FXP831.07.0100C
FXP831.07.0100C
    TAOGLASLIMITED
    FXP831.07.0100C
FXP831.07.0100C 数据手册
Specification Patent Granted Part No. : FXP831.07.0100C Product Name : FXP.831 Freedom 2.4/4.9-6GHz Ground Coupled Antenna Feature : Flexible Ultra Low Profile 45mm*7mm*0.1mm Adheres directly to inside of product plastic or glass housing Form factor and cable routing convenient for integration High Efficiency IPEX MHF Connector (U.FL compatible) 100m 1.37mm co-axial cable RoHS Compliant SPE-11-8-026/I/SS Page 1 of 19 US Patent #9252486 1. Introduction The FXP831 is a high efficiency, small, dual-band, dipole antenna for 2.4/4.9-6GHz band including DSRC, V2V, WiFi, Bluetooth, Zigbee and other applications in these bands. The FXP.831 has a peak gain of 2.5dBi at 2.4GHz and efficiencies of 56%, and 4.5dBi and 55% along bands 4.9GHz to 6GHz. This Taoglas patent granted antenna is unique in the market because it is made from poly-flexible material, has a tiny form factor (45*7*.01mm) and has double-sided 3M tape for easy “peel and stick” mounting. The cable routes conveniently directly out of the bottom of the antenna, reducing the volume the antenna takes up in the device to an absolute minimum compared to other designs. The FXP.831 is the ideal all-round antenna solution for squeezing into narrow spaces and still maintaining high performance, for example on the inside top or adjacent side applied directly to the plastic housing of LCD devices. Many module manufacturers specify peak gain limits for any antennas that are to be connected to that module. Those peak gain limits are based on free-space conditions. In practice, the peak gain of an antenna tested in free-space can degrade by at least 1 or 2dBi when put inside a device. So ideally you should go for a slightly higher peak gain antenna than mentioned on the module specification to compensate for this effect, giving you better performance. Upon testing of any of our antennas with your device and a selection of appropriate layout, integration technique, or cable, Taoglas can make sure any of our antennas’ peak gain will be below the peak gain limits. Taoglas can then issue a specification and/or report for the selected antenna in your device that will clearly show it complying with the peak gain limits, so you can be assured you are meeting regulatory requirements for that module. For example, a module manufacturer may state that the antenna must have less than 2dBi peak gain, but you don’t need to select an embedded antenna that has a peak gain of less than 2dBi in free-space. This will give you a less optimized solution. It is better to go for a slightly higher free-space peak gain of 3dBi or more if available. Once that antenna gets integrated into your device, performance will degrade below this 2dBi peak gain due to the effects of GND plane, surrounding components, and device housing. If you want to be absolutely sure, contact Taoglas and we will test. Choosing a Taoglas antenna with a higher peak gain than what is specified by the module manufacturer and enlisting our help will ensure you are getting the best performance possible without exceeding the peak gain limits. SPE-11-8-026/I/SS Page 2 of 19 US Patent #9252486 2. Specification Electrical Frequency 2.4 ~ 2.5GHz, 4.9 ~ 6.0GHz Peak Gain (free space) 2.5dBi 4.5dBi Peak Gain (on plastic*) 3.0dBi 5.5dBi Average Gain (free space) -2.6dBi -2.6dBi Average Gain (on plastic) -2.6dBi -1.8dBI Efficiency (free space) 56% 55% Efficiency (on plastic) 56% 75% VSWR ≦2.5 : 1 Impedance 50 Ohms Polarization Linear Radiation Pattern Omni Input Power 2W max. Mechanical Dimensions 45mm x 7mm Antenna Body Material Polymer Cable Gray 100mm 1.37 co-axial Connector Ipex MHF ENVIRONMENTAL Temperature Range -40°C to 85°C Humidity Non-condensing 65°C 95% RH SPE-11-8-026/I/SS Page 3 of 19 US Patent #9252486 3. Electrical Characteristic 3.1 S11 Free space with 1.0mm ABS with 1.5mm ABS with 2.0mm ABS 0 -5 -10 S11(dB) -15 -20 -25 -30 -35 -40 -45 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 Freq(GHz) SPE-11-8-026/I/SS Page 4 of 19 US Patent #9252486 3.2 Test Setup A ETS AMS-8500 test chamber is used for the free space radiation testing for FXP831.07.0100A. The measurement is taken with the antenna properly mounted in the designated device Device tested in AMS-8500 Rectangular test chamber. y x z FXP831 on Baxter device to indicate the testing coordinate x z y FXP831 on Baxter device to indicate the testing coordinate SPE-11-8-026/I/SS Page 5 of 19 US Patent #9252486 3.3 Radiation Pattern 3.3.1 XZ plane (at 2400MHz) 0 5 330 30 0 -5 -10 300 60 -15 -20 -25 -30 270 90 -35 240 120 Free Space with 1.0mm ABS 210 150 with 1.5mm ABS with 2.0mm ABS 180 3.3.2 XZ plane (at 2500MHz) 0 5 330 30 0 -5 -10 300 60 -15 -20 -25 -30 270 90 -35 240 120 Free Space with 1.0mm ABS 210 150 with 1.5mm ABS with 2.0mm ABS 180 SPE-11-8-026/I/SS Page 6 of 19 US Patent #9252486 3.3.3 XZ plane (at 5000MHz) 0 10 330 30 5 0 -5 -10 300 60 -15 -20 -25 -30 270 90 -35 240 120 Free Space with 1.0mm ABS 210 150 with 1.5mm ABS with 2.0mm ABS 180 3.3.4 XZ plane (at 5500MHz) 0 10 330 30 5 0 -5 -10 300 60 -15 -20 -25 -30 270 90 -35 240 120 Free Space with 1.0mm ABS 210 150 with 1.5mm ABS with 2.0mm ABS 180 SPE-11-8-026/I/SS Page 7 of 19 US Patent #9252486 3.3.5 XZ plane (at 6000MHz) 0 5 330 30 0 -5 -10 300 60 -15 -20 -25 -30 270 90 -35 240 120 Free Space with 1.0mm ABS 210 150 with 1.5mm ABS with 2.0mm ABS 180 3.3.6 YZ plane (at 2400MHz) 0 5 330 30 0 -5 -10 300 60 -15 -20 -25 -30 270 90 -35 240 120 Free Space with 1.0mm ABS 210 150 with 1.5mm ABS with 2.0mm ABS 180 SPE-11-8-026/I/SS Page 8 of 19 US Patent #9252486 3.3.7 YZ plane (at 2500MHz) 0 5 330 30 0 -5 -10 300 60 -15 -20 -25 -30 270 90 -35 240 120 Free Space with 1.0mm ABS 210 150 with 1.5mm ABS with 2.0mm ABS 180 3.3.8 YZ plane (at 5000MHz) 0 5 330 30 0 -5 -10 300 60 -15 -20 -25 -30 270 90 -35 240 120 Free Space with 1.0mm ABS 210 150 with 1.5mm ABS with 2.0mm ABS 180 SPE-11-8-026/I/SS Page 9 of 19 US Patent #9252486 3.3.9 YZ plane (at 5500MHz) 0 5 330 30 0 -5 -10 300 60 -15 -20 -25 -30 270 90 -35 240 120 Free Space with 1.0mm ABS 210 150 with 1.5mm ABS with 2.0mm ABS 180 3.3.10 YZ plane (at 6000MHz) 0 5 330 30 0 -5 -10 300 60 -15 -20 -25 -30 270 90 -35 240 120 Free Space with 1.0mm ABS 210 150 with 1.5mm ABS with 2.0mm ABS 180 SPE-11-8-026/I/SS Page 10 of 19 US Patent #9252486 3.3.11 XY plane (at 2400MHz) 0 5 330 30 0 -5 -10 300 60 -15 -20 -25 -30 270 90 -35 240 120 Free Space with 1.0mm ABS 210 150 with 1.5mm ABS with 2.0mm ABS 180 3.3.12 XY plane (at 2500MHz) 0 0 330 30 -5 -10 -15 300 60 -20 -25 -30 270 90 -35 240 120 Free Space with 1.0mm ABS 210 150 with 1.5mm ABS with 2.0mm ABS 180 SPE-11-8-026/I/SS Page 11 of 19 US Patent #9252486 3.3.13 XY plane (at 5000MHz) 0 0 330 30 -5 -10 -15 300 60 -20 -25 -30 270 90 -35 240 120 Free Space with 1.0mm ABS 210 150 with 1.5mm ABS with 2.0mm ABS 180 3.3.14 XY plane (at 5500MHz) 0 10 330 30 5 0 -5 -10 300 60 -15 -20 -25 -30 270 90 -35 240 120 Free Space with 1.0mm ABS 210 150 with 1.5mm ABS with 2.0mm ABS 180 SPE-11-8-026/I/SS Page 12 of 19 US Patent #9252486 3.3.15 XY plane (at 6000MHz) 0 10 330 30 5 0 -5 -10 300 60 -15 -20 -25 -30 270 90 -35 240 120 Free Space with 1.0mm ABS 210 150 with 1.5mm ABS with 2.0mm ABS 180 SPE-11-8-026/I/SS Page 13 of 19 US Patent #9252486 3.4 Peak Gain 8 7 free space with 1.0mm ABS with 1.5mm ABS with 2.0mm ABS 6 Peak Gain (dBi) 5 4 3 2 1 0 2200 2400 2600 2800 3000 3200 3400 3600 3800 4000 4200 4400 4600 4800 5000 5200 5400 5600 5800 6000 Freq(MHz) SPE-11-8-026/I/SS Page 14 of 19 US Patent #9252486 3.5 Efficiency 100 free space with 1.5mm ABS 90 with 1.0mm ABS with 2.0mm ABS 80 Efficiency(%) 70 60 50 40 30 20 10 0 2200 2400 2600 2800 3000 3200 3400 3600 3800 4000 4200 4400 4600 4800 5000 5200 5400 5600 5800 6000 Freq(MHz) SPE-11-8-026/I/SS Page 15 of 19 US Patent #9252486 4. Mechanical SPE-11-8-026/I/SS Page 16 of 19 US Patent #9252486 5. Precautions for Usage SPE-11-8-026/I/SS Page 17 of 19 US Patent #9252486 6. Packaging 100pc FXP831.07.0100C per Small PE Bag Dimensions: 300*100mm 300mm Weight: 70g 100mm 1000pcs FXP831.07.0100C per Large PE Bag Dimensions: 430*280mm 430mm Weight: 807g 280mm 5000pcs FXP831.07.0100C per Carton Carton Dimensions: 320*250*230 mm Weight: 4.5Kg 230mm 320mm 250mm Pallet Dimensions: 1200*1000*1350mm 60 Cartons per Pallet 12 Cartons per layer, 5 Layers 1350mm 1200mm 1000mm SPE-11-8-026/I/SS Page 18 of 19 US Patent #9252486 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. © Taoglas SPE-11-8-026/I/SS Page 19 of 19 US Patent #9252486
FXP831.07.0100C 价格&库存
很抱歉,暂时无法提供与“FXP831.07.0100C”相匹配的价格&库存,您可以联系我们找货
    库存:24
    FXP831.07.0100C
      FXP831.07.0100C
      • 11+70.03537
      • 55+63.04021
      库存:30
      FXP831.07.0100C
