W24P-U
W24P-U
    INVENTEKSYSTEMS
    W24P-U
W24P-U 数据手册
Confidential Inventek Systems, LLC. DOC-DS-20075-1.0 Inventek Systems OEM Wi-Fi Antennas P/N: W24P-U Page 1 of 8 Confidential Inventek Systems, LLC. DOC-DS-20075-1.0 Table of Contents 1 2 GENERAL DESCRIPTION ....................................................................................... 3 PART NUMBER DETAIL DESCRIPTION .............................................................. 3 Ordering Information................................................................................................. 3 3 GENERAL FEATURES ............................................................................................. 3 3.1 Environmental Specifications ............................................................................. 3 4 Features ....................................................................................................................... 4 5 Applications ................................................................................................................ 4 6 Electrical Specifications.............................................................................................. 4 6.1 Return Loss(S¹¹) .................................................................................................. 4 6.2 Smith Chart(S¹¹) .................................................................................................. 5 7 Antenna Dimensions (unit: mm)................................................................................. 5 8 Radiation Pattern......................................................................................................... 6 8.1 3D Gain Pattern (Radiation Pattern at 2442 MHz) ............................................. 6 8.2 9-2 Efficiency Table ........................................................................................... 7 8.3 9-3 Efficiency vs. Frequency .............................................................................. 7 9 Electrical Specifications.............................................................................................. 7 10 REVISION CONTROL .............................................................................................. 8 11 CONTACT INFORMATION ..................................................................................... 8 Page 2 of 8 Confidential Inventek Systems, LLC. DOC-DS-20075-1.0 1 GENERAL DESCRIPTION The Inventek 2400-2500 Mhz Wi-Fi PCB (30 x 5 mm) antennas let you integrate Wi-Fi functionality into your product quickly and easily. It’s suitable for a wide range of applications and recommended for use with Inventek eS-Wi-Fi modules. 2 PART NUMBER DETAIL DESCRIPTION Ordering Information Device W24P-U Description 2400-2500 Mhz Wi-Fi PCB antenna with U.Fl connector and 90 mm cable length Ordering Number W24P-U 3 GENERAL FEATURES Characteristics Outline Dimensions Center Frequency Bandwith VSWR Impedance Polarization Gain Peak Efficiency Specifications 30 x 5.0 x .05 2442 100 min. 2 max. 50 Linear Polarization 3.2 (typical) 79 (typical) 3.1 Environmental Specifications Item Operating temperature rang Storage temperature range Humidity Description -40 deg. C to +80 deg. C -55 deg. C to +100 deg. C 95% max non-condensing Page 3 of 8 Unit mm MHz MHz Ω dBi % Confidential Inventek Systems, LLC. DOC-DS-20075-1.0 4 Features     Stable and reliable in performances PCB antenna has excellent sensitivity to consistently provide high signal reception efficiency Compact size RoHS compliance 5 Applications *IEEE802.11 (b/g/n). *Hand-held devices when WiFi (802.11 b/g/n) functions are needed. 6 Electrical Specifications 6.1 Return Loss(S¹¹) Page 4 of 8 Confidential Inventek Systems, LLC. DOC-DS-20075-1.0 6.2 Smith Chart(S¹¹) 7 Antenna Dimensions (unit: mm) Our standard cable length is 90mm long. Minimum order custom cable lengths can be special order by request. Page 5 of 8 Confidential Inventek Systems, LLC. DOC-DS-20075-1.0 8 Radiation Pattern 8.1 3D Gain Pattern (Radiation Pattern at 2442 MHz) 2.4 Page 6 of 8 Confidential Inventek Systems, LLC. DOC-DS-20075-1.0 8.2 9-2 Efficiency Table Frequency(GHz) 2.400 2.412 2.417 2.422 2.427 2.432 2.437 2.442 2.447 2.452 2.457 2.462 2.467 2.472 2.484 Efficiency(dB) -1.51 -1.26 -1.21 -1.13 -1.09 -0.99 -0.90 -1.01 -1.06 -1.04 -0.87 -0.79 -0.82 -0.86 -0.98 Efficiency (%) 70.63 74.82 75.68 77.09 77.80 79.62 81.28 79.25 78.34 78.70 81.85 83.37 82.79 82.04 79.80 Gain(dBi) 2.76 2.96 3.02 3.05 3.15 3.24 3.32 3.26 3.23 3.26 3.42 3.55 3.56 3.58 3.48 8.3 9-3 Efficiency vs. Frequency 9 Electrical Specifications Page 7 of 8 Confidential Inventek Systems, LLC. DOC-DS-20075-1.0 RoHS: Restriction of Hazardous Substances (RoHS) directive has come into force since 1st July 2006 all electronic products sold in the EU must be free of hazardous materials, such as lead. 10 REVISION CONTROL Document : W24P-U Internal Release Date 10/1/2013 2.4 Ghz PCB antenna DOC-DS-20075 Author FMT Revision 1.0 Comment Preliminary 11 CONTACT INFORMATION Inventek Systems 2 Republic Road Billerica Ma, 01862 Tel: 978-667-1962 Sales@inventeksys.com www.inventeksys.com Inventek Systems reserves the right to make changes without further notice to any products or data herein to improve reliability, function, or design. The information contained within is believed to be accurate and reliable. However Inventek Systems does not assume any liability arising out of the application or use of this information, nor the application or use of any product or circuit described herein, neither does it convey any license under its patent rights nor the rights of others. Page 8 of 8
W24P-U 价格&库存
很抱歉,暂时无法提供与“W24P-U”相匹配的价格&库存,您可以联系我们找货
