ANT-403-SP
ANT-403-SP
    LINXTECHNOLOGIES(灵思)
    SMD
    433MHZ紧凑型表面贴装天线
ANT-403-SP 数据手册
ANT-403-SP Data Sheet by Product Description The Splatch uses a grounded-line technique to achieve outstanding performance from a tiny surface-mount element. This unique antenna is designed for hand or reflow-mounting directly to a product’s circuit board. Its low cost makes it ideal for volume applications. Unlike many compact antennas, the Splatch exhibits good performance in proximity to objects and persons. While suitable for a wide range of RF applications, the 403 version was designed to cover the 402–405MHz medical implant communication service (MICS) band. 27.94 mm (1.10") 13.7 mm (0.54") 1.5 mm (0.06") 5.1 mm (0.20") Very low cost Ultra-compact package Direct PCB attachment Ideal for concealed / internal mounting Perfect for compact portable devices Suitable for hand or reflow-assembly Resistant to proximity effects 2.54 mm (0.10") 2.03 mm (0.08") Recommended Mounting 38.86 mm (1.53 in) Electrical Specifications Center Frequency: Recom. Freq. Range: Bandwidth: Wavelength: VSWR: Impedance: Connection: Oper. Temp. Range: 1.27 mm (0.05") Recommended Footprint Features • • • • • • • 5.1 mm (0.20") 6.32 mm (0.25 in) 403MHz 400–405MHz 5MHz ¼-wave ≤ 1.9 typ. at center 50-ohms Surface-mount –40°C to +130°C 15.48 mm (0.57 in) No ground plane or traces under the antenna PCB pads for the Splatch Vias to ground plane Ground plane on bottom layer for counterpoise 50-ohm microstrip line Electrical specifications and plots measured on 3.8 cm x 8.4 cm (1.50” x 3.30”) reference ground plane. 98.55 mm (3.88 in) 83.57 mm (3.29 in) Ordering Information ANT-403-SP (supplied in tubes of 20 pieces) ANT-403-SP-T (Tape and reel of 500 pieces) 0.51 mm (0.02 in) 37.85 mm (1.49 in) 0.51 mm (0.02 in) Please see AN-00502 for more details on PCB layout. –1– Revised 1/3/2017 Counterpoise Quarter-wave or monopole antennas require an associated ground plane counterpoise for proper operation. The size and location of the ground plane relative to the antenna will affect the overall performance of the antenna in the final design. When used in conjunction with a ground plane smaller than that used to tune the antenna, the center frequency typically will shift higher in frequency and the bandwidth will decrease. The proximity of other circuit elements and packaging near the antenna will also affect the final performance. For further discussion and guidance on the importance of the ground plane counterpoise, please refer to Linx Application Note AN-00501: Understanding Antenna Specifications and Operation. VSWR Graph VSWR 1= 402MHz 2= 403MHz 3= 405MHz 2: 3:1 2:1 1:1 353MHz 1.353 Reflected Power 25% 11% 2 1 3 403MHz 0% 453MHz What is VSWR? The Voltage Standing Wave Ratio (VSWR) is a measurement of how well an antenna is matched to a source impedance, typically 50-ohms. It is calculated by measuring the voltage wave that is headed toward the load versus the voltage wave that is reflected back from the load. A perfect match has a VSWR of 1:1. The higher the first number, the worse the match, and the more inefficient the system. Since a perfect match cannot ever be obtained, some benchmark for performance needs to be set. In the case of antenna VSWR, this is usually 2:1. At this point, 88.9% of the energy sent to the antenna by the transmitter is radiated into free space and 11.1% is either reflected back into the source or lost as heat on the structure of the antenna. In the other direction, 88.9% of the energy recovered by the antenna is transferred into the receiver. As a side note, since the “:1” is always implied, many data sheets will remove it and just display the first number. How to Read a VSWR Graph VSWR is usually displayed graphically versus frequency. The lowest point on the graph is the antenna’s operational center frequency. In most cases, this is different than the designed center frequency due to fabrication tolerances. The VSWR at that point denotes how close to 50-ohms the antenna gets. Linx specifies the recommended bandwidth as the range where the typical antenna VSWR is less than 2:1. Copyright © 2017 Linx Technologies 159 Ort Lane, Merlin, OR 97532 Phone: +1 541 471 6256 Fax: +1 541 471 6251 www.linxtechnologies.com –2– ANT-403-SP Data Sheet by
ANT-403-SP
物料型号:ANT-403-SP
器件简介:Splatch天线使用接地线技术,即使在非常小的表面贴装元件上也能实现出色的性能。这种独特的天线设计用于直接手工或回流焊接到产品的电路板上。其低成本使其非常适合大批量应用。
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 中心频率:403MHz - 推荐频率范围:400-405MHz - 带宽:5MHz - 波长:四分之一波长 - VSWR:典型值 ≤ 1.9(中心频率时) - 阻抗:50欧姆 - 连接方式:表面贴装 - 工作温度范围:-40°C 至 +130°C
功能详解:Splatch天线适合隐藏或内部安装,非常适合紧凑型便携设备,并且适合手工或回流组装。它对接近效应具有抵抗力。
应用信息:适用于广泛的射频应用,403版本专为覆盖402-405MHz的医疗植入通信服务(MICS)频段设计。
封装信息:ANT-403-SP(20件/管供应),ANT-403-SP-T(500件/卷带供应)。推荐安装在没有天线下方的接地平面或走线的PCB垫上,底部层有用于counterpoise的接地平面。
ANT-403-SP 价格&库存
很抱歉,暂时无法提供与“ANT-403-SP”相匹配的价格&库存,您可以联系我们找货
