Mixtus Dual-band Wi-Fi SMD Antenna
Part No. A10194
Product Specification
1 Features
Designed for 2.4 – 2.5 GHz and 4.9 – 5.0 GHz applications: 802.11a/b/g/j/n, Wi-Fi®
Easy to integrate
High efficiency
Light weight
Intended for SMD mounting
Supplied in tape on reel
2 Description
Mixtus is intended for use with all dual-band Wi-Fi applications, including 802.11n MIMO.
The antenna requires a ground plane, i.e. your device acts as an active part of the antenna
and thus demands careful consideration concerning its placement.
3 Applications
Mobile phones
PDAs
Portable Media Players (PMPs)
Headsets
PC-Cards
Game Consoles
Access Points
Set-top-box
Networked Digital TVs
Integrated Antenna and RF Solutions
1
Product Specification 06MD-0010-2-PS
Part No. A10194
4 Part No.
Mixtus: A10194
150
5 General data
Product name
Mixtus Wi-Fi
Part No.
A10194
Frequency
2.4 – 2.5 GHz and 4.9 – 5.9 GHz
Polarization
Linear
Operating temperature
-40 ºC to +85 ºC
Impedance with matching
50 Ω
Weight
0.2 g
Antenna type
SMD
Dimensions
10 x 10 x 0.9 [mm]
6 Electrical characteristics
Typical performance
Peak gain
1.8 dBi
Average gain
-0.5 dBi
Average efficiency
>75%
Maximum Return Loss
-15 dB
Maximum VSWR
Data given for the 2.4 – 2.5 GHz frequency range
All data measured on Antenova’s reference board
part number AN-1-0668-4
1.4:1
Peak gain
4.1 dBi
Average gain
-2.3 dBi
Average efficiency
>60%
Maximum Return Loss
-11 dB
Maximum VSWR
Conditions
Data given for the 4.9 – 5.9 GHz frequency range
1.8:1
2
Product Specification 06MD-0010-1-PS
Part No. A10194
7 Electrical performance
7-1 Return Loss
5
[dB]
mtool5
3
-10
4
1
-15
2
-20
-25
-30
-35
-40
-45
-50
2000
2500
3000
3500
4000
4500
5000
5500
[MHz]
6000
7-2 VSWR
mtool5
10
9
8
7
6
5
4
3
2
3
1
1
2000
4
2
2500
3000
3500
4000
4500
5000
5500
[MHz]
6000
3
Part No. A10194
7-3 Antenna patterns
7.3.1.
2400 MHz – 2500 MHz
Z
θ
φ
X
0°
E5511
Radial Scale: dBi
270°
-35
-25
-15
180°
XY plane
-5
5
90°
Y
0°
E5511
Radial Scale: dBi
0°
E5511
Radial Scale: dBi
Plane XY
Plane YZ
Plane XZ
Pol. Total
Pol. Total
Pol. Total
2400
2400
2400
2450
2450
2450
2500
2500
2500
270°
-35
-25
-15
-5
5
90°
-35
270°
-15
-5
5
90°
180°
180°
YZ plane
-25
XZ plane
Patterns show combined polarisations
measured on reference board AN-1-0668-4
4
Part No. A10194
7.3.2.
4900 MHz – 5900 MHz
Z
θ
φ
X
0°
270°
-35
0°
E5512
Radial Scale: dBi
-25
180°
XY plane
-15
-5
5
90°
Y
E5512
Radial Scale: dBi
0°
E5512
Radial Scale: dBi
Plane XY
Plane YZ
Plane XZ
Pol. Total
Pol. Total
Pol. Total
4900
4900
4900
5400
5400
5400
5900
5900
5900
270°
-35
-25
-15
-5
5
90°
-35
270°
-15
-5
5
90°
180°
180°
ZY plane
-25
XZ plane
5
Part No. A10194
8 Antenna dimensions
Mixtus
L
W
H
Length
Width
Height
10.4 ± 0.2
10.4 ± 0.2
0.8 ± 0.15
Dimensions in mm
9 Antenna footprint
Mixtus (Part No: A10194)
CAD files of the antenna footprint are available from Antenova on request.
Please contact info@antenova.com for further details.
I
S
K
J
M
O
H
R
L
1.5 ± 0.1
1.5 ± 0.1
2.0 ± 0.1
0.5 ± 0.1
1.2 ± 0.1
7.0 ± 0.1
1.9 ± 0.1
3.1 ± 0.1
0.8 ± 0.1
Dimensions in mm
6
Part No. A10194
10 Electrical interface
10-1 Transmission lines
All transmission lines should be designed to have a characteristic impedance of 50 Ω
The length of the transmission lines should be kept to a minimum
Any other parts of the RF system like transceivers, power amplifiers, etc, should also be
designed to have an impedance of 50 Ω
Once the material for the PCB has been chosen (PCB thickness and dielectric constant), a
coplanar transmission line can easily be designed using any of the commercial software
packages for transmission line design. For the chosen PCB thickness, copper thickness and
substrate dielectric constant, the program will calculate the appropriate transmission line width
and gaps on either side of the track so the characteristic impedance of the coplanar
transmission line is 50 Ω.
10-2 Matching circuit
The antenna requires a matching circuit that must be optimized for each customer’s product.
The matching circuit will require up to three components and the following pad layout should be
designed into the device so the correct circuit can be installed:
The antenna feed pad and the antenna ground pad are indicated in the drawing above.
Additional pads are for mechanical attachment only and should not be grounded.
7
Part No. A10194
In addition to the matching circuit, a separate DC blocking capacitor will also be required
between the radio and the antenna matching circuit.
Note: The component values for the matching circuit will vary depending on the size of
the PCB and surrounding components. The impedance of the antenna should be measured
before selecting suitable matching components. Antenova offers this service on request.
Contact info@antenova.com for further information.
10-3 Antenna placement
Antenova strongly recommends placing the antenna near the edge of the board. Maximum
antenna performance is achieved by placing the antenna towards one of the corners of the
PCB and with the feed point of the antenna as close to the same corner of the PCB as
possible.
Additional ground and components near the antenna should be at a distance of at least 5 mm
from the left hand side and 18 mm or more from the right hand side as shown in the drawing
above.
8
Part No. A10194
10-4 Reference boards
The reference boards have been designed for evaluation purposes of Mixtus dual-band Wi-Fi
SMD antenna and they include a SMA female connector
Mixtus
Reference board part number: AN-1-0668-4
Dimensions in mm
To order a reference board contact info@antenova.com
9
Part No. A10194
11 Soldering
This antenna is suitable for lead free soldering.
The reflow profile should be adjusted to suit the device, oven and solder paste, while
observing the following conditions:
- The maximum temperature should not exceed 240 ºC
- However for lead free soldering, a maximum temperature of 255 ºC for no more than
20 seconds is permitted.
- The antenna should not be exposed to temperatures exceeding 120 ºC more than 3
times during the soldering process.
12 Hazardous material regulation conformance
The antenna has been tested to conform to RoHS requirements. A certificate of
conformance is available from Antenova’s website.
10
Part No. A10194
13 Packaging
13-1 Optimal storage conditions for packaged reels
Temperature
-10ºC to 40ºC
Humidity
Less than 75% RH
Shelf Life
18 Months
Storage place
Away from corrosive gas and direct sunlight
Packaging
Reels should be stored in unopened sealed
manufacturer’s plastic packaging.
Note: Storage of open reels of antennas is not recommended due to possible oxidization of pads
on antennas. If short term storage is necessary, then it is highly recommended that the bag
containing the antenna reel is re-sealed and stored in like storage conditions as in above table.
13-2 Tape characteristics
Mixtus
[Part Number: A10194]
W
F
E
P0
P1
P2
B0
K0
T
D0
D1
24 ± 0.2
10.7 ± 0.1
1.75 ± 0.1
4.0 ± 0.1
16.0 ± 0.1
2.0 ± 0.1
10.7 ± 0.1
1.1 ± 0.1
0.3 ± 0.05
Min
1.55 ± 0.1
Min
2.0± 0.2
Dimensions in mm
Quantity
Leading Space
Trailing Space
2000 pcs / reel
50 blank antenna holders
11
Part No. A10194
13-3 Reel dimensions
Width
(W)
Reel
Diameter
(D)
Hub
Diameter
(H)
Shaft
Diameter
(C)
57.5 mm
330 mm
± 2.0
80 mm
(2”)
13.0 mm
± 0.5
13-4 Box dimensions
Width
(W)
Breadth
(B)
Thickness
(H)
338 mm
335 mm
45 mm
13-5 Bag properties
Reels are supplied in protective plastic packaging
12
Part No. A10194
13-6 Reel label information
Mixtus
Dimensions in mm
13
Part No. A10194
www.antenova.com
Corporate Headquarters
North America Headquarters
Asia Headquarters
Antenova Ltd.
Far Field House
Albert Road
Stow-cum-Quy
Cambridge
CB25 9AR
Antenova Ltd.
Rogers Business Park
2541 Technology Drive Suite 403
Elgin, IL 60124
Antenova Asia Ltd.
4F, No. 324, Sec. 1, Nei-Hu Road
Nei-Hu District
Taipei 11493
Taiwan, ROC
Tel:
+44 1223 810600
Fax: +44 1223 810650
Email: info@antenova.com
Tel:
+1 (847) 551 9710
Fax
+1 (847) 551 9719
Tel:
+886 (0) 2 8797 8630
Fax: +886 (0) 2 8797 6890
Copyright 2008 Antenova Ltd. All Rights Reserved. Antenova and gigaNOVA are trademarks of
Antenova Ltd. Any other names and/or trademarks belong to their respective companies.
The materials provided herein are believed to be reliable and correct at the time of print. Antenova does not
warrant the accuracy or completeness of the information, text, graphics or other items contained within these
information. Antenova further assumes no responsibility for the use of this information, and all such
information shall be entirely at the user’s risk.
14
很抱歉,暂时无法提供与“A10194”相匹配的价格&库存,您可以联系我们找货
