TXM-433-LR
TXM-433-LR
    LINXTECHNOLOGIES(灵思)
    SMD-8P
    TXM-433-LR
TXM-433-LR 数据手册
LR Series Transmitter Module Data Guide ! Warning: Some customers may want Linx radio frequency (“RF”) products to control machinery or devices remotely, including machinery or devices that can cause death, bodily injuries, and/or property damage if improperly or inadvertently triggered, particularly in industrial settings or other applications implicating life-safety concerns (“Life and Property Safety Situations”). Table of Contents 1^ 1^ 1^ NO OEM LINX REMOTE CONTROL OR FUNCTION MODULE SHOULD EVER BE USED IN LIFE AND PROPERTY SAFETY SITUATIONS. No OEM Linx Remote Control or Function Module should be modified for Life and Property Safety Situations. Such modification cannot provide sufficient safety and will void the product’s regulatory certification and warranty. 2^ Customers may use our (non-Function) Modules, Antenna and Connectors as part of other systems in Life Safety Situations, but only with necessary and industry appropriate redundancies and in compliance with applicable safety standards, including without limitation, ANSI and NFPA standards. It is solely the responsibility of any Linx customer who uses one or more of these products to incorporate appropriate redundancies and safety standards for the Life and Property Safety Situation application. 6^ Do not use this or any Linx product to trigger an action directly from the data line or RSSI lines without a protocol or encoder/ decoder to validate the data. Without validation, any signal from another unrelated transmitter in the environment received by the module could inadvertently trigger the action. All RF products are susceptible to RF interference that can prevent communication. RF products without frequency agility or hopping implemented are more subject to interference. This module does not have a frequency hopping protocol built in. Do not use any Linx product over the limits in this data guide. Excessive voltage or extended operation at the maximum voltage could cause product failure. Exceeding the reflow temperature profile could cause product failure which is not immediately evident. Do not make any physical or electrical modifications to any Linx product. This will void the warranty and regulatory and UL certifications and may cause product failure which is not immediately evident. 2^ 3^ 4^ 6^ 7^ 8^ 9^ 9^ 10^ 10^ 11^ 12^ 13^ 14^ 15^ 15^ 16^ 17^ 17^ 19^ 20^ 20^ 20^ 22^ Description Features Applications Ordering Information Absolute Maximum Ratings Electrical Specifications Typical Performance Graphs Pin Assignments Pin Descriptions Module Description Theory of Operation The Data Input Using the PDN Line Using the LADJ Line Power Supply Requirements Transferring Data Typical Applications ESD Concerns Antenna Considerations Helpful Application Notes from Linx Protocol Guidelines Interference Considerations Pad Layout Board Layout Guidelines Microstrip Details Production Guidelines Hand Assembly Automated Assembly General Antenna Rules 24^ Common Antenna Styles 26^ Regulatory Considerations LR Series Transmitter Module Data Guide Description The LR Series transmitter is ideal for the cost-effective 0.360 in TXM-315-LR wireless transfer of serial data, control, or command (9.14 mm) LOT RTxxxx information in the favorable 260 to 470MHz band. 0.500 in When paired with a compatible Linx receiver, a reliable (12.7 mm) 0.130 in wireless link is formed, capable of transferring serial (3.3 mm) data at rates of up to 10,000bps at distances of up Typ. to 3,000 feet (1,000m). Applications operating over shorter distances or at lower data rates also benefit Figure 1: Package Dimensions from increased link reliability and superior noise immunity. The transmitter’s synthesized architecture delivers outstanding stability and frequency accuracy and minimizes the affects of antenna pulling. Housed in a tiny reflow-compatible SMD package, the transmitter requires no external RF components except an antenna, which greatly simplifies integration and lowers assembly costs. Features • • • • • • Long range Low cost PLL-synthesized architecture Direct serial interface Data rates up to 10,000bps No external RF components required • Low power consumption • Low supply voltage (2.1 to 3.6VDC) • Compact surface-mount package • Wide temperature range • Power-down function • No production tuning Applications • • • • • • Remote control Keyless entry Garage/gate openers Lighting control Medical monitoring/call systems Remote industrial monitoring • • • • • • – 1 – Periodic data transfer Home/industrial automation Fire/security alarms Remote status/position sensing Long-range RFID Wire elimination Revised 3/18/2015 Ordering Information Electrical Specifications Ordering Information LR Series Transmitter Specifications Part Number Description Parameter TXM-315-LR 315MHz Transmitter Power Supply TXM-418-LR 418MHz Transmitter TXM-433-LR 433MHz Transmitter RXM-315-LR 315MHz Receiver RXM-418-LR 418MHz Receiver Symbol Min. Typ. Max. Units Operating Voltage VCC 2.1 3.0 3.6 VDC Supply Current lCC 3.4 mA 1,2 5.1 mA 2 1.8 mA 5.0 nA TXM-315-LR 315 MHz TXM-418-LR 418 MHz TXM-433-LR 433.92 MHz Logic High Logic Low RXM-433-LR 433MHz Receiver Power Down Current EVAL-***-LR LR Series Basic Evaluation Kit Transmitter Section lPDN Transmit Frequency Range *** = 315, 418 (Standard), 433MHz Transmitters are supplied in tubes of 50 pcs. Figure 2: Ordering Information FC Center Frequency Accuracy Absolute Maximum Ratings –50 Output Power Absolute Maximum Ratings PO Output Power Control Range Supply Voltage Vcc −0.3 to +3.6 VDC Harmonic Emissions Any Input or Output Pin −0.3 to VCC + 0.3 VDC Data Rate Operating Temperature −40 to +85 ºC Data Input: Storage Temperature −40 to +90 ºC Soldering Temperature +260ºC for 10 seconds Exceeding any of the limits of this section may lead to permanent damage to the device. Furthermore, extended operation at these maximum ratings may reduce the life of this device. Notes –4 0.0 –80 PH DC Logic Low VIL Logic High VIH +50 kHz +4 dBm 2 +10 dB 3 –36 dBc 10,000 bps 0.25 VDC VCC–0.25 VDC Power Down Input: Logic Low VIL Logic High VIH 0.25 VCC–0.25 VDC VDC Antenna Port Figure 3: Absolute Maximum Ratings RF Output Impedance ROUT 50 Ω 4 1.0 ms 4 30.0 ns 4 +85 ºC 4 Timing Transmitter Turn-On Time Via VCC or PDN Modulation Delay Warning: This product incorporates numerous static-sensitive components. Always wear an ESD wrist strap and observe proper ESD handling procedures when working with this device. Failure to observe this precaution may result in module damage or failure. Environmental Operating Temperature 1. 2. 3. 4. –40 With a 50% duty cycle With a 750Ω resistor on LADJ See Figure 6 on page 4 Characterized, but not tested Figure 4: Electrical Specifications – 2 – – 3 – Typical Performance Graphs 2. 2.00V/div 4 1 Current Consumption (mA) 1. 500mV/div 4.5 3.5 3 2.5 2 2 6.00 3.00 0.00 -3.00 -6.00 Figure 7: Current Consumption vs. Output Power (50% of Duty Cycle) 100nS/div Figure 5: Modulation Delay 12 LADJ Resistance (kΩ) 10 8 6 4 2 0 9.00 6.00 3.00 0.00 -3.00 -6.00 -9.00 Output Power (dBm) -12.00 -15.00 -18.00 -21.00 Figure 6: Output Power vs. LADJ Resistor – 4 – -9.00 Output Power (dBm) – 5 – -12.00 -15.00 -18.00 -21.00 Pin Assignments 1 2 3 4 Module Description GND PDN DATA VCC GND GND LADJ/VCC ANT 8 7 6 5 The module’s low power consumption makes it ideal for battery-powered products. The transmitter is compatible with many other Linx receiver products, including the LR, KH3, LT and OEM product families. For applications where range is critical, the LR receiver is the best choice due to its outstanding sensitivity. Figure 8: LR Series Transmitter Pinout (Top View) Pin Descriptions Pin Descriptions Pin Number Name I/O Description 1 GND — Analog Ground 2 DATA I 3 GND — 4 The LR Series transmitter is a low-cost, high-performance synthesized ASK / OOK transmitter, capable of sending serial data at up to 10,000bps. Because the transmitter is completely self-contained, requiring an antenna as the only additional RF component, application is extremely straightforward and assembly and testing costs are reduced. The LR is housed in a compact surface-mount package that integrates easily into existing designs and is equally friendly to prototyping and volume production. LR Series modules are capable of meeting the regulatory requirements of domestic and international applications. Digital Data Input Analog Ground Level Adjust. This line can be used to adjust the output power level of the transmitter. Connecting to VCC gives the highest output, while placing a resistor to VCC lowers the output level (see Figure 6 on page 4) LADJ/VCC I 5 ANT — 50Ω RF Output 6 GND — Analog Ground 7 VCC — Supply Voltage 8 PDN I The transmitter is capable of outputting +10dBm into a 50-ohm load. When combined with an LR Series receiver, a reliable serial link is formed capable of transferring data over line-of-site distances of up to 1.5 miles (2,500m) when used with good antennas. Legal regulations in the various countries will require the transmitter output power to be reduced which will reduce range. Following the legal output limit for transmitters in the United States, systems based on the LR Series can achieve ranges of up to 3,000 feet (1,000m). Power Down. Pulling this line low places the transmitter into a low-current state. The module is not be able to transmit a signal in this state. Figure 9: Pin Descriptions – 6 – – 7 – Theory of Operation The Data Input DATA PDN The CMOS-compatible data input on Pin 2 is normally supplied with a serial bit stream from a microprocessor or encoder, but it can also be used with standard UARTs. PLL VCO PA RF OUT XTAL Figure 10: LR Series Transmitter Block Diagram The LR Series transmitter generates 1mW of output power into a 50-ohm single-ended antenna while suppressing harmonics and spurious emissions to within legal limits. The transmitter is comprised of a VCO locked by a frequency synthesizer that is referenced to a high precision crystal. The output of the VCO is amplified and buffered by an internal power amplifier. The amplifier is switched by the incoming data to produce a modulated carrier. The carrier is filtered to attenuate harmonics and then output on the 50Ω antenna port. The synthesized topology makes the module highly immune to the effects of antenna port loading and mismatch. This reduces or eliminates frequency pulling, bit contraction, and other negative effects common to low-cost transmitter architectures. It also allows for reliable performance over a wide operating temperature range. Like its companion LR Series receiver, the LR Series transmitter delivers a significantly higher level of performance and reliability than the LC Series or other SAW-based devices, yet remains very small and cost-effective. – 8 – When a logic ‘1’ is present on the DATA line and the PDN line is high, then the Power Amplifier (PA) is activated and the carrier frequency is output on the antenna port. When a logic ‘0’ is present on the DATA line or the PDN line is low, the PA is deactivated and the carrier is fully suppressed. The DATA line should always be driven with a voltage that is common to the supply voltage present on Pin 7 (VCC). The DATA line should never be allowed to exceed the supply voltage, as permanent damage to the module could occur. Using the PDN Line The transmitter’s Power Down (PDN) line can be used to power down the transmitter without the need for an external switch. It allows easy control of the transmitter’s state from external components, such as a microcontroller. By periodically activating the transmitter, sending data, then powering down, the transmitter’s average current consumption can be greatly reduced, saving power in battery operated applications. The PDN line does not have an internal pull-up, so it needs to be pulled high or tied directly to VCC to turn on the transmitter. The pull-up should be a minimum of 30μA (10kΩ or less). When the PDN line is pulled to ground, the transmitter enters a low-current (
TXM-433-LR 价格&库存
很抱歉,暂时无法提供与“TXM-433-LR”相匹配的价格&库存,您可以联系我们找货
TXM-433-LR
    • 1+57.49920
