X000003
X000003
    ARDUINO
    SMA(DO-214AC)
    GSM ANTENNA ANTA2000A0200BR11
X000003 数据手册
DELTA 7 SERIES Hinged Mount Range of Quad Band GSM/GPRS or 2.4/5.8GHz Antennas General Description The Siretta Delta 7 series is a range of omni directional, direct connect antennas tuned to perform on either GSM/GPRS or 2.4/5.8GHz networks. Vertically polarised, they are suitable for many of today's machine to machine communication applications such as telemetry, remote monitoring and mesh networking applications. Features Hinged Mount Tuned to Specific Frequency Robust Construction Omni-Directional RoHS compliant Benefits Offers widest range of mounting choices via knuckle and swivel connector Optimised for either GSM/GPRS or 2.4/5.8GHz Over moulded whip to ensure durability in the field Provides good 360º transmission/reception coverage Meets all EU compliance criteria for electronic goods Key Specifications – Mechanical Dimensions: Connector: Operating Temperature: Storage Temperature: Antenna cover material: Base / Upper material: Mounting method: 110mm x 10mm SMA male or SMA RP -20ºC to 65ºC -30ºC to 75ºC TPEE (black) Polycarbonate (black) Direct connect Key Specifications - Electrical Operating Frequency: Radiating Element: Polarization: Radiation Pattern: Gain: Return Loss Impedance (ohm): VSWR: Voltage and supply current: ANTA2000A0200BR11 (850, 900, 1800, 1900MHz) ANTQ0000A0200BR11 and ANTQ0000D0200BR11 (2.4 and 5.8GHz) ¼ wave omni directional dipole Vertical Omni Directional 1dBi (Cellular) 1.5dBi (2.4-2.5GHz) 2.1dBi (5.8GHz) - 10dB max 50
X000003 价格&库存
很抱歉,暂时无法提供与“X000003”相匹配的价格&库存,您可以联系我们找货
