℃) 2.0 50 2.00x1.20x0.95 B RFBPF2012100K6T 5.15~5.85 1.6max.(25℃) 1.8max.(-40~+85℃) 2.0 50 2.00x1.20x0.95 B RFBPF2012090K9T 5.725~5.85 2.0 2.0 50 2.00x1.20x0.95 B RFBPF2520090K1T 4.9~5.85 1.2 47(824 MHz) 47(1500 MHz) 47(1910 MHz) 15(9800 MHz) 2.0 50 2.50x2.00x0.90 A Insertion Loss (dB) Attenuation ( dB min. ) VSWR (max.) Impedance (Ω) Size(mm) STRUCTURE 2.0 29(880~915 MHz) 29(1710~1785 MHz) 21(1850~1910 MHz) 15(1920~1980 MHz) 18(4600~4780 MHz) 23(6900~7170 MHz) 2.0 50 1.60x0.80x0.70 B 1.5(4.90GHz) 1.5(5.25GHz) 1.5(5.85GHz) 1.7(4.90GHz) 1.5(5.25GHz) 1.5(5.85GHz) Attenuation ( dB min. ) 33(100~2170 MHz) 29(2170~2500 MHz) 32(9800~12000 MHz) 38(30~2700MHz) 16(3453~3547MHz) 33(3667~3883MHz) 9(6900~7093MHz) 32(7333~7750MHz) 40(10600~11650MHz) 18(15540~17760MHz) 40(30~2700MHz) 45(3400~3800MHz) 20(7250~7800MHz) 20(10300~11700MHz) 35(30~2700MHz) 30(3400~3800MHz) 12(7250~7800MHz) 20(10300~11700MHz) 40(30~2700MHz) 45(3400~3800MHz) 20(6900MHz) 20(7250~7800MHz) 20(10300~11700MHz) 35(4000MHz) 35(4500MHz) 40(4600MHz) 35(340~1195 MHz) 19(2140~3580 MHz) 25(6855~7150 MHz) 20(8570~8930 MHz) 30(500 MHz) 35(3450 MHz) 30(4000 MHz) 20(4200 MHz) 15(9800 MHz) 15(11700 MHz) 30(500 MHz) 40(2000 MHz) 35(3450 MHz) 30(4000 MHz) 20(4200 MHz) 30(500 MHz) 30(4000 MHz) 20(4200 MHz) 32(5000 MHz) 15(9800 MHz) 15(11750 MHz) WiMAX BAND WORKING FREQUENCY Part Number RFBPF16082G3W0T Frequency Range(GHz) 2.3~2.39 19 HIGH FREQUENCY MULTILAYER BAND PASS FILTER MoCA / Docsis Application Part Number Frequency Range(MHz) Insertion Loss (dB) RFBPF3225180Y1T 975~1025 3.0 RFBPF3225200Y07B1U 475~675 2.5max.(25℃) 2.7max.(-40~+85℃) RBBPF3225180Y27B1U 400~700 2.0 RFBPF3225180C07B1U 1125~1675 1.8max.(25℃) 2.0max.(-40~+85℃) RBBPF3225180C67B1U 1125~1675 2.0 RBBPF3225180C77B1U 1125~1225 2.0 Attenuation ( dB min. ) 30(54~870 MHz) 30(1125~1675 MHz) 30(2300 MHz) 60(2.5 MHz) 40(2.5~100 MHz) 35(100~200 MHz) 35(200~300 MHz) 8(300~400 MHz) 57(950 MHz) 47(950~2025 MHz) 41(2025~2500 MHz) 35(2500~3000 MHz) 42(1~200 MHz) 30(950~2150 MHz) 35(2150~3000 MHz) 27(3000~5900 MHz) 30(5~864 MHz) 34(864~1002 MHz) 32(2300~3000 MHz) 40(1~900 MHz) 25(900~1002 MHz) 35(2000~2500 MHz) 27(2500~5900 MHz) 33(1~900 MHz) 25(900~1002 MHz) 25(1350~1675 MHz) 35(2000~2500 MHz) 27(2500~5900 MHz) VSWR (max.) Impedance (Ω) Size(mm) STRUCTURE 2.0 75 3.20x2.50x1.80 K 2.0 75 3.20x2.50x1.80 K 2.0 50 3.20x2.50x1.80 K 2.0 75 3.20x2.50x1.80 K 2.0 50 3.20x2.50x1.80 K 2.0 50 3.20x2.50x1.80 K LTE Band Application Part Number Frequency Range(MHz) Band Insertion Loss (dB) Attenuation ( dB min. ) VSWR (max.) Impedance (Ω) Size(mm) STRUCTURE RFBPF1109B101T 2110~2170 B1 1.7 25(4280MHz) 2 50 1.10x0.90x0.60 E RFBPF1109B201T 1930~1990 B2 1.7 25(3920MHz) 2 50 1.10x0.90x0.60 E RFBPF1109B301T 1805~1880 B3 1.4 25(3685MHz) 2 50 1.10x0.90x0.60 E RFBPF1109B501T 869~894 B5 0.9 12(1763MHz) 2 50 1.10x0.90x0.60 E RFBPF1109B701T 2620~2690 B7 1.2 25(5310MHz) 2 50 1.10x0.90x0.60 E RFBPF1109B801T 925~960 B8 0.9 12(1885MHz) 2 50 1.10x0.90x0.60 E  TYPICAL ELECTRICAL CHARACTERISTICS 20 RFBPF1005040A1T RFBPF1005040A3T RFBPF1109060A0T RFBPF1411060A1T HIGH FREQUENCY MULTILAYER BAND PASS FILTER RFBPF1411060A2T RBBPF1411060A3T RFBPF1608060AA7M1U RFBPF1608060ADT 0 dB(S(2,1)) dB(S(1,1)) -10 -20 -30 -40 -50 0 1 2 3 4 5 6 7 8 9 Frequency (GHz) RFBPF1608060AET RFBPF1608070AFT 0 dB(S(2,1)) dB(S(1,1)) -20 S-Parameter (dB) S-parameter (dB) -10 -30 -40 -50 -60 -70 0.5 1.5 2.5 3.5 4.5 5.5 Frequency (GHz) 7.5 Frequency (GHz) RFBPF1608050A0T S-Parameter (dB) RFBPF1608070AWT 6.5 Frequency (GHz) RFBPF1608060A1T RFBPF1608060A7T 21 HIGH FREQUENCY MULTILAYER BAND PASS FILTER RFBPF1608060A8T RFBPF2012080AM0T62 RFBPF2012080AC2T00 RFBPF2012090AS1T35 0 S-Parameter (dB) -10 -20 -30 -40 -50 -60 -70 -80 0 1 2 3 4 5 6 7 8 9 10 Frequency (GHz) 22 RFBPF2012040ABT RFBPF2012050ACT RFBPF2012080ADT RFBPF2012080AFT RFBPF2012080AGT RFBPF2012040AHT HIGH FREQUENCY MULTILAYER BAND PASS FILTER RFBPF2012090ALT S-Parameters RBBPF2012050AHT RFBPF2012090AMT RFBPF2012100ANT 0 dB(S(2,1)) dB(S(1,1)) S-parameter (dB) -10 -20 -30 -40 -50 -60 -70 0.5 1.5 2.5 3.5 4.5 5.5 6.5 7.5 Frequency (GHz) RFBPF2012090AQT RFBPF2012090ART RFBPF2012100AVT RBBPF2010A108Q1C 0 dB(S(2,1)) dB(S(1,1)) S-parameter (dB) -10 -20 -30 -40 -50 -60 -70 0.5 1.5 2.5 3.5 4.5 5.5 6.5 7.5 Frequency (GHz) RFBPF2012090A1T RFBPF2012090A2T 23 HIGH FREQUENCY MULTILAYER BAND PASS FILTER RFBPF2012040A3T RFBPF2012080A7T RFBPF2520090ACT RFBPF2520070AMT 0 dB(S(2,1)) dB(S(1,1)) S-parameter (dB) -10 -20 -30 -40 -50 -60 -70 0.5 1.5 2.5 3.5 4.5 5.5 6.5 7.5 8.5 Frequency (GHz) RFBPF2520080AUT RFBPF2520100A5T RFBPF2520100A6T RFBPF1608060K2T 0 dB(S(2,1)) dB(S(1,1)) S-parameter (dB) -10 -20 -30 -40 -50 -60 1 3 5 7 9 Frequency (GHz) RFBPF1608060K68Q1C 24 RFBPF1608060K788Q1C 11 HIGH FREQUENCY MULTILAYER BAND PASS FILTER RFBPF1608060K88Q1C RFBPF1608060KG8D1T RFBPF2012100KST RFBPF2012090K5T 0 dB(S(2,1)) dB(S(1,1)) -10 -20 -30 -40 -50 0.5 2.5 4.5 6.5 8.5 10.5 freq, GHz RFBPF2012100K3T RFBPF2012100K6T RFBPF2012090K9T RFBPF2520090K1T 0 dB(S(2,2)) dB(S(2,1)) dB(S(1,1)) -20 -40 -60 -80 0 2 4 6 8 10 12 freq, GHz RFBPF1109060E0T RFBPF1411070E0T 25 HIGH FREQUENCY MULTILAYER BAND PASS FILTER RFBPF2520090B08Q1C Low Band Low-Band 0 -10 -10 -10 -10 -20 -30 -40 -50 -30 -40 -50 -60 -60 -70 -70 0 1 2 3 4 S-Parameter (dB) 0 S-Parameter (dB) 0 -20 -20 -30 -40 -50 50 Frequency (GHz) 61 72 83 Frequency (GHz) High-Band -20 -30 -40 -50 -60 -60 -70 4 05 High Band High-Band 0 S-Parameter (dB) S-Parameter (dB) Low-Band 16 27 38 4 -70 50 61 72 83 4 5 6 7 8 Frequency (GHz) Frequency (GHz) RFBPF3225180Y1T RFBPF3225200Y07B1U RBBPF3225180Y27B1U RFBPF3225180C07B1U 0 S-Parameter (dB) -10 -20 -30 -40 -Insertion Loss -Return Loss -50 -60 0.5 1.0 1.5 2.0 Frequency (GHz) 26 RBBPF3225180C67B1U RBBPF3225180C77B1U RFBPF1109B101T RFBPF1109B201T 2.5 3.0 HIGH FREQUENCY MULTILAYER BAND PASS FILTER   RFBPF1109B301T RFBPF1109B501T RFBPF1109B701T RFBPF1109B801T For more information, please contact with local sales representative All specifications are subject to change without notice 27 HIGH FREQUENCY MULTILAYER BALANCED FILTER HIGH FREQUENCY MULTILAYER BALANCED FILTER  STRUCTURE AND PIN ASSOCIATED STRUCTURE A STRUCTURE A-1 STRUCTURE A-2 STRUCTURE B  STRUCTURE AND DIMENSION Unit: mm Structure\ Dimension A L W T A B C D E F G 1.60±0.15 0.80±0.15 0.60±0.10 0.175±0.15 0.25±0.15 0.25±0.15 0.50±0.15 0.20±0.15 0.20±0.15 0.30±0.15 1.20±0.10 0.40±0.10 0.175±0.10 0.35±0.15 0.30±0.15 0.65±0.10 0.20±0.10 0.20±0.15 0.50±0.10 0.50±0.10 0.20±0.15 0.30±0.15 0.35±0.15 0.65±0.15 0.20±0.15 0.20±0.15 0.30±0.15 0.60±0.10 0.20±0.15 0.30±0.10 0.35±0.10 0.65±0.10 0.20±0.15 0.20±0.15 0.50±0.10 0.65±0.10 0.20±0.15 0.20±0.15 0.30±0.10 0.63±0.10 0.20±0.15 0.20±0.15 0.50±0.10 2.00±0.15 0.90±0.10 0.20±0.15 0.30±0.10 0.35±0.10 1.25±0.15 B 28 1.00±0.10 0.20±0.15 1.10±0.10 0.20±0.15 0.30±0.10 0.35±0.10 0.65±0.10 0.20±0.10 0.20±0.15 0.50±0.10 0.30±0.10 0.35±0.10 0.65±0.10 0.20±0.15 0.20±0.15 0.55±0.10 0.50±0.10 0.35±0.10 0.65±0.10 0.20±0.15 0.20±0.15 0.50±0.10 2.50±0.20 2.00±0.20 0.85±0.10 0.35±0.20 0.40±0.10 0.30±0.10 0.70±0.20 0.15(Typical) 0.15(Typical) 1.20±0.20 2.00±0.15 1.25±0.10 0.60±0.10 0.20±0.10 0.30±0.15 0.25±0.15 0.65±0.10 0.25±0.10 - - HIGH FREQUENCY MULTILAYER BALANCED FILTER  ELECTRICAL SPECIFICATION 2.4GHz BAND WORKING FREQUENCY Part Number RFBPB2012090A1T Impedance(Ω) Frequency Range Unbalance Balance (MHz) 2.4~2.5 Insertion Loss (dB) Attenuation ( dB min. ) VSWR (Max.) 50 Conjugate match to BC series of Bluetooth chipset 3.5 35(880~960MHz) 30(1710~1880MHz) 20(1880~1990MHz) 30(4800~5000MHz) 2.1 180°± 10 2.8 35(880~960MHz) 30(1575MHz) 25(1710~1880MHz) 30(4800~5000MHz) 2.1 3.5 35(880~960 MHz) 30(1710~1880 MHz) 20(1880~1990 MHz) 30(4800~5000 MHz) Size (mm) STRUCTURE 2 2.00x1.25x0.90 A-1 180°± 10 2 2.00x1.25x0.90 A-1 2.1 180°± 10 2 2.00x1.25x0.90 A-1 12(1000 MHz) 15(4800~5000 MHz) 20(7200~7500 MHz) 2.0 180°± 15 2 2.00x1.25x0.60 B 3.5 30(880~960MHz) 30(1710~1880MHz) 20(1880~1990MHz) 30(4800~5000MHz) 2.0 180°± 10 2 2.00x1.25x0.90 A-1 2.0 180°± 10 2 2.00x1.25x0.95 A-1 RFBPB2012090A9T 2.4~2.5 50 Conjugate match to BC series of Bluetooth chipset RFBPB2012090AAT 2.4~2.5 50 Conjugate match to CSR BC03/ 04 series Impedance match to T.I. CC253X,CC25 1.5max.(25℃) 4X, CC257X, 1.7max. CC853X and (-40~+85℃) CC852X Chipsets Phase Amplitude Difference Difference RFBPB2012060ABT 2.4~2.5 50 RFBPB2012090AHT 2.4~2.5 50 100 50 Conjunction to MT5931/MT66 28 Chipset 2.5 (typ.2.2) 35( 824~960 MHz) 32(1990 MHz) 18(2170 MHz) 40(4800~5000MHz) 25(7200~7500MHz) 50 Conjugate match to MTK MT6611 Bluetooth chipset 2.8 35(880~960MHz) 30(1710~1880MHz) 20(1880~1900MHz) 30(4800~5000MHz) 2.1 180°± 10 2 2.00x1.25x0.90 A-1 3.5 35(880~960MHz) 30(1710~1880MHz) 20(1880~1900MHz) 40(4800~5000MHz) 2.0 180°± 10 2 2.00x1.25x1.00 A-1 RFBPB2012090AM1T59 RFBPB2012090AM1T61 2.4~2.5 2.4~2.5 RFBPB2012100A6T 2.4~2.5 50 Conjugate match to BC series of Bluetooth chipset RFBPB2012110A5T 2.4~2.5 50 50 2.8 30(880~960 MHz) 30(1710~1880 MHz) 20(1880~1990 MHz) 30(4800~5000 MHz) 2.0 180°± 10 2 2.00x1.25x1.10 A-1 RFBPB2520090A7T 2.4~2.5 50 Conjugate match to TI BRF6150 3.5 35(880~960MHz) 30(1710~1880MHz) 25(1880~1990MHz) 25(4800~5000MHz) 2.0 180°± 15 1.5 2.50x2.00x0.90 A-2 29 HIGH FREQUENCY MULTILAYER BALANCED FILTER  TYPICAL ELECTRICAL CHARACTERISTICS RFBPB2012090A1T RFBPB2012090A2T RFBPB2012100A6T   30 For more information, please contact with local sales representative All specifications are subject to change without notice HIGH FREQUENCY MULTILAYER LOW PASS FILTER HIGH FREQUENCY MULTILAYER LOW PASS FILTER  STRUCTURE AND PIN ASSOCIATED STRUCTURE A STRUCTURE A-1 STRUCTURE A-3 STRUCTURE A-2 STRUCTURE A-4 STRUCTURE B STRUCTURE B-1 STRUCTURE C STRUCTURE D STRUCTURE E STRUCTURE B-2 STRUCTURE F STRUCTURE G STRUCTURE H 31 HIGH FREQUENCY MULTILAYER LOW PASS FILTER  STRUCTURE AND DIMENSION Unit: mm Structure\ Dimension L W A 1.60±0.15 0.80±0.15 2.00±0.15 1.25±0.10 D 3.20±0.20 1.00±0.10 1.60±0.15 0.65±0.10 2.50±0.20 0.50±0.10 0.80±0.15 0.50±0.10 E 1.60±0.15 0.80±0.15 1.60±0.10 0.80±0.10 B C F 2.00±0.15 1.25±0.10 G 1.00±0.10 0.50±0.10 H 3.20±0.20 2.50±0.20 T A B C D E F 0.50max. 0.60±0.10 0.65±0.10 0.70max. 0.90±0.10 0.95±0.10 1.05±0.10 1.00±0.20 0.40±0.10 0.50max. 0.40max. 0.45max. 0.65max. 0.65max. 0.90±0.10 1.00max. 0.40 max. 1.00±0.20 1.80±0.20 0.20±0.10 0.175±0.15 0.175±0.15 0.175±0.15 0.20±0.10 0.20±0.10 0.20±0.10 0.10min. 0.35±0.10 0.45±0.15 0.20±0.05 0.23±0.05 0.23±0.05 0.60±0.10 0.95±0.10 0.95±0.10 0.18±0.05 0.95±0.20 0.95±0.20 0.24±0.10 0.25±0.15 0.25±0.15 0.25±0.15 0.30±0.10 0.30±0.10 0.30±0.10 0.55±0.15 0.30±0.10 0.70±0.15 0.20±0.05 0.40±0.10 0.40±0.10 0.25±0.10 0.275±0.10 0.275±0.10 0.18±0.05 0.60±0.20 0.60±0.20 0.24±0.10 0.25±0.15 0.25±0.15 0.25±0.15 0.35±0.10 0.35±0.10 0.35±0.10 0.45±0.15 0.15±0.10 0.20±0.15 0.025±0.025 0.30±0.10 0.30±0.10 0.25±0.10 0.25±0.10 0.25±0.10 0.05±0.05 0.30±0.15 0.30±0.15 0.50±0.10 0.50±0.15 0.50±0.15 0.50±0.15 0.65±0.10 0.65±0.10 0.65±0.10 1.00±0.15 0.15±0.10 0.20±0.15 0.10±0.05 0.65±0.10 0.65±0.10 0.40±0.10 0.60±0.10 0.60±0.10 0.125±0.05 0.70±0.15 0.70±0.15 0.15±0.10 0.20±0.15 0.20±0.15 0.20±0.15 0.20±0.10 0.20±0.10 0.20±0.10 0.30±0.15 0.30±0.10 0.30±0.15 0.25±0.05 0.20±0.05 0.20±0.05 0.10±0.05 0.175±0.10 0.175±0.10 0.15±0.05 1.20±0.15 1.20±0.15 0.20±0.10 0.20±0.10 0.20±0.10 0.70±0.20 0.25±0.15 0.025±0.025 0.23±0.05 0.23±0.05 0.10±0.05 0.15±0.10 0.15±0.10 0.05±0.05 2.00±0.15 2.00±0.15  ELECTRICAL SPECIFICATION GSM850/900GHz BAND WORKING FREQUENCY Part Number RFLPF06050G9D0T Frequency Range (MHz) Insertion Loss (dB) Attenuation ( dB min. ) VSWR (max.) Impedance (Ω) Size(mm) Structure 824~915 0.5max.(25℃) 0.7max.(-40~+85℃) 20(2400~2750MHz) 2.0 50 0.65x0.50x0.40 D 2.0 50 1.00x0.50x0.40 C 2.0 50 1.00x0.50x0.40 C 2.0 50 1.00x0.50x0.40 C 2.0 50 1.00x0.50x0.40 C 1.6 50 1.60x0.80x0.65 A-3 2.0 50 1.60x0.80x0.50 A-4 2.0 50 1.00x0.50x0.40 G 2.0 50 2.00x1.25x0.95 B-2 2.0 50 2.00x1.25x0.95 B-2 VSWR (max.) Impedance (Ω) Size(mm) Structure 2.0 50 1.00x0.50x0.40 C 2.0 50 1.00x0.50x0.40 C 2.0 (typ.1.16) 50 1.00x0.50x0.40 G 2.0 50 1.60x0.80x0.50 C 2.0 50 1.60x0.80x0.60 F 1.9 50 2.00x1.20x0.90 F RFLPF10050G9D0T 824~915 0.6 RFLPF10050G9D3T 824~915 0.5max.(25℃) 0.7max.(-40~+85℃) RFLPF10050G9D4T 699~915 0.5max.(25℃) 0.7max.(-40~+85℃) RFLPF10050G9D58Q1C 814~915 RFLPF16080G9D4T 698~960 RFLPF16080G9DM1T58 698~960 0.8 RFLPF10050G9DM1T76 698~960 0.6max.(25℃) 0.65max.(-40~+85℃) RFLPF20120G9D0T 890~915 0.6max.(25℃) 0.75max.(-40~+85℃) RFLPF20120G9D1T 890~915 0.6max.(25℃) 0.75max.(-40~+85℃) 0.5max.(25℃) 0.65max.(-40~+85℃) 0.60(698~830MHz) 0.70(830~900MHz) 0.75(900~915MHz) 0.90(915~960MHz) 25(1648~1830MHz) 25(2472~2745MHz) 25(3296~3660MHz) 25(1648~1830MHz) 25(2472~2745MHz) 25(3296~3660MHz) 25(1648~1830MHz) 25(2472~2745MHz) 25(3296~3660MHz) 18(1648~1830MHz) 17(2472~2745MHz) 30(1554~1830MHz) 35(2097~2745MHz) 16(1565~1610MHz) 32(2110~2155MHz) 13 (1554~1610MHz) 35(1805~1830MHz) 35(2110~2170MHz) 30(1710~2700MHz) 30(1780~1830MHz) 30(2670~2745MHz) 40(1720~1765MHz) 30(1780~1830MHz) 30(2670~2745MHz) DCS/PCS BAND WORKING FREQUENCY 32 Part Number Frequency Range (MHz) Insertion Loss (dB) RFLPF10051G8D0T 1710~1910 0.8 RFLPF10051G8DM5T51 1710~1910 0.6 RFLPF10051G8DM1T76 1880~2025 1.4max.(25℃) 1.6max.(-40~+85℃) RFLPF16081G8D3T 1710~1910 0.45max.(25℃) 0.55max.(-40~+85℃) RFLPF16081G8D78Q1C 1880~2025 1.4 RFLPF20121G8D1T 1880~2025 1.35max.(25℃) 1.50max.(-40~+85℃) Attenuation ( dB min. ) 35(3420~3570MHz) 35(3700~3820MHz) 35(5130~5730MHz) 26(3420~3570MHz) 21(3700~3820MHz) 21(5130~5730MHz) 20(2400~2500MHz) 25(3760~4050MHz) 25(5150~5850MHz) 25(5640~6075MHz) 30(3420~3570MHz) 25(3700~3820MHz) 25(5130~5730MHz) 25(2400~2500MHz) 18(4020~4045MHz) 25(6030~6075MHz) 38(2400~2500MHz) 25(4020~4045MHz) 27(6030~6075MHz) HIGH FREQUENCY MULTILAYER LOW PASS FILTER 2.4GHz BAND WORKING FREQUENCY Part Number Frequency Range (MHz) Insertion Loss (dB) Attenuation ( dB min. ) RFLPF1005040A0T 2450±50 0.45max.(25℃) 0.55max.(-40~+85℃) RFLPF1005040A1T 2450±50 0.75 RFLPF1005040A2T 2450±50 0.75max.(25℃) 0.90max.(-40~+85℃) RFLPF1608060AM2T66 2450±50 0.65 (typ.0.55) RFLPF1608060AAT 2450±50 0.65 RFLPF1608060A0T 2450±50 0.65 (typ.0.48) RFLPF1608060A1T 2450±50 0.6 RFLPF1608060A2T 2450±50 0.42 RFLPF1608060A9T 2450±50 0.50max.(25℃) 0.60max.(-40~+85℃) RFLPF2012110A0T 2450±50 0.7 21(4800~5000MHz) 21(7200~7500MHz) 33(4800~5000MHz) 37(7200~7500MHz) 32(4800~5000MHz) 35(7200~7500MHz) 20(3603~3720MHz) 30(4804~4960MHz) 10(6005~6200MHz) 20(7206~7440MHz) 10(8407~8680MHz) 20(9608~9920MHz) 10(10809~11160MHz) 10(12010~12400MHz) 10(13211~13640MHz) 15(14412~14880MHz) 10(15613~16120MHz) 10(16814~17360MHz) 20(3603~3720MHz) 30(4804~4960MHz) 10(6005~6200MHz) 20(7206~7440MHz) 10(8407~8680MHz) 20(9608~9920MHz) 10(10809~11160MHz) 10(12010~12400MHz) 10(13211~13640MHz) 15(14412~14880MHz) 10(15613~16120MHz) 10(16814~17360MHz) 35(4800MHz(typ.40)) 27(7200MHz(typ.40)) 27(4800~5000MHz) 30(7200~7500MHz) 25(4800MHz) 18(7200MHz) 20(3400MHz) 20(3600MHz) 30(4800~5000MHz) 30(7200~7500MHz) 30(2x(fo±BW/2)) 20(3x(fo±BW/2)) VSWR (max.) Impedance (Ω) Size(mm) Structure 1.7 50 1.00x0.50x0.40 C 2.0 50 1.00x0.50x0.40 C 2.0 50 1.00x0.50x0.40 C 2.0 (typ.1.5) 50 1.60x0.80x0.65 A-1 2.0 50 1.60x0.80x0.70 A-1 1.5 50 1.60x0.80x0.60 A-1 2.0 50 1.60x0.80x0.60 A-2 1.5 50 1.60x0.80x0.60 A-1 2.0 50 1.60x0.80x0.60 E 1.5 50 2.00x1.25x1.05 B-1 5GHz BAND WORKING FREQUENCY Part Number Frequency Range (MHz) Insertion Loss (dB) RFLPF1608050K0T 5400±500 0.60(25℃) 0.70(-40~+85℃) RFLPF2012090K0T 5400±500 0.55(25℃) 0.65(-40~+85℃) Attenuation ( dB min. ) 25(9800MHz) 30(11900MHz) 20(17850MHz) (forreference) 30(9800MHz) 30(11800MHz) 20(17550MHz (forreference) VSWR (max.) Impedance (Ω) Size(mm) Structure 2.0 50 1.60x0.85x0.50 C 2.0 50 2.00x1.25x0.90 B-1 VSWR (max.) Impedance (Ω) Size(mm) Structure 2.0 50 1.00x0.50x0.40 G 2.0 50 1.60x0.85x0.65 A-3 30(1554~1830MHz) 35(2097~2745MHz) 1.6 50 1.60x0.85x0.65 A-3 33(800~940MHz) 2.0 50 2.00x1.25x0.90 F 33(1000~1400MHz) 2.0 50 2.00x1.25x0.90 F 2.0 50 2.00x1.25x0.95 B-2 LTE BAND APPLICATION Part Number Frequency Range (MHz) Insertion Loss (dB) Attenuation ( dB min. ) RFLPF1005040YM1T76 746~878 0.6(25℃) 0.65(-40~+85℃) RFLPF1608060Y08Q1C 470~787 0.65(25℃) 0.71(-40~+85℃) 30(1554~1610MHz) 25(2238~2361MHz) 26(1429~1501MHz) 30(1565~1607MHz) 35(1570~1580MHz) 18(1920~1980MHz) RFLPF1608060Y18Q1C 698~960 RFLPF2012090Y2T 400~470 RFLPF2012090Y3T 500~700 0.60(698~830MHz) 0.70(830~900MHz) 0.75(900~915MHz) 0.90(915~960MHz) 0.50(25℃) 0.65(-40~+85℃) 0.65(25℃) 0.80(-40~+85℃) RFLPF2012100Y0T DC~500 0.70 9(824~960MHz) 25(1710~1990MHz) 25(2400~4000MHz) RFLPF1608060E0T 1400~2690 0.25(25℃) 0.30(-40~+85℃) 25(4905~5845MHz) 1.92 50 1.60x0.85x0.65 F 0.50 30(4800~8000MHz) 25(8500~12500MHz) 2.0 50 1.60x0.85x0.65 F RFLPF1608060F0T 600~2700 33 HIGH FREQUENCY MULTILAYER LOW PASS FILTER LTE BAND APPLICATION Part Number Frequency Range (MHz) Insertion Loss (dB) Attenuation ( dB min. ) VSWR (max.) Impedance (Ω) Size(mm) Structure 2.0 50 1.60x0.85x0.65 F 2.0 50 1.60x0.85x0.65 E 1.56 50 2.00x1.25x1.00 B-2 2.0 50 2.00x1.25x1.00 F RFLPF1608060F18Q1C 673~2690 0.50 35(4950~6000MHz) 35(6000~7500MHz) 35(7500~8100MHz) 35(8100~10500MHz) 27(10500~12500MHz) RFLPF1608060F88Q1C 10~2700 0.5 30(4900~5950MHz) 15(2400~2500MHz) 25(3250~3350MHz) 25(3420~3570MHz) 23(3700~3820MHz) 23(3840~3960MHz) 23(4100~4600MHz) 25(4905~5845MHz) 23(5850~6400MHz) 20(6600~7350MHz) 10(2400~2500MHz) 23(3250~3350MHz) 20(3420~3570MHz) 18(3700~3820MHz) 18(3840~3960MHz) 18(4100~4600MHz) 20(4905~5845MHz) 18(5850~6400MHz) 5(6600~7350MHz) RFLPF2012100F18Q1C 1710~2170 1.30(25℃) 1.50(-40~+85℃) RFLPF2012100F28Q1C DC~2170 0.75(25℃) 0.85(-40~+85℃) RFLPF10052G5WM1T76 2300~2700 0.5(25℃) 0.6(-40~+85℃) 25(4600~5400MHz) 25(6900~8100MHz) 2.0 50 1.00x0.50x0.40 G RFLPF16082G6W0T 2400~2690 0.6 26(4800~5390MHz) 23(7200~8085MHz) 2.0 50 1.60x0.80x0.60 A-2 RFLPF16082G6W2T 2300~2700 0.40(25℃) 0.43(-40~+85℃) 2.0 50 1.60x0.80x0.60 A-2 RFLPF16082G5W0T 2300~2700 0.90(25℃) 1.00(-40~+85℃) 1.8 50 1.60x0.80x0.60 A-1 RFLPF16082G5WM0T29 2300~2690 0.80 (typ.0.40) 2.0 50 1.60x0.80x0.60 A-1 RFLPF16083G5W7T 3300~3800 0.55 1.9 50 1.60x0.80x0.60 A-3 RFLPF2012090BM0T29 800~1000 1700~1910 2010~2025 0.5(800~1000MHz) 0.8(1700~1910MHz) 1.5(2010~2025MHz) 2.0 50 2.00x1.25x0.90 F Part Number Frequency Range (MHz) Insertion Loss (dB) Attenuation ( dB min. ) VSWR (max.) Impedance (Ω) Size(mm) Structure RFLPF3225180Y1T 54~870 2.5 35(975~1675MHz) 2.0 75 3.20x2.50x1.80 H RFLPF3225100Q07B1U 5~1002 2.4(25℃) 2.6(-40~+85℃) 36(1125~1675MHz) 2.0 75 3.20x2.50x1.00 H RFLPF3225100Q2T 5~1002 2.4(25℃) 2.6(-40~+85℃) 28(1125~1675MHz) 1.9 75 3.20x2.50x1.00 B-1 RFLPF3225200Q5T 5~1002 1.8(25℃) 2.05(-40~+85℃) 33(1125~1400MHz) 26(1400~1675MHz) 2.0 75 3.20x2.50x1.80 H 21(4600~5400MHz) 22(6900~8100MHz) 30(4600~5400MHz) 30(6900~8100MHz) 20(9200~10800MHz) 15(11500~13500MHz) 25(4600~5400MHz) 25(6900~8070MHz) 17(6600~7600MHz) 20(9900~11400MHz) 20(2300~3700MHz) 30(3700~4100MHz) 20(4100~6100MHz) 10(6100~8000MHz) MoCA APPLICATION  TYPICAL ELECTRICAL CHARACTERISTICS RFLPF06050G9D0T RFLPF10050G9D0T 0 dB(S(2,1)) dB(S(1,1)) S-parameter -10 -20 -30 -40 -50 -60 0 1 2 Frequency (GHz) 34 3 4 HIGH FREQUENCY MULTILAYER LOW PASS FILTER RFLPF10050G9D3T RFLPF10050G9D4T 0 0 dB(S(2,1)) dB(S(1,1)) dB(S(2,1)) dB(S(1,1)) -10 -20 S-parameter -20 -30 -30 -40 -40 -50 -50 -60 -60 0 1 2 3 0 4 1 2 3 4 Frequency (GHz) Frequency (GHz) RFLPF10050G9D58Q1C RFLPF16080G9D4T 0 -10 S-Peremater (dB) -20 -30 -40 -50 -60 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 Frequency (GHz) RFLPF16080G9DM1T58 RFLPF10050G9DM1T76 RFLPF20120G9D0T RFLPF20120G9D1T RFLPF10051G8D0T RFLPF10051G8DM5T51 0 0 dB(S(2,1)) dB(S(1,1)) -10 dB(S(2,1)) dB(S(1,1)) -10 S-parameter (dB) -20 S-parameter S-parameter -10 -30 -40 -50 -20 -30 -40 -50 -60 -70 1 2 3 4 Frequency (GHz) 5 6 -60 1 2 3 4 5 6 Frequency (GHz) 35 HIGH FREQUENCY MULTILAYER LOW PASS FILTER RFLPF10051G8DM1T76 RFLPF16081G8D3T 0 dB(S(2,1)) dB(S(1,1)) S-parameter -10 -20 -30 -40 -50 -60 1 2 3 4 5 6 Frequency (GHz) RFLPF16081G8D78Q1C RFLPF20121G8D1T RFLPF1005040A0T RFLPF1005040A1T 0 dB(S(2,1)) dB(S(1,1)) -10 -20 -30 -40 -50 -60 1 2 3 4 5 freq, GHz RFLPF1005040A2T RFLPF1608060AM2T66 0 dB(S(2,1)) dB(S(1,1)) -10 -20 -30 -40 -50 -60 1 2 3 4 5 6 7 8 freq, GHz RFLPF1608060AAT 36 RFLPF160806A0T 6 7 8 HIGH FREQUENCY MULTILAYER LOW PASS FILTER RFLPF1608060A1T RFLPF1608060A2T 0 dB(S(1,1)) dB(S(2,1)) -10 -20 -30 -40 -50 1 2 3 4 5 6 7 8 freq, GHz RFLPF1608060A9T RFLPF2012110A0T RFLPF1608050K0T RFLPF2012090K0T 0 S-parameter (dB) -10 -20 -30 -40 S21 S11 -50 -60 4 6 8 10 12 14 16 18 Frequency (GHz) RFLPF1005040YM1T76 RFLPF1608060Y08Q1C RFLPF1608060Y18Q1C RFLPF2012090Y2T 0 -10 S-Peremater (dB) -20 -30 -40 -50 -60 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 Frequency (GHz) 37 HIGH FREQUENCY MULTILAYER LOW PASS FILTER 38 RFLPF2012090Y3T RFLPF2012100Y0T RFLPF1608060E0T RFLPF1608060F0T RFLPF1608060F18Q1C RFLPF1608060F88Q1C RFLPF2012100F18Q1C RFLPF2012100F28Q1C RFLPF10052G5WM1T76 RFLPF16082G6W0T HIGH FREQUENCY MULTILAYER LOW PASS FILTER RFLPF16082G6W2T RFLPF16082G5W0T RFLPF16082G5WM0T29 RFLPF16083G5W7T 0 dB(S(2,1)) dB(S(1,1)) -20 -40 -60 -80 1 2 3 4 5 6 7 8 freq, GHz RFLPF2012090BM0T29 RFLPF3225180Y1T 0 dB(S(2,1)) dB(S(1,1)) -10 -20 -30 -40 -50 -60 0.0 0.5 1.0 1.5 2.0 2.5 3.0 Frequency (GHz) RFLPF3225100Q07B1U   RFLPF3225200Q5T For more information, please contact with local sales representative All specifications are subject to change without notice 39 HIGH FREQUENCY MULTILAYER HIGH PASS FILTER HIGH FREQUENCY MULTILAYER HIGH PASS FILTER  STRUCTURE AND PIN ASSOCIATED STRUCTURE A STRUCTURE B STRUCTURE C STRUCTURE D  STRUCTURE AND DIMENSION Unit: mm Structure\ Dimension L W T A B C D E F A 0.65 ± 0.10 0.50 ± 0.10 0.4 max. 0.225 ± 0.10 0.20 ± 0.05 0.10 ± 0.10 0.20 ± 0.05 0.05 ± 0.05 - B 1.60 ± 0.15 0.80 ± 0.15 0.60 ± 0.1.0 0.23 ± 0.05 0.40 ± 0.10 0.30 ± 0.10 0.65 ± 0.10 0.20 ± 0.05 0.23 ± 0.05 C 2.50 ± 0.20 2.00 ± 0.20 0.90 ± 0.1.0 0.20 ± 0.20 0.55 ± 0.20 0.50 ± 0.20 0.20 ± 0.20 0.20 ± 0.20 - D 3.20 ± 0.20 2.50 ± 0.20 1.7 max. 0.95 ± 0.20 0.60 ± 0.20 0.30 ± 0.15 0.70 ± 0.15 1.20 ± 0.15 2.00 ± 0.15 Size (mm) Structure 2.50x2.00x0.90 C  ELECTRICAL SPECIFICATION ISM 2.4/ 5GHz Band Application Part Number Frequency Range (MHz) Insertion Loss (dB) Attenuation ( dB min. ) VSWR (max.) 2400~2500 2.0max.(25℃) 2.3max.(-40~+85℃) 30(869~960 MHz) 45(1805~1990 MHz) 2 5150~5825 1.3max.(25℃) 1.6max.(-40~+85℃) 30(869~960 MHz) 45(1805~1990 MHz) 2 RFHPF2520090L0T 2496 ~ 2690 MHz BAND WORKING FREQUENCY Part Number Frequency Range (MHz) Insertion Loss (dB) Attenuation ( dB min. ) VSWR (max.) Size (mm) Structure RFHPF16082G5W0T 2496~2690 1.2max.(25℃) 1.3max.(-40~+85℃) 25(1710~1995MHz) 2.0 1.6 X 0.8 X 0.6 B 5GHz BAND WORKING FREQUENCY Part Number Frequency Range (MHz) Insertion Loss (dB) Attenuation ( dB min. ) VSWR (max.) Size (mm) Structure RFHPF0605040K0T 4900~5840 0.60max.(25℃) 0.65max.(-40~+85℃) 14(2400~2500MHz) 1.6 0.65 X 0.5 X 0.4 A Part Number Frequency Range (MHz) Insertion Loss (dB) Attenuation ( dB min. ) VSWR (max.) Size (mm) Structure RFHPF3225170F07B1U 950~2150 2.00max.(25℃) 2.2max.(-40~+85℃) 50(475~675MHz) 2.0 3.2 X 2.5 X 1.7 DC MoCA Application 40 HIGH FREQUENCY MULTILAYER HIGH PASS FILTER  TYPICAL ELECTRICAL CHARACTERISTICS RFHPF2520090L0T RFHPF16082G5W0T 0 0 S-parameter (dB) S-parameter (dB) -10 -20 -30 -40 -10 -20 -30 --Insertion Loss --Return Loss -40 dB(S(2,1)) dB(S(1,1)) -50 -60 0.5 1.5 2.5 3.5 4.5 5.5 6.5 7.5 8.5 Frequency (GHz) RFHPF0605040K0T   -50 0.5 1.5 2.5 3.5 4.5 5.5 6.5 7.5 8.5 Frequency (GHz) RFHPF3225170F07B1U For more information, please contact with local sales representative All specifications are subject to change without notice 41 BALUN TRANSFORMERS BALUN TRANSFORMERS  STRUCTURE AND PIN ASSOCIATED STRUCTURE A STRUCTURE A-1 STRUCTURE A-2 STRUCTURE A-3 STRUCTURE A-4 STRUCTURE A-5 STRUCTURE B STRUCTURE B-1 STRUCTURE B-2 STRUCTURE C STRUCTURE D 42 STRUCTURE C-1 STRUCTURE C-2 STRUCTURE E STRUCTURE F BALUN TRANSFORMERS  STRUCTURE AND DIMENSION Unit: mm Structure\ Dimension L W T 1.60±0.10 0.85±0.10 0.80±0.10 1.60±0.15 A 0.85±0.10 0.85±0.15 2.00±0.15 1.25±0.15 A B C D E F G H 0.70±0.10 0.20±0.10 0.20±0.10 0.30±0.10 0.50±0.05 0.50±0.05 - - - 0.50±0.10 0.175±0.15 0.25±0.15 0.25±0.15 0.50±0.15 0.20±0.15 - - - 0.40 max. 0.175±0.15 0.25±0.15 0.25±0.15 0.50±0.15 0.20±0.15 - - - 0.60±0.10 0.175±0.15 0.25±0.15 0.25±0.15 0.50±0.15 0.20±0.15 - - - 0.175±0.15 0.25±0.15 0.25±0.15 0.50±0.15 - - - - 0.80±0.10 0.20±0.20 0.30±0.20 0.35±0.20 0.65±0.20 - - - - 0.85±0.10 0.20±0.20 0.30±0.20 0.35±0.20 0.65±0.20 - - - - 0.80±0.10 0.20±0.15 0.30±0.20 0.35±0.20 0.65±0.20 - - - - 0.95±0.10 0.20±0.20 0.30±0.20 0.35±0.20 0.65±0.20 - - - - 0.70±0.10 0.65±0.10 1.00±0.10 0.50±0.10 0.37±0.10 0.10±0.10 0.30±0.10 0.20±0.10 0.50±0.10 0.125±0.10 - - 1.00±0.10 0.50±0.10 0.40±0.10 0.10±0.10 0.30±0.10 0.20±0.10 0.50±0.10 0.125±0.10 - - - C 2.00±0.10 1.25±0.15 0.90±0.10 0.125±0.10 0.25±0.10 0.25±0.10 0.50±0.10 0.475±0.10 0.30±0.10 0.20±0.15 0.20±0.15 D E 1.60±0.15 0.80±0.15 0.50±0.10 0.175±0.10 0.25±0.10 0.25±0.10 0.50±0.10 0.25±0.10 - - - 0.65±0.10 0.50±0.10 0.40±0.10 0.20±0.05 0.20±0.05 0.025±0.025 0.10±0.05 0.25±0.05 0.025±0.025 - - F 1.00±0.10 0.50±0.10 0.5 max. 0.35±0.10 0.30±0.10 0.15±0.10 0.15±0.10 0.30±0.10 - - - B  ELECTRICAL SPECIFICATION ISM Band 2.4GHz APPLICATION Frequency Range (MHz) Unbalance Balance RFBLN1005040A3T 2400~2500 50 RFBLN1005040A6T 2400~2500 Part Number Return Loss (dB)Min. Insertion Loss (dB) Amplitude Difference (dB)Max. Phase Difference Size(mm) Structure Conjugate match to AR6003 chipset 10 1.4 2.0 180± 10 1.00x0.50x0.40 B-1 50 50 10 0.8 2.0 180± 10 1.00x0.50x0.40 B-2 10 1.2 2.0 180± 10 1.60x0.80x0.50 D Impedance(Ω) RFBLN1608050AAT 2400~2500 50 Conjugate match to AR6003 chipset RFBLN1608060AM1T59 2400~2500 50 200 10 1.2 2.0 180± 10 1.60x0.80x0.65 A-3 RFBLN1608050AM8T62 2400~2500 50 50 10 1.2 2.0 180± 10 1.60x0.80x0.50 A-2 RFBLN1608050AM0T63 2400~2500 50 50 10 1.0 1.0 180± 10 1.60x0.80x0.55 A-2 RFBLN1608050AM6T30 2400~2500 50 35 10 1.0 1.0 180± 10 1.60x0.80x0.55 A-2 10 1.6(25℃) 1.8(-40~+85℃) 2.3 180± 18 1.60x0.80x0.60 A-5 RFBLN1608060AC6T40 2400~2500 50 Conjugate match to TI CC26XX Chipset RGBLN1608070A1T 2400~2500 50 100 10 1.5 2.0 180± 15 1.60x0.85x0.70 A-1 RFBLN1608070A3T 2400~2500 50 100 10 1.0 2.0 180± 10 1.60x0.85x0.70 A-1 RFBLN1608070A4T 2400~2500 50 100 10 1.0 2.0 180± 10 1.60x0.80x0.70 A-1 RGBLN1608070A5T 2400~2500 50 100 10 1.2 2.0 180± 10 1.60x0.80x0.70 A-2 RGBLN2012080A5T 2400~2500 50 50 12 1.0 1.0 180± 10 2.00x1.25x0.85 A-2 RFBLN2012080A7T 2400~2500 50 100 10 1.0 2.0 180± 10 2.00x1.25x0.80 A-2 RGBLN2012090A0T 2400~2500 50 50 10 1.2 2.0 180± 10 2.00x1.25x0.95 A-2 RFBLN2012090A1T 2400~2500 50 100 10 1.0 2.0 180± 10 2.00x1.25x0.95 A-2 Insertion Loss (dB) Amplitude Difference (dB)Max. Phase Difference Size (mm) Structure ISM Band 2.4GHz APPLICATION Frequency Range (MHz) Unbalance Balance Return Loss (dB)Min RFBLN1005040K1T 4900~5950 50 50 10 1.2 2.0 180± 10 1.00x0.50x0.40 B-2 RFBLN2012090K0T 4900~5900 50 50 10 1.1 2.0 180± 10 2.00x1.25x0.95 A-4 RFBLN2012090K1T 4900~5900 50 100 10 1.2 2.0 180± 10 2.00x1.25x0.95 A-4 Insertion Loss (dB) Amplitude Difference (dB)Max. Phase Difference Size (mm) Structure Part Number Impedance(Ω) LTE Band APPLICATION Frequency Range (MHz) Unbalance Balance Return Loss (dB)Min RFBLN16080G9D2T 699~960 50 100 10 1.05(25℃) 1.15(-40~+85℃) 2.5 180± 15 1.60x0.80x0.70 A-4 RFBLN1005040YM1T69 703~803 50 100 10 0.80 2.0 180± 12 1.00x0.50x0.40 F Part Number Impedance(Ω) 43 BALUN TRANSFORMERS LTE Band APPLICATION Frequency Range (MHz) Insertion Loss (dB) Amplitude Difference (dB)Max. Phase Difference Size (mm) Structure Balance Return Loss (dB)Min Unbalance RFBLN0605040Y1T 717~821 50 100 15 0.55(25℃) 0.65(-40~+85℃) 2.0 180± 10 0.65x0.50x0.40 E RFBLN0605040YM9T16 729~821 50 100 10 0.55(25℃) 0.65(-40~+85℃) 2.0 180± 10 0.65x0.50x0.40 E RFBLN0605040Y09FNH 729~869 50 100 15 0.55(25℃) 0.65(-40~+85℃) 2.5 180± 10 0.65x0.50x0.40 E RFBLN06050G9D0T 729~960 50 100 15 0.85(25℃) 0.95(-40~+85℃) 4.8 180± 10 0.65x0.50x0.40 E RFBLN16080G9D3T 824~894 50 50 10 1.2 1.0 180± 10 1.60x0.80x0.60 A-2 RFBLN20120G9D0T 824~894 50 100 10 1.2 1.0 180± 10 2.00x1.25x0.90 A-2 1.5 180± 17 1.60x0.80x0.70 A-4 Part Number Impedance(Ω) RFBLN1608070F48Q1C 673~2700 50 100 10 1.7(25℃) 2.0(-40~+85℃) RFBLN2012090E0T 1500~3000 50 100 10 1.0 2.0 180± 10 2.00x1.25x0.90 A-4 RFBLN20121G8D1T 1700~2000 50 100 10 1.0 2.0 180± 10 2.00x1.25x0.95 A-2 1.8 180± 10 0.65x0.50x0.40 E RFBLN06051G8DM1T69 1805~1990 50 100 10 0.60(25℃) 0.65(-40~+85℃) RFBLN10051G9D1T 1805~1990 50 100 10 0.60(25℃) 0.70(-40~+85℃) 2.2 180± 12 1.00x0.50x0.40 B-2 RFBLN10051G9D0T 1805~2020 50 100 10 0.65(25℃) 0.75(-40~+85℃) 2.0 180± 10 1.00x0.50x0.40 B-2 RFBLN10051G8D1T 1805~2170 50 100 10 0.65(25℃) 0.70(-40~+85℃) 3.0 180± 15 1.00x0.50x0.40 E RFBLN1005040F1T 1805~2170 50 100 10 0.70(25℃) 0.80(-40~+85℃) 1.2 180± 15 1.00x0.50x0.40 F RFBLN2012090F0T 1920~1980 2110~2170 50 50 10 1.0 2.0 180± 10 2.00x1.25x0.95 A-2 RFBLN0605040E0T 2000~2500 50 100 10 0.60(25℃) 0.70(-40~+85℃) 3.5 180± 10 0.65x0.50x0.40 E RFBLN06052G5WM9T16 2300~2690 50 100 10 0.55(25℃) 0.65(-40~+85℃) 2.5 180± 10 0.65x0.50x0.40 E RFBLN10052G5WM9T16 2300~2690 50 100 10 0.55(25℃) 0.65(-40~+85℃) 2.5 180± 10 1.00x0.50x0.40 B-1 RFBLN10052G5W37N2T 2300~2690 50 100 10 0.65(25℃) 0.75(-40~+85℃) 2.5 180± 10 1.00x0.50x0.40 B-2 RFBLN16082G5W0T 2300~2700 50 100 10 1.1 2.0 180± 10 1.60x0.80x0.70 A-2 RFBLN16082G5W38Q1C 2300~2700 50 100 10 0.55(25℃) 0.65(-40~+85℃) 1.0 180± 10 1.60x0.80x0.40 A-4 RFBLN16082G5W4T 2300~2700 50 50 10 1.2 2.0 180± 10 1.60x0.80x0.50 A-2 GSM 850/ GSM 900/ DCS1800/ PCS1900 APPLICATION Part Number Frequency Range (MHz) Unbalance Balance Return Loss (dB)Min Insertion Loss (dB) Amplitude Difference (dB)Max Attenuation (dB min.) Phase Difference 869~960 50 200 10 1.1 2.0 10(1738~1920MHz) 20(2400~2500MHz) 20(2607~2880MHz) 180± 10 1805~2025 50 200 10 1.8 2.0 15(2400~2500MHz) 20(3610~3980MHz) 20(5415~5970MHz) 180± 15 869~960 50 200 10 1.1(25℃) 1.3(-40~+85℃) 2.0 10(1738~1920MHz) 20(2400~2500MHz) 20(2607~2880MHz) 180± 15 1805~1990 50 200 10 1.6(25℃) 1.8(-40~+85℃) 2.0 15(2400~2500MHz) 15(3610~3980MHz) 20(5415~5970MHz) 180± 15 869~960 50 200 10 1.1(25℃) 1.3(-40~+85℃) 2.0 10(1738~1920MHz) 20(2400~2500MHz) 20(2607~2880MHz) 180± 15 1805~2025 50 200 10 1.8(25℃) 2.0(-40~+85℃) 2.0 15(2400~2500MHz) 15(3610~3980MHz) 20(5415~5970MHz) 180± 15 RFBLN2012090BM5T25 RFBLN2012090BS0T53 RFBLN2012090BS0T50 44 Size(mm) Structure 2.00x1.25x0.95 C-1 2.00x1.25x0.95 C-1 2.00x1.25x0.95 C-2 BALUN TRANSFORMERS  TYPICAL ELECTRICAL CHARACTERISTICS Hz) Insertion and Return Loss RFBLN1608060AM1T59 Amplitude and Phase Balance Insertion and Return Loss RFBLN1608050AM8T62 Amplitude and Phase Balance Insertion and Return Loss RFBLN1608050AM0T63 Insertion and Return Loss 2 185 1 180 0 175 -1 170 2.30 2.35 2.40 2.45 2.50 Frequency (GHz) 2.55 -2 2.60 0 190 Phase Balance (deg) 190 -5 RL & IL (dB) Phase Balance (deg) Amplitude and Phase Balance Amplitude balance (dB) 0 4.5 5.0 5.5 6.0 RFBLN1005040A3T Amplitude and Phase Balance -10 -15 -20 -25 -30 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 185 180 175 170 2.30 2.35 Frequency (GHz) 45 BALUN TRANSFORMERS RFBLN2012080A7T Amplitude and Phase Balance Insertion and Return Loss RGBLN2012090A0T Amplitude and Phase Balance Insertion and Return Loss RFBLN16080G9D2T Amplitude and Phase Balance Insertion and Return Loss RFBLN1005040YM1T69 Amplitude and Phase Balance 46 Insertion and Return Loss BALUN TRANSFORMERS RFBLN0605040YM9T16 Amplitude and Phase Balance Insertion and Return Loss RFBLN06051G8DM1T69 Amplitude and Phase Balance Insertion and Return Loss RFBLN10050G9D1T Amplitude and Phase Balance Insertion and Return Loss RFBLN10050G9D0T Amplitude and Phase Balance Insertion and Return Loss 47 BALUN TRANSFORMERS RFBLN1005040F1T Amplitude and Phase Balance Insertion and Return Loss RFBLN2012090F0T Amplitude and Phase Balance Insertion and Return Loss RFBLN0605040E0T Amplitude and Phase Balance Insertion and Return Loss RFBLN06052G5WM9T16 Amplitude and Phase Balance 48 Insertion and Return Loss BALUN TRANSFORMERS RFBLN10052G5WM9T16 Amplitude and Phase Balance Insertion and Return Loss RFBLN10052G5W37N2T Amplitude and Phase Balance Insertion and Return Loss RFBLN16082G5W0T Amplitude and Phase Balance Insertion and Return Loss RFBLN16082G5W38Q1C Amplitude and Phase Balance Insertion and Return Loss 49 BALUN TRANSFORMERS RFBLN2012090BM5T25 Low Band High Band RFBLN2012090BS0T53 Low Band High Band   50 For more information, please contact with local sales representative All specifications are subject to change without notice DIPLEXER DIPLEXER  STRUCTURE AND PIN ASSOCIATED STRUCTURE A STRUCTURE B STRUCTURE C STRUCTURE D STRUCTURE D-1 STRUCTURE D-2 STRUCTURE D-3 STRUCTURE D-4 STRUCTURE E STUCTURE E-1 STUCTURE E-2 STRUCTURE F STUCTURE F-1 STUCTURE F-2 STUCTURE F-3 51 DIPLEXER  STRUCTURE AND DIMENSION Unit: mm Structure\ Dimension L W T A B C D A 2.00±0.15 1.25±0.15 0.95±0.10 0.20±0.20 0.30±0.20 0.35±0.20 0.70±0.10 0.35±0.10 0.30±0.10 0.65±0.10 E F 0.65±0.20 0.25±0.20 0.30±0.20 0.60±0.10 0.275±0.10 - B 2.00±0.15 1.25±0.15 0.90±0.10 0.35±0.10 0.30±0.10 0.65±0.10 0.60±0.10 0.275±0.10 - C 2.50±0.15 2.00±0.15 1.0max. 0.375±0.15 0.25±0.15 0.25±0.15 0.50±0.15 0.20±0.15 - 1.60±0.15 0.80±0.15 0.60±0.10 0.175±0.15 0.25±0.15 0.25±0.15 0.50±0.15 0.20±0.15 - 2.00±0.10 1.25±0.20 0.55±0.15 0.20±0.15 0.30±0.15 0.35±0.15 0.65±0.15 0.20±0.10 - 2.00±0.15 1.25±0.15 0.95±0.10 0.20±0.20 0.30±0.20 0.35±0.20 0.65±0.20 - - 1.60±0.15 0.80±0.15 0.60±0.10 0.175±0.15 0.25±0.15 0.25±0.15 0.50±0.15 0.20±0.15 - 1.60±0.15 0.80±0.15 0.60±0.10 0.65±0.15 0.30±0.15 0.20±0.15 0.20±0.15 0.25±0.15 0.30±0.15 2.00±0.15 1.25±0.15 0.95±0.15 0.20±0.20 0.30±0.20 0.35±0.20 0.65±0.20 0.30±0.20 0.25±0.20 D E F  ELECTRICAL SPECIFICATION ISM Band 2.4GHz/5GHz APPLICATION Part Number Frequency (MHz) Impedance (Ω) Insertion Loss (dB) 2400~2500 50 0.8 4900~5900 50 1.2 2400~2500 50 0.8 4900~5900 50 1.2 2400~2500 50 0.6 4900~5900 50 1.4 28(30~2700MHz) 10(9800~11900MHz) 2400~2500 50 0.6 20(4800~5000MHz) 20(7200~7500MHz) 4900~5900 50 1.4 28(30~2700MHz) 10(9800~11900MHz) 2400~2500 50 0.6 4900~5900 50 1.4 18(4800~5000MHz) 18(7200~7500MHz) 20(3700~3900MHz) 20(1800~2500MHz) 10(9800~11800MHz)) 2400~2500 50 0.6 4900~5900 50 1.4 2400~2500 50 0.5 RFDIP1608060L0T RFDIP1608060L3T RFDIP1608060LBT RFDIP1608060LCT RFDIP1608060LET RFDIP1608060LFT RFDIP160806BLM6T25 4900~5950 50 0.6 2400~2500 50 0.5 RFDIP160806ALM6T30 4900~5950 52 50 0.6 Attenuation ( dB ) Return Loss (dB)Min Isolation Size(mm) Structure 18(4800~5000MHz) 20(7200~7500MHz) 20(3700~3900MHz) 20(1800~2500MHz) 20(9800~11800MHz) 10 - 1.60x0.80x0.60 D-1 10 - 1.60x0.80x0.60 D-2 10 28(30~2700 MHz) 26(4900~5950 MHz) 1.60x0.80x0.60 D-3 10 28(30~2700 MHz) 26(4900~5950 MHz) 1.60x0.80x0.60 D-4 18(4800~5000MHz) 20(7200~7500MHz) 20(3700~3900MHz) 20(1800~2500MHz) 20(9800~11800MHz) 20(4800~5000MHz) 20(7200~7500MHz) 10 - 1.60x0.80x0.60 D-1 10 - 1.60x0.80x0.60 D-2 1.60x0.80x0.60 D-1 1.60x0.80x0.60 D-2 18(4800~5000MHz) 18(7200~7500MHz) 20(3700~3900MHz) 20(1800~2500MHz) 10(9800~11800MHz) 10(3600~3750MHz) 20(4800~5000MHz) 20(5000~5950MHz) 10(7200~7500MHz) 10(9600~10000MHz) 25(860~960MHz) 25(1545~1605MHz 25(1710~1990MHz 30(2170 MHz) 10(8100~8800 MHz) 15(8820~9800 MHz) 25(9800~11900 MHz) 10(3600~3750MHz) 20(4800~5000MHz) 20(5000~5950MHz) 10(7200~7500MHz) 10(9600~10000MHz) 25(860~960MHz) 25(1545~1605MHz 25(1710~1990MHz 30(2170 MHz) 10(8100~8800 MHz) 15(8820~9800 MHz) 25(9800~11900 MHz - 10 25(4800~5000 MHz) - 10 25(4800~5000 MHz) DIPLEXER ISM Band 2.4/5GHz Application Part Number Frequency (MHz) Impedance (Ω) Insertion Loss (dB) Attenuation ( dB ) 2400~2500 50 0.6 - 4900~5950 50 0.8 32(30~2700MHz) 15(9800~11900 MHz) 11(14700~17850 MHz) 2400~2500 50 0.5(25℃) 0.6(-40~+85℃) 22(4800~5000MHz) 24(7200~7500 MHz) 5100~5900 50 1.1(25℃) 1.3(-40~+85℃) 25(1800~2500MHz) 24(3700~3900MHz) 22(9800~11900MHz) 2400~2496 50 0.5 35(4800~5000MHz) 15(7200~7500 MHz) RFDIP1608060LVT RFDIP1608060LST 5150~5950 50 1.0 30(70~2000MHz) 30(2400~2690MHz 12(7250~7800MHz 25(10300~12000MHz) 10(15000~18000MHz) 2400~2500 50 0.55(25℃) 0.60(-40~+85℃) 29(4800~5000MHz) 24(7200~7500 MHz) 4900~5950 50 0.70(25℃) 0.80(-40~+85℃) 32(30~2700MHz) 15(9800~11900MHz) 11(14700~17850MHz) 2400~2500 50 0.6 23(4800~5000MHz) 30(7200~7500MHz) RFDIP1608060LY8Q1C RFDIP1606L168M1U 5100~5850 50 1.5 25(2400~2500MHz) 15(3400~3600MHz) 10(3600~3900MHz) 20(6900~7550MHz) 30(10600~11700MHz) 20(15300~16200MHz) 2400~2500 50 0.6 23(4800~5000MHz) 30(7200~7500MHz) RFDIP1606L42T Return Loss (dB)Min Isolation Size(mm) Structure 10 32 (30~2700 MHz) 28(4900~5950 MHz) 1.60x0.80x0.60 D-4 10 - 1.60x0.80x0.60 F-3 12 - 1.60x0.80x0.60 D-3 10 32(30~2700MHz) 28(4900~5950 MHz) 1.60x0.80x0.60 D-3 10 40(5150~5850MHz) 1.60x0.80x0.60 D-3 10 40(5150~5850MHz) 1.60x0.80x0.60 D-4 20(DC~2500MHz) 20(4900~5950MHz) 2.00x1.25x0.40 D-3 20(DC~2500MHz) 20(4900~5950MHz) 2.00x1.25x0.40 D-4 20(DC~2500MHz) 20(4900~5950MHz) 2.00x1.25x0.40 D-3 5100~5850 50 1.5 25(2400~2500MHz) 15(3400~3600MHz) 10(3600~3900MHz) 20(6900~7550MHz) 30(10600~11700MHz) 20(15300~16200MHz) 2400~2500 50 0.5 10(3600MHz) 20(4800~5000MHz) 20(7200~7500MHz) 10 10 RFDIP1606L44T 10 4900~5950 50 1.0 20(824~915MHz) 20(1800~2500MHz) 10(3000~3900MHz) 4(7250MHz) 20(9800~11900MHz) 20(14700~17850MHz) 2400~2500 50 0.5 10(3600MHz) 20(4800~5000MHz) 20(7200~7500MHz) 10 10 KFDIP2004L157B1U 4900~5950 50 1.0 20(824~915MHz) 20(1800~2500MHz) 10(3000~3900MHz) 4(7250MHz) 20(9800~11900MHz) 20(14700~17850MHz) 2400~2500 50 0.6 15(3600MHz) 25(4800~5000MHz) 20(7200~7500MHz) 1.0 20(824~915MHz) 18(1800~2500MHz) 14(3000~3900MHz) 20(9800~11900MHz) 20(14700~17850MHz) KFDIP2004L167B1U KFDIP2004L197B1U 4900~5950 50 10 53 DIPLEXER ISM Band 2.4/5GHz Application Part Number Frequency (MHz) Impedance (Ω) Insertion Loss (Db) Attenuation ( Db ) 2400~2500 50 0.7 18(4800~6000MHz) 18(7200~7500 MHz) 4900~5900 50 1.0 19(1800~2500MHz) 25(10300~10700MHz) 2400~2500 50 0.7 4900~5900 50 1.0 2300~2500 50 0.65(25℃) 0.8(-40~+85℃) 4900~5950 50 1.0 2400~2500 50 0.7 20(4900MHz) 25(5200MHz) 25(5800MHz) 4900~5900 50 0.9 25(2450MHz) 2400~2500 50 0.7 20(4900MHz) 20(5200MHz) 20(5800MHz) 4900~5900 50 0.9 20(2450MHz) 2400~2500 50 0.7 20(4900MHz) 25(5200MHz) 25(5800MHz) 4900~5900 50 0.9 25(2450MHz) 2400~2500 50 0.7 20(4900MHz) 20(5200MHz) 20(5800MHz) 4900~5900 50 2400~2500 50 4900~5950 50 1.1 0.5(25℃) 0.55(-40~+85℃) 0.65(25℃) 0.75(-40~+85℃) 20(2450MHz) 23(4800~6000MHz) 20(7200~7500MHz) 20(800~2500MHz) 15(9800~11900MHz) 2400~2500 50 0.5(25℃) 0.55(-40~+85℃) 23(4800~6000MHz) 20(7200~7500MHz) 4900~5950 50 0.65(25℃) 0.75(-40~+85℃) 20(800~2500MHz) 15(9800~11900MHz) 2.2(25℃) 2.4(-40~+85℃) 30(824~915MHz) 30(1545~1610MHz) 30(1710~1990MHz) 25(2110~2170MHz) 8(3200~3600MHz) 12(3700~3900MHz) 28(4800~5000MHz) 25(7200~7500MHz) 1.2(25℃) 1.5(-40~+85℃) 20(1545~1610MHz) 20(1710~1990MHz) 20(2110~2170MHz) 23(2400~2500MHz) 8(3450~3900MHz) 8(7250~7800MHz) 20(9800~11700MHz) 2.2(25℃) 2.4(-40~+85℃) 30(824~915MHz) 30(1545~1610MHz) 30(1710~1990MHz) 25(2110~2170MHz) 8(3200~3600MHz) 12(3700~3900MHz) 28(4800~5000MHz) 25(7200~7500MHz) RFDIP2012050L5T RFDIP2012050L7T RFDIP2012050L8T RFDIP2012100L0T RFDIP2012100L1T RFDIP2012100L3T RFDIP2012100L4T RFDIP2012050LPT RFDIP2012050LQT 2400~2500 50 RFDIP2008L107N3T 5150~5850 2400~2500 50 50 RFDIP2008L117N3T 5150~5850 54 50 1.2(25℃) 1.5(-40~+85℃) 18(4800~6000MHz) 18(7200~7500MHz) 19(1800~2500MHz) 25(10300~10700MHz) 20(4600~5000MHz) 20(6900~7500MHz) 19(1800~2500MHz) 25(10300~10700MHz) 20(1545~1610MHz) 20(1710~1990MHz) 20(2110~2170MHz) 23(2400~2500MHz) 8(3450~3900MHz) 8(7250~7800MHz) 20(9800~11700MHz) Return Loss (Db)Min Size(mm) Structure 10 2.00x1.25x0.55 D-1 10 2.00x1.25x0.55 D-2 10 2.00x1.25x0.55 D-3 10 2.00x1.25x0.95 D-3 10 2.00x1.25x0.95 F-1 10 2.00x1.25x0.95 D-2 10 2.00x1.25x0.95 F-2 10 2.00x1.25x055 D-1 10 2.00x1.25x0.55 D-2 10 2.00x1.25x0.80 D-1 10 2.00x1.25x0.80 D-2 DIPLEXER GPS 1.575GHz/ISM 2.4GHz/5GHz Band Application Part Number Frequency (MHz) Impedance (Ω) Insertion Loss (dB) Attenuation ( dB ) 1574~1577 50 0.65 20(2400~2500MHz) 2400~2500 50 0.8 20(1574~1577MHz) 1570~1610 50 0.6(typ.0.5) 20(2400~2500MHz) 20(4900~5900MHz) 2400~2500 4900~5900 50 0.65(typ.0.55) 20(1570~1610MHz) 1710~1880 50 0.70(typ.0.59) 15(2500~2390MHz) 2500~2690 50 0.65(typ.0.58) 15(1710~1880MHz) 1570~1610 50 2400~2500 50 1570~1610 50 2400~2500 50 698~960 1427~1511 1560~1607 50 0.40 max. 0.55 max. 0.65 max. 20(2400~2500MHz) 20(2620~2690MHz) 20(5150~5850MHz) 2400~2500 2620~2690 5150~5850 50 0.70 max. 0.60 max. 0.80 max. 1570~1610 50 0.6(typ.0.5) 20(698~960MHz) 20(1427~1511MHz) 20(1560~1607MHz) 20(2400~2500MHz) 20(4900~5900MHz) 2400~2500 4900~5900 50 0.65(typ.0.55) 20(1570~1610MHz) 1572.5~1578.5 1597~1607 50 0.4(1572.5~1578.5MHz)(25℃) 0.45(1572.5~1578.5MHz) (-40~+85℃) 0.45(1597~1607MHz)(25℃) 0.5(1597~1607MHz)(-40~+85℃) 13(2400~2500MHz) 2400~2500 50 0.55(25℃) 0.65(-40~+85℃) 22(1572.5~1578.5MHz) 20(1597~1607MHz) Insertion Loss (dB) Attenuation ( dB ) 0.8(typ.0.45) 25(1710~2700MHz) 1710~2700 0.7(typ.0.50) 20(698~960MHz) 20(5150~5850MHz) 824~960 0.6(25℃) 0.65(-40~+85℃) 15(1710~2170MHz) 0.6(25℃) 0.65(-40~+85℃) 20(824~960MHz) 0.6(25℃) 0.65(-40~+85℃) 15(1710~2170MHz) 0.6(25℃) 0.65(-40~+85℃) 20(824~960MHz) 0.75 20(1427~2700MHz) 0.85 20(570~960MHz) 0.65 15(1554~1580MHz) 20(1710~2700MHz) 1710~2700 0.65 20(824~960MHz) 698~960 0.4(25℃) 0.45(-40~+85℃ 13(1710~2690MHz) 0.55(25℃) 0.65(-40~+85℃ 19(698~960MHz) 0.35(25℃) 0.45(-40~+85℃ 20(1710~2690MHz) 0.55(25℃) 0.65(-40~+85℃ 25(698~960MHz) 5(3420~3820MHz) RFDIP1608060T1T RFDIP1608060TM7T62 RFDIP1608070TM1T76 RFDIP1608060T8T RFDIP1608060T9T RFDIP1608060TAT RFDIP1608060TCT RFDIP2012090T2T 0.45(25℃) 0.55(-40~+85℃) 0.5(25℃) 0.6(-40~+85℃) 0.45(25℃) 0.55(-40~+85℃) 0.5(25℃) 0.6(-40~+85℃) Return Loss (dB)Min. Size (mm) Structure 10 1.60x0.80x0.60 A 10 1.60x0.80x0.60 D-4 10 1.60x0.80x0.70 E-2 10 1.60x0.80x0.60 D-4 10 1.60x0.80x0.60 D-3 10 1.60x0.80x0.60 A 10 1.60x0.80x0.60 D-4 10 2.00x1.25x0.90 D-3 Return Loss (dB)Min. Size (mm) Structure 10 1.60x0.80x0.60 E-2 10 2.00x1.25x0.90 D-3 10 2.00x1.25x0.90 D-4 10 2.00x1.25x0.70 B 10 2.00x1.25x0.90 D-4 10 2.00x1.25x0.90 B 10 2.50x2.00x1.00 C 20(2400~2500MHz) 20(1560~1607MHz) 20(2400~2500MHz) 20(1560~1607MHz) 892 MHz & 1.94GHz Band Working Frequency Part Number Frequency (MHz) Impedance (Ω) 698~960 RFDIP1608070GM1T76 50 RFDIP2012090G0T 50 1710~2170 824~960 RFDIP2012090G3T 50 1710~2170 570~960 RFDIP2012070G5T 50 1427~2700 698~960 RFDIP2012090G77N2T 50 RFDIP2012090GM1T58 50 1710~2690 698~960 RFDIP2520100G2T 50 1710~2690 55 DIPLEXER  TYPICAL ELECTRICAL CHARACTERISTICS RFDIP1608060T1T RFDIP1608060TM7T62 0 0 dB(S(2,1)) dB(S(1,1)) dB(S(3,1)) -10 S-parameter (dB) S-parameter (dB) -10 -20 dB(S(2,1)) dB(S(1,1)) dB(S(3,1)) -30 1.5 2.5 3.5 4.5 5.5 -30 -40 -50 0.5 6.5 1.5 2.5 3.5 4.5 Frequency (GHz) Frequency (GHz) RFDIP1608060T8T RFDIP1608060T9T 0 0 -10 -10 S -p aram eter (d B ) S -p aram eter (d B ) -40 0.5 -20 -20 -30 dB(S(2,1)) dB(S(1,1)) dB(S(3,1)) -40 5.5 6.5 -20 -30 dB(S(2,1)) dB(S(1,1)) dB(S(3,1)) -40 -50 -50 0.5 1.5 2.5 3.5 0.5 4.5 1.5 2.5 3.5 4.5 Frequency (GHz) Frequency (GHz) RFDIP1608060TAT RFDIP2012090T2T 0 S-parameter (dB) -10 -20 -30 dB(S(2,1)) dB(S(1,1)) dB(S(3,1)) -40 -50 0.5 1.5 2.5 3.5 4.5 5.5 6.5 Frequency (GHz) RFDIP2012070G5T RFDIP2012090GM1T58 0 - 10 - 20 - 30 S-param eter (dB ) 56 d B (S (2 ,1 )) d B (S (1 ,1 )) d B (S (3 ,1 )) - 40 - 50 0.5 1 1.5 2 2.5 Fre q u e nc y (G H z ) 3 3.5 4 DIPLEXER RFDIP1608060LET RFDIP1608060LBT RFDIP1608060L0T RFDIP1608060L3T RFDIP160806ALM6T25 RFDIP1608060LVT RFDIP2012050LPT RFDIP2012050LQT 57 DIPLEXER   58 RFDIP2012100L0T RFDIP2012100L1T RFDIP2012100L3T RFDIP2012100L4T RFDIP2012050L5T RFDIP2012090G0T For more information, please contact with local sales representative All specifications are subject to change without notice TRIPLEXER TRIPLEXER  STRUCTURE AND PIN ASSOCIATED STRUCTURE A STRUCTURE A-1 STRUCTURE A-2  STRUCTURE AND DIMENSION Unit: mm Structure\ Dimension L W T A B C D E F G A 2.00±0.15 1.25±0.15 0.90±0.10 0.20±0.20 0.30±0.20 0.35±0.20 0.65±0.20 0.20±0.20 0.20±0.20 0.30±0.20  ELECTRICAL SPECIFICATION GPS 1.575GHz/ ISM 2.4GHz/5GHz band RF application Part Number Frequency (MHz) Impedance (Ω) Insertion Loss (dB) Attenuation ( dB ) Return Loss (dB)Min Isolation 1560~1606 50 0.6 15(2400~2500 MHz) 15(4800~6000 MHz) 10 - 10 20(1559~1606 MHz) 25(4800~5000 MHz) 2400~2500 50 0.7 RFTIP2109ATM0T63 4900~5950 50 0.8 1560~1606 50 0.6 2400~2500 50 0.7 RFTIP2109BTM5T62 4900~5950 50 0.8 10(860~960 MHz) 15(1545~1605 MHz) 10(3600~3750 MHz) 20(4800~5000 MHz) 10(7200~7500 MHz) 10(9600~10000 MHz) 25(860~960 MHz) 25(1545~1605 MHz) 25(1710~1990 MHz) 30(2170 MHz) 10(8100~8800 MHz) 15(8820~9800 MHz) 25(9800~11900 MHz) 15(2400~2500 MHz) 15(4800~6000 MHz) 10(860~960 MHz) 15(1545~1605 MHz) 10(3600~3750 MHz) 20(4800~5000 MHz) 10(7200~7500 MHz) 10(9600~10000 MHz) 25(860~960 MHz) 25(1545~1605 MHz) 25(1710~1990 MHz) 30(2170 MHz) 10(8100~8800 MHz) 15(8820~9800 MHz) 25(9800~11900 MHz) 10 25(1559~1606 MHz) 10 - 10 20(1559~1606 MHz) 25(4800~5000 MHz) 10 Size(mm) Structure 2.00x1.25x0.90 A-1 2.00x1.25x0.90 A-1 25(1559~1606 MHz)  TYPICAL ELECTRICAL CHARACTERISTICS RFTIP2109ATM0T63 Low band Middle band High band 59 COMMON MODE FILTER COMMON MODE FILTER  STRUCTURE AND PIN ASSOCIATED STRUCTURE A  STRUCTURE AND DIMENSION Unit: mm Structure\ Dimension L W T a b c 1.20+0.40 -0.20 2.00+0.40 -0.20 1.00±0.20 0.45±0.20 0.40±0.20 0.80±0.10 1.60±0.20 3.20±0.20 0.95±0.20 0.60±0.20 0.50±0.20 1.10±0.20 1.00±0.20 0.60±0.20 0.50±0.20 1.10±0.20 A  ELECTRICAL SPECIFICATION DISCRETE CMF for HIGH SPEED TRANSMISSION LINES、USB2.0、IEEE1394、LVDS(mini) Part Number Characteristic Impedance (Differential) Common Mode Attenuation ( Min. ) DC Resistance (Ω) max. Rated Current (mA) Size(mm) Structure RFCMF1220100M3T 90 ohm 9.0(240MHz ~ 1GHz) 1.5 300 1.20x2.00x1.00 A RFCMF1220100M4T 90 ohm 9.0(130 MHz ~ 1GHz) 2.5 200 1.20x2.00x1.00 A RFCMF1632090M1T 90 ohm 9.0(140 MHz ~ 1.0 GHz) 1.5 300 1.60x3.20x0.95 A RFCMF1632100M3T 90 ohm 9.0(240 MHz ~ 1.0 GHz) 1.5 300 1.60x3.20x1.00 A  TYPICAL ELECTRICAL CHARACTERISTICS RFCMF1220100M3T RFCMF1220100M4T TYPICAL ELECTRICAL CHARACTERISTICS Impedance vs Frequency Characteristic: -1 0 -1 0 -2 0 -2 0 dB 0 dB 0 -3 0 -3 0 -4 0 -4 0 C o m m o n M o d e A tte n u a tio n D iffe r e n tia l M o d e L o s s C o m m o n M o d e A tte n u a tio n D iffe r e n tia l M o d e L o s s -5 0 -5 0 0 0 .2 4 0 .4 8 0 .7 2 0 .9 6 1 .2 F r e q u e n c y (G H z )   60 0 0 .2 4 0 .4 8 0 .7 2 0 .9 6 F r e q u e n c y (G H z ) RFCMF1632090M1T RFCMF1632100M3T TYPICAL ELECTRICAL CHARACTERISTICS TYPICAL ELECTRICAL CHARACTERISTICS For more information, please contact with local sales representative All specifications are subject to change without notice 1 .2 COUPLER COUPLER  STRUCTURE AND PIN ASSOCIATED STRUCTURE A STRUCTURE A-1 STRUCTURE A-2 STRUCTURE A-3 STRUCTURE A-4 STRUCTURE B  STRUCTURE AND DIMENSION Unit: mm Structure\ Dimension L W T A B C D E F 1.60±0.10 0.80±0.10 0.60±0.10 0.10±0.10 0.30±0.10 0.25±0.10 0.55±0.10 0.20±0.10 - 1.60±0.10 0.80±0.10 0.60±0.10 0.175±0.10 0.25±0.10 0.25±0.10 0.50±0.10 0.20±0.10 - 0.65±0.04 0.50±0.04 0.35±0.10 0.20±0.04 0.20±0.04 0.025±0.025 0.10±0.04 0.25±0.04 0.025±0.025 A B  ELECTRICAL SPECIFICATION ISM Band 2.4GHz Application Part Number Frequency (MHz) Insertion Loss (dB) Coupling in BW Directivity in BW dB (min.) Isolation in BW dB (min.) VSWR Dimension ( mm³) Structure RFCPL1806B2450T 2400~2500 1.83 6.5 ± 1.0 dB - 21.0 dB min 1.5 1.60x1.80x0.60 A-2 RFCPL1807B2450T 2400~2500 1.30 7.0 ± 1.0 dB - 30.0 dB min 2.0 1.60x1.80x0.60 A-1 RFCPL1810B2450T 2400~2500 0.74 10.0 ±1.0 dB - 22.0 dB min 1.8 1.60x1.80x0.60 A-2 2400~2500 0.40 (typ.0.32) 14.6 ± 1.0 dB 20.0 dB min. - 1.3 0.60x0.50x0.35 B Frequency (MHz) Insertion Loss (dB) Coupling in BW Directivity in BW dB (min.) Isolation in BW dB (min.) VSWR Dimension ( mm³) Structure 2400~2500 0.5 19.0±1.5dB 15 dB min. - 1.3 4900~5850 0.5 12.5±1.5dB 15 dB min. - 1.3 0.60x0.50x0.35 B 2400~2500 0.2 19.3±0.7dB 15 dB min. - 1.3 5150~5850 0.5 13.0±1.5dB 15 dB min. - 1.3 0.60x0.50x0.35 B TFCPL0605B24508Q1C ISM Band 2.4/5GHz Application Part Number TFCPL0605030L18A1U TFCPL0605030L28Q1C 61 COUPLER LTE BAND APPLICATION Part Number Frequency (MHz) Insertion Loss (dB) Coupling in BW Directivity in BW dB (min.) Isolation in BW dB (min.) VSWR Dimension ( mm³) Structure RFCPL1608070P08Q1C 698~2690 0.20(698~960MHz) 0.22(1427.9~2170MHz) 0.25(2300~2690MHz) 23.0~27.0(698~915MHz) 21.5~26.5(1427.9~2025MHz) 22.5~27.5(2300~2620MHz) 20. - 1.5 1.60x1.80x0.60 A-3 RFCPL1608070P18Q1C 698~2690 0.20(698~960MHz) (Typ.0.02) 0.22(1710~2170MHz) (Typ.0.07) 0.25(2300~2690MHz) (Typ.0.10) 23.0~27.0(698~915MHz) 21.5~26.5(1710~2025MHz) 22.5~27.5(2300~2620MHz) 20 - 1.45 1.60x1.80x0.60 A-4 RFCPL1608070P28Q1C 698~2690 0.20(698~960MHz) 0.22(1427.9~2170MHz) 0.25(2300~2690MHz) 23.0~27.0(698~915MHz) 21.5~26.5(1427.9~2025MHz) 22.5~27.5(2300~2620MHz) 20 - 1.5 1.60x1.80x0.60 A-3 RFCPL1608070P38Q1C 698~2690 0.20(698~960MHz) 0.22(1710~2170MHz) 0.25(2300~2690MHz) 23.0~27.0(698~915MHz) 21.5~26.5(1710~2025MHz) 22.5~27.5(2300~2620MHz) 20 - 1.45 1.60x1.80x0.60 A-4 700~2700 0.2(700~790MHz) (Typ.0.07) 0.2(820~900MHz) (Typ.0.07) 0.3(1701~2100MHz) (Typ.0.15) 0.3(2300~2700MHz) (Typ.0.15) 24~27(700~790MHz) 24~27(820~900MHz) 20~23(1701~2100MHz) 20~23(2300~2700MHz) - 40(700~790MHz) 40(820~900MHz) 35(1701~2100MHz) 35(2300~2700MHz) 1.45 1.60x1.80x0.60 A-2 RFCPL1608070PM9T16  TYPICAL ELECTRICAL CHARACTERISTICS TFCPL0605B24508Q1C TFCPL0605030L18A1U 62 COUPLER  TYPICAL ELECTRICAL CHARACTERISTICS RFCPL1806B2450T RFCPL1807B2450T RFCPL1810B2450T RFCPL1608070P08Q1C 63 COUPLER RFCPL1608070P18Q1C RFCPL1608070P28Q1C RFCPL1608070P38Q1C RFCPL1608070PM9T16   64 For more information, please contact with local sales representative All specifications are subject to change without notice SAW Filter SAW Filter  STRUCTURE AND PIN ASSOCIATED STRUCTURE A STRUCTURE A-1 STRUCTURE A-2 STRUCTURE B STRUCTURE C  STRUCTURE AND DIMENSION Unit: mm Structure\ Dimension L W T A B C D 1.10±0.10 0.90±0.10 0.50max. 0.40 1.40±0.13 1.10±0.13 0.65max. 0.50 B 1.80±0.10 1.40±0.10 0.65max. C 1.50±0.10 1.10±0.10 0.60max. E F G H I 0.40 0.25 0.50 0.325 0.20 0.05 0.075 0.25 - - 0.25 0.075 0.10 0.25 - 0.65 0.30 - 0.50 0.25 0.35 0.25 - - 0.18 0.18 - 0.39 0.49 0.075 0.21 0.07 0.21 0.15 A  ELECTRICAL SPECIFICATION Type Part Number Band Frequency (MHz) Insertion Loss (dB) Package (mm) STRUCTURE Tx SAW SF11092017B3403T B34 2010~2025 1.6 1.1 x 0.9 A-1 Tx SAW SF11092595B3804T B38 2570~2620 1.6 1.1 x 0.9 A-1 Tx SAW SF11091900B3907T B39 1880~1920 1.9 1.1 x 0.9 A-1 Tx SAW SF11092350B4004T B40 2300~2400 1.9 1.1 x 0.9 A-1 Tx SAW SF11092605B4111T B41 2550~2655 2.3 1.1 x 0.9 A-1 Tx SAW SF14112595B3803T B38 2570~2620 1.8 1.4 x 1.1 A-1 Tx SAW SF14112350B4001T B40 2300~2400 1.8 1.4 x 1.1 A-1 Tx SAW SF14112605B4107T B41 2550~2655 2.9 1.4 x 1.1 A-1 Rx SAW SF11092595B3805T B38 2570~2620 1.6 1.1 x 0.9 A-1 Rx SAW SF11092350B4005T B40 2300~2400 1.9 1.1 x 0.9 A-1 Rx SAW SF11092140B102T B1 2110~2170 1.9 1.1 x 0.9 A-1 Rx SAW SF11091960B201T B2 1930~1990 2.3 1.1 x 0.9 A-1 65 SAW Filter  ELECTRICAL SPECIFICATION Type Part Number Band Frequency (MHz) Rx SAW SF11091842B305T B3 Rx SAW SF11090881B506T B5 Rx SAW SF11092655B702T B7 Rx SAW Insertion Loss (dB) Package (mm) STRUCTURE 1805~1880 2 1.1 x 0.9 A-1 869~894 1.3 1.1 x 0.9 A-1 2620~2690 2.3 1.1 x 0.9 A-1 SF11090942B805T B8 925~960 2 1.1 x 0.9 A-1 DF18141950B102T B1 1920~1980/2110~2170 2.0/2.0 1.8 x 1.4 B DF18140836B507T B5 824~849/869~894 1.7/1.8 1.8 x 1.4 B DF18140897B801T B8 882.4~912.6/927.4~960 2.1/2.9 1.8 x 1.4 B Rx SAW SB11092140B103T B1 2110~2170 2.0 1.1 x 0.9 A-2 Rx SAW SB11091960B202T B2 1930~1990 2.8 1.1 x 0.9 A-2 Rx SAW SB11091842B306T B3 1805~1880 2.9 1.1 x 0.9 A-2 Rx SAW SB11090881B507T B5 869~894 1.5 1.1 x 0.9 A-2 Rx SAW SB11092655B703T B7 2620~2690 2.5 1.1 x 0.9 A-2 Rx SAW SB11090942B806T B8 925~960 1.9 1.1 x 0.9 A-2 Rx Dual SAW BF1511B394101BT B39/B41 1880~1920/2550~2655 1.8/2.2 1.5 x 1.1 C SAW Duplexer  TYPICAL ELECTRICAL CHARACTERISTICS SF11092017B3403T SF11092595B3804T SF11091900B3907T 66 SAW Filter  TYPICAL ELECTRICAL CHARACTERISTICS SF11092350B4004T SF11092605B4111T SF14112595B3803T SF14112350B4001T SF14112605B4107T 67 SAW Filter  TYPICAL ELECTRICAL CHARACTERISTICS SF11092595B3805T SF11092350B4005T SF11092140B102T SF11091960B201T SF11091842B305T 68 SAW Filter  TYPICAL ELECTRICAL CHARACTERISTICS SF11090881B506T SF11092655B702T SF11090942B805T SB11092140B103T SB11091960B202T 69 SAW Filter  TYPICAL ELECTRICAL CHARACTERISTICS SB11091842B306T SB11090881B507T SB11092655B703T SB11090942B806T 70 ANTENNA SWITCH ANTENNA SWITCH  Application Circuit (GPIO) RFASWDH2418ATF09 RFASWHH1416ATF09 RFASWH656ATF03 SP8T SP6T SP6T 13 N/C 14 12 13 C1 1 11 RF6 RF5 1 11 RF6 RF3 2 10 RF4 RF3 2 10 RF4 RF1 3 9 RF2 RF1 3 9 RF2 4 8 4 8 5 6 N/C VDD 7 5 6 C2 13 1 10 SDATA 2 9 SCLK 3 8 N/C TRX1 ANT N/C 7 4 VC1 VC1 VC2 VC2 VC3 C3 14 C2 5 6 TRX5 C4 VIO TRX6 C4 11 VDD 12 RF5 VDD TRX3 N/C 14 12 N/C RF8 RF7 TRX2 ANT ANT 7 VC3 C1 C3 C2 C1 TRX4 RFASWKH4414ATF09 RFASWMT2628ATF02 RFASWMH6373ATF02 SP4T SP3T SP3T RFC ANT N/C VC2 N/C VC1 14 N/C RF3 RF1 VDD 13 1 11 2 10 3 9 4 8 5 C4 VDD C3 12 6 C1 C2 12 N/C RF1 1 RF4 RF2 8 10 9 2 8 RF3 2 9 6 RF1 3 4 5 RF3 3 7 4 RF2 5 6 VC1 VDD VC2 VC2 ANT VC3 C3 C2 VC1 C1 C3 C2 C1 RFASWA697ATF06 RFASWA630ATF06 RFASWA681ATF02 SPDT SPDT SPDT RF1 VCTL RFC C1 RF2 1 6 VDD 6 11 VDD VCTL 1 C1 5 C1 RF2 7 N/C 7 11 1 C2 2 5 RFC VCTL 10 9 8 12 7 13 6 14 5 RFC C2 2 4 3 RF2 3 RF1 4 RF1 VDD 1 2 3 4 C2 RF2 RFASWAH9628ATF09 RFASWAM3489ATF09 SPDT SPDT VC2 VC1 VDD C3 C1 C2 VCTL 1 6 RF1 2 5 RFC 3 4 RF2 C1 1 8 7 RF2 2 9 6 RF1 3 4 5 VDD NC(float) C2 ANT 71 ANTENNA SWITCH  ELECTRICAL SPECIFICATION 72 Part Number Description Frequency (GHz)Min. Frequency (GHz)Max. Insertion loss (dB) Isolation (dB) VSWR Package (mm) RFASWDH2418ATF09 SP8T GPIO 0.1 2.7 0.45~0.70dB 22~33 1.67 14-pin 2.00 x 2.00 x 0.55 RFASWHH1416ATF09 SP6T GPIO 0.1 2.7 0.40~0.55dB 26~35 1.43 14-pin 2.00 x 2.00 x 0.55 RFASWH656ATF03 SP6T GPIO 0.4 2.7 0.40~0.76dB 20~30 1.43 14-pin 2.00 x 2.00 x 0.78 RFASWKH4414ATF09 SP4T GPIO 0.1 2.7 0.40~0.55dB 26~35 1.43 14-pin 2.00 x 2.00 x 0.55 RFASWMT2628ATF02 SP3T GPIO 0.5 2.7 0.30~0.50dB 20~30 2.00 9-pin 1.15 x 1.15 x 0.55 RFASWMH6373ATF02 SP3T GPIO 0.1 2.7 0.40~0.50dB 23~32 1.43 12-pin 2.00 x 2.00 x 0.55 RFASWA697ATF06 SPDT GPIO 0.7 6.0 0.45~1.00dB 15~32 2.00 6-pin 1.00 x 1.00 x 0.50 RFASWA630ATF06 SPDT GPIO 0.7 2.7 0.55~0.60dB 25~30 2.00 6-pin 1.10 x 0.70 x 0.55 RFASWA681ATF02 SPDT GPIO 0.1 3.0 0.50~0.60dB 25~30 1.43 14-pin 1.60 x 1.60 x 0.45 RFASWAH9628ATF09 SPDT GPIO 0.5 2.7 0.30~0.50dB 20~30 1.43 9-pin 1.10 x 1.10 x 0.42 RFASWAM3489ATF09 SPDT GPIO 0.7 2.7 0.38~0.48dB 21~33 1.43 6-pin 1.10 x 0.70 x 0.45 ANTENNA SWITCH  Application Circuit (MIPI) SP8T TRX2 VDD TRX2 SP8T TRX4 SP6T TRX3 RFASWDT1561ATF03 TRX3 RFASWD658DTF03 N/C RFASWH656DTF03 13 12 11 TRX4 TRX5 VDD C1 C1 VIO 14 13 12 VIO 11 C2 1 SDATA 2 9 SCLK 3 8 C2 TRX1 10 14 1 ANT ANT 1 TRX3 2 15 TRX2 3 14 TRX7 TRX1 4 13 TRX8 20 19 18 17 4 5 6 SDATA 2 9 ANT SCLK 3 8 TRX5 4 7 5 6 TRX6 TRX1 10 5 N/C 16 6 12 7 8 9 10 11 7 VDD SCLK C1 SDATA VIO TRX6 TRX7 TRX8 TRX4 TRX5 TRX6 C2 RFASWET1562ATF03 RFASWFT2563ATF03 SP10T SP12T TRX9 TRX9 TRX10 TRX10 TRX5 ANT 1 16 TRX5 ANT 1 TRX4 2 15 TRX6 TRX4 2 15 TRX6 TRX3 3 14 TRX7 TRX3 3 14 TRX7 TRX2 4 13 TRX8 TRX2 4 13 TRX8 N/C 5 12 TRX1 TRX12 5 12 TRX1 11 N/C 11 TRX11 6 20 7 19 8 18 9 17 10 VDD 6 20 7 19 8 18 9 17 10 VDD SCLK C1 16 SP8T SCLK C1 SDATA SDATA VIO VIO C2 C2  ELECTRICAL SPECIFICATION Part Number Description Frequency (GHz)Min. Frequency (GHz)Max. Insertion loss (dB) TRXx ports Isolation (TRXx to any off TRXx port [non-adjacent ports]) Isolation (TRXx to any off TRXx port [adjacent ports]) VSWR Package (mm) RFASWH656DTF03 SP6T DRX MIPI 0.4 2.7 0.40~0.76dB (704~2690MHz) 20~30 17~26 2.0 14-pin 2.0 x 2.0 x 0.73 RFASWD658DTF03 SP8T DRX MIPI 0.4 2.7 0.40~0.76dB (704~2690MHz) 20~30 17~26 2.0 14-pin 2.0 x 2.0 x 0.73 RFASWDT1561ATF03 SP8T DRX MIPI 0.4 2.7 0.50~0.80dB (700~2690MHz) 25~35 20~26 2.0 20-pin 2.5 x 2.5 x 0.78 RFASWET1562ATF03 SP10T DRX MIPI 0.4 2.7 0.50~0.80dB (700~2690MHz) 25~35 20~26 2.0 20-pin 2.5 x 2.5 x 0.84 RFASWFT2563ATF03 SP12T DRX MIPI 0.4 2.7 0.50~0.80dB (700~2690MHz) 25~35 20~26 2.0 20-pin 2.5 x 2.5 x 0.84 73 ANTENNA SWITCH MODULE ANTENNA SWITCH MODULE  Application Circuit RMASMFT1488BT RMASME494AT RMASMF496AT SP12T SP10T SP12T TXLB TXLB TXHB TXHB TXLB TXHB ANT 1 16 TRX7 ANT 1 16 TRX8 ANT 1 16 TRX8 TRX6 2 15 TRX8 TRX7 2 15 N/C TRX7 2 15 TRX9 TRX5 3 14 TRX9 TRX6 3 14 N/C TRX6 3 14 TRX10 TRX4 4 13 TRX10 TRX5 4 13 TRX1 TRX5 4 13 TRX1 TRX3 5 12 TRX1 TRX4 5 12 TRX2 TRX4 5 12 TRX2 11 TRX2 11 TRX3 11 TRX3 6 19 20 8 7 18 9 17 10 VDD 19 20 6 18 8 7 9 17 10 VDD SCLK 6 SDATA C2 C2 RMASMP491AT RMASMNT1492AT SP14T SP16T TXLB TXHB 21 20 19 TRX8 18 TRX7 2 17 TRX9 TRX6 3 16 TRX10 TRX5 4 TRX4 5 14 TRX12 6 13 TRX1 12 TRX2 8 9 10 11 TXHB ANT 1 20 TRX8 TRX7 2 19 TRX9 TRX6 3 18 TRX10 TRX5 4 17 TRX11 TRX4 5 16 TRX12 TRX3 6 15 TRX1 TRX13 7 14 TRX2 13 TRX14 8 VDD 24 23 22 21 TRX11 15 TRX3 7 SCLK SDATA C2 22 10 VIO VIO 1 9 17 SDATA VIO ANT 8 18 C1 C1 TXLB 7 19 VDD SCLK C1 20 SCLK 9 10 11 VDD C1 12 SCLK C1 SDATA SDATA VIO VIO C2 C2  ELECTRICAL SPECIFICATION Part Number 74 Frequency Frequency Description (GHz) (GHz) Min. Max. Insertion loss (dB) TRXx ports Isolation GSM Insertion Insertion (TRXx to Attenuation loss (dB) loss (dB) any off (dB) TXLB(f0) TXHB(f1) TRXx port (2f0 , 3f0) 824~915MHz 1710~1910MHz [non-adjac (2f1 , 3f1) ent ports]) Isolation (TRXx to any off VSWR TRXx port [adjacent ports]) Package (mm) RMASMFT1488BT SP12T ASM MIPI 0.4 2.7 0.60~0.90dB (824~2690MHz) 1.25 1.25 25 23~30 20~26 2.0 20-pin 2.5 x 2.5 x 0.78 RMASME494AT SP10T ASM MIPI 0.4 2.7 0.60~0.85dB (824~2690MHz) 1.25 1.25 25 23~30 20~26 2.0 20-pin 2.5 x 2.5 x 0.78 RMASMF496AT SP12T ASM MIPI 0.4 2.7 0.60~0.85dB (824~2690MHz) 1.25 1.25 25 23~30 20~26 2.0 20-pin 2.5 x 2.5 x 0.78 RMASMP491AT SP14T ASM MIPI 0.4 2.7 0.70~1.15dB (700~2690MHz) 1.25 1.25 25 20~30 16~20 2.0 22-pin 2.5 x 2.9 x 0.78 RMASMNT1492AT SP16T ASM MIPI 0.4 2.7 0.60~1.00dB (824~2690MHz) 1.25 1.25 25 20~30 16~20 2.0 24-pin 2.5 x3.3 x 0.78 DIPOLE ANTENNA (N/SMA) DIPOLE ANTENNA (N/SMA)  ELECTRICAL SPECIFICATION Series 8709 1313 1513 1713 3913 1310 1413 1913 2213 2220 2520 Size(mm) L Ø 87 9.95 137.5 157.5 172.5 392 135.7 148.5 196.6 217.1 220 25 Working Frequency Range Gain VSWR Return Loss 2.4~2.5 GHz 2dBi
