TXM-418-KH3
TXM-418-KH3
    LINXTECHNOLOGIES(灵思)
    模块
    TXM-418-KH3
TXM-418-KH3 数据手册
KH3 Series Transmitter Module Data Guide ! Warning: Some customers may want Linx radio frequency (“RF”) products to control machinery or devices remotely, including machinery or devices that can cause death, bodily injuries, and/or property damage if improperly or inadvertently triggered, particularly in industrial settings or other applications implicating life-safety concerns (“Life and Property Safety Situations”). Table of Contents 1^ 1^ 1^ NO OEM LINX REMOTE CONTROL OR FUNCTION MODULE SHOULD EVER BE USED IN LIFE AND PROPERTY SAFETY SITUATIONS. No OEM Linx Remote Control or Function Module should be modified for Life and Property Safety Situations. Such modification cannot provide sufficient safety and will void the product’s regulatory certification and warranty. 2^ Customers may use our (non-Function) Modules, Antenna and Connectors as part of other systems in Life Safety Situations, but only with necessary and industry appropriate redundancies and in compliance with applicable safety standards, including without limitation, ANSI and NFPA standards. It is solely the responsibility of any Linx customer who uses one or more of these products to incorporate appropriate redundancies and safety standards for the Life and Property Safety Situation application. 8^ Do not use this or any Linx product to trigger an action directly from the data line or RSSI lines without a protocol or encoder/ decoder to validate the data. Without validation, any signal from another unrelated transmitter in the environment received by the module could inadvertently trigger the action. All RF products are susceptible to RF interference that can prevent communication. RF products without frequency agility or hopping implemented are more subject to interference. This module does not have a frequency hopping protocol built in. Do not use any Linx product over the limits in this data guide. Excessive voltage or extended operation at the maximum voltage could cause product failure. Exceeding the reflow temperature profile could cause product failure which is not immediately evident. Do not make any physical or electrical modifications to any Linx product. This will void the warranty and regulatory and UL certifications and may cause product failure which is not immediately evident. 2^ 3^ 4^ 8^ 9^ 10^ 10^ 11^ 12^ 12^ 12^ 12^ 14^ 14^ 15^ 16^ 17^ 18^ 19^ 19^ 21^ 22^ 22^ 22^ Description Features Applications Ordering Information Absolute Maximum Ratings Electrical Specifications Typical Performance Graphs Pin Assignments Pin Descriptions Module Description Theory of Operation Compatibility with the KH2 Series Encoder Operation Setting the Transmitter Address Data Inputs Enabling Transmission Input Type Selection Using LADJ Power Supply Requirements Typical Applications Antenna Considerations Helpful Application Notes from Linx Interference Considerations Pad Layout Board Layout Guidelines Microstrip Details Production Guidelines Hand Assembly Automated Assembly 24^ General Antenna Rules 26^ Common Antenna Styles 28^ Regulatory Considerations 30^ Notes KH3 Series Transmitter Module Data Guide Description 1.21 in The KH3 Series is ideally suited for (30.73 mm) volume use in OEM applications such as remote control and command, and 0.63 in keyless entry. Housed in a compact SMD (16.00 mm) package, it combines a highly optimized RF transmitter with an on-board encoder. 0.106 in When paired with a matching KH3 (2.69 mm) Series receiver / decoder module, a reliable wireless link is formed, capable of transferring the status of 8 parallel inputs Figure 1: Package Dimensions over distances of up to 3,000 feet. Ten address lines provide transmitter uniqueness. No external RF components are required except an antenna, making integration straightforward. Features • • • • Low cost On-board encoder 8 parallel binary inputs 10 addresses for security and uniqueness • No external RF components required • • • • • • Ultra-low power consumption Compact SMD package Stable SAW-based architecture Adjustable output power Transmit enable line No production tuning Applications • • • • Remote control / command Gate openers Lighting control Call systems • • • • Remote status monitoring Home / industrial automation Remote status / position sensing Wire elimination – 1 – Revised 3/18/2015 Ordering Information Electrical Specifications Ordering Information KH3 Series Transmitter Specifications Part Number Description Parameter TXM-315-KH3 315MHz Transmitter / Encoder Power Supply TXM-418-KH3 418MHz Transmitter / Encoder TXM-433-KH3 433MHz Transmitter / Encoder RXM-315-KH3 315MHz Receiver / Decoder RXM-418-KH3 418MHz Receiver / Decoder RXM-433-KH3 433MHz Receiver / Decoder Power-Down Current EVAL-***-KH3 KH3 Series Basic Evaluation Kit Transmitter Section Symbol Min. Operating Voltage VCC 2.7 Average TX Supply Current ITX At 3.3dBm mA 1,2,3,4 1.0 µA 315 MHz TXM-418-KH3 418 MHz TXM-433-KH3 433.92 MHz FC PO Harmonic Emissions PH −0.3 to +6.0 VDC Antenna Port Any Input or Output Pin −0.3 to VCC VDC RF Impedance Operating Temperature −40 to +85 ºC Encoder Storage Temperature −55 to +125 ºC Data Length +225ºC for 10 seconds Exceeding any of the limits of this section may lead to permanent damage to the device. Furthermore, extended operation at these maximum ratings may reduce the life of this device. –75 Output Power Supply Voltage Vcc Soldering Temperature –4 RI N –1 +75 kHz 2,4 +4 dBm 2,3 –36 dBc 2 Ω 50 26 bits 3x Average Data Duty cycle 50% 5 Data Input Logic Low 0.0 Logic High VCCx0.8 Input Sink Current Figure 3: Absolute Maximum Ratings VDC 1.5 IPDN Center Frequency Accuracy Absolute Maximum Ratings 5.2 Notes 1,2,4 TXM-315-KH3 Absolute Maximum Ratings Units mA Transmit Frequency Figure 2: Ordering Information Max. 2.7 At 0dBm *** = 315, 418 (Standard), 433MHz Transmitters are supplied in tubes of 20 pcs. Typ. 0.6 0.1 0.2xVCC VDC 5 VCC VDC 5 5 µA 5 +70 ºC 5 Environmental Operating Temp. Range 1. Warning: This product incorporates numerous static-sensitive components. Always wear an ESD wrist strap and observe proper ESD handling procedures when working with this device. Failure to observe this precaution may result in module damage or failure. – 2 – 2. Curent draw with 50% mark/space ratio Into a 50Ω load –30 3. 4. 5. Figure 4: Electrical Specifications – 3 – With a 430Ω resistor on LADJ At 3V and 25ºC Characterized, but not tested Typical Performance Graphs Supply Currnent (mA) 8.00 +85°C 7.00 +25°C 6.00 -40°C 5.00 +25°C 4.00 LADJ = 0Ω +85°C 3.00 Supply Currnent (mA) 8.00 LADJ = 430Ω 3 3.5 4 4.5 +25°C 5.00 LADJ = 0Ω 4.00 +25°C 3.00 -40°C +85°C -40°C LADJ = 430Ω 1.00 2.5 1.00 2.5 +85°C 6.00 2.00 -40°C 2.00 7.00 5 3 3.5 6 5.5 Supply Voltage (V) 4 4.5 5 5.5 6 Supply Voltage (V) Figure 7: TXM-433-KH3 Transmitter Supply Current vs. Supply Voltage Supply Currnent (mA) 8.00 7.00 +85°C 6.00 +25°C 5.00 -40°C 4.00 LADJ = 0Ω +25°C +85°C 3.00 -40°C 2.00 LADJ = 430Ω 1.00 Transmitter Output Power (dBm) Figure 5: TXM-315-KH3 Transmitter Supply Current vs. Supply Voltage 11.00 -40°C 9.00 +25°C LADJ = 0Ω +85°C 7.00 -40°C 5.00 +25°C 3.00 1.00 +85°C -1.00 LADJ = 430Ω -3.00 -5.00 2.5 3 3.5 4 4.5 Supply Voltage (V) Figure 6: TXM-418-KH3 Transmitter Supply Current vs. Supply Voltage – 4 – 5 5.5 6 2.5 3 3.5 4 4.5 Supply Voltage (V) Figure 8: TXM-315-KH3 Transmitter Output Power vs. Supply Voltage – 5 – 5 5.5 6 3.00 +25°C 9.00 -40°C LADJ = 0Ω 7.00 +85°C 5.00 -40°C 3.00 +25°C 1.00 +85°C -1.00 LADJ = 430Ω -3.00 Transmitter Current (mA) Transmitter Output Power (dBm) 11.00 -5.00 2.5 3 3.5 4 4.5 5 5.5 2.50 2.00 1.50 1.00 0.50 -7.00 6 -6.00 -5.00 -4.00 -3.00 Supply Voltage (V) LADJ = 0Ω 9.00 -40°C 5.00 +25°C 3.00 1.00 +85°C 3.00 4.00 7.00 6.00 5.00 4.00 3.00 2.00 LADJ = 430Ω -3.00 2.00 8.00 +85°C -1.00 1.00 9.00 +25°C 7.00 0.00 10.00 -40°C 11.00 -1.00 Figure 11: KH3 Series Transmitter Output Power vs. Supply Current at 3.0V Attenuation (dB) Transmitter Output Power (dBm) Figure 9: TXM-418-KH3 Transmitter Output Power vs. Supply Voltage 13.00 -2.00 Output Power (dBm) 1.00 -5.00 0.00 2.5 3 3.5 4 4.5 Supply Voltage (V) Figure 10: TXM-433-KH3 Transmitter Output Power vs. Supply Voltage – 6 – 5 5.5 6 0 200 400 600 800 LADJ Resistance (Ohms) Figure 12: KH3 Series Transmitter Output Power Attenuation vs. LADJ Resistor – 7 – 1000 1200 Pin Assignments Module Description 1 LADJ/GND ANT 24 2 D0 GND 23 3 D1 A9 22 4 GND A8 21 5 VCC A7 20 6 TE A6 19 7 D2 A5 18 A4 17 D4 A3 16 10 D5 A2 15 11 D6 A1 14 12 D7 A0 13 25 26 27 D_CFG A_CFG1 D3 A_CFG0 8 9 Figure 13: KH3 Series Transmitter Pin Assignments (Top View) Pin Descriptions The KH3 Series transmitter / encoder module combines a high-performance Surface Acoustic Wave (SAW) based transmitter with an on-board remote control encoder. When combined with a Linx KH3 Series receiver / decoder, a highly reliable RF link capable of transferring control or command data over line-of-sight distances of up to 3,000 feet is formed. The module accepts up to 8 parallel inputs, such as switches or contact closures, and provides ten address lines for creating unique transmitter / receiver relationships. The KH3’s compact surface-mount package integrates easily into existing designs and is friendly to hand production or automated assembly. 50Ω RF OUT (ANT) SAW Oscillator 1 Address Inputs A0-A9 D_CFG D_CFG0 D_CFG1 Keyed Output Pin Descriptions Pin Number TX Enable Data Out Name GND / LADJ I/O Description — Level Adjust. This line adjusts the output power level of the transmitter. Connecting to GND gives the highest output, while placing a resistor to GND lowers the output level. Data Input Lines. When TE goes high, the module encodes the state of these lines for transmission. Upon receipt of a valid transmission, the receiver / decoder replicates these lines on its output lines. These lines are pulled to GND internally. 2, 3, 7, 8, 9, 10, 11,12 D0 to D1 I 4, 23 GND — Analog Ground 5 VCC — Supply Voltage 6 TE I/O Transmit Enable Line. When this line goes high, the module encodes the states of the address and data lines into a packet and transmits the packet three times. 13, 14, 15, 16, 17, 18, 19, 20, 21, 22 A0 to A9 I Address Lines. The state of these lines must match the state of the receiver’s address lines in order for a transmission to be accepted. These lines are pulled to VCC internally. 24 ANT — 50-ohm RF Output 25 D_CFG I/O Data Line Configuration. Determines whether a low on a data line is interpreted as a zero bit or an open bit. See the Input Type Selection section. This line is pulled to GND internally. 26, 27 A_CFG0 / A_CFG1 Output Isolation & Filter RF Amplifier RF STAGE ENCODER STAGE Figure 15: KH3 Series Transmitter Block Diagram Address Configuration. These lines determine the address bit type interpretation. See the Input Type Selection section. A_CFG0 is pulled to GND and A_CFG1 is pulled to VCC internally. Figure 14: KH3 Series Transmitter Pin Descriptions – 8 – – 9 – Parallel Inputs D0-D7 Theory of Operation Encoder Operation The KH3 Series transmitter operation is straightforward. When the Transmit Enable (TE) line is taken high, the on-board encoder IC is activated. The encoder detects the logic states of the data and address lines. These states are formatted into a 3-word transmission, which continues until the TE line is taken low. The encoder creates a serial data packet that is used to modulate the transmitter. The KH3 Series transmitter internally utilizes the DS Series encoder. The encoder begins a three-word transmission cycle when the Transmission Enable line (TE) is pulled high. This cycle repeats itself for as long as the TE line is held high. Once TE falls low, the encoder completes its final cycle and then stops as shown in the Encoder / Decoder Timing diagram (Figure 16). When a transmission enable signal is applied, the encoder scans and transmits the status of the 10 bits of the address code and the 8 bits of the data serially in the order A0 to A9, D0 to D7. The transmitter section is based on a simple, but highly-optimized, architecture that achieves a high fundamental output power with low harmonic content. This ensures that most approval standards can be met without external filter components. The KH3 Series transmitter is exceptionally stable over variations in time, temperature, and physical shock as a result of the precision SAW device that is incorporated as the frequency reference. The transmitted signal may be received by a Linx KH3 Series receiver / decoder module or a Linx LR Series receiver combined with the appropriate decoder IC. Once data is received, it is decoded using a decoder IC or custom microcontroller. The transmitted address bits are checked against the address settings of the receiving device. If a match is confirmed, the decoder’s outputs are set to replicate the transmitter’s inputs. Power On Standby Mode No Transmission Enabled? Yes 3 Data Words Transmitted No Transmission Still Enabled? Yes The state of address / data pins can be 3 Data Words Transmitted interpreted as ONE, ZERO or OPEN bits, Continuously following the logic of the D_CFG, A_CFG0 and A_CFG1 inputs. See the Input Type Selection Figure 16: Encoder Flowchart section for more details. The open bit on the data input is interpreted as logic low by the decoders since the decoder output only has two states. The address pins are usually set to transmit particular security codes by DIP switches or PCB wiring, while the data is selected using push buttons or electronic switches. Compatibility with the KH2 Series The Legacy KH2 Series used encoders and decoders for Holtek® and the KH3 migrates to the Linx DS Series encoder and decoder. The protocol and functionality are compatible. There is some difference in the hardware set-up for the address lines and the data lines. The legacy Holtek® products used tri-state lines, so high, low and floating were each valid states. The DS Series has bi-state lines; high and low only. Three lines have been added to the KH3 module to allow for the selection of how the address and data line states are interpreted. Please see the Input Type Selection section for more details. The KH3 transmitter has been designed to be compatible with legacy systems. The module has been configured for the most common use of the KH2 so that it can be placed on existing boards without modification. This makes the KH3 a drop-in replacement for most applications. – 10 – Encoder Transmit Enable Encoder Data Out Decoder VT < 1 Word 3 Words Transmitted Continuously 2 Words Check Check Decoder Data Out Figure 17: Encoder / Decoder Timing Diagram – 11 – 3 Words Setting the Transmitter Address The module has ten address lines. This allows the formation of up to 1,022 (210 – 2) unique transmitter-receiver relationships. Note: All address lines high or all low is not allowed, so at least one line must be different from the others. Because the address inputs have internal pull-up resistors these pins can be left floating or tied to GND. These pins may be hardwired or configured via a microprocessor, DIP switch or jumpers. The receiver’s address line states must match the transmitter’s exactly for a transmission to be recognized. If the transmitted address does not match the receiver’s local address, then the receiver will take no action. lines. Tri-state inputs are connected to ground for zero bits, VCC for one bits, or left unconnected for open bits. Since the DS cannot match this operation the D_CFG, A_CFG0 and A_CFG1 lines are provided to select the desired interpretation. The settings must match on both ends. Pulling the D_CFG line high configures the data inputs as one and zero. A high on a data line is interpreted as a one bit and a low on the line is interpreted as a zero bit. Pulling D_CFG low configures the data inputs as one and open. A high on a data line is interpreted as a one bit and a low on the line is interpreted as an open bit. The decoder outputs open data bits as logic low. This is shown in Figure 18. D_CFG Configuration Configuration Data Inputs When the Transmit Enable (TE) line goes high, the states of the eight data input lines are recorded and encoded for transmission. Because the data inputs have internal pull-down resistors, these pins can be left floating or tied to VCC. The states of the data lines can be set by switches, jumpers, microcontrollers or hardwired on the PCB. The encoder sends the states of the address and data lines three times. If the TE line is still high, it begins the cycle again. This means that the states of the data lines are refreshed with each cycle, so the data lines can be changed without having to pull TE low. There can be up to a 150ms lag in response as the transmitter finishes one cycle then refreshes and starts over. Bit Interpretation D_CFG High Low 0 One Open 1 One Zero Figure 18: D_CFG Configuration A_CFG0 and A_CFG1 are used to select the bit type for the address lines. These are shown in Figure 19. A_CFGO and A_CFG1 Configuration Configuration Bit Interpretation A_CFG1 A_CFG0 High Low 0 0 One Zero Enabling Transmission 0 1 One Open The module’s Transmit Enable (TE) line controls transmission status. When taken high, the module initiates transmission, which continues until the line is pulled low or power to the module is removed. In some cases this line will be wired permanently to VCC and transmission controlled by switching VCC to the module. This is particularly useful in applications where the module powers up and sends a transmission only when a button is pressed on the remote. 1 0 Open Zero 1 1 One Zero Input Type Selection The KH3 Series transmitter incorporates the DS Series remote control encoder, which is designed to be operable with previous generation products based on Holtek® encoders and decoders. The Holtek® encoders and decoders have tri-state input lines but the DS has bi-state – 12 – Figure 19: A_CFG0 and A_CFG1 Configuration D_CFG is pulled low internally so that a high on a data line is transmitted as a one bit and a low on the line is transmitted as an open bit. A_CFG0 is pulled low and A_CFG1 is pulled high internally so that a high on an address line is interpreted as an open bit and a low as a zero bit. This configuration matches the Linx OEM products and the most common implementation of the legacy KH2 Series. This enables customers using the KH2 Series to populate the KH3 Series without any PCB modifications since pins 25, 26 and 27 can be left unconnected. – 13 – Using LADJ Typical Applications The LADJ line allows the transmitter’s output power to be easily adjusted for range control, lower power consumption, or to meet legal requirements. This is done by placing a resistor between GND and LADJ. When LADJ is connected directly to GND, the output power is at its maximum. Placing a resistor lowers the output power by up to 7dB, as shown in Figure 12. Figure 21 shows an example of a basic remote control transmitter utilizing the KH3 Series transmitter. VCC 0 ohm TXE-XXX-KH3 VCC 5 + 6 GND 7 8 9 10 11 The module does not have an internal Vcc TO MODULE voltage regulator; therefore it requires a clean, well-regulated power source. While it 10Ω is preferable to power the unit from a battery, Vcc IN it can also be operated from a power supply 10µF as long as noise is less than 20mV. Power supply noise can affect the transmitter modulation; therefore, providing a clean power supply for the module should be a Figure 20: Power Supply Filter high priority during design. GND D1 A9 GND A8 VCC A7 TE A6 D2 A5 D3 A4 D4 A3 D5 A2 D6 D7 25 12 Power Supply Requirements D0 A_CFG1 4 GND ANT A_CFG0 This is very useful during FCC testing to compensate for antenna gain or other product-specific issues that may cause the output power to exceed legal limits. A variable resistor can be used so that the test lab can precisely adjust the output power to the maximum level allowed by law. The resistor’s value can be noted and a fixed resistor substituted for final testing. Even in designs where attenuation is not anticipated, it is a good idea to place a resistor pad connected to LADJ and GND so that it can be used if needed. 3 LADJ/GND A1 A0 24 23 GND 22 21 20 19 18 17 16 1 2 3 4 5 6 7 8 9 10 20 19 18 17 16 15 14 13 12 11 15 GND 14 13 27 2 D_CFG 1 26 GND 100k GND + A 10-ohm resistor in series with the supply followed by a 10µF tantalum capacitor from VCC to ground will help in cases where the quality of supply power is poor. These values may need to be adjusted depending on the noise present on the supply line. Figure 21: KH3 Series Transmitter Typical Application Circuit The data lines are connected to buttons. When a button is pressed it takes the corresponding data line high and the TE line to begin the transmission process. Since the data pins are internally pulled down to GND, no pull-down resistors are needed. Diodes are used to pull the TE line high when any data line goes high, while isolating the data lines from each other. This makes the transmitter send data when any button is pressed without affecting any of the other data lines. A ten-position DIP switch is used to set the address to either ground or VCC. Since the address lines are internally pulled up to VCC, no pull-up resistors are needed. A resistor is placed on the LADJ line going to GND. This allows the transmitter output power to be adjusted if needed. – 14 – – 15 – Antenna Considerations Helpful Application Notes from Linx The choice of antennas is a critical and often overlooked design consideration. The range, performance and legality of an RF link are critically dependent upon the antenna. While adequate antenna performance can often be obtained by trial and error methods, antenna Figure 22: Linx Antennas design and matching is a complex task. Professionally designed antennas such as those from Linx (Figure 22) help ensure maximum performance and FCC and other regulatory compliance. It is not the intention of this manual to address in depth many of the issues that should be considered to ensure that the modules function correctly and deliver the maximum possible performance. We recommend reading the application notes listed in Figure 23 which address in depth key areas of RF design and application of Linx products. These applications notes are available online at www.linxtechnologies.com or by contacting Linx. Linx transmitter modules typically have an output power that is higher than the legal limits. This allows the designer to use an inefficient antenna such as a loop trace or helical to meet size, cost or cosmetic requirements and still achieve full legal output power for maximum range. If an efficient antenna is used, then some attenuation of the output power will likely be needed. This can easily be accomplished by using the LADJ line. Helpful Application Note Titles Note Number Note Title AN-00100 RF 101: Information for the RF Challenged AN-00126 Considerations for Operation Within the 902–928MHz Band AN-00130 Modulation Techniques for Low-Cost RF Data Links AN-00140 The FCC Road: Part 15 from Concept to Approval AN-00150 Use and Design of T-Attenuation Pads AN-00300 Addressing Linx OEM Products AN-00500 Antennas: Design, Application, Performance AN-00501 Understanding Antenna Specifications and Operation Figure 23: Helpful Application Note Titles It is usually best to utilize a basic quarter-wave whip until your prototype product is operating satisfactorily. Other antennas can then be evaluated based on the cost, size and cosmetic requirements of the product. Additional details are in Application Note AN-00500. – 16 – – 17 – Interference Considerations Pad Layout The RF spectrum is crowded and the potential for conflict with unwanted sources of RF is very real. While all RF products are at risk from interference, its effects can be minimized by better understanding its characteristics. The pad layout diagram in Figure 24 is designed to facilitate both hand and automated assembly. Interference may come from internal or external sources. The first step is to eliminate interference from noise sources on the board. This means paying careful attention to layout, grounding, filtering and bypassing in order to eliminate all radiated and conducted interference paths. For many products, this is straightforward; however, products containing components such as switching power supplies, motors, crystals and other potential sources of noise must be approached with care. Comparing your own design with a Linx evaluation board can help to determine if and at what level design-specific interference is present. External interference can manifest itself in a variety of ways. Low-level interference produces noise and hashing on the output and reduces the link’s overall range. High-level interference is caused by nearby products sharing the same frequency or from near-band high-power devices. It can even come from your own products if more than one transmitter is active in the same area. It is important to remember that only one transmitter at a time can occupy a frequency, regardless of the coding of the transmitted signal. This type of interference is less common than those mentioned previously, but in severe cases it can prevent all useful function of the affected device. Although technically not interference, multipath is also a factor to be understood. Multipath is a term used to refer to the signal cancellation effects that occur when RF waves arrive at the receiver in different phase relationships. This effect is a particularly significant factor in interior environments where objects provide many different signal reflection paths. Multipath cancellation results in lowered signal levels at the receiver and shorter useful distances for the link. 0.07 in (1.78 mm) 0.065 in (1.65 mm) 0.046 in (1.17 mm) 0.096 in (2.44 mm) 0.10 in (2.54 mm) 0.10 in (2.54 mm) 0.274 in (6.96 mm) 0.61 in (15.49 mm) 0.14 in (3.56 mm) Figure 24: Recommended PCB Layout Board Layout Guidelines The module’s design makes integration straightforward; however, it is still critical to exercise care in PCB layout. Failure to observe good layout techniques can result in a significant degradation of the module’s performance. A primary layout goal is to maintain a characteristic 50-ohm impedance throughout the path from the antenna to the module. Grounding, filtering, decoupling, routing and PCB stack-up are also important considerations for any RF design. The following section provides some basic design guidelines. During prototyping, the module should be soldered to a properly laid-out circuit board. The use of prototyping or “perf” boards results in poor performance and is strongly discouraged. Likewise, the use of sockets can have a negative impact on the performance of the module and is discouraged. The module should, as much as reasonably possible, be isolated from other components on your PCB, especially high-frequency circuitry such as crystal oscillators, switching power supplies, and high-speed bus lines. When possible, separate RF and digital circuits into different PCB regions. – 18 – – 19 – Make sure internal wiring is routed away from the module and antenna and is secured to prevent displacement. Do not route PCB traces directly under the module. There should not be any copper or traces under the module on the same layer as the module, just bare PCB. The underside of the module has traces and vias that could short or couple to traces on the product’s circuit board. The Pad Layout section shows a typical PCB footprint for the module. A ground plane (as large and uninterrupted as possible) should be placed on a lower layer of your PC board opposite the module. This plane is essential for creating a low impedance return for ground and consistent stripline performance. Use care in routing the RF trace between the module and the antenna or connector. Keep the trace as short as possible. Do not pass it under the module or any other component. Do not route the antenna trace on multiple PCB layers as vias add inductance. Vias are acceptable for tying together ground layers and component grounds and should be used in multiples. Microstrip Details A transmission line is a medium whereby RF energy is transferred from one place to another with minimal loss. This is a critical factor, especially in high-frequency products like Linx RF modules, because the trace leading to the module’s antenna can effectively contribute to the length of the antenna, changing its resonant bandwidth. In order to minimize loss and detuning, some form of transmission line between the antenna and the module should be used unless the antenna can be placed very close (
TXM-418-KH3 价格&库存
很抱歉,暂时无法提供与“TXM-418-KH3”相匹配的价格&库存,您可以联系我们找货
