ANT-868-CW-QW
Data Sheet
by
Product Description
7.8 mm
(0.31")
CW Series ¼-wave antennas deliver outstanding
performance in a rugged and cosmetically
attractive package. These antennas are available
with standard SMA or FCC Part 15 compliant
RP-SMA connectors. RP-SMA connectors allow
for easy field replacement while complying with
FCC requirements. A wide variety of matching
connectors permit numerous mounting options.
13.0 mm
(0.51")
6.0 mm
(0.24")
Features
84.0 mm
(3.31")
Low cost
Excellent performance
Omni-directional pattern
Wide bandwidth
Very low VSWR
Fully weatherized
Flexible main shaft
Rugged & damage-resistant
SMA or Part 15 compliant RP-SMA connector
Use with plastic* or metal enclosures
52.0 mm
(2.05”)
4.5 mm
(0.18")
14.5 mm
(0.57")
*Requires proximity ground plane
Electrical Specifications
Center Frequency:
Recom. Freq. Range:
Wavelength:
Peak Gain:
VSWR:
Impedance:
Connector:
Oper. Temp. Range:
End
View
868MHz
750–950MHz
¼-wave
1.6dBi
很抱歉,暂时无法提供与“ANT-868-CW-QW”相匹配的价格&库存,您可以联系我们找货
