ANT-868-CW-QW-SMA
ANT-868-CW-QW-SMA
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    CW系列四波段天线在坚固和美观的包装中提供了出色的性能。这些天线配备了标准的SMA或FCC第15部分合规的RP-SMA连接器。RP-SMA连接器允许现场更换,同时符合FCC要求。多种匹配连接器提供了多...
ANT-868-CW-QW-SMA 数据手册
ANT-868-CW-QW Data Sheet by Product Description 7.8 mm (0.31") CW Series ¼-wave antennas deliver outstanding performance in a rugged and cosmetically attractive package. These antennas are available with standard SMA or FCC Part 15 compliant RP-SMA connectors. RP-SMA connectors allow for easy field replacement while complying with FCC requirements. A wide variety of matching connectors permit numerous mounting options. 13.0 mm (0.51") 6.0 mm (0.24") Features • • • • • • • • • • 84.0 mm (3.31") Low cost Excellent performance Omni-directional pattern Wide bandwidth Very low VSWR Fully weatherized Flexible main shaft Rugged & damage-resistant SMA or Part 15 compliant RP-SMA connector Use with plastic* or metal enclosures 52.0 mm (2.05”) 4.5 mm (0.18") 14.5 mm (0.57") *Requires proximity ground plane Electrical Specifications Center Frequency: Recom. Freq. Range: Wavelength: Peak Gain: VSWR: Impedance: Connector: Oper. Temp. Range: End View 868MHz 750–950MHz ¼-wave 1.6dBi
ANT-868-CW-QW-SMA 价格&库存
很抱歉,暂时无法提供与“ANT-868-CW-QW-SMA”相匹配的价格&库存,您可以联系我们找货
