Calvus Penta-band SMD Antenna
Part No. A10340
Product Specification
1 Features
GSM/UMTS antenna supporting up to 5 frequency bands
High efficiency
Easy to integrate
Intended for SMD mounting
Supplied in tape on reel
Calvus supports the following communication standards:
GSM/GPRS/EDGE
GSM850
(E)GSM900
GSM1800 (DCS)
GSM1900 (PCS)
CDMA2000
1xRTT/EV-DO/EV-DV
UMTS
WCDMA/HSPA
Band Classes:
1,2,3,4,6,8,9,12,14,15
Bands I – VI
Bands VIII – X
Other Standards
Korean PCS
DECT (outside USA)
TD-SCDMA
AWS
2 Description
Calvus uses a ground plane in order to radiate efficiently, but the ground plane must not be
present underneath the antenna itself.
The antenna uses a matching circuit to achieve optimized results for the specific frequency
bands that are required. This product specification shows the performance of the antenna
when optimized to cover a typical penta-band reception: GSM850/900/1800/1900 and
WCDMA. If the antenna is used for fewer than 5 bands, higher efficiencies are possible.
3 Applications
Femto / Pico base stations
Vehicle tracking
Machine to machine communication
Remote monitoring
Integrated Antenna and RF Solutions
1
Product Specification 09MD-0023-2-PS
Calvus GSM SMD Antenna
Part No. A10340
4 Part numbers
A10340
150
5 General data
Product name
Calvus GSM SMD
Part Numbers:
A10340
Frequency (typical)
824MHz-960MHz
1710MHz -2170MHz
Polarization
Linear
Operating temperature
-40 ºC to +85 ºC
Impedance with matching
50 Ω
Weight
很抱歉,暂时无法提供与“A10340”相匹配的价格&库存,您可以联系我们找货
