SRCW004
SRCW004
    ANTENOVA(安诺亚)
    用于所有2.4GHz应用。设计紧凑,易于集成和实施。在不同的接地平面尺寸上有效。在多天线系统中能良好共存。抗失谐效应意味着设备可以在不同环境中良好工作。是小型可穿戴设备的理想天线选择。
SRCW004 数据手册
Weii 2.4 GHz Ceramic Antenna Part no: SRCW004 ceriiANT® Product Specification 1. Features:  2.4GHz applications  Bluetooth, WiFi, Zigbee, ISM.  Ultra small ceramic chip solution.  High Efficiency.  SMD mounted.  Resistant to de-tuning.  Omni-directional  RoHS compliant 2. Description For use in all 2.4GHz applications. Compact design with simple integration and implementation. Effective on varying GND plane sizes. Coexists well in multiple antenna systems. Resistant to de-tuning effects means devices can work well in different environments. Ideal antenna choice for small wearable devices. 3. Applications: 4. Quick Specs: Part Number SRCW004 Frequency 2.4 – 2.5GHz Medical devices Operating Temp -40°C to125°C  PNDs Antenna Dimensions 1.0 x 0.5 x 0.5  Dongles Antenna Clearance Area 9mm x 4.5mm  Sensors Average Efficiency 70%  Small wearable devices  Headsets  Antennas for Wireless M2M Applications 1 Product Specification DS-SRCW004 -1.0 Weii 2.4 GHz Chip Antenna Part No. SRCW004 5. Mechanical Specifications Product Name Weii 2.4GHz Chip Antenna Part Number SRCW004 Frequency Range 2.4 - 2.5 GHz Polarization Linear Operating Temperature -40 ºC to +120 ºC Weight
SRCW004 价格&库存
很抱歉,暂时无法提供与“SRCW004”相匹配的价格&库存,您可以联系我们找货
SRCW004
  • 1+7.664581+0.98180
  • 10+5.4643810+0.69997
  • 25+4.9208525+0.63034
  • 100+4.31836100+0.55317
  • 250+4.03125250+0.51639
  • 500+3.85831500+0.49424
  • 1000+3.715951000+0.47600
  • 2500+3.682702500+0.47174
库存:39801
SRCW004
  • 1000+4.057911000+0.51980
SRCW004
  • 10000+3.4004310000+0.43558
  • 20000+3.3390720000+0.42772
库存:39801
SRCW004
  • 1000+3.73115
